View Full Version : Do It Yourself
Pages : 1 2 3 4 5 6 [7]
  1. Diy Grounding Kit?
  2. shaving side moldings
  3. How to replace 1990-93 Distributor sub-housing assembly
  4. a/c control light bulbs
  5. Blinking Security LED
  6. How To: Flip Up Trunk
  7. My CF hood is faded and ugly
  8. Integra Carpet Install
  9. can i prep my car myself?
  10. How hard is it to replace transmission cover?
  11. Honda Civic 92-95 : DIY Smoking Headlights (640x480 pics)
  12. is welding hard?
  13. 94+ teg front end on 93Si h/b... HELP
  14. Honda Accord Coupe 03-07: Tinting Taillights
  15. How To: Paint Your Rims
  16. Honda Accord 90-93: Changing Bulbs
  17. Acura Integra 94-01: Installing CD Player
  18. Paint Color/Code for Rota "Gunmetal"
  19. How To: Replace Clutch Master Cylinder
  20. loctite or anti-seize on exhaust, spring kit?
  21. Brake hard line
  22. Honda Accord 90-93: Stud Replacement
  23. where to buy ground-control adapter for koni shocks
  24. Wash, Wax, Polish?
  25. Installing a short throw
  26. DIY Door Panels w/ details and pics
  27. Painting brake calipers
  28. putting on lower rear strut bar?
  29. Door Panel Swapping
  30. How To: Polish Headlights
  31. Installing aftermarket cd player on 03 accord?
  32. Honda Accord 94-95: Installing Corner Lights
  33. Fixing exhaust hanging too low problem
  34. DYI Turbo Question
  35. Need Help With My Headlight Wiring
  36. resistors for LEDs question
  37. Request Installing Catback
  38. Honda Civic 96-00: Shift & E-Brake Boot Removal
  39. thread locking compound
  40. Misc. Honda/Acura: Radiator Flush
  41. Where do I run A power wire thru?
  42. Honda Accord 94-97: Rear Aftermarket Speaker w/ OEM Grill Fix
  43. Is A Rear Disc Conversion Possible?
  44. Misc. Honda/Acura: Lamborghini "Scissor" Doors
  45. How To: Paint and Prep OEM and Aftermarket Lips/Skirts
  46. Drum Brakes: How To Perform Maintenance
  47. Misc. Honda/Acura: Pinstripe Removal
  48. Honda Civic 96-0: Installing Intake
  49. Honda Accord 2003-2007: Clear or Gunmetal Headlights
  50. tinting/dying 96-00 civic headlight plastic cover
  51. Honda Civic 96-00: DIY CTR Headlights Guide(with Pictures)
  52. Honda Civic D-Series Engine: DIY Valve Adjustment
  53. Honda Accord 94-97: DIY Type-R Grill with Pics
  54. Honda Civic Wagon 88-91: De-Rattle Your Rear Gate
  55. Misc. Honda/Acura: Keyless Entry Remote Programming Instructions
  56. Misc. Honda/Acura: Badge Removal
  57. Ingalls Front Camber Kit Install [640x480 img's]
  58. Brake Pad DIY
  59. Misc. Honda/Acura: Indiglo Needles
  60. Honda Accord 90-93: Mugen Front Lip Install
  61. Bodykits/Lowered cars - How to get under & on lifts
  62. 88-91 Civic/CRX DIY Daytime running lights
  63. A very good HID FAQ and Info site!!
  64. Adjusting Ground Control Coilovers
  65. Honda Civic 2001-2003: Turning the A/C off while defrosting
  66. Should I Replace The OEM Head Bolts?
  67. suspension installation
  68. Can you DIY a shift light?
  69. 88 Civic Tach
  70. Honda Civic 2001-2003: Spark Plug Installation
  71. Painting Taillights?
  72. FWD Honda/Acura: DIY Tire Rotation
  73. rotors
  74. 1996-2000 Honda Civic: Aluminum Mesh Grille ("Type-R Grille")
  75. Honda Accord 98-02: Resetting Maintenance Required Indicator
  76. H22A Swap FAQs
  77. headlight replacement for 91 integra please help
  78. Adjusting Hydro Clutch Engagement
  79. Acura CL/Accord 94-97: Spring Install w/pics
  80. Request: Modifying s-type tails
  81. Honda Accord Sedan 01-02: Taking out the orange in the taillights
  82. Installing Halo Headlights???
  83. Cleaning Engine Bay
  84. DIY Electric Boost Controller.
  85. Honda Accord Coupe 98-00: Grillcraft Sport Grille (Lower)
  86. Honda Accord Coupe 98-00: Grillcraft Sport Grille (Upper)
  87. Honda Civic 92-00: B18 Swap
  88. B18C: Compression test
  89. Vortech Supercharger Install
  90. Jackson Racing Supercharger Install
  91. Honda/Acura 4 Cylinder: Header Install
  92. Misc. Honda/Acura: Fuel pressure regulator
  93. Misc. Honda/Acura: Aftermarket fuel pump
  94. B18, B16, LS/VTEC, or B20/VTEC: Oil Catch Can
  95. How To: Install Angel Eye Headlights
  96. Misc. Honda/Acura: Adjustable Front Camber Kit Install
  97. Honda Accord 94-97: Koyo Radiator Install
  98. Misc. Honda/Acura: Checking Drive Belts
  99. Misc. Honda/Acura: Check CV Boots
  100. Misc. Honda/Acura: Checking Hydaulic Clutch Fluid
  101. Misc. Honda/Acura: Brake Fluid Flushing
  102. Misc. Honda/Acura: Checking Brake Fluid
  103. Misc. Honda/Acura: Battery Replacement
  104. Misc. Honda/Acura: Base Idle Adjustment
  105. Misc. Honda/Acura: Checking your A/T Fluid
  106. Misc. Honda/Acura: Car Washing Tips
  107. Misc. Honda/Acura: Sticker Installation Tips
  108. Misc. Honda/Acura: Custom Mugen Grille
  109. Misc. Honda/Acura: Black Housing Headlights
  110. Misc. Honda/Acura: Custom Clear Corners
  111. Honda Accord 98-02: CL-S/TL-S rear sway bar
  112. Bending the Steering Wheel?
  113. Honda Accord 98-02: Brake Pad Replacement
  114. Honda Civic 88-91: Replacing Main Relay
  115. Honda Civic 88-91: Rear Disc Swap
  116. Honda Civic 88-91: Installing Keyless Entry
  117. Honda Civic 88-91: Replacing a Wheel Stud
  118. Honda Civic 88-91: Replacing an Axle
  119. Honda Accord 98-02/Honda Civic 97-01: HID Install
  120. Honda Accord V6 95-97: CAI Install
  121. Acura Integra 94-01: DIY JDM Amber clock
  122. Acura Integra 94-01: Headlight Halos
  123. Acura Integra (non-ITR) 94-01: ITR Rear Sway Bar Install
  124. Mid 80s-Early 90s Accord, Civic & Prelude: Main Relay Fix
  125. How To: DIY Turbo
  126. Welcome to the DIY/How-To forum!
  127. Honda Accord 98-02: Pollen/Dust Filter
  128. Honda Accord 94-97: Changing Manual Tranny Fluid
  129. Honda Accord 98-02: TL-S Steering Wheel Swap
  130. TL-S steering wheel swap on 6th gen Accords DIY instructions
go
