View Full Version : '92+ Civic/EL & Del Sol
  1. Speedomoeter/lighting problem
  2. starting problem...
  3. side moldings
  4. hehe
  5. im back
  6. be nice to people that dont know
  7. CEL after removing AFC
  8. How exactly does the pressure plate line up with the flywheel?
  9. Honda Del sol 1997
  10. where is my main realy? (pic)
  11. del sol engine swap
  12. Do i need to pull the halfshalft to pull the tranny out?
  13. b18b idle pronlem? HELP
  14. Speedometer needle sticks, Help!
  15. 2002 honda civic 2 door & 4 door have the same headlights?
  16. tread depth
  17. Civic Help
  18. ? about Tornado
  19. 2000 Civic ex Left front blinker problem.
  20. Eric's (Raiden's) New Motor! pix inside (b-swap)
  21. Pictures of a del sol i did body work on
  22. Trouble with choosing a ecu
  23. ACT flywheels
  24. Hewwo
  25. The Greddy Turbocharger
  26. Shift knob thread?
  27. Civic Si Rear Speaker Size?
  28. Going back to stock=SUXORS!
  29. sohc v build...
  30. Looking for 92-95 civic CATBACK
  31. 95 civic dx pulls to the right?
  32. Ebrake on '97 Civic DX
  33. will 4 bolt 18 inch rims fit on a honda del sol
  34. electric turbo
  35. No brake lights, reverse lights...or tank gauge.
  36. No Spark on 92 Civic
  37. i need help
  38. Idle Problem
  39. Question on mirrors
  40. clutch slave?????
  41. Projector Headlight Nightmare
  42. thinking of buying a racing seats
  43. Need a USDM b16 engine
  44. 92 civic Take -off is terrible, feels like the tires stick to the ground
  45. Dynamat
  46. Cloth VS Leather...?
  47. p30 ecu
  48. Help!! Whats Next for me to do?
  49. Can't find Bump Stops
  50. 98 civic ex idle problems and lights flicker
  51. 97 honda maintenace
  52. Does this = me screwed? (flywheel cover bolt)
  53. Axle???
  54. cold air intake
  55. Jdm intake?
  56. ?'s about maintenace on my 97 civic
  57. Fuse Problem.
  58. eg and b16a2
  59. Belt Squeaking
  60. thinking of buying a del Sol
  61. b16a sir2 motor problems
  62. So far so good.
  63. will any 96-98 factory radio work with factory keyless entry
  64. Keyless entry stopped working
  65. rear lip search
  66. EK Drum Brake Parking Brake Lever
  67. Fuel Problem!!
  68. What does an S80 transmission come off of???
  69. A/C belt removal
  70. Man, this doesn't even deserve a thread. But I'm stumped.
  71. Automatic vs. Manual
  72. 1990 Honda Civic EX Sedan 4D stolen
  73. 2000 Civic SI bulb/headlight question
  74. Yellow Check Engine Light
  75. i need torque!
  76. a/c relay, cooling fan relay. Cheap part number?
  77. fog light oem harness/switch
  78. 90-93 integra mounts/throttle cable. same as 94-95???
  79. invidia Exhaust system
  80. Can plastic be buffed?
  81. doing the power window swap tomorrow, or at least attempt.
  82. lowered 2000 civic
  83. Ok, I'm not driving my car till this problem is solved...I could have died.
  84. Woah nelly, now I got some grinding.
  85. Mirror Block off Plate
  86. del sol ecu?
  87. Temp is going up yet again after it was ok
  88. help brake conv question
  89. honda civic ´98
  90. Grinding noise, possibly valves?
  91. looking toward the future
  92. Main Relay Problems?? or something else.
  93. thinkin about
  94. ? about 97 civic lx
  95. Lug Pattern
  96. steering
  97. Interior swap
  98. Tutorials on interior work on a 98 civic
  99. electrical... pain in the ass
  100. Please for the love of god, someone have the answer to this.
  101. Picture of hatch with te-37 or rota grids?
  102. Fricken' temp's up again....
  103. just started driving the civic today
  104. Need a IACV, need help
  105. h22 help please
  106. real body parts and kits for civic si 00
  107. All right guys....get ready to welcome me back
  108. 2004 Civic Front Bumper Replacement
  109. Yoink!!!
  110. Tuner wheels...with pic!
  111. Honda/Acura Models Name Changing.
  112. enigne and turbo noobs, come to me
  113. Civic LX 98 Factory Radio Removal.
  114. Is rms-usa.com a fake company?
  115. What size rim and tire IYO?
  116. Ok, my problem all squeezed into one thread(shifting problem)
  117. How do I add transmission fluid?
  118. Which ECU, shifter, radiator... and some other ?
  119. EG Cooling plate?
  120. Civic Ride and Drive w/ Free Concert
  121. 00 civic si performance chips??
