- Yo guys and Gals Just got my first Honda
- 95 Honda Civic Clunking Noise
- how do I get vents ect. out to paint them
- LS/Vtec
- what need for turbo install..???
- A question about horsepower
- Best type of air intake?
- searching for a hole in firewall
- RWD conversion
- oil line for turbo
- Coilover preload
- A/C not working for 1995 Civic
- i think starter is going!!!
- Need 92 Civic Si fuse diagram
- best plugs for the job??
- Wheel / Tire Set Up
- Maintance Required
- Introducing my new Del Sol (many pics)
- distinct turbo whistle...
- Question about ECU???
- Alt wire and starter wire ?s
- My dragstrip times.
- Quiet Exhaust
- Power locks not working
- engine noise
- Cylinder misfires... Hmm...
- 2001 battery light flicker
- 16" rims throw speedometer off?
- Quick question about tach after swap
- Clutch??????????????????
- Finding Civic plastic bumper push clips?
- Rear Calpier for a 94 EX?
- cv axle
- 1998 ex suspension
- A/C output decreases on recirc
- rough idle
- ls intake manifold on my b16a2?
- Want to get first Civic
- Auto Shifter Stuck
- Top Speed Limiter?
- Dash is out! Speedo, odometer, ebrake light all not working!
- Civic troubles
- hoses for wastegate
- can a worn clutch affect starting...
- Test Pipe
- Want to install MSD ignition, wiring help?
- Needing to check these things out
- buying rims/tires
- stock front and rear bumpers ??? (painted)
- oem carbon fiber fenders ???
- block drain in 00 civic si
- Civic A/c not working
- need new cat back ,but which one
- 96 EX for sale (Toronto)
- Question about CV axles on a Honda Civic
- Rings?
- humidity=CEL WTF?
- turbo charger for a 93 honda civic lx sedan
- jackson racing or vortec?
- AEM Intake bypass valve
- rear strut tower bar
- 1.8L Ls ?
- adjusting boost
- Can someone please run a vin# check for me
- del sol brake?
- Engine Decision Again
- 89 civic hb dx not starting
- Hello new to the civic forums!
- 7th gen turbo
- A few maintenance issues, need help
- mayb blown head gasket gsr b18c
- Header Question
- problems
- OBD1/2 wiring schematics
- civic wiring harness question.. please help!
- cheap power?
- Front Grille
- Engine Swap
- brake light
- Need help with tires for Civic
- Shaking/vibrating with A/C on 92'
- Problem with shift my car out of parking.
- new car door
- Question about OBD-1 and emissions test
- just dyno'd my car
- suspension differences
- vtec problem
- A/C Problem Need Help?
- Got my gf an eg9
- ?!? It won't go away ?!?
- 05 Civic LX SE head unit question
- Premium gives me much better gas mileage
- Will the F22A1 go into a 90 Civic?
- n00b question
- Cmber kit
- HELP: removing door handles from 98 4dr civic
- size IC to go with...
- vtec controller question
- preperations for turbo install???
- Wheel rub!!!!! (help)
- Question about rear lower strut bar?
- Trouble with trunk leaks
- b16a 2 into civic dx/cx/ls/si
- Autozone Turbo II Muffler
- b16a1 vs b16a2
- Removing the Dash of a 93 Civic HB
- pics of ek9
- What BOV makes this sound...???
- 2001 Civic Si - Headlights
- top fuel japan
- k24 in ek9
- no EGR on D16Y8s...how is NOX controlled?
- can someone run this VIN
- I need help installing a radiator for my 1989 Civic
- 97 Civic Aftermarket radio tie ins.
- VSS location on 94 civic coupe manual?
- 1996 Civic 1.5i LS Keyless Entry...
- help on 93 honda civic front end
- what size IC pipe and inlets needed...???
- rear sway bar install question
- Greddy turbo kit questions...
- what does the crankcase filter do?
- Del Sol Fuse Box Help!
- 17 inch tires for track and street ?
- Trying to buy a 1998 Civic EX, Carfax please??
