- fuel pressure
- d16y7 and d15b ecu's
- How to check my Acura 92 integra tranny after wreck?
- Help with b16 head!!!
- Allmotor biuldup
- Are there any good tuners in SoCal?
- Ostrich Tuning
- Buddy Club VTEC VCON
- Shifter wont move
- Tuners in Socal?
- 99 b16 into 97 ex auto HELP HONDA VETS!
- EG w/H22 injector question
- swap D16 to ???
- Wastegate problem
- the 1 millionth oil question
- 4th gen accord problems
- 95 4 door integra engine swap
- 92 civic SWAP Help!!! p75 wire harness ECU with b18a
- tranmisson rebuild kits?
- fuel just stopped?
- problem changing gear
- weight
- Whats ur style
- GSR block, which head should i use?
- Should I align my GSR as a Type R?
- Summer / Fall / Spring project
- idle problems
- oil [for B18A1 motor]
- I Need Advice!!!!!!!!
- Desperate 92 Accord owner
- my plans..
- turbo ?'s
- -0.03V going to knock sensor?
- turbo Q's
- installing injectors;have question
- best place to buy K&N filter
- Help needed>blown gearbox?
- motor swap help...
- 02 sensor wiring
- Difference between ULEV and VTEC
- jrlovejoy
- b20 vtec Catch Can
- Building a turbo B18b1
- Lsvtec-gsr Block
- Cold Air Intake for 95 civic
- installing shifter bushings...need help
- Rear main oil seal in a 95 accord ex
- b18 cam gear fit d16y7
- type R trans speed sensor?????
- Test Pipe????
- Chip for H23A1?
- Is this turbo kit that bad?
- please help me Mr. Tech i believe in you
- I Need Help Please
- Bogging down
- 93 Integra WOT sensor install?? HELP??
- intake/exhaust opinions for GSR
- Radiator hose question?
- Poor gas mileage??
- what manual tranny can i use with an h23 ?
- riced
- finishing up parts list for NO2 setup, did I miss anything?
- Valve clearance setting
- 1996 accord 2.2 vtec error code 55
- Gasoline Brand
- B18C GSR swap
- grinding 3rd gear...bad syncro?
- Supercharger question?@?!
- engines for integs?
- why is my engine skipping?
- what could be wrong?
- Is my relay bad?
- Cool cheap mod!
- Help me with miss please
- external tial 38 mm question
- Blitz R-VIT
- First Build : 96 Teg LS
- Turbo size for B16a2?
- Aem Uego Vs Innovate Lm-1
- 91 Integra looking to put a b16 si r in
- turbo kit for k24 accord
- Wastegate NOT Opening/ Vacuum Problem?
- white smoke
- 1992 Honda Accord Starting Problems
- Turbo question?
- Performance muffler with low noise?
- Slow EG6!
- Boost on Weisco & eagle internals...
- B-series civic swap guide
- Need help with 99 civic ECU
- need help with codes and more
- Ecu - How Long Until Ready For Inspection
- 92 integra b18c1 swap
- b16 First gen or Second ?
- which head flows better b16 or gsr?
- tune up on 98 accord v6
- How do I change air conditioner filter? 98 accord
- timing belt replacement for accord v6
- is there a diffrence in the wiring, ecu pin out on a 2000 civic cx then other modles
- knock sensor - I need help!
- Not another Question
- 97 ls turbo hp?
- turbo
- What should I expect? (H22 turbo)
- Misfiring
- which trannys are compatible with b16a?
- 94 accord radiator
- can someone explain the engine types
- Blox vs. JDMShit Intake Manifold's
- H22 Injectors in my B16A
- B18A/B Turbo Setups?
- B18c itr vs h22a
- The weirdest problem - Any help appreciated
- 2001 Acura Cl
- 98 Civic DX Swap Question
- Please help! swap only runs on 3 cylders.
- engine code 43 [LS motor in Civic, turbocharged]
- ls/vtec comparison
- i think my clutch it goin
- new engine???
- "killer K swap"
- s2000 engine & tranny weight
- Gears don't work?? :(
- spark plug cover
- piston rings
- Secondary butterfly question/theory...
