View Full Version : Do It Yourself
Pages : 1 2 3 4 [5] 6 7
  1. diagnostic and troubleshooting woes.
  2. Getting Rid of Rust...
  3. Foglights
  4. help on 94 accord headlight swap
  5. fuel cut off switch or kill switch
  6. 01 ody drivers door panel removal
  7. how do I clean my headlight lenses?
  8. How to Install Rear Swaybar Suspension Techniques on 1996 Accord DX Sedan
  9. RSX Titanium-Look Interior Trim
  10. code 6 on stock 88 CRX DX
  11. how to remove shifter console cover
  12. 4th Gen snappy door stops
  13. What gasket do I need?
  14. Any one know how to Install Right Door Window, 1997 Acura CL
  15. OBD0 -> OBD1 Conversion Write Up
  16. D-Series Camshaft and Valve Spring Install Write-Up
  17. HOWTO: Timing Belt/Water Pump Change on a D16Z6
  18. Uberdata - Write Up
  19. D16Y8 manifold swap how to
  20. Making your own Subwoofer Box
  21. 96-98 CTR Rear lip install question
  22. changing hoses- easier way?
  23. how do you take out the ignition lock or what ever its called?
  24. element mnct req'd light
  25. 6gen accord coil over install help
  26. Si Gauges/si!
  27. What do I need to Paint My Own Car?
  28. Cleaning ur headlights
  29. jdm??????
  30. seatbelt coloring
  31. What kind of plaster?
  32. Quick question about painting with spray gun
  33. Shampooing Interior?
  34. Help!! I need a paint code!!!!!!
  35. welding holes in hood for scoop
  36. brade pad installation gone bad!
  37. camber adjustment
  38. DIY: Center armrest 88-91 civic crx
  39. DIY: Most Honda 5 spd Models: Turn Characters Red
  40. Painting your car....
  41. Headliner Repair?
  42. 92 Legend Freeze plug
  43. Accord ABS light
  44. Quick, easy, and cheap preventitive maintenance
  45. Installing HID Ballasts in 04 Accord V6
  46. installing springs
  47. idiots guide to turbo timers???
  48. Warm AC......
  49. trying to get old hg off
  50. Common oil leaks on 95 Civic?
  51. center console swap
  52. Aftermarket seats into 91 civic HB ??? need help
  53. afr alteration
  54. Help~ Body
  55. problem with door lock wiring
  56. CRV Rear wheel conversion
  57. Please Help w/ Rear Upper Strut Bar(in trunk)
  58. 96-00 Civic to GSR Rear Seat Conversion?
  59. Repainting interior
  60. Painting/touching up wheels
  61. Tail Light Gasket Material??
  62. Taking Amber out of headlights?
  63. installing jdms
  64. painting rims?!
  65. Emblems!
  66. Need a hand getting car running again!
  67. Question about ALT BELT install
  68. pictures of grille!
  69. Install help!
  70. Quality of Haynes manuals
  71. Cel Codes
  72. Fuel Problem?? HELP ANYONE???
  73. HVLP Gravity paint guns?
  74. ~DIY~ Oxygen Sensor Replacement
  75. HELP H22 into 6 Generation Accord! PLEASE
  76. 1994 civic alarm and remote
  77. Code 20 Electrical Load Detector?
  78. Civic Flywheel/Clutch Install (58 pics)
  79. cleaning windows
  80. Help !!
  81. Painting hubcaps
  82. info on hub centric kit
  83. Kia Sephia Won't Start in Park
  84. installing thermostat on a integra
  85. Painting Integra JDM front end conversion?
  86. How would i....
  87. Need Help
  88. Paintless Dent Removal
  89. Skunk2 Short Throw Shifter
  90. How do you get sponsored?
  91. Remove AC from 90 Accord
  92. rotating tires
  93. Acura integra 95, replacing thermostat
  94. Help: "Civic" badge removal..
  95. Carbon fiber question?
  96. Replacing Clutch Master and Slave Cylinders
  97. De-ricing my civic
  98. 99 Civic Carbon Fiber Hood
  99. Reaching 30k miles
  100. valve cover + sand blasting = ?
  101. A/F Gauge install Help please
  102. Bang For The Buck
  103. Switching shift knob for 04 Civic EX
  104. new seats
  105. need help
  106. Acura Vigor Front Speakers
  107. 95 civic drum brake adjustment
  108. Painting interior
  109. Looking for a manual conversion for 98 Integra LS
  110. Light Bulb on Climate Control
  111. Before I even think about attemping this myself
  112. shift linkage questions
  113. Need help detaching shift linkage from tranny
  114. driver side kick panel removal
  115. Rebuilding/remodeling rusted exhaust?
  116. moon roof help
  117. Help installing EG9 Spoiler
  118. Cleaning Exhaust
  119. First Attempt To Paint Interior Bulb
  120. HELP! Installing XM radio
  121. need help - hazy discoloration on headlamps
  122. gasket
  123. Cam timing D16Z6 Pully marks
  124. Cheapest place for d16z6 head gasket
  125. MY FIRST HOW TO: making a flange for the Apexi Filter *PICS*
  126. Mounting tires?
  127. Q about primer when painting plastic
  128. door panel clips?
