View Full Version : '92+ Civic/EL & Del Sol
  1. Rack and Pinion Squeaks
  2. s2000 seats
  3. which camber kit to choose?
  4. Engine over-revving incident...
  5. Oil around the tranny v. eeek?!?
  6. adjusting clutch 95 civic
  7. My next mod......what should it be?
  8. 04 civic e-brake
  9. Car died during short drive and will not start up!
  10. DIY Shift Light
  11. N/A or Turbo? help?
  12. best oil for a b16a1/2
  13. whats the faster car that honda make
  14. What did I pull out of my tranny ?
  15. civic integra an delsol sideskirts
  16. urgent help needed...washed engine bay
  17. del sol to integra dash
  18. Back in Business
  19. 14x6 38 offset
  20. bore stroke
  21. V-tec question
  22. Is the 5th Gen Ex gearing same as 5th Gen Si?
  23. Which bus feeds the sun roof circuit?
  24. obd1 to obd2 harness
  25. stock gsr engine
  26. what cam for sohc turbo
  27. on a budget...need opinion on shocks/struts
  28. trouble with engine code..
  29. head stud issue....
  30. Nitrous Laws
  31. civic a/c problem
  32. D-series Dizzy question
  33. time for new tires!
  34. sunroof wont shut
  35. Clock won't hold time
  36. wiring diagram-parking lights on an EG
  37. factory car alarm gone haywire
  38. Seat options for EG civic
  39. Bodykit Or Not!!!
  40. Brake upgrades
  41. It Lives!!!
  42. civic power window not rolling up all the way
  43. civic ex still 127 hp after 10 yrs?
  44. Keys Gettin Stuck in Ignition
  45. whats wrong?!
  46. Alternator or battery???
  47. What do you guys think about this car??
  48. electrical problem-interior-93 Si
  49. Stupid Distributor
  50. keeping tack of miles on a swapped engine
  51. Help me fix this so I can boost my Civic!
  52. ITB's Pro's/Con's
  53. any valve adjustment diy?
  54. car parts
  55. Knocking sound when turning?
  56. need help asap...starting issues.
  57. Intake "hotness"
  58. why wont my shit start????
  59. One Wire O2 Sensor??
  60. Civic rear main oil seal
  61. who has a oem front bumper with a lip?
  62. Sunroof motor problem
  63. Catalytic Converter Code for CEL??
  64. help
  65. vtec sound?
  66. What color!?
  67. missfire
  68. Too much play in reman axles?
  69. feedback on build
  70. Good deal?
  71. cam gear question..
  72. coming back to honda with a new toy
  73. It all started so innocently
  74. RSX seats bolt into EG civic?
  75. 3rd gear lag
  76. Manual Conversion
  77. CEL code
  78. 4 lug rotors that dont rust?
  79. Turbowoes.v4
  80. 92-95 Civic, plastic gas tank?
  81. Which rotors?
  82. I got some weird problems with my 94 honda need help please!!!
  83. Skunk 2 Manifold...
  84. Del Sol registration questions
  85. D15B7 vs. D15B Crankshaft
  86. d16z6??how to's????
  87. itr and ctr?
  88. Lower Ball joint won't come off
  89. Main Relay Experts HELP!!!
  90. freaking check engine light
  91. boosted 93' 4-door
  92. Which suspension would be better
  93. del sol suspension
  94. Stock Radio...
  95. Engine likes to loose responsiveness
  96. Battery Acid!!
  97. Shift Linkage Fell Off (need bolts)
  98. indicator signal clicking noise for no reason!
  99. To drain or not to drain...
  100. Fuel injector help
  101. changing fuel filter
  102. help sourcing jdm sedan mirrors
  103. turn signals
  104. "My Subaru WRX would trash you Del Sol VTEC"
  105. 2000 civic frontal area
  106. '89 civic lx electrical problem with lights and braking
  107. running without vtec
  108. i gat a new civic HB 94
  109. GSR cluster?
  110. Uninstalling a Stock Steering Wheel
  111. New Guy
  112. Good Wideband O2 Sensor for tuning?
  113. question regarding installing keyless entry
  114. Timing marks
  115. My distributor
  116. Suspension
  117. exhaust?
  118. Apexi v-tec controller tuning
  119. connecting rods
  120. my clock is out
  121. Transmission questions
  122. Transmission questions
  123. tans problem...
