View Full Version : '92+ Civic/EL & Del Sol
  1. camber adjustment
  2. which control arm bushing kit?
  3. air vents...??
  4. Exhaust question- cat. fitment
  5. Honda/ Acura similar parts guide?
  6. headers
  7. Where is the alternator fuse? 1996 Civic
  8. help with finding parts for 05 lx
  9. H E L P !!!!!! Fuel pump problem i guess
  10. 92 Si ECU code 19 Error
  11. 95 civic idling up and down?
  12. Crv-tec?
  13. Wat Engine
  14. When does VTEC engage on my D16Y8?
  15. I'm lost. I have no clue why my car won't start.
  16. Possibly damage or self heal?
  17. stolen cold air intake box and throttle body
  18. Left brake light not working
  19. Intermittent Battery Light
  20. questions on performance exhaust
  21. 95 Honda Civic Firewall
  22. What ecu is this ...??
  23. Possible suspension problem ?
  24. Air Intake Installation Problem: 97 Civic LX
  25. what seats
  26. 10 gallons for 180 miles?
  27. koni suspension
  28. si lip.
  29. new battery for 1992 civic?
  30. Molding Plastic?
  31. Help Got Problem!
  32. 95 Civic STEERING PROBLEM!!!
  33. Method of buying Japanese cars and parts cheap!
  34. another itb question
  35. Out of curiosity
  36. auto cluster in man. tranny?
  37. What would this motor handle for Boost?
  38. low idle?
  39. Changing Head Gasket
  40. No Check Engine Light
  41. Last E-Town event 11/20 I did an alright time for my set-up
  42. Fuse keeps blowing, help please!
  43. help...stereo install
  44. how hard is it to replace an alternator 01 civic
  45. 92 Si DC header 1PC or 2PC?
  46. Tail Light Fillers?
  47. hard starting 92 civic sedan
  48. Help! My car won't start
  49. CV axle install problem
  50. Help
  51. good sports tires?
  52. What is the lug pattern for a 94 Del Sol?
  53. Help What's The Average Gas Mileage Supposed To Be For My 95 V-tec
  54. Boost question
  55. Clutch Kit Conundrum
  56. Apex Boost gauge
  57. could my alternator be going bad with only 95000 miles
  58. 99 civic SI radio code?!?!
  59. CTR Shiftboot in EG or EJ?
  60. Headlights
  61. Driving Lights Or Fog Lights?
  62. vtec
  63. JDM Type-R ecu vs. JDM B16 ecu
  64. exhaust
  65. JDM B16 Pistons??
  66. boost gauge vaccuum source!
  67. C8's, C10's, or RGM Slips? Red Civic
  68. Orginal manifold
  69. wrecked my Sol :'(
  70. Exhaust question
  71. Speed Sensor Location
  72. Any SoCal Tuners?
  73. ITR seats in 92-95 HB
  74. How many 02 sensors?
  75. Finnaly Full Booost!!!!
  76. Opinion wanted
  77. Stereo Wiring
  78. ABS code 1-2
  79. Went to the Honda dealer for a quote...and...
  80. Five lug convertion
  81. Engine swap or rebuild?
  82. Identify This Part...
  83. Civic front end conversion question
  84. new o2 sensors and a problem!
  85. AEM Pads' Reliability???
  86. Brake light on in dash...e brake down...help
  87. Brand New 05 Civ Ex Se..wat Can I Do?
  88. HELP! EK 97 CX hatch, whats needed-H22 swap.
  89. How does some of U calculate the miles per gallon ratio?
  90. changing honda civic tail light
  91. Throttle Body
  92. Omnipower Coilovers Thump noise... anyone fix?
  93. A/C relocation
  94. Door panel swap 94/95 coupe to 92 Si
  95. I have a 98 civic ex w/ 99gsr swap, springs
  96. jdm fog lights
  97. Clutch peddle stuck.
  98. heater fan vibrating, noise, smell, you name it
  99. codes
  100. Correct Tire Size?
  101. shifting hard i think
  102. Alternator Replaced, Check engine light still on
  103. iac
  104. Question 96 Civic Ex
  105. Bumper Replacement?
  106. Annoying sound from the engine (video)
  107. Omni Power Coilover System vs... Omni Power Coilovers
  108. Help needed...power steering question
  109. speakers
  110. d2 coilovers?
  111. numbers on b16 greddy bolt-on
  112. 1997 Honda Civic
  113. Slight vibration
  114. Gas Light
  115. Titanium pistons for SOHC ...heeeellpppppp
  116. EG civic with cages
  117. lowering civic hatch...height?
  118. come on civic COME ON
  119. Keyless Entry Problems
  120. check engine light
  121. Civic that overheats
  122. Vtec Controller?????
  123. korbach frame locks?
