View Full Version : Engine Swaps, Tech & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34
  1. Hey im new here B18c1 gsr hatch engine question!!!
  2. D16a6 head bolt Q
  3. Wanted: Tranny Swap, Please Help
  4. Buying a used eclipse stock turbo
  5. fast foot...
  6. MrFatBooty is a FAKE!!
  7. Ls/ VTEC (how the **** to you get the head bolts off)
  8. h22a complete price break down
  9. hp output on stage 1 skunk cams?
  10. For a higher redline you need the following....?
  11. what's the deal with crank bearings???
  12. need this part ASAP
  13. wierd question
  14. Non-starter after timing belt job
  15. Help with Spark Plugs
  16. Why is horsepower per liter (hp/l) so popular?
  17. All you people with 96-98 JDM B20B or USDM B20B. Look here please... Compression theo
  18. Custom Turbo Kit Recommendations for 2.5L Inline 5 (Vigor, 2.5TL)??
  19. B20 Crank Pulley or B16a Crank Pulley for B20b in a 93 Civic CX???
  20. B20 Crank Pulley or B16a Crank Pulley for B20b in a 93 Civic CX???
  21. fuel injectors for a 92-95 Civic DX into a 91 CRX Si?
  22. turbo charging a stock b16a
  23. D16Y8 vs. Y7
  24. H22 wiring
  25. disabling the secondary O2 sensor
  26. replaced spark plugs, all 4 old ones look different.
  27. d16y7 head on d15b2? hopefully i'm not nuts
  28. D16A6 Rev Limiter
  29. D16A6 Oil Burner!!!!
  30. sorry newbie question about 2002 si seats
  31. cai on a 95 integra rs...
  32. Need: Bigger Throttle body for 88 crx si
  33. Who would win?
  34. counter balance belt
  35. help,missfiring like crazy
  36. Obd2->1 B18c1 ??
  37. Hybrid EG Pics & 1/4 Times
  38. Question about motor dealer
  39. 92-93 Integra PR4 ECU is OBD-1 and should work with B20b right??
  40. 92-93 Integra PR4 ECU is OBD-1 and should work with B20b right??
  41. little off topic, but would you guys use a mobil dyno service?
  42. Info: MSD 6AL & Blaster 2 coil
  43. Differences between B18C auto and manual?
  44. Need HELP asap!! H22a --> EG ECU wiring!!
  45. good machine shop springs/retainers?
  46. vx o2 to gsr
  47. jdm dohc zc in a 92 cx hatch help please!
  48. Will this work??
  49. Trying to re-time a balance shaft motor
  50. Intermitant idle 91 Legend
  51. fuel pump question
  52. ANYWAY to make an integra exhaust fit a civic hatch
  53. injectors.
  54. ATTN: Need help...awkward idle when cold
  55. Smog Question
  56. What exactly is "Piston Slap?"
  57. Head swapping??Help
  58. Stock timing setting?
  59. **INspyral** UPDATE!!
  60. Code 22?
  61. ZC motor swap questions for 90 crx Si
  62. b16 assembly questions.
  63. B17A1 engine buildup
  64. proportioning valve.
  65. Out of ca$h. Is 1.75 inch exhaust okay for h22a1?
  66. NooB Question about turbos
  67. Will a B16a header fit a B20?
  68. Will a B16a header fit a B20?
  69. My '92 CX/B18C1 Hybrid is for sale
  70. Can i use an ls distributor on a GSR head?
  71. Jdm Itr Cat
  72. Ls Motor Question
  73. 89 Accord idle fluctuation problem
  74. B18B lower end build
  75. Possibly IDLE problems and Bogging.
  76. quick ? about rear disc conversion
  77. age old question, but have to ask...
  78. swap question
  79. 00 Civic Si ECU Question.???
  80. price range
  81. quicky question about ecu compatibilty
  82. engine tuning/tweaking
  83. Need SMOG Help!!
  84. Need Smog Help!!
  85. CL Type S swap into a 5th gen Accord?
  86. P72 vs. P28 for my JDM B16A
  87. wire cover bolts question!
  88. diy motor mounts for b series into civic
  89. B16a2??
  90. broken bolt
  91. How to tell if it's a 99+ JDM B20B???
  92. potential dangers of short trip driving?
  93. 93' Accord vibration at idle
  94. What kind of cold air intake is available for my car???
  95. head install ?
  96. Where is the engine code?
  97. '92 'Teg Engine Swap
  98. RSX head
  99. Prelude Possible Engine Swap
  100. boosted automatic : is there a point?
  101. D15B8, whats heads are good.
  102. HELP... 99 Accord LX 2.3L runs rough when cold
  103. online factory service manual
  104. lowering compression from 12:1
  105. D-series and B-series weight difference
  106. J30, J32 Transmissions
  107. INspyral!! Need help fast!
  108. Stock HP in 99 Si Canadian version?
  109. Snap on Valve Adjustment Tool
  110. 92 Integra GS-R Header/Muffler
  111. 92-93 Integra LS Distributor work with P75 ECU for B20 Swap?
  112. swap obd1 to obd2
  113. Difference betw. Ram A.I. and Cold A.I.?
  114. Time to get serious,but i need a little help.
  115. where to find oil separator/pcv valve BOX??