  124. del sol audio wiring
  125. Thinking about getting rid of my civic
  126. Upper control arms
  127. Check engine light
  128. 2006 Civic Side Mirror Replacement Help Needed
  129. tire follow up
  130. What springs and retainers to run!?
  131. Civic once again drinking my MONEY!
  132. Clear Coat :$
  133. Del sol w/ Integra tails STILL NOT DONE!!
  134. what do u think about this civic
  135. I'm an idiot: over-reved
  136. looking for a ground strap
  137. Is this radiator OK?
  138. stupid question
  139. d16y7 help please
  140. Civic D15Z6 (Vtec E) poor idling
  141. 99 si front end conversion on eg hatch
  142. V-tech????
  143. cylinder compression test numbers D16Y8
  144. if no one can help me im gonna have to junk it
  145. cylinder not firing
  146. $2200 and still check engine light is on
  147. helpp me
  148. Help - Car leaking coolant?
  149. Muffler Systems
  150. changed my mind... again...
  151. Would A 02 4dr Climate Control Bezel...
  152. stumped...
  153. Ignition timing on my d16y7
  154. Auto tranny question?
  155. installing 6 x 9 into a civic 04
  156. -ls crank in gsr block???
  157. Cel 45
  158. adding manual tranny fluid.....
  159. Will it pass smog?
  160. rims
  161. Del sol stock exhaust help
  162. fuel pump problem? maybe?
  163. fenders
  164. Clutch Problem
  165. Kill switch
  166. power steering fluid?
  167. 97 Civic climate control lights
  168. EDM Civic
  169. passing inspection
  170. Help buying a 94 civic, what to look for
  171. 01 Civic - electrical problem? Please Help!!
  172. Entire Dash Diagram
  173. Turbowoes .v3
  174. Del sol map lights FS
  175. Failed Emissions in Texas
  176. rear seats
  177. Repair Shop Horror Stories
  178. HELP I have a question on audio
  179. H22 Swap in a 96 Civic EX
  180. Where can I purchase original parts for a Honda Civic (EK-3) ...
  181. Long Block Question
  182. how roomy is a integra compared to a del sol???
  183. civic problem..
  184. Need help with my A/C
  185. 2000 integra ls.......
  186. sohc zc motor
  187. SI front end dilemma
  188. not to sure where this should go but here is a custom guage pod in the works...
  189. Intake Manifold OPINIONS!!!
  190. Changin the manifold...
  191. kilometer keeps rolling
  192. problems putting tranny back in help!!!
  193. when VTEC hits [B18C1 in Del Sol]
  194. how high can astock ls/vtec rev to
  195. Indiglo Dash
  196. What's the Stock Ride Height of 99/00 Sedan?
  197. 92 del sol sir problem
  198. idle control valve heating bypass
  199. SUpercharge
  200. Compatible ECU's
  201. How to do a compression test on D16Y8?
  202. 92 tranny swap
  203. CAI doesnt fit
  204. splitting tranny from motor help!!!
  205. suspension issues.
  206. SRS Light question
  207. appearance question
  208. b16 head
  209. Shud i swap my civic for this
  210. 88-91 or 92-95
  211. Loud ticking noise coming from rear....
  212. Lound ticking noise form the rear.......
  213. Blown head basket
  214. Part Swapping
  215. Car won't start!!!
  216. I need to completely bypass my alarm
  217. what it this?
  218. brake lights
  219. 05 Civic whine
  220. I need an expert, car's bein wierd
  221. Battery always dead
  222. camber kit
  223. weight reduction....
  224. roof leak...
  225. intake mani swap ??
  226. Energy Suspension inserts
  227. oem o2 sensors vs jobber
  228. if i get my car back
  229. STock civic piping size?
  230. help engine light
  231. shift linkage
  232. Hid retro fit VS buying Projector headlight (civic 2002)
  233. 93 si won't start
  234. Koleshiya badges
  235. Possible gsr swap into ek
  236. B16A2: Look at these ECM pictures - what am I missing?
  237. second o2 sensor
  238. del sol corner lights
  239. a few ???'s
  240. p2p?
  241. Sealing rad leak
  242. its stock and auto right?
  243. b18c5 type-r is the best b18
  244. What all do I need h22 into civic.
  245. air suspention
  246. 1999 Civic LX keyless entry question
  247. Been a while, sadly, I return with MAP problems.
  248. my car is gone
  249. Spring/ Shock combo question
  250. Rear Bumper Diffuser's on Hatches
go