  129. DIY on Shaving emblems or shaving period...?
  130. Are ball joints needed for a camber kit???
  131. Excessive Break Wear - 99 Accord
  132. Front Brake Pads
  133. Bolt-outs not working for me...
  134. JDM ITR master cylinder/brake booster -> Civic
  135. side moldings suck
  136. Springs
  137. Maintenance on Rear Drums
  138. gsr head
  139. DIY - o2 Simulator install
  140. Mazda wheels on a Civic
  141. Grill insert thingy on a 94 Accord
  142. How do u take these pieces out of a 5th gen interior?
  143. cheap ways to increase horsepower?
  144. need nos
  145. looking for a car
  146. looking for a car
  147. Occasional Starting Problem
  148. very simple DIY
  149. Air/Fuel Gauge install...weird readings
  150. Qs about power window motor
  151. is there a such thing?
  152. 96 civic hatch cx
  153. High Temperature Paint
  154. 96-00 civic manual spoon(replica) mirrors
  155. Immobilizer to PCM signal error problem HELP!!!!!!!!!
  156. seats
  157. 86 crx si Hydrolic clutch conversion
  158. MDX maintenance light
  159. How do i remove...
  160. INstall help coilovers and shocks.
  161. DIY Ram Air "icebox"
  162. NEED HELP!!! Installing CRX rear seat
  163. carbon fiber
  164. good or bad idea? touch up paint
  165. Mugen lip install
  166. Replacing timing belt on Honad Civic 1995
  167. Steps on painting a bumper!
  168. Brake install on 'teg
  169. Chicago Ppl, We Do Honda Engine Work For 1/2 Price
  170. 89 Civic won't start
  171. trying to rotate tires...rim stuck on hub
  172. H22 Valve Adjustment
  173. water hose install
  174. I need to know how to remove factory side skirts from a teg
  175. Cooling troubles :(
  176. Shave Emblems & Fill In holes
  177. Integra GS-R O2 Sensor
  178. JDM Fogs??
  179. Parking Light Power Source
  180. Noob question on d16z6 engines
  181. Changing Rim Size, Speedometer?
  182. laying down vinyl...HELP!
  183. bolt pattern
  184. Swap Question
  185. Climate Controls Bulb...
  186. Headlight and taillight paint..
  187. How to fix foggy headlights
  188. Integra Instrument Panel Bulb Replacement
  189. Gutting interior - where to start???
  190. Removing speedometer in an 96' accord
  191. Smoked Taillights (56k warning over 1MB of pics)
  192. air/fuel gauge
  193. '92-'95 Civic Ingalls Camber Kit Install
  194. Lower ball joint removal
  195. DIY Cvic 6th Gen Skunk2 Camber Kit Install
  196. Drum To Disc Conversion
  197. squeaking sound from my integra?
  198. How do you remove...
  199. Help with PS2 in the glove box on a civic
  200. Building H22a to Type S Specs
  201. help with tweeters.
  202. Basic maintenance: What should I use?
  203. how much to rebuild tranny?
  204. help! in the middle of installing mount
  205. need help removing '98 civic alternator
  206. Honda Civic 96-00: DIY JDM EK City Light Kit
  207. how do i install my new cylinder head
  208. Octane on gasoline
  209. All of my step by steps.
  210. Honda Civic 96-00/Misc.: Taillight DIY
  211. Installing CD Player.. ?!?!
  212. How to change interior lights in 2003 Honda Accord Coupe
  213. 2000 Civic EX Guage Swap
  214. civic door panel removal 92-95
  215. Looking for a fuel filter on a dodge...Uhg
  216. Replacing the Starter in a 98 3.2 TL
  217. All people who paint there own stuff get in here.
  218. Wheels
  219. How To: Fix Power Antenna
  220. cheap ghetto white face guages anyone?
  221. Painting brakes
  222. changing a starter
  223. 3 - 5 angle valve job
  224. Header/Exhaust install
  225. Help--keyless remote
  226. I need coilover installation help.
  227. Ideas for tail lights CIVIC!
  228. help remove door panel
  229. install ground wire
  230. fuse goes out when adjusting lights...
  231. Lights blow fuse...
  232. 94-97 Moonroof VS 98-01 Moonroof fitting
  233. Integra - hatch latch won't release
  234. Integra - power mirror rattle
  235. Tightening Integra doors - indicator coming on
  236. CRV transmission fluid change
  237. fuse box.....
  238. red clears --> red ambers
  239. DIY: Cheap *ghetto* White Face Gauges
  240. Help: Goodridge Lines Installed (Pics)
  241. Help about installing coilovers
  242. Looking for someone to install coilovers
  243. Help with DIY headlights...
  244. S2000 trunk spoiler install
  245. headers for cx?
  246. problem after installing new cd deck. help..
  247. honda civic lx to ex exhaust swap
  248. how to make paint stick on a mesh?
  249. 1994 Accord EX - 4 cyl VTEC EGR Port cleaning
  250. extra wires
go
