View Full Version : '92+ Civic/EL & Del Sol
  1. will delsol dash fit in eg?
  2. 9civichatch3 ~New Project EJ8~
  3. brake rotors help
  4. found a cut in my wire harness, what would this cause?
  5. Plain shift knob
  6. i
  7. carburated to fuel injection
  8. Check Engine light/ Codes/ Fuel Pressure
  9. Speedo cluster swap???
  10. Speedo cluster swap
  11. Block guard???
  12. exaust question
  13. SMooTHn's EG6
  14. Cabin Air Filter
  15. sound deadening material??? [removal ?]
  16. Civic Spoiler
  17. just a start
  18. Question about 99 civic ex RPM
  19. key less entry
  20. 1999 unstable revs help
  21. Help
  22. Swap vent on a 96-98 center bezel?
  23. Legal B series?-?-?
  24. Frozen Door Handles??
  25. 2000 civic si fuel pressure check
  26. What kind of clutch?
  27. Knocking under the Hood
  28. g2_teg_na's EJ1 Build-Up Thread
  29. Where to get white Honda emblems for 93 Del Sol
  30. can i replace a back bumper cover myself?? :(
  31. Civic Si Motor Stumbles
  32. Noisy EG
  33. Wassap Homies!
  34. Idle problem, IACV?
  35. 96 to 99 conversion
  36. Speedo cluster swap
  37. momo or mugen steering wheel...i searched
  38. Hood not fitting HELP
  39. Anyone done a DIY a/c & alternator belt replacement?
  40. installing subs
  41. Cold air intake modify
  42. Need a 14" steering wheel cover
  43. an engine question
  44. cluster fux? lol
  45. TDC sensor?
  46. help! my car Literary is falling apart
  47. tein damper problem...
  48. V-tech choice
  49. shock and spring
  50. lip kits
  51. Another interior question, reupholstery?
  52. What the hell? Electric supercharger?
  53. Choose My Car Color
  54. Alternator Belt Issues
  55. ek steering wheel into eg
  56. car won't start
  57. h22a4 turbo problem
  58. 1995 del sol engine swap problems
  59. New Sol In Boxes????
  60. What is the best tire size for SI rims
  61. Civic emission problems
  62. Rear brake conv. ???
  63. 2005 SI gauges
  64. Motor swapped,2 questions
  65. Some Civic Pics
  66. 93 civic coupe want to make the gauges light up red
  67. Hatch project v.1 : body
  68. ATTN: WHEEL TECHS Will 15x8 +0 offset fit?
  69. How to change The tail light assembly of 04 honda civic
  70. will they fit??
  71. My new Turbo Manifold (TopMount)
  72. 98 Civic EX drivers door leak
  73. Three gauges
  74. Coolant Problem
  75. HVAC control switchout?
  76. Color selection for my civic?? Any opinions??
  77. 1.4 to 1.6 distributor cap
  78. Going to replace valve seals. Anything else?
  79. Has anyone ever replaced interior trim?
  80. Honda del sol si ECU
  81. o2 sensor wire
  82. TYPE R fuel rail
  83. new cd player...should i tint my windows for thiefs?
  84. check out my buid-up WHAT DO U THINK?
  85. dumb ricer
  86. power windows and locks
  87. 95 Civic EX console
  88. ek fog opinions
  89. Bad bearing in 96 HX transmission.. options?
  90. how to: replace the throttle body?
  91. motor swap
  92. 95Civic Cooling Not On
  93. Big Brake kit Recomendation
  94. Does it fit?
  95. whats the diff between these b-series heads....
  96. what i need to turbo d series vtech
  97. flowmaster on 00 civic si
  98. help with '01 Acura EL mods...
  99. vtec breaking up
  100. 92 Civic EX problem
  101. radio security code
  102. How to disable factory alarm????
  103. 2002 civic ex instrument cluster bulbs
  104. short shifters
  105. Civiv 04 EX Dash lights
  106. Civic wouldn't start
  107. Service Manuals
  108. radiator issue
  109. temperature gauge
  110. What Are Hid?
  111. B/D Series Axel Question
  112. part replacements
  113. Ignition Coil
  114. wheels for my civic
  115. noob-whats tuning?
  116. Engine Swap
  117. best civic upgrades
  118. Engine Swap
  119. possible track times for civic si
  120. What civic is this from??
  121. 95 civic coupe rear shock replacement
  122. 93 Honda Del Sol Si... Mods or JDM??
