- I need more air
- plug installation
- Recommended Exhaust Size
- Anything Else Needed?
- BOV question
- i searched first! injectors..
- Stripped Coilovers???
- Good SS turbo cat back?
- Need A good Website!
- HX Rims ON EG Si
- Catalyst System Threshold Inefficiency question
- b20b to d16z6 wiring harness
- B series 1.6 and 1.8 motor ?
- Can anyone tell me why my steering wheel shakes??
- Wing questions
- Radiator install info for '95 Civic EX
- any way around pcv box
- want to build b20 vtec turbo
- idle problems
- Roll Cage questions
- test pipe=black smoke
- Heater circuit malfunction - code 41
- gimme boost
- bubbles in the radiator?
- o2-sensored cat replacement
- Newbie... has a 93 Civic Si, suggestions?
- valve cover painting
- black plugs...again!
- leaking/dripping!
- HELP!!! Making an "EX" an "Si"
- 97 civic dx hatch dyno'd
- d15b8
- 4-2-1 dc sports header: need help
- b16a Good?
- will my auto be ok???
- where is the vss located on a si sohc del sol
- A/c
- Which parts do I need?
- how much are swaps now?
- 2006 Civic Si!
- Civic 1.5,16V exhaust manifold
- thanks to all...
- Shamelessly ripping open the jack at the toe hook debate
- 2v3v4 door civic dashes
- what are the best headers i can get
- red4's clean EJ8...
- I need to be schooled on engines, trannys, etc
- OBD problem!!!!!!!!
- Stock Tire Size
- Eh, so damn stupid...
- sears sucks a$$
- Please help me out!
- Quiet Exhaust
- ECU made my car overheat!!!
- Fair price for turning 96 civic flywheels?
- i might have found a turbo kit (finally)
- 93 civic si
- Which is better?
- Torque Spec request.
- when buying a complete swap...
- Fog light adjustment
- Tein Edfc
- Tires
- Overheating problems
- aem intake? should i cut it in 2
- Blown Headgasket Sypmtoms?
- Carbon Fiber Duckbill question
- Why is it (tires)?
- Naxos mufflers
- Question about header?
- updated pics
- camber kit
- where to find good CAT???
- highest octain for b16
- Finally got fixed,but another problem!!!
- Del sol storage boxes/ stereo question.
- help lower my civic
- Purge my nitrous on the sol
- project ideas
- Integra rear seats in 98ex Civic?
- headlight condesnsation
- cat search
- What do you think happened? (water puddle)
- Oil cooler pressure drop?
- OEM Exhaust
- Beating a dead horse (Gauges)
- question about axles
- Newbie intake question
- ebay ctr mirrors
- where to get quality amber corners?
- need power
- Mugen front lip
- maintenance (and confession) time... *sigh*
- High Volume Oil Pump
- 1992 Civic lighting problem, headlights work but nothing else does
- Unorthodox Racing???
- RELEASED : New Civic Production Car!!!
- will everything go back to normal if i do this???
- Troubleshooting Evap Controls MIL P1457
- sunroof
- NE1 know of replaceable upper ball joint?
- Camera Mount
- b16a sirII
- halo projector setup
- Tire Rotation
- High flow catalytic converter... info please
- Hid
- Vafc???????
- Small leak from power steering pump??
- still stuck- piece of crap car is ruining my life
- How to replace window regulator
- How to make my cooling fan stay on all the time
- power needed bad!!!!!!
- f/r lower tie bars on 99 civic
- gas gauge + clearing headlight question :)
- headlight issues
- Koni + Omni Suspension Q's
- z6 and y8
- Help!! Oil Change
- 02 Sensor
- Tired of Tampa Hondaland
- is a 93 coupe ex vtec?
- O2 sensor wiring...
- A/c Not Cooling Enough! HELP ME!!!
- 98 civic
- oxygen sensors...
- about to buy a "longblock", what should i look for?
- Jasma Headers
- what would i need to do AFC???
- Oil Cooler and IC
- freeking civic AC problem, STILL!!!
- need help ASAP....
- Oxygen Sensor II
- can i get rid of Emanage????
- fender rubbing...
- havnt connected wastegate line!
- does this mean i have bad grounds???
- can this cause bogging???
- codes...
- Primary oxygen sensor bad?
- need help with CERL codes...
- Need Help replacing headlight 98 Honda Civic EX
- online sources needed
- Should I Get These Rims?
- '94 Honda Civic Del Sol and it's problems
- what do u guys think..
- speed odometer problem: need help asap
- short throw shifter
- kms performance
- car bogging after warm-up...need help!!
- lowered clean look
- tapping after valve adjustment
- Black soot out of exhaust, poor fuel economy
- del sol turbo info
- help deciding paint job color!
- turbo seals
- Question about intake?
- boosting the b16a2 or the b18
- Starting sound of hondas
- Jackson Racing SC pulley?
- Dont know how to hook up BOV!!!
- ECU's
- front speaker help 93 civic lx
- CAR FAX (I think i just got ripped)
- exhaust gaskets
- honda troubles...
- Extending stock o2 sensor...
- location of civic ECU
- Pics of the EG9
- vacuum pressure in gas tank? PCV problem?
- how low should I or can I lower my car??
- GSR cluster into 00 civic
- no start after compression test
- 2000 civic wat kind of motor fits
- driving
- performance parts
- Swaybar too big?
- replacing cap and rotor
- Rear oxygen sensor wires in a 96 hx
- 01 Civic LX Keyless Entry
- need help real bad
- suspension techniques sway bar pic.
- If you bought Omni Powers.... well you get what you pay for.
- trouble getting into gear
- pics of my civic
- what do you guys think of this?
- Tranny Suggestion
- 93 civic randomly won't start.
- Squeaky belts
- Head light problem
- Help with check engine light
- Civic EXi 2000 brake info
- Apexi RSM, where ?
- my vtech isn't working
- turbo gas question....
- This is starting to get old...
- Fireballs
- Omnipower + Neuspeed/Koni's?
- H2B Adapter Plate Template....
- 99 dx sway bar question
- slipping AT transmission!
- jdm good or bad
- testing waters (93 si red SC'ed)
- Clutch engagement problem.
- Dash light will not turn on
- Help with non-OEM indash mp3 player installation
- looky what came in the mail today :rick:
- best way to cut hole....
- 00 civic gauge pillar question..
- gapping NGK plugs
- shocks
- K20a Question
- Locks for the del sol
- Help with keyless entry (98 Honda Civic LX, 4Dr)
- rear view mirror always moving
- Please Help Me!!!
- EK9 Rear Spoiler
- air quality
- need help 96 honda civic 1.6 v-tec
- fan remooval...
- best Intercooler for the job????
- CAI or Front Mount
- can i do 8500 rpm with a stock d16z6?
- Darn....i got suckered.
- got some goodies
- got everything wired up now
- camber kit
- Changing Head Gasket / 95 Civic Hatchback CX
- top speed question...
- unsteady rpm problems
- timing belt
- the windows...
- new setup
- need help with tail light wiring
- exhaust rattle. plz help
- my car bounces
- Still no LCA's....
- wiring audio equipment to fuse panel in 98 civic
- oil line for turbo
- Install DelSol Map Lights
- Lowering Practices
- ebay h22 mounts and axles???
- h23a
- Which NGK plugs are these????
- pics of 17" Subzeros on an EK
- foil tape??????
- Autozone calipers....
- valve adjustment...
- Possessed signal relay???
- reading boost
