View Full Version : Do It Yourself
Pages : 1 2 3 [4] 5 6 7
  1. center console
  2. timing belt.....
  3. Broken Off Antenna-'92 Civic LX
  4. mechanics books
  5. Heat Shield
  6. Update on shifter (pics) (btw, ebay shifters = teh suck)
  7. 01 Civic Power Lock Problem
  8. Rear Speaker install on 2003 Civic (4dr)
  9. DIY: ITR Rear Sway Bar
  10. CEL on - Please help me figure this out
  11. DIY Muffler
  12. Where can I get a new OEM Hood (civic EX)
  13. timeing belt
  14. Spring compressors don't fit between coils
  15. EGR Valve Replacement ('01 Odessey)
  16. Any diy to quiet down exhaust?
  17. i need of manual
  18. CHecking OBDII
  19. Repeater/Sidemarker
  20. just had an idea but how do i make it happen?strobe light
  21. Help me with my leaking 97 CL2.2 ?!?!
  22. My Tailgate is stuck closed!!!
  23. Clear out 93 accord tail lights?
  24. Code P1457 - where do I start
  25. Fuel line location
  26. jack points?
  27. Anyone knows how to install 2003 accord (4dr) tail lights?
  28. Chrome Grill DIY
  29. Question about Wiring?
  30. 91 Honda Accord Front Speakers, HELP WANTED!
  31. Clear out TSX orange corners??
  32. A little cash to spend... im sure this wont be hard
  33. Civic needs some loven' care
  34. Timing belt replacement..what the hell?
  35. S2000 antenna install guides?
  36. Head lights
  37. Timming Belt D.I.Y for D16Z6 anyone got one?
  38. changing springs
  39. building an exhuast
  40. 96 civic lx swap 98 prelude(H22) SH
  41. do i need a new axle?
  42. Honda Prelude 2.3 Si Engine Swap
  43. oil line from non vtec to vtec head
  44. LS Custom Valve Cover
  45. 92 EG6 RH axle boot circlip removal
  46. '03 Odyssey Front Brakes How-To?
  47. fuel line
  48. DIY help with streetglow underbody neon
  49. NEED HELP With Seat Swap
  50. 93 civic with 90 000 miles, what sort of things need to be serviced on it?
  51. DIY grounding kit!
  52. Custom map lights for your CRX!
  53. jack w/ jack stands or ramp
  54. has this been done before??
  55. Difference between main bearings and rod bearings and the color coding?
  56. removing A/C
  57. Scratched wheel
  58. Headlight bulb installation
  59. Help me spend my money!
  60. Honda Accord 02 4cyl Ex Parking Brake Adjust
  61. Honda accord 02 4cyl brake and rotor change help
  62. WTB: 92 Civic DX HB
  63. rust repair
  64. wiring
  65. chek engine problem
  66. clearing headlights in '97 accord
  67. clueless novice: ATF change
  68. 4th Gen Accord front wheel shake
  69. N.O.S. bottle opener instructions?
  70. brakes on an odessey
  71. help on oil pressure guage 98 civic ex
  72. Head lights dont come on
  73. Broken bolt in caliper
  74. accord oil pressure gauge install
  75. Denzo vs Botch Spark Plugs
  76. Parking Brake Help
  77. HELP question with brakes
  78. paint that matches a polished lip?
  79. Accord speed sensor replacement
  80. `97 Accord Crank bolt removal??Help!
  81. breaks--help please!
  82. stuck in park and ignition wont turn
  83. Location of EGR valve?
  84. Header Gasket
  85. is it worth it?
  86. Urgent Suspension problems!!!
  87. taking out climate control
  88. DIY 2004 Accord EXV6 Rear Disc Brake Pad replacement
  89. anti theft code help
  90. HELP w/ rear main seal
  91. Leaky compressor
  92. Lowering my 95 accord ex
  93. can you take out the dash of a 96 integra 2 door??
  94. Differential Fluid question for 99 RL
  95. plug wires...
  96. brakes question...
  97. wiring/alingment
  98. 94 accord too lean
  99. dash swap
  100. Is removal of rear window defroster possible??
  101. Main relay problems
  102. Valvespring Replacement Help
  103. 84 civic thermostat--HELP!!
  104. Guage Cluster Conversion
  105. electrical problem with A 91 civic - help!!!
  106. looking for a clutch
  107. I want to give my head a bath
  108. Adding power windows to EK hatch - anyone done it B4?
  109. Silverstars for 92 accord
  110. 1996 Honda Accord Oil Pan Replacement! HELPPPPPP!
  111. paint guns??
  112. i could get some help here !
  113. Honda fluids only?
  114. Help?
  115. Bent Rims
  116. Get rid of beeping
  117. 92-95 civic spoon mirrors?
  118. tune up?
  119. Anyone know wether Weapon-R Curcit Pro Coilovers can be.....
  120. Does any1 have install instructions for 2 gen. teg. Weapon R Circuit Pro Coilovers ??
  121. headlight harness help
  122. DIY redding taillights-96-00 civic
  123. 1990 Honda Accord PWR Door Locks Problem
  124. Black out headlights
  125. need help on coilovers. please help.
