- electrical problems
- Performance springs?
- Johnny Race Car
- Bought Used Civic Si 2003
- Full Exhaust=problem Solved
- New Del Sol Owner...need tiny bit of speed
- Anyone know what causes this?
- make 5 lug?
- Correct Transmission??
- electrical issues...
- Need Help Fast Plzz Read If Good With Hondas
- Firing Orders??
- Master Cylinder is leaking?
- Will high flow CATs pass Cali smog?
- tail lights (eg6)
- Full Exhaust= more problems
- Out of curiousity...???
- Where is the headlight vertical tilt adjustment? EK
- Best place to get a paintjob?
- Integra type R manifold question
- adjustable coil overs dont stay after adjustment
- What should I do to a civic
- 2005 Civic Coupe OEM Tires
- Civics at SEMA
- 92-95 HB rear wiper
- Stalling/hesitation at start
- weight reduction
- Turbo on 145k
- Civic Brake Upgrade
- "Defensive" Driving Course @ TRC...
- Running rich because of an 02 sensor..i think
- B16 Bogging down after 1/4 throttle
- lowering springs?
- more speed from my D16Y2?
- Emanage Vs. Hondata
- car troubles
- Circle Racing 15x7 aluminum- what Backspace?
- are b series down pipes interchangable
- wheel rub on 15x6.5 wheels??
- tach question
- so my car stopped...
- Anyone lowered about 2.5 F 2.25 R??
- Master brake cylinder problem
- My '96-'00 conversion (so far)
- torque
- led taillights
- GSR swap in a single cam EK
- AUTO in my EG!!! HELP!!!!!
- Guage cluster issues
- Overheating (but not in its normal way problem
- EMISSION CHECK,please help?????
- 2006 Civic Si
- H22 in '92-'95 Civic HB?
- What should I do?
- 93 civic h/b possable engine swap
- Custom dual exhaust
- Tach install help
- B16a1 quoted at 150bhp in uk.
- B18b for more Horses
- Twin Turbo b16a2??
- Engine Swap Arizona
- Will a F20C fit in a 00 civic?
- Camber Kit
- Pistons
- Koni Red Shocks..Good with what springs?
- ECU Question
- The limits of OBD-II?
- 96 civic ex questions
- LED Lights
- issues with new clutch
- thinking of doing all motor
- Interior panels
- Weather Stripping. Is it easy?
- Blower control not working correctly..
- Hi all
- what is the difference between ebay and brand name intakes
- Del Sol d16z6 engine issue question
- 92 Civc Camber
- 92 Civic Si Sludge in radiator neck.
- Replacing steering wheel. HELP.......
- Civic 01 cabin air filter
- !!! is this true !!!
- MSD 6a install question
- Fan control/88 civic
- Integra door panels in a civic?
- ecu question...
- Will an RSX Dashboard Fit into an EJ?
- Zoie has had a rough week
- gsr into civic shifter
- just bought 94 ex 2dr
- 93 civic runs funny
- Black shit means an exhaust leak right?
- just found this...for Civic people
- LED License Plate Frame
- i'm lost
- quick question about tokico illuminas...
- Camber Kit
- mini-me ??
- gas milage?
- cyclonefuelsaver
- top speed question
- Are these street Legal?!
- How do i tell if i have a b16a1 or a2?
- O2 sensors for 97 Civic CX
- 5 mpg decrease
- review on good lugs..
- Why not a H22A
- Civic lowered...Tire size?
- 92 Si still revsfunny issue P28 ECU change
- Disc swap from 90 Integra to Del Sol, possible?
- Short Ram or Regular Intake
- Here's some poorly taken pics finally
- skunk2 coilover o-rings???
- shifter bushings...
- Yellow JDM fog lights
- best headlights?
- Which is the best Aftermarket wire set? 92 Si
- A little japan info????
- are basicly all d series the same?
- Front End Shimmy
- Leaking
- question about Bumper trim
- 3rd Listing!! Big Idle/Fuel Problems
- Wheel Hop: 92 honda civic
- fuel injectors not working
- VSS location on a manual 6th generation civic?
