PDA
View Full Version : Engine Swaps, Tech & Tuning
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. Dart Block
  2. legend intake???
  3. What was the 1st year fior v-tec ??
  4. timing belt install issue on b18c1
  5. B18c1 intake on a DA
  6. An idea on a b18 build
  7. Projekt Em2
  8. water pump
  9. I Need Help...
  10. Slipping Clutch Issues... again
  11. build up
  12. My Car shakes, get's low mileage, and loses power. PLZ HELP!!!!
  13. Tuning/Dyno Results - NA B16A2
  14. Hesitation in first gear on starts.
  15. lsd axle prob???
  16. B16a valve lash specs
  17. h22a ligeal
  18. b18b vs b18b v-tec
  19. Transmission question.
  20. titanium retainers
  21. turbo manifolds
  22. oil pan.....cleaning.....
  23. 95 Accord V6..H22 Swap ???
  24. Help me with 89 Integra ZX
  25. Brake Discs
  26. Vtec question B16 & B18C
  27. rings and bearings...
  28. oil gauge....
  29. Missfire/splutter problem
  30. Legend Head/Block/Valve Cleaning
  31. Engine crankshaft
  32. Sakura Industry?
  33. B18a1 into 89 civic si hatch
  34. can this be the builders fault?
  35. New Civic performance?
  36. H22a? Honda Accord...
  37. B18a (jdm gsr)??
  38. dual vale spring ?
  39. to your question
  40. nitrous to HP question......
  41. 1988 crx engine swap
  42. HELP B18C1 troubles
  43. hi
  44. B18C5 and LSD trans problems
  45. p72 in h22a going in limp mode.
  46. blew the gsr
  47. B16 question....
  48. How light of a flywheel? [B18B1 in CRX]
  49. where to buy a good used motor
  50. Denver/Colorado Springs ek/k20 swap
  51. Auto to Manual swap-B18C into DA questions
  52. ls vtec turbo
  53. Exhaust Manifold Cover Question
  54. engine and trans swap help
  55. I cant seem to put a finger on my problem... violent engine shake when cold
  56. Coolant problems??
  57. SI B16A2 Swap
  58. Recommendations for engine internals learning
  59. Will it fit? Jackson Charger, H22, in a 99 civic
  60. Will it fit? Jackson Charger, H22, in a 99 civic
  61. Typer For Sale
  62. Typer For Sale
  63. Can someone help plz
  64. How much boost?
  65. help me with my swap B18C1 INTO EG HATCH
  66. HELP: b18c1 swap into my eg 92 civic hatch
  67. 1986 Acura Integra engine swap
  68. state referee and engine block #?
  69. car wont start please help
  70. open header
  71. Will this p72 ecu with hondata work for me?
  72. State Referee question?
  73. i need sugestions
  74. B18c1 head swap onto B18B1
  75. Is This Possible???
  76. Tornbonator?
  77. b18b1 into 91 civic!!! help
  78. honda civic hatchback 1990
  79. now thinking h22
  80. h23 teg
  81. Noobie needs some swap help....
  82. Aluminum flywheel on F22 motor?
  83. engine swap help
  84. 97 ek hatch
  85. EG hatchback
  86. best suspension for 93 civic hb/h22a1 swap
  87. um it broke
  88. 95 h22 lude egr problem
  89. tuned ecu
  90. throttle problem
  91. OBD1 ecu on obd2 motor??
  92. Whats the best upgrades?
  93. Base Map?
  94. Who's got the lowest prices on new OEM Acura parts???
  95. b18c1 gsr or b16???
  96. 94 integra gsr
  97. Turbo Question for my Accord
  98. any tricks to removing wiring harness?
  99. Vacuum Leak Check
  100. B16a2
  101. broken screw
  102. is this really a GS-R tranny?
  103. Vtec cut off
  104. help for my wife !!!!!!!11
  105. Need input from all who wish to help...
  106. Question about fuel pump
  107. ST Chip Tuning
  108. Run in?
  109. Which One??
  110. Over-heat engine block
  111. lsvtec turbo
  112. Ebay chips
  113. power in a civic
  114. need help with crankshaft pulley
  115. ls vtec build
  116. Does anyone know of a shop on oahu that Dyno Tunes?
  117. 06 Accord - Putting it in neutral
  118. Engine Break In
  119. Just a quick question about my DA...[B18B1 swap]
  120. King Bearings
  121. Honda engine bearings......OEM versus ACL?
  122. engine nocking
  123. can an ls ecu be wired for vtec?
  124. 96 prelude H23a1 to H22a Swap
  125. Can i keep a/c + p.s. with my turbo setup?
  126. pms tuning
  127. need a d16z6 engine wiring harness
  128. boost a b16a or ls
  130. need help with abs please!!!!!!
