- i bit off more than i can chew - mini me failure, couldnt get off timing belt cover
- Eibach pro-kits with 205/55/15
- stiffen the chassis...maybe?
- ign problem
- itr motor in a bubble back
- 87 Honda Help!
- piecing together a stolen mess...can you help me guys
- new pix of the hatch
- Late night teaser.........
- head swap question
- Couple questions for u guys
- Need help!!!!!!!
- 93 del sol vertical play in passenger side driveaxle
- 93 civic automatic shifter
- Engine bay sizes for del sol
- overheating problem
- how to adjust valve's..
- 94 del sol si shaky at mph over 60
- b16a swap question "Urgent"
- Intake mainifold
- Got a situation. Let me know what you think.
- Help me with my AC
- this is a off- subject ? but i need and answer..!
- My New Downpipe!
- Transmission
- WTB 92-95 civic hatchback si or cx
- Can someone help me?
- Which turbo should I go with?
- a tad bit of creativity
- Back Coolant Flush Help
- top end help..
- ? About headlights
- So I got a little creative today...
- ek headlight/front grill question
- Intercooler for GReddy turbo kit
- fuel pump?
- 02 civic aem intake
- 93 civic si check engine help
- break lights stay on please help!!!!!
- Which valves should I choose??
- 19998 honda civic ex cd player error code
- what motor do I have...
- $1000
- 92 civic dx hatch engine torquing back...
- SRS DTC's - 2001 Civic HX
- Header???
- 97 Civic ex (auto ---> manual)
- Found my stolen Civic......PICS!!!
- HELP! What's would this Ferio be?
- running out of fuel?
- 205/45/16 for rota slipstreams????????
- 2005 Civic passenger window won't work after taking off door panel
- What websites can I go to to get performance parts for my D15?
- heated seat wiring connection
- Some new things for my Civic
- Lower Ball Joint?
- EG cluster
- What interior came in what car?
- idea?
- reman Dizzy
- B16A2 into 99 civic coupe
- Using p28 on d15b vtec but get p08 maps?
- ARP head studs
- fuel pump relay or main relay?
- Civic - scotchgard and seat covers
- Ecu?
- Where exactly on cat does o2 go?
- Headlight Question
- 1.6 vs 1.7
- crosswinds
- Resurrecting my '94 EX
- How to heat your springs?
- b16b del Sol
- Turbo nitrous Q
- Changing front grill on Civic 96
- 88 project civic
- Rim Shims / Bushings / Sleeves
- Car pulls to the right only when accelerating
- Built D16 First start up - Won't idle or rev Help!
- Wastegate Spring Question HELP!
- here's another one
- del Sol Rims
- Broken Hearted
- New fuel parts
- Im getting hatched
- SRS problem on a 2000 Acura EL
- quarter mile
- Where o2 sensor goes?
- 99-00 ECU Swap
- help with tranny issue
- Where I'm at and going
- 31 in a 40?
- help: engine light after install
- del sol w/Integra tails has paint!!!
- Radiator Support 4dr fot a hatch?
- Shifter is hard and makes Noise
- 94-01 Integra Exhaust fit 96-00 Civic??
- Will 00 Civic Si shocks fit 93 Civic Si?
- looking for a del sol
- Rota's
- I know you guys maybe answered this a million times but.
- bolt pattern size
- Got a quick question about '93 cx hatch.
- 93 Civic Hatch??
- car shakes(vibration)??
- Trade: H22 EG to B18C5 EK
- BOV flange
- 1994 Civic EX Coupe
- Intake manifold???
- My Dashboard
- Installing Tach
- Need a Clutch
- exhaust
- Sold My Sol...
- Engine options for my EG
- Edelbrock Turbo
- Need a Clutch
- 02 civic ideas anyone
- guage cluster from auto civic work ok in a 5spd civic?
- Fu**in oil gauge
- Rims anyone?
- '95 Civic EX
- remove dash trim 97 civic
- Eibach ground control urgent help plz
- Bouncing idle. help....
- 93 DX airconditioner ground?
- Fuel Pump going bad?
- Lost!!!!!!!!!!!!!!!!
