- main relay problem?
- 92 Civic Cx electrical problems
- Euro Lights
- Late model Civic tranny fluid change
- climate control issue
- is this a rip off?
- FPR Installation
- Auto To Manual Convertion!!
- chiped ecu?
- Hydrolock Question!!!
- 99-00 civic si a/c fitting onto 96 w/ 00 front conversion
- n00b internals questions
- taking out the dash
- torque b16aII bolts
- Wheels
- wholsale prices
- need help quick 1.6 vtec
- 99 civic si spring?
- ground wires
- short shifter
- engine rebuild questions
- Need help ASAP
- B16+T-4 Turbo VS GSR+T-4Turbo?
- My new project
- Stick Shift Question!!! PLZ READ!!!
- Carbon fiber hood
- throttle body ?
- ACT clutch+fly on b16
- I hate to ask this on a car forum...Muffler, I need one
- Main relay hates the cold?
- Cheap Speed
- RS-R Exmag vs.. RS-R Exmag GT-II
- Interior questions...panels, sub box etc???
- Skunk2 Exhaust is VERY LOUD and Raspy .......
- greddy catback for $220. Is this a scam?
- civic speedometer problem
- civic idle problem
- civic idle problems
- Need a quick answer on OEM spoiler light
- Exhaust and Cat Raddeling ????
- Strut Bar
- Strut Bar
- Suspension...
- b20 vtec vs b16
- trouble P0141?
- 95 transmission questions
- Suspension Question!!! Plz Read!!
- b16a all motor vs supercharged
- rota slipstreams
- Are these ITR cams judging by the rings. Plus other questions
- Del Sol Problem
- Newb Suspension Questions
- 94 civic timing belt
- Loosing Power & DONT KNOW WHY!!
- MSN site to check out
- what engine i have ?
- oil
- B16a1 help
- heater problems
- Civic Paint
- mugen & jdm parts
- boreing out some stuff(need clarification)
- Leaking hatch??
- Some general questions...
- Civic HX exhaust sytem
- PICS of Ciciv HX motor
- Catalytic Converter is missing!!!
- Big Help!! Help!!! Help!!!
- idle screw....which way?
- del sol
- A/C Question
- look at this
- Timing belt installation question
- CEL on hb
- Rebuilt axles
- Cats oxygen sensor
- bought del sol tonight
- just a ?
- Funny Night
- clutch upgrade
- gas
- need new carpet
- neeeed help quick
- JDM aftermarket coilovers good or bad?
- I am noob are revchip performance chips any good
- axxis brake pads
- Sometimes it just wont start
- need help 1.6 vtec
- General question
- Every Civic needs these.
- Civic VX hatch MPG 48-55? Verify...
- anyone buy one of these Radiators?
- Car taking longer to heat up???
- dx coupe speakers installation
- Another exhaust dilemma...help
- code 9
- help?
- New Project EK/EJ- parts list
- how much is it to install a right fender for a 99 civic lx??
- del sol s, si, vtec !!
- who else has a boosted EG?
- turbo d16y7
- Best Seats Out
- Anybody know how to register JDM RHD?
- How do u get your engine bared?
- Eric's Motor Ver.101005
- Intermitent roaring sound while idle
- whats going on with my steering?
- just bought a used GReddy Muffler
- Opinions on latest project
- Big brake
- gsr cams for b16?
- external ignition
- civic 98 cluster
- 02+ Si Civic Seats
- 96-98 Civic DX Owners Manual
- Strange noise at 1500rpm..
- Newbie -- What can I expect to pay? 04 Civic Hybrid
- how do i clean out my headlights?
- DH racing ported&polished d16y8 head?
- flywheel side oil seal removall help
- Front intercooler, cold air intake
- my civic wont start, just put in new clutch kit and replaced the starter too
- Socal Bodyshop Needed! (714)
- 96-00 EX header on DX
- How to replace rear bumper on '97 Honda Civic EX??
- changing color of LEDs?
- 5th and Reverse?????????
- does this look right?
- using amorall
- Drum brake adjuster lever
- 2000 Civic EX Cruise Control Issue
- Anyone????