  124. Removing clearcoat and paint from plastic
  125. front end noise
  126. readjusting
  127. Noise Problem
  128. Carbon fiber hood
  129. Understeer?
  130. 92 Si Clutch Stage 1, 2, 3?
  131. civic gauge pod problem!
  132. radiator hose
  133. help needed?? am I Stoopid?
  134. Cross Pin in ES Trailing Arm Bushing Sliding
  135. 03 civic block heater question
  136. Steering knocking vibration, picture!
  137. Okay, how about filters? any recommendations?
  138. Blinker *blink blink* noise
  139. New Shoe's!!! (Wheels, for the un-informed!)
  140. Need HELP! Koni Struts
  141. Should I switch to synthetic?
  142. speed problems
  143. oil in distributor
  144. I Need Exhaust Help Bad!
  145. Any one have.......
  146. Engine Swap DIY
  147. HID kit on OEM headlamps?
  148. agony
  149. proper set up of coilover
  150. H22-97 HB parts inquiry
  151. Loud thumping/knocking noise when braking
  152. What type of oil does honda dealer use?
  153. Have a check engine light on!!
  154. Removing a/c?
  155. sohc pistons
  156. Can I put an O2 sensor from a 94 EX in a 99 EX?
  157. 93 HB DX axle question
  158. I heart my Honda decal placement?
  159. Titanium Pistons for 95 SOHC
  160. Tranny instaled with problems
  161. quick question about SI seats...
  162. Possibly changing suspension...
  163. new car.. need help
  164. head gasket
  165. Webmaster???
  166. Does high speed requires special maintenace?
  167. How Am I supposed to place the jackstands
  168. Are the axles changed when doing an Engine Swap
  169. Time for a new engine - 1995 Del Sol Si
  170. Car heating up
  171. shocks problem
  172. GSR In EG
  173. fuse box problem?
  174. exhaust: name brand vs generic
  175. cable clutch conversion
  176. Yellow Top Optima
  177. Idle bouncing
  178. code 3 map trole have searching for ever
  179. D series throttle body which is better
  180. Jdm Ek3 Vtec Ecu
  181. dash rattle
  182. UBERDATA or Hondata s300 .... You Tell Me ???
  183. o2 sensor/high flow cat question
  184. List of Civics (help!)
  185. B20 Civic HB?
  186. OEM Foglight Installation
  187. im gonna to the dyno in less than a week!
  188. Tranny replacement
  189. Si Camber kit. Which one?
  190. Performance Wires on Stock Civic
  191. Blurred rear mirror
  192. Srr Rear Lca Hitting Shock Mount
  193. Catback Exaust Question
  194. high rpm bad for engine?
  195. sudden strong smell of gas inside car, engine stalled a couple times..
  196. confusion!!
  197. Pcv Valve
  198. 04 civic pin-out
  199. My transmission...
  200. 96 del sol check engine light
  201. ITR seats
  202. What can i do to my engine?
  203. civic eg shocks
  204. 6th gen c-pillar bar
  205. Im out of ideas (boost issues)
  206. VIN labels on a 95 civic motor and trans
  207. what else would i need??
  208. Some advice???
  209. DC sports header + o2 sensor relocation= check engine light.
  210. adjusting the door hinges
  211. Redtop
  212. Est. How much would this put out?
  213. Diff between Front susp on teg Type R and 5th gen Civic
  214. B18C1 question
  215. VTEC Engagement Problem .. PLEASE HELP ASAP
  216. double bend shifter...haha
  217. So my question wasn't good enough?
  218. manual transmission fluid change?
  219. 96 headlight fit on 00 Civic?
  220. 5 Speed Conversion Parts
  221. Power door switch 92 Si
  222. 92 Civic Si smells like gas inside.....
  223. Hid
  224. Is this clutch wear?
  225. squeaky clutch
  226. my car wont start
  227. Aiming Headlights
  228. my car is a piece of sh*@
  229. Tyre wear
  230. Over Reved Engine
  231. ***This Forum Is For Cars 1992 And Newer***
  232. Transmission Problem
  233. P0135 - Primary heated Oxygen sensor (sensor 1)
  234. Plug wire keeps popping up
  235. jerking during acceleration
  236. What do you guys think about a 1.75" drop on stock shocks?
  237. Installing rear trailing arm bushings
  238. slow cranking
  239. stupid problem...
  240. one last question
  241. engine paint
  242. Big Brake Conversion???
  243. check engine light
  244. which FPR with set-up???
  245. obd2 conversion??
  246. head work
  247. Civic Swap
  248. Door Pin Problems
  249. Has anyone installed a sunroof?
  250. b18a vs b18b
go
