View Full Version : '92+ Civic/EL & Del Sol
  1. Location of horn relay
  2. Oil Leak!!
  3. Tapping noises at warmup
  4. 2000 Civic will stall after Battery was changed
  5. Car Jerks Hard Before i GoTo Shift to 2nd
  6. BuMper EK9
  7. New clutch-still noise???
  8. hey
  9. Tapping in the engine? Dont know what the problem is?
  10. Good sway/strut bar for underbody front end??
  11. what is code P1399 ??
  12. Install Question 98 Civic LX
  13. Thumping in the front end
  14. Low Budget Enthusiast
  15. Bolt pattern???
  16. Newbie has a problem (MC2) Honda Civic Aerodeck
  17. Nos
  18. Getting ready for a motor swap.....
  19. header....
  20. Where can I find???
  21. 1998 Civic Keyless Entry Problems
  22. Stroker kit???
  23. Cams?
  24. 03 Civic EX Front Grill Replacement
  25. Swap Q - Will fit, anything special needed?
  26. 96 civic w/ 00 motor, no speed HELP!!!!
  27. shift knob fitment
  28. How much did you pay for your EG?
  29. need feedback on performance on civic v-tec
  30. park brake handle
  31. ive been pondering this.
  32. z6 swap ih hatch
  33. SRS Light??
  34. diffrence between front and back springs
  35. Remove Factory Indash CD player
  36. Which struts/shocks?
  37. has any1 heared about shocks that....
  38. 96 Honda Civic EX door panel question???
  39. Brake light fuse location?
  40. selling car soon i hope,parting out...
  41. rear seat swap
  42. 2 Quick Questions-idle problem-intake Q..
  43. Dohc Zc??? Jdm
  44. If you were given 8G's to mod your ride, what would you do?
  45. no ac
  46. stop me from drilling holes in my cf hood
  47. Work Emotion CR
  48. doubleyou-tee-eff
  49. Gmax springs
  50. Supertech?
  51. need to transport a car from califonria to alabama
  52. Lower Motor Mount Brackets on DOHC Sol, need quick help ....
  53. Whew, the damage isn't anywhere near where I thought it was.
  54. need advice on sohc del sol
  55. 92-95 civic interior questions
  56. Looking For A 93 Civic Body Kit
  57. what do you think.... 1994 civic ex 2000$
  58. Changed waterpump still whirring noise
  59. Si Question
  60. Where to find a cheap complete swap?
  61. civic dx
  62. My friend said I should use 89 instead of 87.
  63. Brakes or wheels?
  64. Finally!
  65. d15 - d16
  66. guages and turn signals not working, but hazards do?
  67. civic 1994 alarm help
  68. honda civic 1994 Alarm
  69. koni yellows
  70. engine remote start for a 95 civic..need help
  71. !!!! Over Heat !!!!
  72. 96 honda civic ex help?
  73. honda tune-up stuff???
  74. Quick Brake Swap Question
  75. Wiring problem
  76. Steering Wheel Shakes Real Bad
  77. What on earth can I do with this car?
  78. koni suspension adjstment
  79. My Potential Project
  80. I need help finding a A/F meter
  81. d16y8 to 99hx help request
  82. Do I Need A Differnt ECU?
  83. facts about swap
  84. es tuning muffler
  85. Turbonator?
  86. quick reply please
  87. How to make carbon fiber parts for your cars
  88. How to custom carbon fiber for your cars
  89. 01 El rims on 95 DX coupe
  90. conversion help 2.4 JRSC'd ep3 civic Type R
  91. P28 MT-AT How can you tell?
  92. IAC question?
  93. New clutch but now transmission leaks
  94. B18a1 92 civic
  95. 1999 Civic coolant bleed bolt
  96. looking for pics of carbon fiber fenders...on a car??
  97. 96 Civic ex possibility
  98. Please Read! Car Not Starting.
  99. Radiator Problem
  100. 2000 Civic Si - Needs new Carpet and Seat Covers
  101. tein springs or eibach springs
  102. h22 in eg
  103. Ebay suspension stuff NE1 use?
  104. Need help here
  105. Tranny
  106. Quick, cheap power
  107. 96 civic ex keyless entry
  108. FINNALY gonna get my car back!!
  109. Auto tranny to 5 speed
  110. 16Y8 intake on D16z6?
  111. H22 eg peeps i need your help
  112. Anyone know dyno tuning locations in SoCal?
  113. 5 lug conversion
  114. Whats this???
  115. 95 with a b18vtec
  116. Vx Owners
  117. sell? or keep?
  118. B18B Swap to 93 Civic
  119. Maintenance Required Indicator
  120. f20b in a civic good idea or bad
  121. car turns wont start, been sitting 5 mo
  122. Engine swap, two problems
  123. Alternator & Waterpump bolt - HELP!!! '92 civic
  124. smells stinky...
