View Full Version : '92+ Civic/EL & Del Sol
  1. OBD1 to OBD2
  2. MOMO steering wheel question
  3. 92 civic dash help. cant get it out of car
  4. throw out bearing
  5. 99' si help!!!!!!!
  6. How serious is the problem
  7. obx exhaust?
  8. CEL code retrieve
  9. Help with 01 fuse/relay box??
  10. Tornado Fuel Saver As Seen on TV....
  11. oil filter
  12. whats wrong?
  13. How do you remove sunroof
  14. 94-01 integra brakes for my 92-95 civic hatch
  15. paint job
  16. 310cc injectors be ok???
  17. will this muffler fit??
  18. yeah yeah search..I did
  19. CV joint prblm
  20. Not to warp head when removing d16z6
  21. i need help in replacing my axle?
  22. a body question... 92-25 civic
  23. b20 water pump and ls water pump
  24. aftermarket steering wheel
  25. OBD2 to OBD1 what about my 2nd o2 sensor?
  26. performance chip
  27. ex engine swap
  28. StEERING COLUMN
  29. flip flop trunk
  30. Stripped & Broken exhuast bolts. Easy to fix?
  31. Cheapest place to buy Real HONDA PARTS (OEM) online??
  32. Possible tranny problems(automatic)
  33. 2 door coupe, vs. 3 door hatch (92-95). Are the door seals the same?
  34. Real Honda Parts Or Oem Stuff?
  35. Problem
  36. Knock Sensor?
  37. 10mpg in a cx?
  38. 98 civic hatchback door lock jammed
  39. uberdata? where can i get it
  40. cheap intakes
  41. Mufflers
  42. Thing above Thermostat?
  43. Swapped Engine Intakes
  44. kosei rims looking for cheap tires
  45. bought a new radiator
  46. installing a new rear fender
  47. chiping a p28 ecu?
  48. quick question!! 94 dome light in a 92 hatch???
  49. Turbo B16
  50. steering wheels
  51. no catalytic converter
  52. Locking differentials
  53. Bolt problem
  54. head gasket blown in stock civic
  55. Transmission
  56. PCV valve problem = oil smell in cabin for Civic 99si
  57. Carfax Please.............
  58. Gear box swap on honda civic
  59. is this cheaper?
  60. need help with these b16 issues
  61. Turbo Kits???
  62. 92 civic dash removal
  63. was the best cat back to use?????
  64. D16z6 v.s. B18b
  65. D16- wats a good mod besides turbo?
  66. h22 into eg swat guide?
  67. VAFC question
  68. my dyno video
  69. B16 Swap
  70. 97 Civic: Feels like I let off the gas (but I didn't) Ideas?
  71. Auto to Manual
  72. driver side cv joint
  73. Ignition Tune up
  74. is my car worth doing engine swap?
  75. Power window regulators 2dr 4dr same?
  76. newbie
  77. 92-95 civic factoy service manual here soon!!!
  78. Please Help!!! Vtec Bolt On?
  79. turbo head gasket
  80. clutch question...
  81. civic super charger
  82. Injectors
  83. interior question
  84. underdrive pulley
  85. 87 honda civic
  86. Will a 02' si shift knob fit my............
  87. Anyone seen this?
  88. steering help
  89. anyone want to take a stab at this?
  90. lowering springs
  91. need link
  92. Shifter overhaul
  93. Suspension help
  94. New civic owner Got some Questions?????
  95. problem with tranny/clutch
  96. civic 92-95 rear break conversion
  97. My new mods
  98. Damn Hard to deside.
  99. b16a2 into 92 civic cv shaft problems
  100. Have a lil bit of money Thinking bout hookin up my 92 civic
  101. My VAFC Settings- tell me what u think
  102. Cruise control for `94 Civic CX?!
  103. Need help finding the fuel filter in a 1994 Honda Civic.. Can anyone help?
  104. civic 92-95 ticking sounds
  105. Honda Civic 92-96, Stainless Steel Sebring backbox
  106. Stoopid Bolt stuck (searched already)
  107. Hondata/Neptune/???
  108. boost
  109. soon to be turbo
  110. Door Adjustment
  111. GSR Throttle Body Swap attempt...
  112. Best Pistons
  113. Coil over problem
  114. Cold Air Intake, Honda Civic EX, 2001
  115. Front Strut Bar, Honda Civic EX 2001
  116. 96 ex -00si conversion????? helpp
  117. Driving w/ E-brake to Clean Brakes
  118. Del Sol trunk struts...
  119. If I sold my hatch???
  120. d16z6 replacements ?
  121. Dropping in a b-series engine?
  122. this has prolly been asked a hundred times but...
