View Full Version : '92+ Civic/EL & Del Sol
  1. Main relay car not starting
  2. Short Shifter Information
  3. b18b1 into a 95 civic 2 dr
  4. B18C Wiring Q.
  5. Help
  6. Help
  7. 92-95 civic coupe questions
  8. Open/close loop related question
  9. What pistons in d15b7???
  10. Questions about: Drum breaks
  11. 92 eg JDM b16a !!
  12. Is E-motor turbo kit worth buying?
  13. vss wiring diag.?
  14. My car Revs up and down but doesnt die???
  15. impact wrench and ft/lb needed on suspension
  16. bolt name please???
  17. block filling
  18. need help broke something!!!!!!!
  19. 15" Wheels/Slicks on Wilwood brakes.
  20. great tech info
  21. ls rods in d16y8
  22. I can't get my injectors back in my fuel rail.
  23. Front lip
  24. Fuel guage issue
  25. boost gauge question
  26. too heavy man
  27. stupid question.
  28. new toy
  29. Is this a good deal?
  30. jdm del sol bumper moldings?
  31. What oil pressure gauge?
  32. Fuel gauge problems
  33. Exaust and engine proformance.
  34. Car dont Start and coolent missing
  35. running rich
  36. B18c Swap
  37. How much is reasonable to have a head gasket changed on a '95 Civic?
  38. speedometer problem please help
  39. how fast
  40. which parts
  41. h22 but with wut springs?
  42. Shaking Problems
  43. EDELBROCK TURBO KIT ON a 00' civic d16y8
  44. tranny!!
  45. OEM Si springs on DX
  46. honda civic si 99 engine oil
  47. '05 Si engine into '00 Si
  48. d16y8 crankshaft problems
  49. !!B18C or other... Swap in 1999 EX Coupe!!
  50. Need Piston Help
  51. where to get CTR headlights
  52. !! leaking tranny? !!
  53. Iyo?
  54. machine help.. what to do
  55. crankshaft 411
  56. These Rims look good?
  57. Installing Mesh Grill '98 Civic EX
  58. i need help bad
  59. rims
  60. Whistling and lower fuel economy than usual
  61. window shades?
  62. 92 Right Hand Civic Trans ?
  63. wiring harness
  64. .:: Question ::.
  65. springs on 99 si
  66. Respond Fast, will these rims fit my car,found new set
  67. Suggest/Recommend Site to Sell My Babie'94DOHC/VTEC
  68. Da Civic left me STRANDED!
  69. squeak while turning hard left
  70. Will 99-00 hatch taillights fit 96-98 hatch?
  71. Greddy turbo kit for 2000 civic ex...
  72. Help Finding Itr
  73. 95 civic headlight problems
  74. Check engine light readings
  75. NGK Iridium Spark Plugs
  76. Buddy club p1 rims
  77. will these rims fit my civic?
  78. '00 Civic Si Stolen!
  79. need to replace cv boot
  80. D16Z & D16V head difference?
  81. Clutch installation help
  82. 96 civic b16a install?
  83. H22 del Sol
  84. Need a lInk
  85. Compression Ratings
  86. h22 and a\c
  87. Manual window on drivers side problem...
  88. Modifying (taking apart) 99-00 Si Headlights
  89. Are D and B Series ECT sensors the same?
  90. no spark on '95 civic from distributor
  91. creak in rear
  92. need help w/disc conversion
  93. need help fast
  94. jdm d15 ? need help fast
  95. civic drinking water and over flowing
  96. Small Ringing Noise when Accelerating
  97. dizzy
  98. Power question!!!!!
  99. hope this is the right place
  100. i need a front bumper for 95 honda civic 4 dr
  101. d16z6 distributor same as b16
  102. Keyless Entry Antenna
  103. over heating civic
  104. what can you do with a d16
  105. Please help!!! problems!!!!!!!!!!
  106. Rear Bracket During Auto to Manual
  107. At It Again!!
  108. 97 hx 5 speed conversion?
  109. Help with AC?
  110. KYB GR-2 or AGX
  111. wich ones.......?
  112. D15z
  113. Plz help on a 95 Civic
  114. Radiator Fan
  115. realign front end of 96 civic hb
  116. good cheap clutch set
  117. manual window messing up
  118. b16a in 1996 civic
  119. 00 civic ex turbo kit....need help
  120. del Sol Emissions
  121. Anyway to By-Pass Knock Sensor.. Story inside
  122. 2006 Civic Hybrid, how do I program the keyless entry?