- B18 swap in 94 civic
- What cams should i get?
- n00b Introducing my Sol
- fuel pump ?
- civic eg idle problem
- my del sol is rusting
- Building motor
- will this shift linkage fit in my auto to 5 spd swap
- POP! sound after replacing distributor o-ring
- 94 civic
- B16A1 into 96 Civic Dx Questions...
- New Setup, Dyno Numbers...
- Dome light won't work.
- Will A Greddy Turbo Fit . . .
- Jackson Supercharger ? what type of boost ....
- Ok, I just took my car out for the 1st time since I did my clutch....
- Honda Civic Throttle body
- Integra Interior Into Hatch
- help finding parts
- weatherstripping for del sol
- ? about lowerin kit
- Need some buying advice from a possible dealer '06 Civic Ex Sedan
- How do I Go from D15 B7 to D16Z6
- Honda Civic 1.5 LSI Idle Problem
- Will A B16A First Generation .....
- new drums installed....weird noise under light braking
- Wicked shimmy, No AC, Frequent shorts...
- gauges dont work :-(
- 92 Civic Fuse Layout
- Need Help On Rebuild and What Parts to Use
- Input pls.
- Anyone had these problems with their 2000 CIVIC
- Is it my distributor cap or Ignition distributor
- Engine Dampener
- how much does a 1.5L weigh?
- Valve Adjustment Tool
- E-Brake Lever Housing Inserts? wtf mate
- Wich Wing for an 98 Civic?
- 93 Civic NOT STARTING HELP!!
- 02 Civic wheel question
- Thank you very much guys, you all were a big help.
- Prices of Engines
- Help!
- Si Wing
- How close should the tranny get to the block when reinstalling it?
- Head problems?
- F20C civic Swap
- Honda Swap Information
- b16a
- Civic VX O2/CAT question
- Broken Wiper switch... question..
- civic V-6
- will crx springs work on 96 hatch
- 97 Civic EX idle questions
- Just Tire ripping me off?
- Fuel Filters?
- Jackson Racing Supercharger +ZC
- obd II diagnostics port
- popping the clutch?
- turbo problem
- 93 si..engine cutting out
- SiR cluster
- Shift knob question.
- Battery or alternator
- Will '03 After Market Parts fit an '05 EX?
- Cooling fan switch.
- GSR gauge cluster in EG
- Cat-back exhaust worth it?
- back to the ferio crew!
- Is it worth?
- Is there any uh, tips or anything to line the tranny back up?
- B18a1 in delsol
- dyno time???
- HELP! My SRS light is on.
- lighting problem...
- I'm tempted to bUy a 2006 civic even though I don't want one
- nos for 00si...help
- 94 to 97 civic front end?
- Oil pan change on '93 Del Sol 1.5L
- anybody know where i can buy a jun spoiler
- I saw the new Civic Coupe today in the flesh!
- How do I take off my eg steering wheel?
- fan turn on time????
- 3040 Proportioning Valve
- HAH! Found the culprit.
- Blew-up my '98 Civic EX - now what... ?
- B16a2
- 3/4th's through the clutch job with no problems!(Thats a first)
- Corss drilled vs. Slotted
- Rallying A CIVIC!
- Suspension Interchangeable?
- axle came off while driving
- motor questions
- s2k seats in 6th gen civic
- aem filter
- Things to check for...
- next step in making my civic faster?
- transmission diagrams
- apexi vafc help
- How difficult is it to install...................
- ac taken out good or bad?
- lowered civic, alignment pronlem?
- 95 del sol si
- 97 Civic DX stereo removal HELP!!
- Engine Light
- 98 Automatic Civic Shifting Hard
- Civic/Del Sol Confusion
- radiator help please
- I have a header question.
- Having trouble finding performance parts.
- What engine is this?!
- Neuspeed and Tokico Illumnia 5-way?
- cel 22 can this stop engine from starting?
- Before, I pop the tranny off, there's one more thing.
- fuel filter
- This has to be a tuning issue!!!
- tune up
