- Is it possible to build a b18b1 block
- Need help on a chipped ecu ASAP...
- Simple question about dyno's
- is a b18c better than an ls/vtec swap
- All Motor or Forced Induction?
- hesitation before 4000rpms?
- Starter and some other probelms
- Air/Fuel Ratio Guages....
- cams discussion
- A/c?
- what is spark plug gap?
- More trouble..bogging
- It runs!
- sc and turbo boost
- cat or test pipe?
- Speedometer wrong?
- Cylinder dead porting
- When should I clean the filter on my CAI?
- Will adding a tranny cooler help my performance?
- Cause knowledge is power.......
- Type R Pistons Good
- How Do You Guys Mount Your Blocks to Engine Stands?
- Throttle cable
- Zex
- 95 V6 Accord valve knock
- what brand oxygen sensor to use
- car seems to want to turn off when i stop
- bad bad situation
- HELP!! I need a CARFAX Report on an H22 Accord
- GSR Turbo on a 95 teg SE
- Hard Clutch
- how much more boost can my d16 handle
- Fluctuating idle
- RX7 Engine Swap
- CEL 36???? what is this??
- possible rethread of block need informed advice!!
- H22a w/ Turbo and NOS Posiable?????
- Pls bear w/ newbie quest: TURN SIGNAL not working
- stop
- Engine apart, need help
- Running Rich...
- could a wrong computer
- s2k engine in a gsr
- SRR SOHC VTEC Flywheel
- still got lag in 4th/5th gears
- Turbo on a b18c3
- need a new starter...help
- how to fix lag in 4th/5th gears
- FoHeavens Sake!!!!
- transmission /Lsd
- Hey you guys in CA need some info regarding smog with a swap
- when running nitrous...
- NE1 here w/ a B20B and Crower cams?
- project h22 civic/ t3/t4 turbo....
- some balancing questions.
- Upper radiator hose connection... help?
- what spark plug and wire set fits my car the best
- Valvoline Throttlebody cleaner SUCKS AZZ...need suggestions
- SC's
- Lookie what the UPS man brought me
- K&N Crankcase Vent Filters ?
- Who can guess the reason for my low compression #'s?
- wtf... this timing belt is a joke.
- noisy cai
- On a b18b1
- new rods and pistons
- rev limit
- 91 CRX, 99 sohc vtec swap HELP -injection
- what the heck is up with my lights!!!!
- tune up at home.
- An inquiring FI question?
- Piston 1 TDC???
- ls no vtec
- 94 Accord LX Suspension HELP!!
- QUICK HELP.. distributor replacement question
- Just had all my valves replaced
- H22 into a 5gen hatch?
- may b stupid question but doesnt hurt to ask
- LS/VTEC Timing Belt???
- need assistance with turbo
- Header wrap
- D16A6 idle questions, and also wierd smell
- I need a favor all nitrous people please read!
- IAT Question
- tranny fill-up
- Quick easy udgrades?
- JG Edelbrock VTEC manifold
- price
- machine shop experts... block fixable????? *pix*
- Just bought a beater Hybrid
- Where can I buy a VTEC solenoid?
- Auto shift-shock
- Exhaust question
- Flywheel bolts backing out--please help
- Flywheel bolts backing out --HELP
- dual-point to multi-point injection?
- b16a, easy swap?
- Need a harness....
- hesitation in VTEC
- Need help bad! Engine Hesitation!
- radiator problem
- where should i post gb info?
- Ordered engines -> damaged?
- Buying Used Turbo Setup Help
- PS pump on an H22 in a 4th gen Accord...
- time for a head gasket...use a thinner one?
- 3" exhaust for h22a?
- Running lean, out of ideas...
- Wiring Help!
- Anyone have a B16 hybrid civic? with a mugan OBD1 ECU?
- where to get 600cc injectors
- Flickering Check Engine Light
- which intake is better
- This Sucks
- 3rd gear synchro ?
- which wire to check codes on a 94 civic ex?
- OEM Turbo Hondas ? ? ?
- B18B drop in 93 civic hb cx-- questions
- Turbo
- which slave cylinder
- should i put vtec head on dx
- sohc vtec swap into a CRX, need help
- Wannabe hybrid, need advice please....
- Rollerwave Pistons
- SPOON 70mm throttle body
- how do you tell if a motor is stolen???