  116. Help on 90 Civic B16 swap
  117. So Cali Swap Shops
  118. Doing a b20 swap into my EG. Need a few double checks...
  119. Doing a b20 swap into my EG. Need a few double checks...
  120. Does D15B7 fuel hose = B18C1 fuel hose?
  121. Skunk2 Stage1 Cams
  122. test pipe question
  123. Car hopping....
  124. ACT 6 puck clutch
  125. My b16a3 sounds like crap.... Help please, VERY detailed info included
  126. My b16a3 sounds like crap.... Help please, VERY detailed info included
  127. Cap and Rotor from b18c1 94 GSR fit b16a3 95 Del Sol VTEC?
  128. headgasket
  129. rainbow rod bearings :( part #'s?
  130. Will a first gen b16 starter work on a 2nd gen b16a (USDM Del Sol)?
  131. Canton Racing fuel filters
  132. Easy question!!
  133. help with d16y8 head on my 16y7?
  134. Engine cuts out at 5k RPM, CEL, code 4
  135. ATTN::: INspyral!!
  136. Oil Pressure Gauge
  137. Wiring Diagrams
  138. Regarding ECU Reprogram
  139. my motor is missing that plastic timing belt cover.. will..
  140. time to change my headgasket :(
  141. good credible places to buy stuff?
  142. engine swap questions?
  143. My engine is echoing at 2000+ RPMs
  144. Manual tranny problems
  145. Anyone used thse cams in a ZC?
  146. For those considering LS/VTEC...
  147. Car starts, run for while, backfires and then stalls?!?!?!?!?!?!
  148. head stud install
  149. Help Asap
  150. Engine fitting my GS-R ??
  151. Conecting rods for the DOHC ZC...
  152. idle jump when idle but jump down
  153. turbo reccomendations
  154. lost motion assembly
  155. Cam Timing Differences with D18Z6/Y8
  156. lagging while accelerating
  157. 89 Accord won't start
  158. guide me! b-series engine specs
  159. Civic with a V6???
  160. B20Z /w B16a head - ALL stock, Reliable if only revving to 7kRPM?
  161. External Coil
  162. LS crank into B16 block
  163. h22 accord f/s
  164. Weber cams???
  165. what to mod first in stock b18c1 in eg?
  166. h22a accord downpipe Q
  167. ZC swap into 1st Gen CRX DX
  168. replacing rear main seal
  169. ENDYN info
  170. intake sound?
  171. Best way to pull seals
  172. tech question on how clutches work
  173. GSR internals for lsvtec instead of CTR/ITR
  174. Alternator removal
  175. Clutchmasters?
  176. Spun a cam with the timing belt off!
  177. Spoon Cams
  178. battery light
  179. Msd Help Please!!!
  180. hybrind swap need cherry picker?
  181. 92 accord auto tranny problems
  182. what body for swap?
  183. 1989 Acura Integra LS Engine Problems
  184. HELP! Something blew out in my engine.
  185. Spark Plug Difference! HELP
  186. Help with Oil Pressure guage!!
  187. Cooling system question!!
  188. I almost urinated in my pants today.
  189. ticking noise from fuel injectors
  190. Twinturbo on Honda?
  191. Spoon Cams
  192. valve springs removal???
  193. Civic GSR owners please read
  194. Burning oil :dunno:
  195. Head Gasket 101
  196. H22 EG info needed
  197. question
  198. JUn, Toda, help me
  199. Clutch reccommendations please.
  200. need help
  201. weight, torque, labor, etc... (noOB question)
  202. swap for same or rebuild?
  203. Safe shot for 96 DX?
  204. supercharged b20
  205. G-tech Pro!!!
  206. removing broken exhaust manifold stud
  207. CRX map sensor upgrade
  208. So do you just put the new timing belt on and drive?
  209. any difference ls vs gsr injectors
  210. Exhaust Leak!!!
  211. Fuel Injectors by Holley/NOS...
  212. Valve Job
  213. Swaps are illegal right?
  214. Uhh Oh! I kinda fukced up the timing belt job!
  215. A/C and engine swap?
  216. how to disable turbo
  217. vortech s/c for b18c
  218. bad for engine...so i was told
  219. what cause turbo leaking?
  220. what size is this turbocharger?
  221. a few general questions
  222. RSX Type-S Auto
  223. Putting head back together need help
  224. The complete b16a1 SWAP PARTS LIST NO ONE ever bothered to type up, just for YOU!
  225. people with LS motors...
  226. Need help seperating harness plugs...
  227. High flow or just a pipe???
  228. Help please
  229. D16 Crank pulley bolt
  230. NOS or Nitrous Express????
  231. Custom piping?
  232. 92 2.3 Prelude Si NON v-tec
  233. clean burning...diesel?
  234. vehicle speed sensor
  235. VTEC wiring into a 94 Civic DX
  236. type r cams good for turbo??
  237. crx will not run is it spark or fuel or ....?
  238. Missing Engine
  239. head bolts????
  240. d16a and d16zc rods and pistons
  241. Crower cams for b16
  242. General High Reving machine
  243. Cam Question
  244. Cam Question
  245. Cold air intake? short ram? Question!
  246. head gasket ????
  247. Broken Gauge Needles - Fixable?
  248. Transmission case
  249. poss. n00b question - exhaust gaskets
  250. idle vibration please help
go
Search Engine Friendly URLs by vBSEO 3.5.2