  123. b16a in 1996 civic
  124. steering noise
  125. Door/Lock problem
  126. wanting to add hondata but ecu is not on website but can it still work(p13)
  127. Loose Clutch Pedal
  128. What kind of Security System do you guys have?
  129. integra swap
  130. math
  131. I have a low-HP 92 Civic DX. What should I do to it?
  132. Help.cluncking sound coming near passenger side wheel.
  133. Intake manifold swap??
  134. Intake Spot for Boosted Application Question
  135. rear brake light 94 civix DX
  136. ITR powered 99 coupe anyone?? have a look
  137. hello new here
  138. Intake pipe air mass sensor and electrics
  139. removing stock shift knob....
  140. Door panel removal 2006 civic sedan
  141. Forced ITB and Setup Questions
  142. I'm trying out the G-tech PRO RR
  143. Check out this Honda Civic powered British built SUPERCAR
  144. Iacv
  145. car wont pass emissions
  146. k20a2 into a 96 ex coupe? is it possible?
  147. k20a2 into a 96 ex coupe? is it possible?
  148. Honda Civic 96-2000:Rear disc conversion
  149. B16A2 into 99 Civic EX (d16y8)
  150. muffler question
  151. Whats wrong with the H23
  152. D16y8 Mounting Kit, Where???
  153. Antenna doesn't go up.
  154. Seat Brackets
  155. vibration shudder problem help me please!!
  156. 99-00 B16a2 will a jdm obd1 p30 work fine?
  157. QUestion
  158. rubbing
  159. references?
  160. ctr pistons in a jdm b16a sir2
  161. 2000 front end conversion on a del sol
  162. Brake Light Switch?
  163. tire pressure
  164. problem installing spoiler.
  165. suspension shop in MI
  166. Noob!
  167. CLUtch problem............
  168. 96-00 Hatch
  169. external coil & MSD 6AL box
  170. Del Sol
  171. Civic Painting Questions
  172. Oil Pan cleaning What to use?
  173. Front sway bar install 03 civic dx
  174. speedo and mileage quit working
  175. UK Jrsc CTR.
  176. Question??
  177. Speaker Question
  178. hesitation
  179. cold air w/pics!
  180. engine swap
  181. GOTO HONDA.COM and see 2007 CIVIC SI Sedan
  182. 92 civic Fuel Injector Question
  183. A/C Blows Smoke
  184. del Sol pricing
  185. Corners for 92-95 Civic . . . NEED OPINIONS! n PICZ!
  186. what are the best headers?
  187. Short Shifter
  188. Brakes droping?
  189. New Pics! After Swap. Sleeper
  190. First Civic (95 LX) few questions/problems.
  191. re B and D series oil pressure sending unit sensors the same?
  192. older honda
  193. One Quick Question
  194. 2000 Accord Radio (stock) fit a 92 Civic?
  195. AC troubles with clutch
  196. weird question
  197. OBD II reader question....
  198. Which stock engine can I swap into 91 Civic HB 4 speed?
  199. Whats Best price or Invoice price for 2006 Honda Civic Si/ or EX Automatic
  200. Braking issue
  201. turbo d16y7 spark plug pics, white plugs but rich??
  202. Need help on 1st DIY
  203. Will a Whole Rear Disc setup from a '90 teg fit on my 93 Civic hatch
  204. axles
  205. Floor Finishes??? Want A Clean Look
  206. exhaust tone is indicative of performance?
  207. ABS on a 98 civic ex?????
  208. rpm/tac gauge help.
  209. Water in the floor - found problem
  210. swaping steering
  211. Rear Disc Caliper Issues
  212. Squeak
  213. P05 ecu
  214. 00 Civic SI Air Conditioning System...
  215. Is my motor blown?!?!??!
  216. Reverse lights
  217. auto to manual
  218. Navigation
  219. freon in a 99 dx hatch
  220. Headlight help
  221. Headlight help
  222. primary O2, before or after cat?
  223. Rebuilding the engine to handle a turbo...
  224. help newbie del sol info please
  225. Tires don't spin
  226. Engine Harness question May be stupid tho!
  227. Will this work?
  228. Chrome header
  229. Canadian 1997 Civic EX HP?
  230. will these headers fit my car
  231. Can I even fit a 3''?
  232. ATL Gas is $3.00 /Gal and rising!
  233. turbo suggestions
  234. Best engine for 05 civic
  235. HELP: car would crank but wont fire up?
  236. mini me swap c/r /turbo question
  237. Dc Sports 4-2-1 Headers
  238. Internals
  239. radiator question
  240. JDM VX Engine - Transmission match
  241. how do you install this? have pic
  242. Tell me its only a blown head gasket?
  243. different tire widths on front / rear?
  244. Difference between these ecu's?
  245. my clutch went out
  246. a/c problems
  247. Need Help With D15y7 Engine
  248. Brakes!
  249. removing seats from a 98 civic dx to clean carpet
  250. Projector Headlights
go
