- differential noise?
- 95-00 Civic Hatch
- Check This Turbo List...i Need Feedback...
- Hi Everybody !
- civic rims???
- Question About A Turbo Xs Kit????
- can i swap a vetec head for my SOHC 1.5 civic head
- b16 from 00 si into 94 cx
- Hey help I have D15B ?s
- Accord Turbo Problem
- Replacement center muffler?
- Tranny Fluid
- Tranny question????
- more clutch questions..
- newbie needs help with usdm d16 to jdm d15 swap
- d15b vtec help
- 2000 Si Build-Up Questions (newbie questions.. beware)
- civic 1994 cv joint ripped
- Door Wont Open
- 96 keyless problem
- 2001 Honda Civic Climate control problem
- Questions for a D16Y8 civic....
- talk me into buying a b16
- Razo Sport Pedals
- 04 civic radio help
- Throttle body problems?
- Need Help ASAP!
- some advice please?
- Headers Help
- Headlight switch help please....
- EDU Wiring
- I Need Help With my 92 Civic Ls
- S2000 Cluster Pinout
- Distributo help pleeze
- 98 Civic ex brake problems....
- Stealth security: fuel pump kill switch (6th gen)
- Please Help!!!
- clutch questions
- Blinking SRS and CEL
- i think its the battery...need help!
- I need a quite yet performance changing exhaust
- tranny swap
- civic resonator
- Need engine suggestions...
- Not again....DIE THIEVES
- Parts for B-18C1 Swap into a 96-98 hatch???
- anyone got a diy on tranny swap?
- Way too much
- my friends an idiot
- firing order
- brake upgrade fit in 97 gsr rims?
- I need your spare SOHC parts!
- Wind sheild wipers dont work
- Spark plug JDM B16
- Went to the Dyno today
- Are these rotors any good?
- strut bar question...
- rotors needs changing??
- 93' civic battery light.
- D16z6 swap on Friday need HAN advice
- 6th gen SiR I swap
- electrical issues
- 5th gen to 6th gen parts
- lowering civic
- What engine?
- D Series motor mounts for B series SWAP
- D series Hybrid Transmissions. What I did this Friday afternoon
- 4dr LS SWAP NEED HELP Shift Linkage
- Gram Lights wheels
- Civic LS 5th Gear??
- Tranny oil change.. DIY Possible?
- for people in San Jose, CA - need some hookup
- Manifold
- 6th Gen Civic Tail Lights
- Anyone Know what Spolier this is?
- 5 Speed Conversion Parts
- Civic LSI power cuts out
- short axle assembly?
- o2 Sensor
- is trans-X really good for 1994 honda Civic auto transmissons
- TPS 92-95 Civic Broken... How do you replace?
- speedometer not working
- smoke from exhaust
- Help replacing instrument panel
- what is Trans-X and will it help my 1994 Civic LX
- 1st Car!!! Can i please Get opinions before buying???
- 91 Civic Si Motor ValveCover Bolts.
- uh oh.. *pic*
- Help me out HAN
- skunk2 coilover popping noise
- '92 Civic Shell?
- heat shield?
- 01 Civic Daytime Running Lights Not Working
- Important info that I need to know about the B20B/Z
- b18 problems
- Time to work!!
- d series transmission, gearset swap. Help getting gearset back in
- will 96-00 guages fit 92-00?
- Del Sol JDM
- I know this is a security question, but I want to ask Civic guys
- High beams problem
- Steering went out!!!!
- anyone got a mini-me swap how to link?
- Exhaust fitment question.. HELP!
- fuel pump relay
- Rev Limiter Question
- Im new a few engine questions
- Quick Question
- is this what i need?
- Oil Filters...
- Foldable Side Mirrors for 2002 Civic
- s2000 instrument cluster in 98 ek
- change drum brakes
- how to replace front and rear bumpers on a Civic 00
- civic back door problem
- Performance Chips
- Help 2000 Si
- keyless entry programming WITHOUT factory radio
- More HP
- iac problems
- clutch or fuel pump?
- 96-00 Civic Hood lock installation.
- Who of you have done rod/pistion installs at your homes/on your own?