- Day two still in progress!
- every gear grinding under 40 mph?
- Odessy Navigation in 02 Civic LX
- high compression pistons
- What injector size do I need?
- Test Pipe
- Exhausts
- Day one went really F'in smooth.
- Trim piece replacement
- Timing Belt Broke! Help!
- 2000 Civic Si, what rpm at 70mph???
- New to the site and My 02 civic doesnt want to move!
- hot motor whats the prob?
- VTEC/V-AFC Question
- are aem cold air intakes worth the big $$$?
- how do i fix engine code 43 on a 92 civic
- vibration/sound coming from shifter?
- 95 teg brakes into 92 eg hatch
- Problem with lower motor mount
- preformance upgrades for my 99' civic
- My New Civic Hatch EG
- Shorting out/Clutch engage switch??
- Front Suspension Swap
- New 94 Civic, Need Rims
- *PiCs* some updated pics *PicS*
- b16a2 wont start
- Windshield washer motor (fuse location?
- 92 civic makes a putt sound.and little smoke
- ls to gsr/type r?
- 94 civic vx questions?
- Which BOV Should I go with.
- Rods/pistons
- 95 civic weight?
- civic power windows stuck
- supercharged SOHC
- Quiet muffler?
- HID Projectors question
- 97 honda civic wheel offsets?
- pics of 98 civic with projectors?
- just moved to denver
- Read Me
- rsx rear seats into a 98 hatch
- Too Much Blow-By, ? about Headgasket
- Del Sol question
- piston question -> d16y8 head on d15b8 (cx) block
- EG disk brake conversion problem
- B16A2 O2 wire up question??
- 99 honda civic torque spec head studs
- clutch question
- 92 civic rough idle and unable to take off smoothly!!!! HELP
- Power Locks IN a DEL SOL
- DC Sports Header
- Info on 2003 Acura EL
- Help taking off window tint!
- del sol makeover
- Clutch master cylinder
- EK steering hub
- 96 exhaust system on a 92 civic?
- How Do get 40mpg 2006 Civc
- del sols in springfield,IL ?
- Vtec motors..
- Which car better handling?
- Squeak in the clutch still even after Tbearing change
- D15b
- small coolant hose disconected... proglems ensued FTL
- clutch/pressure plate problems!!!!!!
- Replacing tranny questions?
- 1992 Civic gas tank replacement
- Valve Cover Bolts ?
- Truth of Cops & Civics...
- EG one piece headlights
- potential buy
- Slipping gears...what to do?
- h22a civic axles and ecu?
- The guy that bought my car sent me pics :hs:
- problem with b16a3 del sol
- turning lights?
- center console question
- Airbag question
- v-tec wiring
- anybody put SI exhaust on a base civic?
- help on buying a street cam
- Engine Mounts
- Motor mounts? [B18C1 / Del Sol Chassis]
- rota offset sizes
- Engine swap registering...
- Civic front-end conversion
- New to civics not to hondas, need advice on which car
- Noob from PA.
- back to honda again
- exhaust spit's when goin down in rpm's
- o2 sensor
- Eg or EK? DX
- Starter question
- Integra Gauge Cluster In 98 Civic
- 93 civic 4dr..
- Weird smell coming from a/c after changing starter
- How To Remove Upper Front Grill On Civic96
- 98 Civic headers...yes its a diff question!
- MPG Engine swap: VX into a DX chassis
- Plug wire sequence
- SURVEY: How long did your original clutch last?
- Easyest way to install strut bar
- Help needed. Plz.
- Hi-Flow Cat and Emissions
- New axel, still having problems...need some help
- what could this be
- Engine Swap Or Fix Body Work?
- del sol w/Integra tails wiring problem!
- Engine oil for a '00 Civic EX
- Any Clues About A/c Systems....
- Turbo Question!!!!
- Out of the Civic scene for a while
- A few shots of the turbo.
- whats the best bov
- 92 civic needs little more horsepower
- 95 civic lx fusebox
- Syncro damaged?
- Civic Battery Cables ? ? ?
- Good shops in TN?
- fuel injectors help
- About how long do alternators last normally?