- AC question
- B16 Questions
- Engine Dress up Kits/Hose's
- Problems removing axle nut
- intercooler help!!!
- Check this ebay kit out!!
- Question about valve cover gasket?
- Car not starting when its hot out
- back door on 2000 Civic won't open...
- legit check on these racing hart c2s
- Ecu codes.....
- Modded 2000 Civic EX...how fast?
- It just keeps on getting better!!
- just bought a civic, is this normal:
- alinment question
- Tein Pillowball mounts
- quick release kit for steering wheel
- high-flow cat?
- tapping the oil pan...
- Coilover Help
- Is it time for tranny fluid change?
- projector headlights
- got another civic
- Installing 5th Gen Cd player
- Bad VC gasket, while I'm there anything else?
- replacing driver and passenger side frames, adivce needed
- tony's hell
- My car problems suck!
- Tire Recommendations!!!!!!!!!!
- 92-95 cruise control wiring
- D16Y8 is in......but there is a NOISE ???
- b16a3 swap, need rear tanny brakcet
- installing oil/ feul lines
- changing bulbs on angel eye/halo lights?
- how to wire vtec?
- B18 shift points
- Momo horn problem
- LSD question
- hondarot
- d16y8 fuel pump life span question
- How do I replace front brake pads for 98 Honda Civic
- ITS DONE.....sorta...
- need info for b16 turbo
- Anyone Got Chiltons or Haynes on cd?
- clutch question
- b16a ecu and engine harness question
- LS Turbo Kit compatibility
- Location of all thermo sensors for 92-95 civic
- exhaust question
- Driver's side window
- 95 Civic. Climate Control Panel - burnt out bulbs
- CEL Codes
- New here, My Ride......
- D15B v.s. D16Y8
- obd-2 to obd-1
- SPW lips anygood...???
- How do I find the width of my tires?
- I regret to inform you that....[please read further]
- carfax?
- battery or Starter?
- Lug nut size
- another teg brake swap thread
- A little help please(painting)
- axel bolt...tie rods
- paint codes for the 99'-oo' si?
- del Sol B18c Swap... HELP
- average price to find an engine
- problem with foglight light output
- where to find type-r rear lip???
- CarFax report?
- Uh Oh Spaghettios?
- '94 del Sol S b18c Swap questions...
- NEED MORE POWER !!!
- Viration on idle on my old Ballade 160E
- _____________________________________
- JDM D15 SOHC VTEC any info ????
- PLEASE HELP? b16A SIR 2 SWAP
- Thermostat Removal
- Lowering/Chamber Question
- oem lip kit for sols?
- Need Help
- b16a1 in a 98 hatchback
- how easy is it to swap a b16a or b18c into a sol
- Boosting the B16A2
- Car won't start, engine doesn't turn
- spring install....
- auto to manual!!!
- condenser fan fuse
- obd2-p1457
- Wheel Hub
- So i got this b16a2 from a junkyard (need help first engine)
- Need A New Engine !!!! Plz Help!!
- troubles with nj inspection
- B16a2 question
- 5 Lug Rims
- 5 Lug Rims
- D17a1 Turbo???
- building the b16a or ls/vtec
- I need some advice quick
- 95 brake swap
- Question about aftermarket intake?
- Lemme see your Valve covers!!!
- FINALLY! i drive a turbo D :)
- Help with length size of resonator
- Need help with first time buying wheels.
- idle problem...
- Kinda embarassing question.
- sol knowledge?
- Front Shock Housings
- Vtec-E head on a d15
- civic+h22+87 accord parts?
- why go B when H is best bang for buck?
- Problem ahead??
- Tie Rod Question
- Electrical problems on 99 Civic EX
- changing Tranny fluid
- 1993 Civic EX 1.6l SOHC Starting Probs
- Rubbing sound after car wash
- Need picture of a 1993 civic fuse box cover
- change of interior color?
- stiff shifter
- noob swap Qs
- 99 LX Keyless Entry Help
- help please, my 95 civic ex won't start!
- Cam gear question
