- door swap
- Motor Builders! Your opinions please?
- Car won't start after installing new cams!!!
- What ECU should I get?
- Engine codes...?
- Question about B20s.
- B16b just arrived..
- Greddy Turbo vs JRSC
- b20vtec valve clearance and obd???
- Tips for reducing wheel hop and gaining traction
- Looking for a stock D16 dyno chart
- OBD1 and OBD2???
- Where should the money go?
- advice on this setup please
- B20z Auto, Will A 5speed Bolt Up?
- whats next?
- 98 gs-r running sluggish/puttering
- Best to Build
- do they make high compression gaskets for non vtec motors??
- swap/conversion is almost done...
- Come on... Tranny suggestions? ;-)
- 96 civic hatchback CX w/ B18C1 motor- stripped - bolt on's and 8psi - how fast?
- not an engine question...braking question
- shot peening?
- Shipping an ECU
- Headwork question!!
- 1st Gen B16a1 into 92-95 Civic Si???
- Which Variable Valve Timing is better ? ?
- 60-1 Turbo but no kit! =(
- 95 D16z....need help
- B20vtec vs. B18c1
- High boost valve sizes?
- MSD ignition help
- Momentary loss of power
- LS Vtec
- 95 integra ls engine?
- B16a Valve sizes?
- big block of metal from Minnesota to Huntsville... how?
- which is bigger?
- h23?
- wiring a 4 wire o2 sensor on 1 wire harness?!
- Code reader
- H22a
- Sleeving the block
- Hondata questions
- I'm stumped...
- what do you think?..
- 4th Gen Civic ?'s
- Older Honda Car, looking to use ZEX kit
- Just bought CTR cams...
- b16 vs b18 block
- would this be possible?
- Shifter skewed!
- Best engine for a 6th gen sedan?
- Acura TL-S piston problem
- Deep Engine Wisdom
- shaved head
- Building B20
- CRX HF EGR location?
- Difference between Integra and Civic Rear brake discs? Urgent
- Swap with '94
- Ls Vtec Swap Info
- 86mm pistons...
- hybrid question
- Low idle condition!
- help!!! car & motor problem!!
- who ever says lsvtec aint worth it can shove a dick up their @$$
- internals question
- This turbo with those pistons?
- GSR swap times
- quick ecu question
- What causes a car to burn oil?
- h22a civic swap??
- h22 civic swap??
- how to check timing?
- Can lightened crank pullies help?
- new radiator problem?
- Need some help
- o2 sensor
- Honda School?
- Intakes
- what are the differences t3/t4 and t3, what does the ratio .48 ar .49 exa
- Alternatives to the T3/04
- doh....oil leak.
- Engine piece broke help!
- JUN ecu chip!
- intakes.
- stupid ebay
- Denso Iridiums quick Q
- how do i wire up this swap ?? 92 civic and 92-95 jdm b16
- i bought my f22b1 AEM rail used with no bolts..what's the thead size of the FPR hole
- D16 crank and B16 crank question
- Cam Seal - 92 Accord
- Check engine light with turbo
- oil return kit
- intercooler question?
- new AEM intake design...
- interesting k series swap dilemma
- Need info on bore size?
- JRSC + NOS ? Anyone Done It Here?
- Can't get 91 octane, only 93. Quick questions...
- Double checking about Valve cover gasket
- Grounding? is it done and will it work..
- Engine Swap
- new to this!!
- Poorman's Type R plus boost?
- Any gear ratios better than Type R?
- exhaust for swap
- Which Tranny to get?
- another turbo question
- home compression test
- how do you know if your valves are too tight?
- B16a2 block, new crank
- 92 civic VX wiring to DX motor please help please !!
- 5G hatchback swap
- XS Engineering Turbos?
- H22 Owners
- If CEL goes out is the problem gone?
- intake manifold question
- more ls/vtec questions
- H23a
- i have a 94 teg and on the engine there
- What is a resignator?
- Removing the dreaded immobilizer...
- my hybrid seems to hesitates on acceleration..
- Let's calculate my c/r ;-)
- tranny issues
- another ls/vtec vs turbo ?
