- Fender question
- idle messed up and sputtering need help
- *Stolen Civic H/B*
- How To Use Keyless Remote
- Smog checks???
- wierd rubbing noise from drums before and after shoe change.....HELP!
- washed car now it boggs
- Axles in.. But not really. QUICK HELP PLEASE
- Carbon Fiber
- My 92 LS integra has some kind of fuel pressure problem, but not sure.
- rate my ride
- Finally Pics of my car
- Honda CD player in-dash error
- type r head on b16 block???
- Worn transmission bearing
- '05 Acura Civic?
- turbo woes
- 2003 Honda civic road noise
- look at this (new si)
- Where should I be shifting on stock internals?
- axle c clip help
- What wheels are these?
- Weird thud/clunk from passenger side
- Powder coating my engine block
- Drive shaft movement and clonk noise
- 99-00 Climate Control Console/Vent.
- d15 fix?
- jdm d15b vtec
- wire gromment
- Replacement lens for Integra style headlights?
- type R intake manifold on a JDM B18B
- Recent pics of my sleeper sedan
- spitting oil
- Fitting '99-2000 Bumper on a '96
- Just thought I'd say Chello.
- Quick tre Question
- Sol wiring harness
- I have pics Now!!!
- engine light
- Gas cap release
- Automotive paint
- got the turbo on
- Is this rust?
- dirty muffler
- looking for civic
- Ahah! Exaust rattle fixed by Honda for free
- p28?
- next mods
- d vs b
- Exhaust ? searched
- where to put vacuum hoses???pics included
- prelude clip?
- westcoast- when will we ever see 600+whp from your setup?
- Updates on my Sol (Pics) and a few questions:
- drivers side window
- need some help ASAP
- Idle
- sol si has no fire
- Shmoo's Valve Cover!
- Honda Civic DX 2 Door
- burning oil?
- burning oil?
- Timing belt & pulley removal question.
- Header/Cat install problems
- which rapes more
- b18b ac compressor and power steering pump on a GSR
- sponcereship
- Finally making some progress on this turd
- Im going to buy an intake system and dont want to pay for installation
- jdm obd-1 B18B into 1992 civic wiring HELP
- my civic Cranks but wont start
- Weak PoinT B20B @ 7psi ????????
- FAQ: Tons of motor swap info for EG/DC/Delsol
- "Tuning" after a new exhaust is installed
- A few questions
- New to Cars, I just got a Honda Civic dx hatchback auto,
- weird noise
- Is this legit?
- Gauge question
- Ok, I realized I'm kind of slow.
- manual tranny fluid
- Trouble Starting 93 Civic when HOT!!!!
- damncar
- No Oil In Civic - Help!!!
- upgrades everywhere
- b16a1 OBD1 Swap into 96 EX
- Keyless Entry Question
- K20 in 95 EX
- coilovers with stock struts?
- 02 or 03 SI brake swap...(i forget wat year)
- 2006 Euro Civic hatch
- hiyas
- 2000 civic auto tranny problem
- header color change
- Recently bought a 96 GSR
- Im an IDIOT!
- oil change time
- Springs
- LSD question
- 99 civic si m/c
- biggest engine that will bolt up in a del-sol??
- the Best ls-vtech MONSTER setup
- Putting power to the ground....
- oem rear bumper
- 95 Civic EX for sale
- grinding noise.. gears tough
- Question about wheel size and drop?
- Ls Type R Pistons 10-1 Comp
- taillights
- valve cover
- ZTracktion bars for a Sol???
- the right turbo?
- Digital tach for engine analysis
- Tach question...
- warm up low idle
- 99 EX Coupe 5sp speedometer inaccurate
- Axle problem
- heads
- NEED Help!!
- too lean how come?
- shifter assembly bushings? shifter problem
- 95 honda civic 4 dr LX automatic
- Possible Alternator Issues?
