View Full Version : Do It Yourself
Pages : 1 2 3 4 5 [6] 7
  1. Timing & Waterpump change 1994 civic lx
  2. DIY Civic 1994 Timing + Waterpump
  3. 2000 Civic DX Resonator
  4. DIY VTEC light.
  5. How To: Gear Position Sensor Replacement
  6. Diy - Valve Adjustment Tool
  7. b18c1 and ecu
  8. 2000 3.2 TL / How to for rear brakes ???
  9. Power Steering Speed Sensor Assistance
  10. fiberglass...
  11. LED Windshield Washers Help!
  12. problem
  13. Remote Starter!! Eek!
  14. 88 legend automatic transmission
  15. DIY: Red/Clear Tailights
  16. Where's the thermostat on a 91 Integra?
  17. yanking out tranny... 98 SH
  18. Custom Interior
  19. Acura ls boost with mitsubish parts??
  20. Update on my fiberglass project
  21. Ls Engine Build
  22. Jdm...
  23. DIY: In-Car Camera Install *pics*
  24. S2000 "Engine Start" button install?
  25. 6th Gen Accord w/ 18's...Do i need a front AND rear camber kit?
  26. Clutch creaks when depressed (from outside) - Easy Fix?
  27. help...speedo
  28. window tinting
  29. Turbo install on F22
  30. Lower mesh grill - civic
  31. Car dies off within 5 sec of start
  32. i need help installing my new cd player
  33. Spark Plugs
  34. seperating lower ball joint
  35. Tach on 90 civic
  36. AAARGH! Need suspension help!
  37. '94 Integra sunroof switch
  38. 5th gen lude speaker removal
  39. suspension wackiness
  40. replacement OEM parts - carpartswholesale.com
  41. some quick Q's
  42. Cutting this off
  43. HID conversion for 4th gen Lude
  44. Books or websites
  45. Where can I buy a killswitch for my car?
  46. thought you guys might want to see
  47. Remote start alarm inst., 93 civic hb elect. wiring dia.........do u have info?????
  48. Programming instruction for 97' 2.5 TL
  49. Noisy ABS Pump?
  50. GSR Dash Conversion
  51. Question about how to install!!??
  52. How to put the lock cylinders back on an 90 crx?
  53. dumb q
  54. 88 honda hatch axle removal
  55. noisy front axle
  56. Plastic molding
  57. LEDs
  58. Accord 97 powerlock issues
  59. 2000 Honda Civic Si moonroof leaking.
  60. B-12 Chemtool Injector Cleaning
  61. Home made cold air intake
  62. Info On: Civic With Integra Frontend Conversion
  63. S2000: Locked Out of Sixth
  64. spraying amber corners
  65. Maintenance required light in the New TSX
  66. 92 integra gauges
  67. How To Tighten Up E-Brake?
  68. I got restless, so I did this........
  69. can i get a how to on polishing a valve cover
  70. Autometer Gauges
  71. 1996 Civic 4 door sedan
  72. Rear camber kit install pics 98-00 Accord
  73. Oil Catch Can DIY - FI'd B18C1 - large pics
  74. Teffetta white color match
  75. Polishing Lips
  76. 6x9 install
  77. DIY: Waterlogged Tail Light Fix
  78. Taking off the entire timing belt cover
  79. custom tail lights
  80. Newbie needs help
  81. Stripped Screws
  82. Ball Joint Problem or Steering Rack????? Wobble & Noise???
  83. Smoking headlights...
  84. Installing Hood Pins on VIS CF Hood
  85. Scrathes
  86. Honda Accord 98-02: Front Speaker Installation/Door Panel Removal
  87. How To: Fix Steering Wheel Coming Loose (Twisting)
  88. Airconditioner / Engine noise
  89. Quick cheap stock to cold air intake hack
  90. '92 LS vs. GS/GSR Differences in header/convertor/exhause???
  91. axle boot
  92. eg door panels
  93. need help w/ e-brake handle
  94. Custom FIBERGLASS
  95. Windows rattle like hell, Help!!
  96. DIY smoke headlight Question
  97. 1987 Honda accord
  98. Can adjust clearance valve in Accord 97?
  99. Apexi N1 Universal Muffler
  100. Help! Thinking of buying Acura but before I do----
  101. civic Headlight highs only work on one side
  102. Installing Lowering Springs
  103. Clearing out the headlights on my 2002 Accord
  104. dashboard
  105. wondering about street glow h1's
  106. Tein Install ?
  107. rattling!!
  108. Gsr Intake
  109. How To: Change Oil Pan Gasket
  110. Headlight bulb replacement
  111. AEM V2 CAI - replica
  112. KIll switch
  113. Timing Advance resistor
  114. Remote start install on the accord...help
  115. How To: Shave Door Handles
  116. Rear Speaker removal 2000 civic
  117. H22A swap, where is knock sensor?
  118. How do i paint the black vinyl part on the door to match the car paint? Help
  119. Polyurethane bushings? YES!
  120. Door panel removal trouble
  121. Installing A New Fuel Pump
  122. Got my subframe fixed
  123. pinstripe????