- how much can 6 psi of boost
- when installing a turbo
- 96 integra GSR check engine codes?
- LS vtec?????
- Insight valve adjustment specs needed.
- DYNO WHP for LS automatic...
- Figure my compression(milled .0030)?
- brake Question
- What's the Difference Between BPT and BSPT?
- Need help w/ V-AFC settings on built all-motor H22A
- Welcome our newest mod
- Cams and cam gears - explanations?
- Turbo questions
- Turning a B16a2 into LS/Vtec
- Water Pump question......help?
- D15z1 on a D15b7 block help
- How Much?
- engine help
- check engine light come on and off
- Putting 1st b16a swap into 3rd gen Teg...
- Ewww... grinding...
- Please Look
- SOHC port and polish problem...
- Does it matter if i buy a ecu that came from an auto for my 5spd....
- Help with coolant leak!???
- Difference Between H22 and H23??
- No Heat!
- Vacuum Hose in tranny fluid?!?
- 2000 ITR head on 1st gen b16?
- car will turn but no start !!
- My check engine light came on but went off.
- A Gsr... (you Wont Belive Till You See) But It Has A V10!!!
- what would you pay for this engine.??
- what would you pay for this engine..??
- little bit of exhaust smoke, but not burning a drop of oil...
- D16 Hybrid
- A/c Recharging question!
- what do you think
- Prelude S F22 upgrades
- Oil Pressure
- Black crap coming out of exhaust...
- Engine rebuild kits???
- FPR setting....????
- labor?
- Hyundai injectors?
- My 1/4 mile time
- Torque Settings!
- exhaust leak/ vacuum leak?
- Clutch won't fully disengage? EEEK!
- Very Useful Info For Doit Yourself Motor Swap (mainly For H22 Swap Into Accord)
- '99civic swap w/ '98 GSR
- Accell DFI Fuel Management System
- not startin'
- What are the differences in these engines
- When doing the H22 swap into a 4th gen Accord....
- Internal engine questions
- Compression questions
- new head gasket...mill head AND block?
- Exedy pedal feel
- Good sites about engines
- rethreading of block complete
- need some help with rpm
- TWM! on a d16a6?
- LS/VTEC Cam recommendation...
- need a new project..what to get
- h22 Tranny QUestion
- Nitrous B16
- how grounding is done ? ? ?
- How many miles on your LS/VTEC?
- does anyone know all the parts req
- is their a book that
- Ultimate Setup
- JRSC, worth it?
- Engine killing in warm weather, opinions?
- My 1/8 mile time
- ZC Auto???
- What aftermarket gauges are important?
- Help me find an oil leak ;-)
- Well, finally visited the strip for the first time, and well :\
- need help now, badly leaking 86 CRX
- turbos turbos turbos
- My swap has come full circle...
- what does everyone think about ls/vtec
- does anybody know any shops in seattle wash
- with a ls/vtec swap what
- Balance shaft belt removal
- aftermarket INJECTOR & cam gear Q's for b18b
- Injectors DON'T FIT...
- Fuel rail for a 94-95 b16a2 from a del sol?
- Hole in my throttle
- after accelerating to 120+
- Dd2000
- Aem Ems...
- weird third gear hesitation
- Fluidyne Integra Radiator in a Civic?
- b16, b18b, & b18c have the same starters?
- motor swap vibrates.... ?
- Were Can I Find A Good Sc?
- when do u know u hit vtec
- Fuel Pump Question
- smoking in higher rpms
- help pulling my d16
- Fuel Injectors
- motor mounts
- idle probs
- vtec care?
- boost w/ stock pistons/rods&1mm gasket?
- help, can't fix my problem
- Long race, what engine mods so won't blow up?
- getting a b16a2
- NEEDED: Ideas for 13sec. Civic Sedan
- how high can you rev a b16 with..
- water sucked into intake.. what now?
- 50 shot of Nitrous?????
- 86 Civic engine swap
- has this been done before?
- UNHEARD OF trouble code! Help!
- higher compression for b18c1
- takin out the ac fo the winter
- B16b ecu pinouts
