View Full Version : '92+ Civic/EL & Del Sol
  1. CKP problems
  2. Help!!! Do I need a new engine? 92 civic
  3. Help with code 45
  4. Hellz yeah, i fixed my A/C!!!
  5. HELP - Lower Motor Mount Bolts Just Spin
  6. A littile audio plan
  7. Help me with a cooling issue
  8. Del Sol seats 1997 vs 1998?
  9. Please Help: CIVIC EX 2000 does not start after passenger side power mirror change
  10. How do I get a new key?
  11. How to ID B18C? or Type R
  12. 2000 Civic-VP-Window problems
  13. 01 civic Crash data in Airbag module ? clear?
  14. D16A into EJ1
  15. ok my little D series turbo whores....
  16. Drivetrain problems HELP!!!!!
  17. need some suggestions
  18. NeEd HeLp PlEaSe!!!!
  19. 96 Civic Hatch DX swapping to b17, need wiring info
  20. help how to remove speed limiter on a B16A
  21. Cluster removal - '96 - how?
  22. valve lash adjustment tips
  23. Wanted Stock Air Breather 99 Civic 1.6
  24. Improve handling on 7th gen?
  25. 92si / old 95 GSR swap Check Engine Light
  26. Looking to do a 2000 conversion to my 98 Civic Ex
  27. 99 Civic Lx failed emissions, cracked exhaust manifold
  28. Radiator Fan Motor
  29. CEL/PGMFI troubles..
  30. 01 Civic computer? driving me nuts...
  31. Motor Mounts
  32. JDM EG6 Folding Mirrors
  33. Halo headlights same as HID?
  34. 97 civic dx hatch leak
  35. Engine stopped running while I was driving the car...Any suggestions to the cause ?
  36. Tranny Fluid Leak Help
  37. 2000 honda civic audio
  38. 98 civic ex idle problem
  39. 40 mpg?
  40. Question regarding new dash light bulbs?
  41. What can I do with a D16 Z6 motor?
  42. 4 door, removal of rear seat
  43. 94 civic ex Seats
  44. Market research feedback regarding 92-95 Civic 5G EG/EJ speedo clusters
  45. Need some input on buying a used car...
  46. Rear drum removal
  47. Starting problem
  48. Question on Lowering Springs
  49. WTB rims.....
  50. header help and wiring help
  51. 99 civic weired electrical problem
  52. What kind of motor do I have? REALLY!!!
  53. B16a Swap Into Ek, Wiring Question
  54. How low should i go? Lowering Springs
  55. How Many Si's
  56. Saving a Sol
  57. 95 lx auto looking to do a gsr swap.. is it worth it?
  58. 98 civic ex ecu/spark question
  59. 92 auto hatch and a 93 manual del sol d16z6
  60. 98 EX burning oil! A lot of it!
  61. 92 civic DS window wont go up or down.
  62. 95 LX auto low idle speed NEED HELP
  63. 92 civic ac help
  64. PCV Valve
  65. 95 lx auto "flooding?" issue
  66. 97 civic ex coupe power loss
  67. How to find if a car is stolen with the VIN
  68. 99 civic fog light install help
  69. Transmission Fluid?
  70. blower
  71. eg conversions
  72. SRS Light On - MES Connector
  73. Tranny Grinds???
  74. Help Change Engine Thermostat In 95 civic lx
  75. How much oil 93 civic dx
  76. Calipers :( DIY gone bad
  77. 06 front end conversion on a 98 using fiberglass
  78. AC Compressor - Will any other years work for a 95?
  79. Sunroof is popped up, but won't shut. Help!
  80. Fiberglass panels
  81. 92 Civic EX won't start.. NEED HELP
  82. Quarter panel
  83. somethings up with my clutch.
  84. tranny rebuild
  85. 94 hatch A/C question
  86. VIS CF hood question - did they screw up?
  87. Spark Plugs, POLL & submit your $.02
  88. Thinking about a little upgrade, from 99 to 2002
  89. fuel pump wont stop!
  90. Yet another "recommend a suspension package" thread - '95 Civic
  91. integra dash into EK ???s
  92. Polyurethane Suspension Bushings.....
  93. rims
  94. Problem With AEM CAI Install
  95. 97 Civic DX will not start *SOUND CLIP INSIDE*
  96. Which coolant? 96 civic hx?
  97. Greddy Evo 2 Exhaust rattle (not heatshield or loose bolts)
  98. 1993 honda civic 1.6ltr
  99. Question Regarding Throttle Body Spacers.....
  100. Belt replacement
  101. new radiator - any tips on the honda install?
  102. P.C.D. On 93 DX
  103. axle questions
  104. condensor hoses - does coolant run thru them?
  105. Is it Possible to Purchase 1 or 2 dampers
  106. maintenance and gas mileage
  107. front speaker install question
  108. someone help!
  109. Wheel Bearing and Wheel Hub
  110. wich V-tec Head is better for my D16?
  111. car won't start!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  112. ebay
  113. I Need Help!!
  114. GSR swap ?
  115. EG6 from Malaysia. B18c type r transplant
  116. 2002 civic bogs
  117. engine swap help, please
  118. Strange sound in a new-used car
  119. OBD-II Help
  120. A/C Question! HELP ME PLZ
  121. 93 civic dx...Value?