  122. torque damper for 1993 del sol
  123. just bought 97 civic LX
  124. New to Honda, Idle problems already!!
  125. What does this mean? It's always fricken' something.
  126. custom exhaust
  127. gsr cluster in 94 vx?
  128. 98 Civic DX: Remote Key Question
  129. good shop
  130. Spring rates for daily driver...
  131. Yep one more Problem
  132. new rims...need tire help
  133. eg 4 door cluster install question
  134. Civic won't start after some weird problem.
  135. Del sol swap or not
  136. B18B1 motor mount problems
  137. To WSC Documentary.The story will Continue!
  138. '94 del Sol drop question...
  139. Help with 89 dx ignition module
  140. What are my valve options??
  141. Need colors of 02 sensor wires for new 02.
  142. Differences. . .
  143. Which brakes pads for my daily driver?
  144. JDM B16 help!!!!!!!!!!!!!
  145. Burning Oil and 3gear pops out while driving
  146. keyless remote 96 civic ex
  147. Civic problem
  148. stock springs??
  149. S20 transmission question
  150. Intake Questions
  151. Load Controller
  152. Engine specs
  153. lights!!!!
  154. Help QUICK
  155. EK Sidemarker works, then doesn't
  156. B16A1 Gas mileage
  157. Fenders?
  158. why deltagates suck (as if you didnt know already)
  159. B18B1 in 92 civic hatch
  160. engine swap ideas
  161. Just bought a Civic CX...few questions please.
  162. This is what water puddles can do to your car...
  163. z6 head on y8 block?
  164. How do I install Taillights?
  165. what ecu
  166. Greetings from Finland
  167. sol wiring
  168. Spring and Strut install
  169. engine swap info...
  170. Brake light help! ASAP
  171. 95 civic ex
  172. v-tec or non-vtec
  173. WCS: Then and Now - A Documentary
  174. Greddy Evo 2
  175. How to program a v-afc II
  176. What type of Air Intake
  177. gsr or si?
  178. Thumping noise from passenger side front.
  179. how to install starter...?
  180. ek question
  181. Which exhaust
  182. ACT or C.M.
  183. timing question
  184. '02 Civic EX acceleration/deceleration problem
  185. I like the new 06 logo
  186. head swap question
  187. steering wheel cover
  188. Internals question. I might have the wrong parts...
  189. D16 Engine Rebuild
  190. Special tools for 94 Civic EX rear brake job?
  191. del sol ???
  192. 99-00 Si B16 trans. bolts for b18b???
  193. Cam gear bad setting ?
  194. 92-95 civic EX gauge cluster install...do you need to rewire the temperature gauge?
  195. Hey new here
  196. 1999/2000 Civic SI B18?
  197. 2006 honda civic
  198. What are these so called "serials"?
  199. Fuel economy and upsizing your wheels.
  200. Reseting SRS in 96-98
  201. headlight conversion
  202. tanabe super racing medallion or skunk2
  203. What? A honda that wont start!
  204. gettin tuned soon
  205. b18b swap setup PIX
  206. dimmed headlights
  207. Air bag question
  208. Correct Crank Pulley tool for 92 civic DX
  209. Civic ignition
  210. Need advice on a 92 civic lx
  211. A/C COmpressor Problem
  212. boost options
  213. help ID these wheels
  214. code 41
  215. Few questions about my 92 hatch
  216. supercharger or turbo?
  217. shifter problem
  218. 5 lug
  219. Civic Ques.
  220. Does any one know
  221. Air/Fuel wont work?!?!!?!?!?
  222. SOHC to DOHC ?
  223. manuals?
  224. Struts will an 99 si fit a Eg ?
  225. Whats the best way to fix classic honda rust?
  226. Honda civic Hatchback Si 1995
  227. questions for smart civic peoples plz help
  228. B16a Supercharged is this tHe right size ?
  229. Hard to start after short break
  230. swap question
  231. Anyway to retain CruiseControl using Type-R steering wheel?
  232. err..this is getting old
  233. 93 civic brake lights don't work
  234. Question about rear lip
  235. 00 To 95
  236. starts, misfires, stalls
  237. 97 civic ex radio fuse
  238. 04 civic coupe rear window deck removal
  239. ////post The Hottest 6th Gen Civic////
  240. Need help
  241. Seat Swapping Question
  242. Why does EVERY honda dealer do this to me?
  243. 2005 Coupe wheels
  244. Sticky Gear Selector in a 96 LX
  245. integra-rsx transmission swap
  246. where to buy?
  247. p28 wanted
  248. S2k steering wheel..??
  249. which swap
  250. car is tuned here are the results
go