- Head Swap
- stock and wondering
- engine build
- engine harness help
- 5-speed harness help
- conversions
- can someone enlighten me please
- gas Question
- guage question
- Installing a turbo??
- Bump stops?
- How long does it take to install cams ballpark estimate?
- Tach Problem
- tail lights
- uneasy idle
- 95 civic massive problem
- HELP!!!! 99 Civic Si PROBLEMS LIKE A MOFO
- Dashboard Lights - Part Number for 98 Civic LX
- I got a serious suspension problem, please help
- HORN (((((((( Get the F out of my way
- matching tires to rims
- Clutch Install
- brake pad problem
- WTF? Friend skipped oil change for 20K miles in 2003 Civic
- 98 Civic 4 Dr LX Turn Signal Question
- 98 Civic 4 Dr LX Heat Shield Question
- Bennifits to new valve train?
- strut install
- What transmission do I have?
- del sol window wiring help
- Change bushing / Install short shifter
- header help
- Tach working correctly??
- Del Sol H23 Intake Vaccum and Shifter ?
- 2000 SI fuel pump problem
- LS-Vtec Questions for the pro's...
- now what could this be???
- EK Power Window Problem *Please Help*
- Which B Series?
- how much do 2.5lb NOS bottles run straight from holley?
- header install
- camber kit help
- ridiculously low idle
- Greddy turbo kit 92-95 civic ex
- Need help on search?
- b18... a1 or b1
- Distributor setup
- Swapping from b16a to d16z6
- Head components before turbo?
- still having problems with idle!!!
- b16 del sol fs
- help a n00b with his civic, please!
- cams in a b16
- Speed bumps are my worst enemy
- 93 honda civic
- need Help!!!!!!!!!!
- 3in exhaust...pre Fab or Custom
- 2gr84u
- carbin fiber crap
- Good place to get a new transmission?
- really, how low do tein s/h tech springs drop??
- need help for acura el !!!!
- engine rev problem
- 98 honda civic stumped!!
- Weird CEl I got
- anyone know where to get cheap nitrous bottles?
- for those of you with a fuel cut off switch
- b18b exhaust manifold to fit 92 hatch??? HELP
- Exhaust Help
- Stereo sreen light!!
- Rain Problem!!!
- Intake Air Temp Sensor
- vtec filter
- Shift Bushing / Short throw
- vtec controller
- 99 Civic HX Horn
- Cooling help!!
- Need Help W/ Exhaust!!!!!!!!!!!!!!!!!!!!!
- 92 honda civic
- help reading codes
- civic
- Grinding sound coming from spark plug area
- How do I grab a bolt that's sawed off?
- Interior rust 94 hatch
- another tire question
- Best winter tires?
- Exhaust Manifold Question
- 96 civic dx w/ 99 civic si conversion.
- Smoke From Exahust?
- A/c?
- b18 shiftlinkage for a 92 hatch
- which way does the distributor go in?
- To the almighty know it alls here at honda-acura
- What is the problem ?
- Definition of the Generations
- Trigger device for civic/del sol
- Help me out - shifter bushings
- 94 civic si
- Stripping Interior--- 94 Civic Hatch
- Window coming off track 94 civic
- Engine mods
- Question: Rod Bearings
- Boost Controllers
- engine types
- Suggestions for new engine replacement...
- 95 del sol mileage sucks *searched*
- Bi-Tron oil additive
- power stearring questions?
- LSD question!!
- what wilwood caliper to buy?
- window regulator
- Missing Car
- Nitrous
- grinding 3rd?
- Purchased a 2kSI
- Suspension malfunction! help please!
- gsr ecu or si ecu??
- 90 civic hatch 4 sale cheap! also a b16 harness .
- gsr ecu or si ecu???
- my 94 civic ex
- AC Filter?
- Looking for Honda with turbo kits pictures (Details inside)
- engine code
- lights
- 5th gear in the rain?
