- Found a 92 civic vx w/ 130k miles
- 96 turbo HB vs 00 Si??
- "H brace bar: useful?
- Brakes making a rubbing noise
- which color
- spring problem
- 98 Honda CRV A/C Issue
- brakes problem
- Weird noise from tranny
- wiring jdm navi. system
- I ordered a Megan Header. Thermo wrap it?
- This is why you build a motor
- 2003 civic rear drivers side window wont go down...
- my eg hatch was just stolen
- HELP!!! Alternator and Starter
- del sol foglight
- More Power.
- ONLY '98 Civic EX owners please look inside - need fuse box help
- 99-00 retrofit onto a 98 civic hatchback????
- Black nipple thing under oil filter on d series
- Dizzy Timing Question!
- how do u make a 94 civic unstealable
- Buying 2004 LX w/21,000 miles - extended warranty???
- Exhaust application
- h22 vs. k20a
- got a question about my headers?
- I have a huge question for you body guys?
- Turbo update#2
- 1997 civic sedan roof rack for bike?
- put a new engine in and problems. Please help
- Car just shut off on highway - need help plz
- difference between floor carpet on ek 2/3/4dr?
- car is smoking
- Ball Joint Problems
- civic trim????
- Ex Gauge Cluster
- disk brakes on back 94 hatch
- what to do with my interior
- coolant lines? vacume lines?
- just put teg leathers in my civic but the rails won't line up in one spot
- 96 civic dx engine bay
- how to?
- Hatchback???
- HELP!!! My B16 Is Running LEAN!!!
- Exhaust suggestions
- 1994 Civic EX headlight help (no info found on it)
- Brake Question
- Taking Out Console
- My 10secs hatcH..
- need help asap
- Pics from the setup while it lasted.
- Skunk 2 Manifold...
- Engine Seems Limited @ 4000rpm
- engine issues
- P/W problem...
- i suck at life. (I think I bent a valve)
- Shift Linkage Mount
- 95 civic HELP!
- 1992 civic LX in need of help
- power window cable messed up
- new to the site..........
- A/C Clutch never kicks in
- a/c woes
- gsr exhast manifold
- Good news and bad news
- 2000 Civic EX Sluggish Accel.. Grinding noise when idle/accel
- Wat shuld i get for my civic?
- A few questions
- what can i do about performance
- drive shaft help
- front left suspension
- 04 Civic Ex Swap...Help Please
- Blew the turbo up in about two hours.
- rear disc ebrake line question
- Wanting to change my headlight bulbs
- skunk 2 intake manifold problem for 92 civic ex
- D16z6 timing when head milled
- Car died, no turnover & clicking from fusebox
- O2 Sensor Not Reading?
- Rear Brake Spring Kit for Civic 2000 4dr. EX
- 98 Civic LX speeeeed mods?
- 93 hatch cluster prob
- Newly Aquired 97 EX
- 91 Civic makes a whistle sound when accelerating
- Putting A Tranny On A Auto Civic....
- interchagable parts for 03 civic
- uh-oh im new and I have a question.
- Need help with my clutch
- Checking compression
- Starting a swap
- Big Suspension Problem
- This Civic is the endearment car?
- Civic EX 2006
- Queer feeling on 01 Civic LX's brake
- A/C belt removal?
- Major Idle Problem 1000-2000 rpm rev
- Another ?/
- Have a question about a motor
- Engine Swap
- MoMobile is back with a Civic
- Stupid question
- Engine Rebuild
- Grinding into 3rd?
- h22 swap
- Torque specs
- oxygen sensor
- h22 jdm civic
- Caliper Rubbing Alloy Wheel
- Worth it for a 97 ex?
- acura honda conversion
- best B18
- Debating a TT setup....
- Enough Games! Time for some traction! StoryTime w/pix!
- Off the line hesistation
- check engine light
- 99 Civic Si Lip fit a 96 Civic Coupe
- rusting out hatch - taking it apart/putting it back together
- will exhaust/cat mate up to header?
- intake manifold fastening nuts
- imput shaft bearing
- Suggestions
- Help Replacing Axle Shafts / CV
- Newbie needs....y'know,help...
