- VTEC solenoid
- civic
- How does the "lip" protect ur rims?
- skunk2/apexi
- Greddy Sp2
- Do you think you know your JDM civic?
- low rpm lag
- low rpm lag
- problems with fidanza 7lb Flywheel
- intake manifold question?
- CRX HF B16a1 motor swap help
- what is this from
- maintance required button location
- is this normal?
- Shmoo's Valve Cover (Part II)
- 2006 Civic Higher Performance?
- wanting to paint my car....
- Torque Spec on oil drain bolt
- Funny Noise from exhaust.....
- The all new Civic!
- Performance Package Help
- Lighted Shift Knob
- is it worth it..
- what size injectors are on a b16a3?
- Some how this story leads to me going all motor...just read. I need advice.
- CRV - Driver Door Lock Won't Release
- New wheel selection: need opinions
- Update on cooling levels.
- b16 connecting rod limit?
- Throttle cable?
- I don't know what to do with my thermostat now...
- Power Locks/Windows ???
- P30 For P72
- I won this type-r steering wheel, now need advice
- Adjustable cam gear
- What kind of Lip
- exhaust
- 2004 Civic white film left on window problem
- Engine bogging/hesitation at low to mid rpms
- Great. It's always something. Overheating...
- Help Finding Tail Lights!!!
- Some f1 fenders
- How to rig up the horn
- 97 civic header question
- Question about putting a EX Gauge cluster in a Civic DX
- STOLEN: 1994 Civic EX coupe Ewa Beach, Hawaii
- D16Y8 A/T to M/T Conversion help
- 93 civic cx B16 swap
- winter tire wheel package
- 86 honda civic pcv valve
- lets beat this dead horse
- poly urethane..fiber glass
- Custom Door Panels
- 96-98 JDM SiR lip
- b18b speed sensor??? HELP
- will a 99-00 civic si strutbar fit a 1992 civic hatch
- Greddy Evo2 Or Sp2
- JDM kit..will it fit..?
- Tranny problem?
- I was robbed :(
- Carfax?
- A/C hose busted, need some help
- Could This Be The Culprit
- EJ Civic Front End Conversions...
- question
- TroubleShooting b18c1 in 95 EG
- TrADER !
- JDM B16 pass cali sMog ?!
- Do I need to run a p30 ecu?
- can i change a 94 integra alternator with a 95 civic alternator?
- me and my friends bought a race car :)
- D16Y8 aftermarket oil pan options?
- 02 Ex Exhaust Manifold
- Head gasket at 56k ?????
- clutch help PLEASE
- o2 sensor relocation??? 92 hatch w/b18b
- wiring up a 4 wire relay
- 02 sensor
- Engine Temp Problem
- shift cables routing?
- GSR Cluster swap
- Air Filter
- I think something is wrong with my motor, not sure...
- Front door panel for 95' dx civic
- idle adjust
- 98 ek hatch 3 inch exhaust catback
- injectors
- Tanabe Racing Medallion
- Honda Service Bay Area Peninsula
- Another short shifter question...
- 92-95 civic hatchback w/b18b. radiator hoses??? HELP
- Where the hell is my oil going?
- Skunk 2
- Which Short Shift?
- Exhuast Help
- Need some SERIOUS help with my civic
- turbo setup
- carbin fiber
- qm time
- front end conversion
- yesterday i did a 14.2!
- windsheild blade?
- coolant hoses for b18b swap into 1992 civic hatch
- How do u adjust the rear shocks in a Civic hatch?
- New clutch, which to get?
- just startin out
- Which bolt?
- ecu question..
- Crazy video of an turboed ek
- Fender question
- idle messed up and sputtering need help
- *Stolen Civic H/B*
- How To Use Keyless Remote
- Smog checks???
- wierd rubbing noise from drums before and after shoe change.....HELP!