- skunk2 coilover install problem
- b16 alternator question
- $3000 power-up budget
- wheels
- cant smog ??
- Ackerman angle and lowering springs and 6th gen
- Suspension and Bracing
- civic designations
- suspension question, eg.
- EK4 shocks on EG civic
- Overheat Problem!!!!
- For a 1/8, turbo or supercharger @7PSI?
- GSR turbo, NA, or Supercharge?
- MTX Q's
- d15b7 compression check.
- 5th gen hb wing/spoiler just for looks?
- Question about this setup??? civic turbo
- need help on torque on main bearing cap on a d16-z6
- 94 civic check engine light
- opinions/facts
- proportioning valves for brake swaps
- Newbie but with hopes!!!
- Coilovers?
- Fog Light Question Need Help!!!
- My car keeps overheating HELP!!!!
- ITR master cylinder question
- starting problems
- new addition to the civic family
- Suspension
- Front Lip ?
- Where can I find a b16a3 (Important)
- best year EK
- spoon sw388 wheels question
- wiper lever fix
- ebay exedy oem clutch replacement kits
- 5th gen Top Gear testdrive...hatchie and 4dr vti..repost?
- 92 Si power window diagram Help
- ABS Light
- 92 Headgasket parts
- Where to buy?
- click click click....
- Exhaust...
- civic P06 chip
- Online source for Purolator PL14459 filters
- steering wheel not straight...
- don't make me go domestic
- Piston+cylinder wall=Bad.
- D16z6 to D16y8 swap
- Civic or Integra?
- Noobie and my car
- LS Vtec
- Can someone help me
- ZC exhaust manifold on a d16z6??
- ALL EJ/EK hatch Pros, HELP ME! (96 civic hatch)
- parts for a d15
- how do you identify if an OBDII ECU is manual
- Confused on setting the VAFC2
- 92 Si passenger airbag install
- ATTN: D Series 1.6L guys
- relocating the hood release cable?
- Will 2001 wheels fit 2000?
- Battery kill switch ???
- 2 birds with one stone...
- 92 SI Saga Continues
- 93' B18a1 into 93' Civic EX - Please help! Urgant!
- Wanting to do b18b swap in 5th Gen Civic
- NE Dynos in SoCal that include A/F graphs?
- how should all this cost
- changing the filter on my cold air intake
- 2000 Honda Civic EX 4dr 1.6L VTECH - Replacement?
- My engine lights blinkin'!
- real hard time getting tranny off
- Resourse Links not working
- Auto 00' civic Tranny dying??
- fuel filter
- 97 civic
- down pipe
- Modifacation Question
- Need som help choosing new colour.
- Cleaning A/C Filter
- Wheel Spin in Neutral? normal?
- where to buy engine in lax area
- Will it fit
- Best Civic $4,000 can buy???
- Any good mechanics?
- Turbo Problem Need Help
- Please help me! I'm selling my totalled '95 civic and I don't want to get ripped off.
- Civic DX gone bad!!!
- questions on lowering springs and koni yellows
- o2 sensors
- 6th gen civic front disc brake rotor removal
- exhaust problem?
- Brake Q's
- Buddy Needs to get EG Smogged in SoCal South Bay
- Dirty manual clutch
- 98 Ex Feels slower now
- LS VTEC...ACL Bearings?
- headlight harness??
- Need an OE equivalent brake pad
- My babies got a couple issues
- Power Steering vs manual steering
- APC seats! What rails?
- fog light help
- 95 Cruise control
- installed the omin power coils on sat!
- Removing headlights (acura 1.6EL)
- Stay Street Legal
- Check engine light codes on a 97 civic ex
- crank bolt woes
- Location of horn relay
- Oil Leak!!
- Tapping noises at warmup
- 2000 Civic will stall after Battery was changed
- Car Jerks Hard Before i GoTo Shift to 2nd
- BuMper EK9
- New clutch-still noise???
- hey
- Tapping in the engine? Dont know what the problem is?
- Good sway/strut bar for underbody front end??
- what is code P1399 ??
- Install Question 98 Civic LX
- Thumping in the front end
- Low Budget Enthusiast
- Bolt pattern???