- Got a question
- Speedometer not working???
- Replacing rear trailing arm bushings - doable?
- crome?
- Where To Get Plastic Fasteners For Under The Car?
- One gear
- 99 Civic Ex Gauge Cluster in 98 Civic Dx
- [del sol] got a GReddy turbo kit, but a intercooler kit?
- DC Header
- Strut choices?
- vtec problems typer swap in ej 4 dr
- JDM ecu, UDSM harness
- how much should i sell my civic for?
- Doesnt look like much
- Can i use a DX header on an EX?
- 2000 integra&98 civic hatchback conversions
- How to firm up sloppy shifter ?
- stalling
- EDFC problem
- obx camber kit
- Cold Air Intake Problem
- teg seats in a del sol?!?!?!?
- shift linkage
- Fresh swap wont start!!!!!!
- tranny question
- Code 45
- Fuses blow like crazy
- coilover vs. spring/adj. strut
- Integra Leathers => In a 96 Civic Coupe
- Welding Options
- Upgrading Rear LCA. OPINIONS!
- New< Help Should I Buy???
- Teg into Si
- Anyone ever buy a distributor from Distributor King on ebay?, cheap prices!
- need shopping list
- Tachometer
- Problem with brakes...
- Bouncing, High Idle
- Picked up my 1993 Civic Si last week.
- 1000g sandpaper????
- Front Bumper Reassembly
- Proper Jacking and Supporting Technique
- EK timing???
- Is there a knock sensor on P28 D16z6?
- BELT REPLACEMENT on 99 Civic HX sohc
- built for boost
- Here i was thinking ive bought everything....
- y8 mani and throttle body
- replacing o2 sensor
- Whats Brighter???????
- Neon Or Leds??????
- Now I believe the time limit on oil change
- Which ecu
- lights dont work
- wiring hearnes for civic si 99
- skimmed/milled d16z6 0.88mm
- PRICE CHECK ON A 05 CIVIC SI HatchBACK 20K miles
- jdm type r motor
- farewell guys...
- New to the Honda world. Just picked up an '06 Civic
- clutch set up
- When is it time for new spark plug wires?
- Car not Starting After it Runs Fuel Problem
- new Car!!
- Suspension choices
- need zc help
- HID's
- sportcompactonly.com??????
- -99 ex w/ 95 LS swap, electrical problems
- problems with the car.. Can anyone help me?, it takes a while to start...
- Can an optima yellowtop fit in my civic LX SE 99'?
- d16z6 cam, flywheel, cam gear
- del sol targe top
- jdm
- boosted 00 si ????
- Getting a lightened Flywheel. Which One?
- ball joint
- how is this hid kit?
- 96 wont start
- engine light
- ? on 99 si
- Shift Linkage Not Right?
- Damnit! Damnit! Damnit!
- New Club "TEAM LOYALTY" under construction!!!
- i need help???
- i need help???
- Best: b16b or b18c??
- Best?? b16b or b18c?
- Smoke coming from back of engine.
- 3 stage vtec
- Im
- stage 1.5 of boost install
- turbo d16y8
- Another Freebie
- H22 or H23 swap??
- obd1 to obd2
- One of my check lights came on..
- 98 DX: Installed gauge cluster with tach, but tach doesn't work
- Auto To 5spd swap
- Del Sol Prices
- Its finnaly here!!
- throttle issue
- Automatic Transmission rattle
- engine question
- I need help fast :(
- Engine not starting.
- would a 01-05 d17 EX head do a mini on a 94 cx?
- Oh no... broken wheel mounting stud.
- help with window handle
- what kind of knock is this?
- I need a picture.
- did a-spec-racing go out of business?
- clutch issues
- Eibach Sportline Springs
- New to the place looking to mod my civic...
- My latest del sol mod (vid)
- Seized O2 Sensor.
- civic back glass install
- gullwing kits?
- Need Help Fast!!!
- auto p28 vs 5spd p28
- Stage one of boost install
- overall
- altezza grill for 01-03 civic question
- reply
- h23 vtech
- HELP!!! Hole in 92 Civic!