- contitech vs tsubakimoto Timing Belt
- noob question
- I need a new car
- need wiring diagram for 97 civic
- new front brake pads
- Does this EG9 cluster fit into...
- just got a 95 honda civic 4dr
- tein or omni power
- quick question
- projector lights
- lowering springs
- freaking help me and respond to my shit god damni
- oil pan question
- 1k idle, feels like the car is about to stall out...
- Bad map sensor affecting my idle?
- Questions about tire size on my 92 civic
- 92-95 civic city lights?
- 95 Honda Civic Marlin, Engine Cutting Out
- JDM Type-R OEM foglights
- 1995 Civic DX - fuse box problem.
- Question about OBD2-OBD1 Conversion
- how hard is it to install a camber kit?
- headlight help needed!
- side markers question
- Knock Sensor Help!
- 2001 civic losing all lights
- 92 civic hatchback rear seat removal?
- del sol #'s
- keyless entry
- problem with door locks
- tail lights coupe on a hatch
- I need advice on a shiftlinkage
- invidia catback?
- Air Fuel Guage Install
- No fuel pump prime?
- code P0141
- body shop and aftermarket help in seattle
- Speedometer, and oil light problems
- Crack on inside of tranny housing.
- 92 Si revs up and down in Idle on its own. ECU?
- car acting up.....
- Rims update... and some "hot" models!
- Alternator
- Civic stutters when.....
- wanna a new suspension
- CTR Front strut bar help
- CV Boots
- Pennzoil High Milage Oil
- K&n Air Filter
- Fuel Filter
- Civic flutters when its in gear
- OMFG I cant find a iacv that will fit my b16 anywhere
- ECU Pin outs
- Best engine to swap into 95
- Rear Wiper Motor Civic 92-95 HB
- Swap or Suspension?
- Question about Idle
- car wont start
- Belt Tensioner Problems
- ctr stuff
- Heater not working....
- What is the about cost?
- getting my first hatch
- Sleeper rims
- pistion ?
- Weird shaking/vibration
- SRS light blinks when pulling CEL codes
- Check Engine Light ON?
- Omni (or Skunk2) UPPER balljoint:
- 03 Civic Hybrid battery
- Nitrous California
- Rough Idle causes?
- Ek/eg/ex?
- Oil Pressure Port
- help...check engine light came on
- question about b16 tranny
- Rear Brake Conversion . . . PLEASE HELP !!!
- Please Help No spark no Fuel
- 94 ex civic starting issue
- 02-05 Civic Si Service Manual
- speaker??
- VX hatch Cat clogging...
- Replacing EK foglights?
- i need tire advice
- my white hatch RECOVERED...PICS galore 56K WARNING!
- having trouble getting traction??? cant figure out why
- My Ride HELP
- Rota Slipstream 15 x 6.5 vs 15 x 7??
- 4x100 to 4x114.3
- Keyless Entry not working, Dome Light Blinking...
- Wtf?
- odometer question
- del sol front end conversion
- Adjust my shocks
- helms manual?
- finaly got the civic running.
- Problem with idling
- Axle Back Help !!!
- lowered springs same as standard springs
- having problem with d15b swap? help?
- Having problems with civic, plz help
- What the Honda dealership said
- 1999 Civic SI grille
- real world
- Should I expect engineering flaws in 2006 Civic (first year of this generation)?
- How can you tell the difference between heads
- Need Help Finding
- Idle problems, and starting problems
- civic drives funny
- Fast Idle Problem
- Breaking in a Clutch?
- Just bought my del sol
- why won't my car take off smoothly?
- 90 Civic AC
- Neeeed Help
- what is the diff. in b16a1,a2 and b
- going from lude to civic and need help/opinion
- D-serise clutch replacement
- what the hell?
- Mini-me Clicking Noise. Help!!
- Video of my car not starting. Maybe this will help?
- Need Exhaust Help .... ASAP
- car stalling and i am gettin no heat
- Airbags