  123. exhaust with rear lip
  124. Getting ODB codes P1753 and P1298.
  125. 2000 Civic Si Window Problems
  126. 99 Civic EX
  127. help out a noob
  128. honda civic eg with 2 inch drop
  129. mileage on your civic
  130. You've just been given a civic...
  131. Central locking options?
  132. Please read.....
  133. Legit online parts stores?
  134. '06 Civic vibration fixed!!!
  135. lost key
  136. oxygen sensor removal
  137. cold air intake vs short ram...?
  138. Just installed some silverstars...
  139. Transmission Problem On 99' Honda Civic Cx
  140. clutch help
  141. Cams
  142. what is so bad about rust?
  143. Bad Oil Leak!!!
  144. Lookin for an exhaust for my EJ6
  145. Please help me out with adjusting my headlights
  146. D16Y8 Innards
  147. volk
  148. Mods for 06+ Civic DX,LX,EX
  149. Tranny trouble
  150. Has anyone installed seat heaters before?
  151. Rust!?!?!
  152. Del Sol with b16 parts needed!!
  153. smoked taillights
  154. antifreeze in iac valve
  155. Wheel Dimensions...
  156. 99 Civic EX
  157. 99/00 civic si stock exhuast diameter
  158. B series spark plug cover crown (cap) nuts..
  159. SoCal Repair Shop?
  160. 95Civic overheating
  161. bleached taillights
  162. cluster problem...plz help
  163. what is so great about carbon fiber
  164. A/C Compressor Turning On and Off
  165. Rad troubles...exhaust/engine blowing white smoke....
  166. just wondering if this is a good price...
  167. How do I remove the radio trim panel???
  168. 1.6 ESi Soch ECU tuning
  169. y8 dizzy have different fireing order than b8?
  170. bleached taillights
  171. How To Change Interior Lightning!!!?
  172. wanted some minor mods to get me started.
  173. tire codes
  174. heres a great issue
  175. type R lip kit.
  176. code 7
  177. Stock Ek4 exhuast measurement?
  178. New here
  179. Help!! Lights Dimming Crazy on every Start, 97 Civic
  180. 1999 civic si
  181. Engine Clicking???
  182. 2007 Skunk2 Catalog.
  183. How fast have you driven?
  184. Honda Civic Idling Problem:NEED HELP
  185. Oil leak on valve cover!! Help!
  186. tokico struts/weapon r springs?
  187. fog lights for 00 4-door
  188. Compression Changes
  189. Cloth for Door Panel's
  190. Paint peeling on 99 Honda Civic DX Hatchback
  191. b16a1 EF distributor, harness, box to EG?
  192. getting a code 43 on a b18 swap (1991)
  193. Is this worth it?
  194. 1/4 panels off a civic
  195. Oil Leak! help
  196. Changing headlight bulbs on 95 Civic
  197. Common Ignition problems?
  198. Lights flicker when using turn signal..?
  199. b20vtec Question???
  200. Grip tape
  201. b20 vtec Franky is scary?
  202. Jasma 4-2-1 will fit to b16a1 OBD1??
  203. First Mods pros do on their 01,02,03 civics?
  204. del sol door panel
  205. D17A2 n00b engineering
  206. wtf clutch pedal!
  207. struts
  208. 99-00 honda civic factory top speed
  209. lsvtec studs
  210. front core support
  211. can someone help me?
  212. Tires?
  213. would Racing Hart C5's fit on 02 civic coupes?
  214. any cool sites?
  215. need help with rear brake drum cover removal!!!
  216. LOOKE WHAT i JUST GOT!!!
  217. Vtec adjustments
  218. suspension question.
  219. del sol questions
  220. Passenger side door lock motor
  221. Passenger Side Door Motor
  222. lightening it.
  223. GSR - SI What Axles?
  224. whp & hp..
  225. cat back or new exhaust system
  226. Del sol and B series parts
  227. Ecu..
  228. No body can get this :confused:
  229. Acceptable Shaft play?
  230. Bad fuel pump on 89 civic
  231. Honda Civic Si history
  232. need help motor shakes
  233. Under Dash Fuse Diagram
  234. No power to anything? Will not turn over
  235. Automatic Seat Belt Problems
  236. Final Drive Kit
  237. GSR vs LS Eagle Rods?
  238. can someone suggest some coilovers
  239. 03 civic si
  240. Civic Headlight Replacement
  241. illegal mods
  242. Del sol SI automatic????
  243. Worth It??
  244. Clutch Kit
  245. rockin' the d15.......again
  246. civic keyless entry
  247. How to change to short shift for 96 CIVIC???
  248. Rota GT3
  249. need info on head studs.. i got screwed
  250. compatability question.
go
