View Full Version : Do It Yourself
Pages : 1 2 [3] 4 5 6 7
  1. MSD problem? Read
  2. Seafoam writeup <56k Beware>
  3. Don't see your thread? Read why!
  4. 4th Generation Accord Main Relay Replacement
  5. some help with halo projectors????
  6. Installing APC side marker lights onto 1990 Honda Accord
  7. Sohc Detailed Engine Assembly Guide. Link? Detailed Online Manual?
  8. you guys have to chill yo i work 12 to 2 in the morning
  9. Civic 01 Coupe - Rear speakers installation
  10. Alternator and coolant check
  11. 94 ACCORD: DIY blackhousing headlights???
  12. '96 Honda Accord EGR Valve
  13. 95 Civic Passenger Window Problem
  14. help: installing a window in 99' civic
  15. painting already painted skirts, help please
  16. custom shift light question?
  17. changing cams and pully wheels in 01 civic
  18. Missfire.. (Help!)
  19. Ls oil pan on a b16a1
  20. wipers are not stopping
  21. How much work to replace a radiator?
  22. does anyone have anything that they want to sell
  23. DIY 95 accord. clean out your dirty A$$ window switches (picz)
  24. Shift Light
  25. 92 Accord EX-R Door Panels
  26. Measuring D16 Crank For Bearing Clearances. Where are the oem sizes stamped?
  27. swap questions
  28. Rear brake change
  29. Honda Civic ECU issue
  30. Cleaning seats and trunk lining
  31. Wheel question...I guess it goes here.
  32. brake system
  33. i hate philips head screws
  34. additions planned for spring/summer...
  35. 91 Honda Accord ac/heater air filter replacement
  36. blacked out clear corners
  37. Whats mm Size of front hub nut 1996 Accord
  38. I need help to finish my RWD integ
  39. Ls-vtec Build
  40. what is this mystery oily fluid coming from the gas tank?
  41. Honda Newbie...Brake Light Problems
  42. Temperature Gauge
  43. Trouble starting 96 accord ex - waiting for something to happen
  44. Need instructions for replacing door mirror
  45. Major Curb Ramping :(
  46. clutch safety switch or whatever its called
  47. Help: Lower Control arm
  48. Replacing Cabin Air Filter
  49. Accord Coupe '03+ Service Manual
  50. How Do You Fix A Dent
  51. Problem with after Axle change
  52. removing a 4 dr 04 civic tail light
  53. MDX Rear Main Seal
  54. Cracked rear bumper HELP!
  55. Fix driver's window
  56. Help wanted: No more ventilation 90 integra
  57. Weapon-R 4 point Harness - legal? mounting?
  58. stalling
  59. Removing rear bumper 96 civic
  60. Head Help Plz
  61. Power Steering Fluid Air Bleeding 03 TL-S
  62. door panel on acura legend. need help
  63. Help! tranny leaking
  64. HELP Hydrolic line
  65. what do you think of cla mufflers?
  66. Needs some help selecting turbo.
  67. Changing my gauge colors
  68. How to Fill Transmission oil after draining
  69. how to rebuild cv axle
  70. Practicle or not?
  71. Troubleshooting Clutch
  72. How can you "kill yourself"?
  73. Rear Pad Replacement Trick
  74. discount honda parts online
  75. headlight swap
  76. Locking Hoodpins Please Help!!!!!!!
  77. Brake Light is ON in my dashboard panel
  78. 1987 Accord Brakes-HELP!
  79. DIY: ANTI-56k 5g Civic Gauge cluster speedometer odometer
  80. Novice needs information
  81. does any one know the gas capacity of a 98 civic dx 2 dr. 1.6 litr?
  82. calipers???
  83. Need assistance
  84. ABS light wont go off ...
  85. Hello... Need Help
  86. DIY HELP: 00 Civic Sunroof
  87. DIY: 15 minute Axle Replacement
  88. AC problems on 1995 civic ex
  89. cold dying battery needs advice
  90. DIY newbie
  91. Broken Door Handle-help Please
  92. Why are my tires leaning in?
  93. 87 civic start up problem
  94. V-FORCE POWER CONTROL MODULE and ZEX
  95. Installing ignition kill switch
  96. new headers in a 94 accord
  97. 1990 Honda Accord project car. Need help!
  98. Removing tint: the tarp, spray bottle, and sun method
  99. removing rear bumper cover
  100. 1990 Honda Accord tail lights
  101. DIY: Custom Bucket Stock Seats?
  102. 86 Honda Accord needs 100 key turns to start
  103. Acura legend 92 crank
  104. blower motor replacement on a '96 accord
  105. B16 swap guide
  106. DIY Tails
  107. vaccuum power booster
  108. Stuck Transmission Drain Bolt
  109. 00 Si to 95 Dx Power Swap???
  110. Stripped Valve Cover Bolt/Thread
  111. Help! Broken Manual Window on 96 civic dx
  112. 95 Accord fuel filter change.
  113. How to make a back seat in a crx...
  114. Honda accord 91 SE 2.2
  115. Can't breath!
  116. Dash Cap question
  117. Antenna on 99 GSR
  118. open up tail lights
  119. JDM Engine????
  120. [b]slow civic dx need more power please help[/b]
  121. Replace Bumper Cover for 2002 Civic LX 4 door
  122. tranny flush accord 01 v6
  123. Honda Accord Lxi 89: trunk won't stay shut
  124. Seatbelt Swap.
  125. my subs purr and thats not good
  126. help on removing the fenders from 95 integra
  127. i have a leak in my trunk
  128. Anyone used GM Syncromesh in there tranny?
  129. 88 CRX....door problem....help
  130. custom dash lighting
  131. Clear corner lights
  132. Need: DIY Integra GS-R Clutch
  133. Coolant loss after Water Pump Replacement
  134. door panels removal 03 civic
  135. side skirt help
  136. Damm Alarm Systems!!!!!!!!
  137. help programming a new keyless entry remote. . .