- gsr head studs
- eg hatch throttle cable situation
- Alternator Fuse Keeps Blowing On 01 Civic
- Blown B18a1... Help!!!
- B20 Block swap!!!
- 5 wire Oxygen Sensor....WTF??
- Different Market Codes??!!
- gsr ecu on a mini me?
- my car is idoling crazy 99 gsr [Swap into 99 EX]
- pistons hitting the head
- JRSC Cracked inlet
- Swap F22A1 with F20a DOHC
- inspection problems
- A Mystery For An Expert!
- P28 chipped ecu
- anyone here ever used a fields vtec controller ?
- Throttle Position Sensor
- Anybody heard of EL Prototypes
- 91 Acura Legend IAC Vavle
- D16z & D16v head differences
- 93 Del sol Engine swap!
- Jdm Itr Pistons In My Ls/vtec Set-up
- 95 accord swap
- Question about missing link
- what codes are these?????
- VAFCII questions
- help me quick
- Throttle bodies: '90 LS vs. '99 Si
- info please
- LS / GSR crank, 5 main girdle questions
- Radiator Fan does not turn on
- Where do I go from here?
- b18c in a 93 cx
- engine tuning ?
- d16y7 performance upgrades?
- Valve adjustment
- Engine
- code for the stereo
- 93 Engine Swap???
- ECU Code 14?
- will this work???
- horn keep going off!
- B18c5 into B16A2' CIVIC EG HATCH
- Which head studs to use for ls/vtec?
- Crower Econo Rods?
- Lost Motion Assembly B16A
- 99 b16a intake man on '90 b16 head?
- high compression on pump gas
- who knows torque specs for these???
- ITR engine into my B16 civic?
- speed sensor problem
- h22 wiring harness
- help me wire my gsr
- h22 harness
- How to Check Code on B16A?
- ls/vtec b20 crank?
- Gas Tank/Gauge Problem
- Problems!!!!
- what injectors should i use??
- Air and Connector Issues
- Short Life
- B18c5 or c6 into a EG
- 98 civic ex
- g2 motor mounts recommended?
- calling all honda tech's(HELP!!!!!) 97civic 4dr dx idle problems
- 2006 SI Dyno plots (before and after mods)
- ls vtech build
- need help with my 91 accord problem
- B16a ?
- engine swap on integra
- b16a b18 engine puzzle.
- Connecting rods-What's recommended?
- oil feed for turbo???
- Decent swap for $2500?
- 95 gsr swap into 93 integra.. please help
- engine swap questions
- I hate cars. (ignition prob)
- Where does this seat go?
- b16a2 to bore?
- Tranny fluid?
- Used car checkup?
- h22 turbo question
- Tempeture Shifting
- How bad can this be?
- 2 step ECU Chiping???
- 65mm Edelbrock vs 66mm Skunk 2 TB/
- 1987 integra will not start
- Vtec Hesitation
- Cams question......
- motor mounts?
- IACV Bolts 98 ACCORD V6 what size torx???
- Allmotor B20 nonvtec vs B16 both having the same tranny and mods and chasis
- What Next Need Some Help
- Identify part--and what for
- starting problem turbo d15
- 96 gsr head swap with 2001 type R
- Mobile 1 oil filters
- Starting Problem
- the right clutch
- Neuspeed Strut bar doesn't fit B18C1 swap
- knock sensor
- B16a2 Cams??
- Cel 22 help
- 91 civic swap questions???? d-15 to b-18
- how High can I rev?
- h22 tuning
- Car not Starting, Need Help!!!
- P30 ecu?
- I need some help on this one !!!
- Vin # check
- ECU 37820-p72-003
- tuner good w/ AEM ems in Boston,MA area?
- B18A intake manifold swap.
- 1997 GS-R B16b Head
- What the?
- What should I do...?
- What is spark knock?
- tb question
- B16A2 Bolt-on Mods Question
- B18A1 #2 cylinder dead + More
- ~best engine for my 1990 integra~
- Powerglide with H22a
- cheap rubber couplers?
- p06 vs other