  131. What will i need?? bOOst Q
  132. Which tranny?
  133. 92-95 civic hatch w/ h22a1 swap
  134. Noob Question
  135. what ratio fmu do i need for a b18b1 94 integra
  136. Wont Start, Gas Draining Sound???
  137. Turbo Charger for 03 NSX
  138. Weird whining noise from under hood
  139. Knocking under the hood..
  140. zc tranni and clutch
  141. best swap for a 90 civic hb
  142. B18C Stroker in a EG
  143. Damage Other Than Blown Fuse ?
  144. b16a1 engine wiring harness
  145. b16a
  146. having 88' integra questions
  147. d16y8 trans
  148. valve lift
  149. b18a1 with si tranny
  150. 1995 del sol engine swap trouble
  151. Obd-?
  152. engine swap
  153. C27A4 internals
  154. cluster problems 98ls
  155. EJ8 to EM1
  156. engine swap
  157. What cars do the b16 vtech's come in?
  158. Swap Complete Car Won't Start Help!!
  159. What Can I Put in my car.
  160. DA gsr bogs in gear alot!! PLEASE HELP!!!
  161. Transmission fluid for Honda/Acura
  162. d15b7 to z6 swap info
  163. 99' 1.6 ex motor into 91 EF9??? help
  164. K24 in an EG.
  165. What would produce more hp power...full b18c1 or lsvtec
  166. 99 gsr 5 speed help
  167. 1990 honda civic hatch won't start!!1 HELP!!!
  168. 1999 Civic EX
  169. s9b .vs. y21
  170. can i swap a b16 into an auto 93 civic dx??
  171. Compression
  172. GSR block on Si Head
  173. engine swap
  174. Engine head difference?
  175. D15b Vtec Sohc
  176. ECU??????? help
  177. d15b
  178. Engine swap
  179. f20b
  180. type r internals
  181. B18a Swapped for B18B
  182. EG civic hatch
  183. if you have a b16 i need your input please..
  184. 1991-1995 JDM Honda Civic SiR/SiRII (EG6/EG9)
  185. swap info
  186. Quick question 96 motor swap
  187. best way to locate cylinder causing bubbling
  188. help with plastigauge readings....
  189. DA Integra with a K24 swap questions ???????????????
  190. ? About B16a
  191. 91 civic
  192. Need help swapping a sh H22a4 motor
  193. Jdm GSR AUTOMATIC REDLINE?
  194. B16a?
  195. Whta Do U Need 4 B16a Swap
  196. 2002 CRV check engine code P1167
  197. b16a-b18c1 hybrid questions
  198. K20Z1: How much nitrous will it handle?
  199. h22 into 5th gen accord
  200. B18b into a 1990 Integra
  201. 1995 civic dx engine problems
  202. B16 Engine & Tach jump over bumps
  203. Zc Swap
  204. Mechanical water gauge in LS integra??
  205. D16 Throttle Body On B16 Is It Possible??
  206. Need Help With Posable New Temp Swap
  207. Engine swap
  208. broken clutch release bearing spring???
  209. Top Mount Turbo Mani
  210. 90 crx swap question
  211. B16a Or B18c1 Or H22a Swap In 91 Civic Si
  212. missfire problem...
  213. legal or illegal???
  214. b20 vtec
  215. 2.0L road
  216. B18c5 pistons in B16a1
  217. catch can question?
  218. 96 civic enging studdering problems help!!!
  219. Help 96 Civic swap studdering Help
  220. cat backs
  221. A cuple questions about rebuilding...
  222. k20 base into eg
  223. H23 Tranny Won't Bolt Up To H22 Engine..
  224. H23 to H22 Swap Help
  225. Which Turbo For My Setup?
  226. clutch [B18A1 in 1988 CRX]
  227. d16z6 engine swap [into DC* Integra]
  228. 94' Acura Integra LS not firing
  229. H23a3 idle
  230. Which cams for my setup...
  231. ITR manifold vs Skunk 2
  232. Help needed on engine swap 95 accord
  233. BUddy cLub v-tec controller
  234. n00b D17A2 engineering
  235. turbo an f22a??
  236. Anyone ever seen one of these in action?
  237. C27 owner... a few questions
  238. b16a2 motor wanted
  239. Civic SI with GSR Motor - WHAT AXLES?
  240. No start condition, no power, will not turn over
  241. CEL 4 Question.
  242. Vafc Troubleshooting
  243. Which Software are you guys using
  244. Accord vs Civic
  245. Swapping in a 99 EX
  246. 95 gsr idle problem!!!
  247. B18C1 into my hatch
  248. swap advice
  249. were is it
  250. B16a2 compression problem