  123. Will this header elliminate the cat?
  124. 2003 civic check engine
  125. 95 Trim/splash guards
  126. Dumb but simple Question about my 92 civic
  127. Strange beeping, 1999 Civic EX
  128. 98 civic
  129. Automatic to Manual Conversion
  130. Coil Overs
  131. Turbo Fuel Management
  132. vtec not working!!
  133. Abs
  134. One more thing that i searched for but didnt see!
  135. Pretty sure noone else cares!
  136. just a name?
  137. Having trouble
  138. My 500$$$ hatch
  139. suspension...my turn
  140. Help!!
  141. 2000 civic door speakers wiring help
  142. 94 civic airbag removal help
  143. Clutch/tranny problems..
  144. winter rims worth it?
  145. Problem: My headlights blink
  146. 99 civic D16y7
  147. D16 SOHC head swap for D16 SOHC VTEC head
  148. Speaking of lug nuts
  149. Are the LS and GSR Throttle Body Same?
  150. Eibach Prokit
  151. Voltage Drop Problems
  152. Aem pulley
  153. Turbo For A 95 Civic Ex
  154. D2 Coilovers
  155. P28 Help, LAST STRETCH FOR TEH BOOST!!!
  156. Tein Springs
  157. Switch for OEM fogs
  158. acura el help
  159. Air Intake Question
  160. 03 civic dx strut tower
  161. 2006 Civic Hybrid at $300 below MSRP a good deal?
  162. Serious problems with 06 Civic
  163. Timing belt and hoses 96 Civic
  164. quick lugnut question...
  165. lube my chasis... tee hee
  166. Speedo
  167. ecu swapping
  168. EG?will it fit?
  169. will it fit?
  170. very dumb question but anyway
  171. 1998 Civic EX Winshiled wipers
  172. quick question
  173. 96 Civic.....Missing Under a Load
  174. fishtailing problem,,
  175. Knocking sound from front end
  176. leaking antifreeze!!!!!!!!!
  177. cold air intake bad gas milege
  178. H22 2.2l Dohc Vtec 97 Jdm Prelude Type-s 220 Hp
  179. eg progress
  180. Help Installing A Short Ram Intake
  181. thinking about selling my ek for a lude
  182. B18C GSR the right engine?
  183. i think i just wet my self.....
  184. Swapping a D15B8 for a D15B7.
  185. Higher power alternator - do I need to upgrade cables?
  186. 1998 Civic bumper and headlight replacement
  187. Help with 01 Civic front struts
  188. b18b Intake Manifold completed! (pix)
  189. ek9 stock engine
  190. solenoid lifters
  191. Door Speaker troubles?
  192. will this return to normal...???
  193. Controller for VTEC?
  194. Installing Wiring for amplifier.
  195. 99' si converter
  196. cam sprocket
  197. 2000 Civic Check Engine Help!!
  198. cant decide
  199. Dont buy a hood from complete in arlington
  200. tune up question
  201. head swap
  202. 99 si vs. gsr
  203. Leaking Distributor
  204. Loose wires
  205. Need info for D17A2
  206. Tires
  207. Painting Aftermarket Bumper
  208. b20vtec
  209. SWAP for a 97 civic lx
  210. help with cams
  211. Civic door and window
  212. Help - I think my dealer is full of it
  213. What in the hell?
  214. turbo question.
  215. high erratic revs 92 civic lx with d16y8
  216. Ebay manifold...will it fit?
  217. Garret t3
  218. Rear Disks for 92-00 Civics
  219. Diff. b/w OBD1 & OBD2 for B18C1 95/96
  220. Special trick to turning ignition key?
  221. changing drums to disc
  222. honda civic lowered 40m on 17's
  223. sidemarker harness?
  224. its colllddddd
  225. 92 civic vx w b18 02 sensor question
  226. B16a2 tech help
  227. Replacing stock bulbs in dash
  228. i need to know everything bout this ecu
  229. Loud as Hell noise
  230. brake problems changing it
  231. install Type-r rear lip
  232. honda swap state ref
  233. Carbon Fiber Panels Question
  234. LS Vtec swap
  235. Tranny swap- '89 CRX to '97 Civic LX?
  236. someone please help me...car overheating problems...
  237. Need Help Fast!
  238. 93 DX LS Swap
  239. alternator belt on a 92 civic
  240. mount question
  241. mount question
  242. shocks and springs
  243. B18C turbo???
  244. Civic B18c NY swap shop
  245. ek3 to d15b...having problems
  246. How would I know???????
  247. vtec or not
  248. headlight signal covers
  249. Gsr Cams In A B16 Turbo
  250. Best Handeling setup???
go
