- Bearing selections
- Where has ANDY gone??
- wiring questions for a B18A1 swap
- Nordskog Electronic Gauge Sender
- injectors for b16
- Clicked of a 13.8 at the track saturday.
- b series oil pressure.
- bad valve adjustment maybe???
- engine overheats with turbo going uphill
- popping noise from exhaust
- Oil Sending Unit for Autometer Gauge
- rsx tranny on h22a4
- What kind of valves should I get?
- Header problems...
- vehicle speed sensor help
- engine swap question!
- ITR Rad Swap
- Throwing in a supercharger
- radiator ?
- Valve Springs
- Timing Belt - 1990 Legend
- obd1 vs obd2 b16
- b18c1 into a 90 Integra LS
- Swap Update* ANDY
- Need help with CEL
- h23 in 92 accord
- GSR im vs Type R im
- Turbo Kit For Itr
- different style injectors
- trying to jumpstart.. sets off alarm
- Air Fuel Ratio Tuner
- swap question
- Just put my new clutch and flywheel in...
- PR3 Distributor
- PR3 Distributor
- Which cams are which, Type R/GSR?
- Motor Swap Or Car For Sale
- Power
- searching help!!!
- Inline vs Horizonally Opposed 4?
- Ecu ??
- Last question on this, I swear
- Enigne swap done. Not running right though. PLEASE HELP ME!
- Engine Rebuild break in mileage??
- Swap Not working, Please HELP
- b16 ecu questions.
- What Lube to use when rebuilding motor?
- Power from a bult up f22a4?
- Running Rich???
- what is your input?
- Good websites for buying engines
- Finally.
- Resignator
- Gen 1 Integra Swap
- Labor Charges
- No axleback = better mileage???
- hondamotorsonline?
- i've risen from the ashes.............