- washed car now it boggs
- Axles in.. But not really. QUICK HELP PLEASE
- Carbon Fiber
- My 92 LS integra has some kind of fuel pressure problem, but not sure.
- rate my ride
- Finally Pics of my car
- Honda CD player in-dash error
- type r head on b16 block???
- Worn transmission bearing
- '05 Acura Civic?
- turbo woes
- 2003 Honda civic road noise
- look at this (new si)
- Where should I be shifting on stock internals?
- axle c clip help
- What wheels are these?
- Weird thud/clunk from passenger side
- Powder coating my engine block
- Drive shaft movement and clonk noise
- 99-00 Climate Control Console/Vent.
- d15 fix?
- jdm d15b vtec
- wire gromment
- Replacement lens for Integra style headlights?
- type R intake manifold on a JDM B18B
- Recent pics of my sleeper sedan
- spitting oil
- Fitting '99-2000 Bumper on a '96
- Just thought I'd say Chello.
- Quick tre Question
- Sol wiring harness
- I have pics Now!!!
- engine light
- Gas cap release
- Automotive paint
- got the turbo on
- Is this rust?
- dirty muffler
- looking for civic
- Ahah! Exaust rattle fixed by Honda for free
- p28?
- next mods
- d vs b
- Exhaust ? searched
- where to put vacuum hoses???pics included
- prelude clip?
- westcoast- when will we ever see 600+whp from your setup?
- Updates on my Sol (Pics) and a few questions:
- drivers side window
- need some help ASAP
- Idle
- sol si has no fire
- Shmoo's Valve Cover!
- Honda Civic DX 2 Door
- burning oil?
- burning oil?
- Timing belt & pulley removal question.
- Header/Cat install problems
- which rapes more
- b18b ac compressor and power steering pump on a GSR
- sponcereship
- Finally making some progress on this turd
- Im going to buy an intake system and dont want to pay for installation
- jdm obd-1 B18B into 1992 civic wiring HELP
- my civic Cranks but wont start
- Weak PoinT B20B @ 7psi ????????
- FAQ: Tons of motor swap info for EG/DC/Delsol
- "Tuning" after a new exhaust is installed
- A few questions
- New to Cars, I just got a Honda Civic dx hatchback auto,
- weird noise
- Is this legit?
- Gauge question
- Ok, I realized I'm kind of slow.
- manual tranny fluid
- Trouble Starting 93 Civic when HOT!!!!
- damncar
- No Oil In Civic - Help!!!
- upgrades everywhere
- b16a1 OBD1 Swap into 96 EX
- Keyless Entry Question
- K20 in 95 EX
- coilovers with stock struts?
- 02 or 03 SI brake swap...(i forget wat year)
- 2006 Euro Civic hatch
- hiyas
- 2000 civic auto tranny problem
- header color change
- Recently bought a 96 GSR
- Im an IDIOT!
- oil change time
- Springs
- LSD question
- 99 civic si m/c
- biggest engine that will bolt up in a del-sol??
- the Best ls-vtech MONSTER setup
- Putting power to the ground....
- oem rear bumper
- 95 Civic EX for sale
- grinding noise.. gears tough
- Question about wheel size and drop?
- Ls Type R Pistons 10-1 Comp
- taillights
- valve cover
- ZTracktion bars for a Sol???
- the right turbo?
- Digital tach for engine analysis
- Tach question...
- warm up low idle
- 99 EX Coupe 5sp speedometer inaccurate
- Axle problem
- heads
- NEED Help!!
- too lean how come?
- shifter assembly bushings? shifter problem
- 95 honda civic 4 dr LX automatic
- Possible Alternator Issues?
- Head Swap
- stock and wondering
- engine build
- engine harness help
- 5-speed harness help
- conversions
- can someone enlighten me please
- gas Question
- guage question
- Installing a turbo??
- Bump stops?
- How long does it take to install cams ballpark estimate?
- Tach Problem
- tail lights
- uneasy idle