  125. jdm d15b vs d16y8
  126. Need help finding a front cover
  127. 96 civic 3dr, water leaking in making puddles!
  128. More "car won't start" problems
  129. 92 civic fuel pump electrical problems..Help Please
  130. OEM vs 6 puck clutch
  131. Urgent! need opinions on this head
  132. B18b $$?
  133. valve cover gasket
  134. Freak accidents suck soooo bad..
  135. Helllllpppp!!!!!!!!!!!!
  136. 98 Civic coupe - guidance on new HU & alarm
  137. civic EG6 Alarm
  138. wiring amp/sub
  139. whats it worth?
  140. bought a 92 SI hatch. worth the money??
  141. Greddy intercooler kit
  142. B series pistons in a D series block?
  143. Civic EK type r lip/splitter
  144. Turbo
  145. legal swap???
  146. Help !!
  147. car jerking
  148. Hood Release
  149. transmission websites?
  150. blinker light & hood
  151. how to tell if you have abs
  152. K series swap to an EK civic???
  153. Troubleshooting Accessory Plug 99 Civic
  154. disassembling 6th gen headlight
  155. disassembling 6th gen headlight
  156. Fuel Pump Problems
  157. itr exhaust?
  158. USED SKUNK2 68mm TB FOR SALE
  159. Simple Cam Question
  160. Tweeter mounts in 96 Civic EX?
  161. Ls Vtec Question??? Block Girdle??
  162. 96 civic head gasket..
  163. SeaFoam
  164. The beast...here she is.
  165. Aftermarket fog lights
  166. fastest d series tranny
  167. Apexi N1
  168. 96 Civic Ex remote Programming
  169. 99 Civic No Dash Lights
  170. door locks
  171. 92-95 civic glove box question
  172. 99-00 dash panel into a 98 EX?
  173. vtec
  174. Head gasket
  175. Bad miss fire, car ran fine and then another miss fire.
  176. 00 Civic EX rear disc conversion
  177. tanabe?
  178. Cleanest EG hatch ?
  179. EK hatches
  180. This is getting way too frustrating.
  181. Quick Exhaust System Question
  182. Street Legal?
  183. 2003 Civic Immoblizer Malfunction
  184. Suspension
  185. merry X-mas every one!!!!
  186. Good size Civic Rim
  187. 94 Civic Hood Latch
  188. Would This Throw A CEL
  189. What do u think?
  190. Questions on Engine Swap
  191. Honda Civic Engines
  192. What no. Peice is this, i'm blind!
  193. What is the best way to remove Dealership Vinyl?
  194. Headlights ?
  195. Dc2 Into Eg6
  196. Ecu ??
  197. TPS Voltage
  198. eg6 convertible
  199. type r k20 swap ?
  200. honda civic
  201. headlight/speedometer problem
  202. Nasty HP/TQ#'s
  203. just drained my MTF, now what?
  204. Backseat Help
  205. 94 EX, new or reman axles?
  206. Installing Taillights
  207. gas question
  208. champ white paint
  209. replaceing headers...
  210. 99 Civic Hood Problem
  211. 02 Sensor Problem
  212. I want brighter headlights for my Civic...
  213. Japan Motor Import
  214. About the 02 sensor in a 96 honda civic
  215. Good Deal on CF Hoods!!! Come and check it out!
  216. JDM Shops in North Carolina
  217. YAY for more efficient set up!!
  218. Jiggle Pin
  219. Key won't come out! HELP!
  220. Anybody replace an oil pan?
  221. 92 civic coilovers how t0 video????
  222. ...The ongoing questions...
  223. 2.5?
  224. Please Help!...96 Civic Ex Problem
  225. S20 5th gear Over drive? Been done?
  226. z6 Head help
  227. does anyone have the DIY for short shifter install?
  228. help...performance parts shops address
  229. help...a
  230. Tachometer slow?
  231. New Header
  232. Things are finnaly looking up
  233. came home to find my new suspension waiting for me..
  234. HELP NEEDED - honda civic 2002 wire colors
  235. Totaled car?
  236. How Do You Tell A 92 Distributor From A 91 Distributor For Civics
  237. gtr spoiler
  238. Inhibitor switch
  239. 92-95 civic hatch vs. sedan whats interchangeable?
  240. 92 Civic Dx Car Dosnt want to Start or stay running.
  241. ThermoStat Stuck Open?
  242. Sleeve's
  243. ac problems
  244. 96 civic gone mad
  245. Question about emissions and my car.
  246. did a swap and car won't start
  247. Drivers side front corner hit in wreck - hood release fubar
  248. Speedometer doesn't Work
  249. Obd 1 Ecu
  250. Oil preasure and Volt meter gauges
go
Search Engine Friendly URLs by vBSEO 3.5.2