  126. rear tie bar and strut bar
  127. springs instalation
  128. Headlight help
  129. what do i need 4 a DIY turbo
  130. Civic only starts if i unplug the main injector
  131. flat black on crx...
  132. 5 lugs conversion
  133. purchasing kit online
  134. damn
  135. Interior Fabric
  136. 1st timer with my wrecked 95 accord ex
  137. Dashboard disassembly problem
  138. headlight question please help
  139. 98 Civic EX will not start
  140. headlight question
  141. under-dash fuse box
  142. DIY Prelude Grille
  143. amber out of lights on the bumber
  144. Pics of my DIY smoked tail lights
  145. REbuilding an 88-90 civic & crx 5 speed
  146. river guy wants swap
  147. tinting headlights black for 92-95 civic
  148. Painting OEM Rims
  149. 92 Honda Civic Interior Ideas
  150. Valve Cover bolts - two have snapped in head NEED HELP!
  151. How can I raise red line on 93 teg ls???
  152. teg ls 00 - painting stock sideskirts (silver)
  153. Should I attempt timing belts? 95 Accord
  154. ?DIY Kill Switch?
  155. good base car
  156. **integra dashboard in a 91 crx**
  157. Rear Brake Calipers
  158. DIY Guage Colour Change....
  159. Installing a Intake Chip PLZ HELP! (01 Accord 4D 4cyl.)
  160. DIY JDM door panels
  161. alarm relay question...
  162. custom trunk enclosures
  163. Custom Interior Doors
  164. Accord power door locks
  165. broke bolt while putting in break pads
  166. I need instructions for installing Eurolights on a 2001 4D accord!
  167. Prepping car for paint, how do you remove trim ? Windshield ?
  168. What grit sand paper for headlights
  169. Blacking or tinting tail lights?
  170. Clearing 96 Civic Sedan Ambers
  171. Air Conditioning Direction thing broken
  172. Chipping an ECU?
  173. Can amber in 93 LS tailites be cleared/removed?
  174. Need a DIY for Lower Mesh Grill...
  175. How to installl SRI on 5th gen Accord?
  176. carbon fiber hood ????
  177. How do I remove console? 94 Accord
  178. wiper/headlight/seatbelt chime wiring crossed?
  179. del Sol Fuel Pump
  180. Master cylinder change advice Plz.
  181. valve adjustment
  182. Need help with Headlight switch
  183. DIY Duplicolor style "review"
  184. Dupli-color high performance Vinyl & fabric spray
  185. 94 Cylinder head
  186. HELP: identify this acura engine part
  187. Mixing Brake Fluids
  188. rad?
  189. new clutch needed
  190. Need Help! Heeeeeeeeeeelp
  191. Diy Question Mesh Grill
  192. ajusting headlights
  193. Serious problem w/ VENOM intake manifold
  194. know anything about installing silverstars
  195. Dirty Headlights
  196. To all Painters!
  197. Good Mechanic
  198. 6th Gen Accord Coupe Door
  199. Looking for DIY "ice box"
  200. vinyl lines...
  201. Spring Slap" progress 2.3" drop
  202. DIY: Momo/ITR Steering Horn Install
  203. JDM ITR Center Console Problem
  204. flat tire help....
  205. 90 civic dx starting problem
  206. Relocating Ignition
  207. Aftermarket parts and new car warranty
  208. A/C Switch (freon)
  209. AEM C.A.I. trouble
  210. need some interior ideas
  211. Hood scoops, fender inserts, and those goodies...
  212. Stock 02 Civic EX VS. 2 Different Preludes... Civic wins
  213. chicago or northeast ohio junkyards
  214. Waterspots
  215. Help, need to fix: Gauges and Odometer remain off?
  216. Wheel Switch
  217. anyone know?
  218. 1991 Honda Accord Windshield Wiper Motor-HELP!!!!!
  219. taillights
  220. DIY: SOHC TypeR Valve Cover Replica w/ Pics
  221. blinkers
  222. Cleaning yellow headlights (pics)
  223. what size socket for the crankshaft pulley bolt?
  224. Replacing headlight bulbs
  225. Fixing Painting
  226. Compression and leak down test
  227. DIY for the Turbo guys: Bosst Leak Testing
  228. How to install Intake?? HELP
  229. 96' accord how low can i go
  230. distributer spark plug wires question
  231. size of a front caliper bolt for 98 Ls Integra
  232. Removing Engine
  233. Installing new head unit 2004 Civc Cpe
  234. Right side radiator fan starts up!
  235. Painting cylinder head cover
  236. Type R wing...
  237. 92 Accord oil pan removal - can't get past tranny
  238. civic/ del sol side skirts?
  239. DIY spring install BIG PROBLEM HELP
  240. Tricky.. But AEM EMS homemade?? DIY?
  241. weather stripping help
  242. Lowering our '00 Accord
  243. Tokico Shock Install Help!!
  244. 96-98 hatch/coupe civic power window conversion/intstall
  245. Maintence required light yellow
  246. how to get specific error codes from engine check light system?
  247. D15B7 vs D15B2 crank
  248. Paint
  249. Red Emblem
  250. electrical problem-help!!!
go