- Cel 20 (eld)??
- type-r gauge cluster
- Venom 400 w/ cam gears?
- dual exhaust
- My car has an attitude.
- multi-point injection into 91 Civic LX
- b18c/b16 series cam brace on a b18b (big pic)
- Eng. Swap
- Valve adjustment
- h series vs. b series weights ...
- 94 Civic Crank Pulley
- OIL leak Woes!!
- Fuel Injection Question
- black smoke??
- SOHC to DOHC
- USDM B18c1 in 6th gen coupe
- b16b... questions..info?
- 1991 Integra... won't crank
- ReBuilDing my b16, nEed suGGestiOns!
- Muffler piping for N1 look??
- Hesitation & Jerking
- Car wont start.
- place racing mount kit?
- Auto to Manual difficulty?
- honda pics @ http://members.lycos.co.uk/thanhng/
- ECU pins/connectors
- B20/vtec teg/GSR
- filler neck
- engine timing question
- Bad to turn A/C on/off a lot?
- Civing dying while driving. (help 1stGenCrx!)
- headers on 96 civic dx?
- Prelude Crankshafts
- K20A2 engin swap with K20A3
- b16a redline
- GSR tranny
- 2.3vtec oil jet discussion
- Which cam is the best for a bolt-on D16?
- 8valve to 16valve head swap?
- Brake swap question.
- Reverse?
- insurance buy back question didnt know where to post
- Ignition Timing
- Fuel pump problem?
- Apexi question
- nitrous safe on an old motor??
- My set-up
- b18c swap into civic coupe
- Gearbox Shake
- who has ls/vtec
- Prevenitive Matanance Time!!!!
- what is R/S ratio?
- VTEC selenoid
- adjustable headers?
- Please help ASAP
- Ls/vtec intake manifold
- hard starting
- nonvtec-vtec head?
- new Spoon cams in, car falls flat on face in VTEC
- Type R B18C5 swap
- Help!
- LS cams, and B20cams, is there a difference?
- Integra Gauge Cluster - Civic Dash
- light flywheel...do I need to rebalance the crank?
- 97 Civic EX SRS Light (HELP!!!!)
- How to calibrate speedometer for bigger wheels?
- B16A Swap In 91 Civic
- Internal mods for a NA vehicle
- Knock, Knock...
- Civic Recall Notice
- 99 prelude check light
- Saw >><<the>><< Sickest Civic
- When do I need to modify fuel flow?
- Exhaust backpressure ? good or bad ??
- will a VTEC oil pump improve oil pressure in notec engine?
- NEED HELP...car wont start..firing order???
- knock sensor readings....
- zc running rich, please help!
- exhaust / muffler question
- What does thevtec solenoid look like???
- Throttle body question?? 96 integra
- where is the ECU located on the 3.2 TL?
- Import parts for sale at Air Flow Design soon.
- Need some help
- want quick accel
- exhaust shaking
- B18c in a 92 Si
- Swapping headgaskets is fun...NOT
- too many choices, btm's
- Major projects - feasable?
- no power
- what do you think of this tranny setup?
- plug and play harneses" are ther any
- what kind of probelms have peole ran in to whiel installing h22's in a 5th gen accord
- timing
- 88 civic with b16a, What Knuckles do I Use??
- Need Help W/ Nitrous ASAP
- Why isn't my power steering working??
- oil pump
- Is the 96-99 Intake Manifold Throttle Body, and Injectors better than a 92-95?
- what timing you people often talking about ? ? ?
- Help please with friends 97 Accord LX & aftermarket ignition system
- How flat does the Deck hafta be?
- Curing fuel starvation?
- Idle Problem, someone please help
- Tuning
- Nearly every Honda USDM, JDM and EDM engine code
- stock parts balanced?
- Turbocharging a 2G Teg, new motor or rebuild?
- Throttle Body Gasket????
- need help...please
- 81mm or 84 mm b16a?
- Code Identity HELP
- CTR or ITR pistons in ls block?
- 91 civic transmission question
- Skunk2 manifold inlet size?
- 11.5:1 Daily Driver?
- What is everything I need?
- type r pistons
- Water Injection systems...
- Where to Buy Engines?
- distributor internals? b18c/b18b
- All you hybrids..