  122. Rear window 2000 civic
  123. big brake kit
  124. Trans Mount
  125. Clunk?
  126. Transmission part
  127. power window help
  128. brake hardlinesfacts
  129. gsr swap mount ?
  130. si/gsr front strut onto 00 hatch...need advice/help
  131. Help Needed - Installing Air Intake on '96 Civic
  132. smog related question...
  133. A/C help kinda
  134. my si rims are fading...help me
  135. 92 hatch suspension advice
  136. Newbie here....
  137. d15z1 swap in 92 Si??
  138. Weird problem..need some expertise here pls.
  139. Wiriing help
  140. 97 Civic Crank Pulley Questions
  141. Rim size?
  142. Side view mirrors
  143. 98 civic ex coupe engine swap Question
  144. E85 Theory
  145. brake pads and rotors...need help
  146. havent been on here in forever... new pics of the civic
  147. 94 civic - exhaust
  148. >>> Midori Green EK Hatch STOLEN in Danbury, CT
  149. Wheel stud question...
  150. 95 Civic Front End Annoying Squeak?
  151. sidemarkers
  152. Tokico Vs. KYB
  153. misfire/bad tach?
  154. Why does paint fade there?
  155. 98 civic Transmission question....
  156. Fuel Regulator / Fuel Rail 97 Ex Civic
  157. wiring help also dizzy
  158. 1997 Civic DX Hatchback need help
  159. Sputtering
  160. CAN SOMEONE TELL ME WHY I HAVE A17 Pinned on a ....
  161. Featured Ride
  162. running with the oem intake w/o the silencer?
  163. B18C1/B16A combo
  164. d15z1 downswap...?
  165. anyone know osaka bane spring company?
  166. Shops in Nor. Cal
  167. JVC kd-s14 not workin in 95 honda civic ex
  168. Dyno'd the turd
  169. carfax reports?
  170. Oil jets B18c1
  171. Engine Check Light
  172. 2001 Civic DX 55K Transmission gone out?
  173. Question about 96 Civic Sedan DX
  174. AC on a civic (GSR)
  175. 1995 SOHC Vtec
  176. Looking for a good choice in spark plugs...
  177. CV axle question - play?
  178. Speedometer not working
  179. strut and strut fork?
  180. No Dash lights/ corner lights
  181. tinting the tailight on a 99 civic....
  182. 96 Civic HB...
  183. new project car
  184. d-series release fork same as b-series y21 gear box
  185. 93 Civic - adding a tachometer
  186. justa ? bout the ecu.
  187. Dont even know what this part is
  188. radiator and/or condensor fan
  189. civic timing tune up
  190. need some new speakers
  191. HELP! Immediate HELP! HELP! plz give pointers
  192. I just bought a 1993 Honda Civic DX and it only has 60,005 original miles!
  193. b16a throttle cable problem? help
  194. Help with OEM tail lights on Civic 05
  195. help.fixing common rust on 95 honda civic.
  196. 93 Civic Headlights (how to wire "always on")
  197. 95 civic air ride
  198. Should I get K20A3
  199. stock taillight help.please.
  200. removal/install door panel in a 99 lx 4 door
  201. help front transmission bracket b16
  202. heres a good one..
  203. 1999 Civic Si Tranny Work
  204. trans build
  205. Some Brake Questions
  206. Error codes
  207. ls into my sol
  208. car wont start.. help
  209. car not feeling right
  210. OBD1 to OBD2 Crank Position Sensor?
  211. This is my new build 93 coupe ground up
  212. 99 Civic LX cracked manifold
  213. CEL 3 short then 5 long flashes!
  214. O man, this thread is sooo locked.
  215. suspension for the civic
  216. Acura 1.7EL Brakes
  217. power steering rack converted? to non p/s?
  218. New '94 Civic EX looking for a new look
  219. question on exhaust valve condition
  220. No spark and relay is clicking CRAZY.
  221. need help quick decision on buying
  222. Clutch problem, no pressure
  223. B18C swaped in a 95 coupe
  224. as I say so long to the civic world....
  225. << So my car was stolen AGAIN >>
  226. what are the cons of increasing compression?
  227. diy camber kit installation 95 civic dx
  228. Civic: Leaky trunk
  229. re-installing rocker arm assembly/camshaft
  230. thermal unit removal from d16y8
  231. Civic gsr swap ?
  232. pshsguy18: will 96 -00 civic air ride fit a 95 civic ?
  233. 2000 Civic SI engine rebuild
  234. Doe Anybody Have A Wiring Diagram On Installing Fog Lights For A 92-95 Honda Civic
  235. Spring length question
  236. i'm looking for a car
  237. Sputtering... Need Help
  238. b16a axles question
  239. 1999 Civic LX Pads
  240. Oxidized sol - help?
  241. 95 Civic tail lights won't turn off
  242. Greddy evo2 vibration when turning
  243. embarrasing noob question but important
  244. b16a wiring harness
  245. keep the gsr or ??
  246. b16a
  247. Car takes a bit to start when cold
  248. 99 Civic Fuel Main Relay.
  249. No Brake Lights!!!!!
  250. which motor?
go