  138. 98- 00 accord alarm/RS DIY
  139. DIY AEM short ram intake????
  140. Replacing an oil pan gasket in a '97 CRV
  141. rear disk conv. on 88 crx
  142. carburetor and fuel vaccum line
  143. does anyone know how to take out a very large dent in my car?
  144. ACCORD 00': Speedometer Paint
  145. Which oil filter wrench do I use for the small honda oil filters?
  146. cv axle
  147. How to disassemble Acura CL doors?
  148. Great i got done and now 1 problem
  149. does anyone know a cheap place to paint?
  150. EXT: Painting Trim
  151. switching power antenna for a manual...need help!-94 accord
  152. PS2 R1 and R2 buttons on shifter?
  153. Alpine TypeR coax. wont fit in the rear of my G3? (Integra)
  154. need help to install new radiator: 94 5spd civic
  155. Hard to shift
  156. 99 Civic Side Panel removel
  157. 88 crx fuel pump
  158. 95 ls thermostat replacement
  159. Help! Adjusting headlamps
  160. Putting my B series on the engine stand...
  161. best way to remove tint?
  162. Help with Car Alarm installation
  163. Can Anyone Advise On This Bodywork
  164. remove car radio
  165. 2000 Civic front Bumper
  166. how do you cut the springs on a 98 civic dx 2dr
  167. 92 Accord EX Wagon Hatch Struts?
  168. which one should i get first an exhaust or an intake?
  169. wiring help?
  170. If you get the b16 engine do you need a trans too if its manual?
  171. 89 Lude 2.0Si Auto to Stick
  172. How to remove rear seats from 95 integra
  173. Odometer stopped working...any ideas?
  174. Spring Rates
  175. How Do You Cut The Springs On A Car To Lower It And..
  176. How Much Would A B16 Engine Cost To Buy And Get Installed
  177. 88 civic pad replacement
  178. 90 Accura Legend Automatic Transmission
  179. Shifty Lowering Of Car !!
  180. replacing front turn signal on 95 accord
  181. Clutch repair question
  182. DIY throttle body,fuel injector and combustion chamber cleaning. has anyone done it?
  183. is there a way to make my clutch pedal looser.will it improve the driving?
  184. shop manual question?
  185. crx thermostat WHERE IS IT LOCATED?
  186. Replace Fuel Press Regulator - Integra
  187. 93 accord blower motor
  188. b16 install questions and answers
  189. How do you wire a switch installed on the steering wheel?
  190. does shell damage cost a lot to fix?
  191. hole on the inside of the exhaust
  192. is the car worth fixing.it runs beautiful though
  193. my clutch is not sencitive enough
  194. will my passenger seat fit?
  195. I was in an accident with my 98 civic help me!
  196. Replacing Clock Bulb on a 2001 Accord EX-V6
  197. DIY Red out tail lights on my Integra.
  198. mixed coolant with tap water !!!!
  199. too much engine oil or transmission fluid?
  200. ECU Modifying? Anyone?
  201. Speedometer troubles
  202. door lock bad on civic
  203. help a gal out PLEASE
  204. 1999 1.8 IS Accord Oil Filter
  205. Help!
  206. Help!!! Drivers side mirror replacement
  207. "how to" bleed clutch?
  208. I gotta big ole hole in my......
  209. Checking Fuel Injectors?
  210. How do I convert my manual Windows to Power Windows?
  211. :mad: this is getting old
  212. do any of you know
  213. DIY for the foglights?????
  214. 89 Civic Gauge Question
  215. i still cant find the damn thing!!!
  216. Fix 96 accord door that wont close
  217. How to weed out RETARDS like "" sno "" Shmoo "" Teg92 ""
  218. what the hell can someone help me out?
  219. 93 civic lx, engine won't start; numorous questions
  220. Window Gets stuck halfway up or down (HELP!)
  221. Help Please - Valve Lifters Gone?
  222. installing SS brake lines in 02 accord
  223. Tire Presure
  224. D series swap problems
  225. Cold Cathodes in Car?
  226. 1996 Accord Automatic 4 cyl installing Transmission Fluid cooler
  227. Cooling/thermostat. Hot air inside car
  228. Help!!! Timing Belt off with camshaft or crank not aligned
  229. lighting problems
  230. DIY ECU Chipping Kits for OBD0 / OBD1
  231. :confused: A20A3 needs transmission
  232. header question
  233. HID upgrades
  234. Help!!!
  235. 90 accord tack wire
  236. 89 civic motor swap help!!
  237. oil filter seal bursting.. need help!!!!
  238. 94 civic radiator flush -- help
  239. Installing Mugen 4-2-1 Headers on 98 Accord
  240. Is a centered single wiper a possibilty on G2
  241. interior dash lights not lighting up
  242. cleaning tinted windows
  243. No door Keys!!
  244. HID projector compatible
  245. tinting windows
  246. aux input question
  247. Speaker wire + and -? 94 EX
  248. Replace 91 Accord Passenger Door Handle
  249. 01 Civic Heater/Ac problem
  250. DIY 6th gen Civic suspension
go