  124. power window lube
  125. DIY: Short Ram Intake Installation Guide
  126. do-it-yourself car repainting
  127. How To: Fix trunk leak
  128. How To: Bolt A Y8 Manifold Onto Y7 engine.
  129. Door won't open...
  130. what car site give out free decals?
  131. Exhaust woes
  132. puttin in a shortshifter
  133. Amber Blinkers That Look Clear?
  134. removing a 96-00 civic dash
  135. Civic 92-95: How to install gauges?
  136. DIY Cylinder Head Porting (port and polish)
  137. Removing door handles, side moldings and mirrors?
  138. eg rear seats
  139. How to install shift boot?
  140. gauge bezel install
  141. How do you install a headunit in a 96 Integra LS?
  142. **FS: 11 New Tools = Screwdrivers, Pliers - cheap**
  143. Prelude oil change
  144. Molded Body parts
  145. How To: Turning clear tails into Red/clear tails
  146. CAI for 91 teg
  147. Fill Holes In My Back Bumper...
  148. 3M paint protection film
  149. Transmission removal
  150. Cleaned out Engine Bay
  151. Headlights Turning Yellow
  152. Has anyone tried the "universal" fender flares?
  153. Slow sunroof
  154. Car Wash, order, tips, etc...
  155. how do u install coilovers??
  156. Civic 92-95 Tail light question
  157. replacing break pads help
  158. Inline fuel pump wiring
  159. How To: Clean Your Throttle Body
  160. Vinal Carbon fiber! [help]
  161. how do i take the side skirt off?
  162. Replacing Bumper?
  163. DIY ion blue headlights?
  164. How To: Snapped Exhaust Manifold Stud Removal
  165. Shaving Side Trim
  166. Installing A Strut Bar?
  167. ATT BobDaGoOn Vinal Carbon fiber?
  168. Leaking distributor
  169. Adding sparkle to your clearcoat?
  170. Repainting entire car, got some bumper ?'s
  171. Removing paint from plastic pieces
  172. Turbo info?
  173. Drag III Kit Civic install questions
  174. aluminum-look dash trim paint?
  175. how difficult is it to replace a hood?
  176. Installing Engine Mount Inserts
  177. Installing a tach in a 92-95 civic...
  178. can I change my own head?
  179. How To Fix Scratches On Rims?
  180. Can anybody help me about adjusting the gear ratios?
  181. Cold-Air Intake System - did I get ripped?
  182. How to take out resonator in a 96 civic
  183. Sidemarkers flashing too slow
  184. Booty Call
  185. Can I jumper my 99 Honda ECU to get the error codes??
  186. Taking a dent out
  187. how to replace bolts for tire lugs
  188. How To: Stop Headlight Condensation
  189. replacing wheel studs?
  190. How To: Make Black Chrome Emblems
  191. temporary/permanent fix on exhaust? :D
  192. Swapping Brakes Between Accord and Civic?
  193. How to fix speedometer & odometer?
  194. How To: Drain Water From Sunroof
  195. Painting Mirrors
  196. Modulator going out?
  197. Sticky Sticker Crap
  198. Interior seat idea
  199. Civic LX 03 Daytime Running Lights - HELP
  200. d16y7 intake aftermarket installation?
  201. Painting Side Skurts
  202. Window Rattle?
  203. DIY removal of sideskirts on 96 integra
  204. Best place to buy OEM parts
  205. Honda Civic 92-95: Installing Integra Gauge Cluster
  206. 93 civic front kit install
  207. installing side marker.s
  208. DIY: Speaker Grill Cleaning
  209. Installing An Alarm On A Non-Powerlock Car
  210. How To: Install A Header
  211. DIY Carbon Fiber (boot-Leg edition)
  212. Honda Accord 03-07: Door-Lock Knob Replacement
  213. door panel removal
  214. How To: Install Sidemarkers
  215. replacing the passagerside axle
  216. How To: Replace Interior Carpeting
  217. installing coilovers...
  218. How to paint valve cover
  219. Evolution of car wash (pics) *56K warning*
  220. DIY tire Patch
  221. Acura Integra 94-01: Removing Side-Rear Interior Panel (Speaker Installation)
  222. need: quick steps for shaving..
  223. recharge AC refrigant???
  224. Installing an alarm
  225. Where to come thru firewall for amp wire?
  226. HELP?!? Replacing factory tweeters in Civic
  227. My 96 Civic HB CX
  228. curbed wheel repair?
  229. seat belt...
  230. 03 accord black housing??
  231. 93 civic axles
  232. Need wiring expertise!
  233. Clutch is starting to slip...
  234. how do you: change DX guage to EX
  235. a/f meter install?
  236. How To: Make Aftermarket Blinkers Blink Slower
  237. Interior Color Spray
  238. Request! : Retrofitting HID projectors into CIv HDlites!
  239. Putting together my DIY ground kit
  240. How do you install EK9 Power folding mirrors?
  241. HELP: How To Clear Amber Taillights
  242. Headlights
  243. wheel alignment
  244. how to install those very bright lights
  245. If You Can't Find Your Thread...
  246. 92 hatch stock rims
  247. b16 swap ?s
  248. How To: Turn Your Shift Knob Characters Red
  249. "crushed" BOV??
  250. Misc. Honda/Acura: Turn Your Amber Taillights Red
go
