- no. 9 code in 89 teg.
- Misfiring?? IDLE help!!!
- axle seals
- Again
- 1995 OBD1 JDM B18c
- No ground at ignitor...WTF?
- My Block *pics* (56k u can try)
- Broke H23 Tranny...Now what?
- Idle Question
- b18b to b18c
- 99 Si exhaust
- Good Compression Numbers YAY
- intake question
- help
- 88 Integra LS
- Exhaust velocity/engine bay temps
- Blown Head Gasket or what???
- Is this possible/ better?
- Inline fuel pump wiring
- Questions about CR/cams/milled head/headgasket
- Hey guys first post! How do you do this
- WHere to get a engine Sleeved in CA
- RS-R Exhausts guaging interest
- Deshrouding valves, SOHC
- LSD help?
- stock looking/sounding 2.5-3" exaust
- 98 ls put in 95 civic ex ?
- B18c1 Help!! I don't know which setup to go for!!
- wrong gasket causing my vtec problems?
- b18c5 turbo in 96 civic with 94 integra conversion questions
- h22a vtec problems
- '91 CRX project
- Wiring help
- Mmmm Euro-R Intake Mnaifold
- The Beast crate engine.
- ignition problem
- Swap Question
- What would cause VTEC to drop off in power?
- VAFC pressure signal help and VAFC settings you ppl have! HELP
- Alignment problem, HELP!
- 2000 Civic EX
- 145.8HP/ 149TQ, prelude SE
- GSR rod sprayers
- distributor trauma
- wiring VTEC wires into the harness?
- Fuel Pressure drops too fast
- Blown Fuses
- 95 Civic Dx - need help replacing distributor rotor and adjusting timing.
- kinda stupid noob question
- Urgent Help Needed :(
- VAFC hook up to VTEC signal!!! HELPHELP!
- low oil pressure problem
- if someone could post a pic of....
- 350 del sol!! crazy!!!
- IAT sensor and Engine dies randomly
- temp & fuel guage died after new faces installed
- BOV question
- few question about 01 teg
- Check Engine light - Code 92 "HELP"
- vacuum probs , and ig timing
- engine cranks but wont start
- B18B1 in 6th Gen hatch vs D16YZ in 89 CRX?
- engine temp problem
- 5th gear ls/vtec problem?
- Which turbo set-up?
- Engine code -- Map Sensor
- Vtec signal wire?
- H23 Swap Problem....
- 5th gen brake swap questions!!!!!
- A/C Bracket
- need help: B16A w/turbo vafc
- extra hose??
- Good or bad turbo kit?
- ignition timing ?
- Accord injectors in H22a in 5th GEn Accord
- What engines fit the 90 4ws lude?
- H22 Swap......
- Mugen Cams?
- Limited Slip Diff?
- vtec oil pressure needed to engage?
- engine swap change in weight
- Engine build up for a turbo
- when i brake... the engine dies
- Question JDM or USDM Engines
- i need all the help i can get!
- timing problem or fried distributor?
- Stalled installing shifter bushing
- B18C => RWD car
- Is LS/Vtec worth it?
- can i?
- Is going LS/Vtec worth it?
- B16 block queation.
- Automatic Transmission ECU?
- Stupid question
- Engines not running right
- help
- what Honda radiators will fit in a CRX?
- Enigne Prob
- VAFC hooked up to PM6 wire harness? HELP!!!
- Battery Relocation Help
- intake manifold
- overheated engine, what to test to determine if it's fried?
- Throwing code 22 (vtec oil pressure) on b18c swap
- Engine Quirk
- Strange Engine
- White smoke, headgasket replaced....what else?
- How much HP can I get?
- nuckle and hub question
- 1994 Legend LS 3.2 timing Belt Blues
- How does a radiator develop a leak?
- **Ceramic/Ceramix, what's the best dust free quality pad??**
- Need Some Help...
- icebox?
- B16a/ obd questions
- Thermostat, Radiator Flush, Bleed the system?
- catalyic converter for a 92 4dr civic
- distributor question..mainly dx=ex?
- Idle problem with '84 Accord please help
- hyper ground
- Eclipse turbo?
- Help with Code 10 (IAT) in H22/Accord
- how much to sleeve block?
- **in Process Of A Swap**
- civic b16a2 swap questions
- D15b7 Mini Me Swap....D16y8??
- b16 Valve adjustments
- Bore and Stroke F23
- Stepless throttless VTEC or high revs Valvetronic
- 99-00 civic si ecu pinout diagram
- Really important!!!
- Octane rating vs Timing
- LOOK!!! Crazy Lookin Inatke!
- How to remove power steering
- cam questions
- AEM intake problem?
- Big trouble starting...please help.
- if ur good with technical terms help me out
- Turbo Self Install or not?
- What is da port and polish????
- Awd Crx??
- 95 ls teg transmission probs
- 94' Integra LS turbo VERY rough idle and stalling
- 95 teg overheating
- Jun III cams in a GSR?
- b16a2 or b18c for engine swap?
- engine burning water?
- Question about F23A1 motor.
- can a f22 and H23 share parts like the h22
- What can I put in my Accord.
- I bought a Cold-
- Cold Air Intake System - did I get ripped?
- intake
- twin disc or single plate
- 95 civic ex swap to 89 si prelude?
- Gauge Question!
- turbo knowitalls: advice plz
- I'm an Engine's N00b and need your helps
- B18C1 Turbo Info...
- rpm unstable when warming
- Bunch of noob questions.
- lsvtec blueish smoke????help
- Degreeing in camshafts with engine out of car
- Rotor & Screw Prob under distributor cap??
- cleaned the K&N this weekend, huge improvement in mileage
- What Happened To My Honda? :(
- B18C has more torque than B18B?
- OEM wires or aftermarket?
- brake swap generational question
- EGR Dirty
- Vtec Controller for CL3.0
- LS/Vtec VS CR/Vtec
- CR/VTec?
- H22a or H23a
- Weird Idle = Vacuum Leak??
- Crankcase.....Positive???
- block girdle, sleves, block guard.
- MINI-ME Gaskets ?s
- TSi extreme turbo kit?
- Ignitor vs Aftermarket Distributor
- Electronic Load Detector
- Testing the ignitor
- Compression Test Done
- Revhard; drag gen; or F-max
- Bellowing smoke
- HELP RYANE Motorsports lowering Steering Knuckle !!!!!
- '93 Honda Civic LX Sedan Engine Questions
- Hybrid Question....noobie
- external wastegate vaccum line
- exhaust ?
- Spark plugs and wires
- ?? Gsr Distributor ?? - Help!!!!!
- HELP! ZC problem: hesitating engine, odd code, erratic idle
- A/C Mount: Bolts Snap
- ls/vtec idle and temp prob help!!!
- exhaust system for a 2nd gen teg
- Skunk 2 Cams?
- B18b Vs. B16a
- Timing belts vs Timing chains...
- engine corrosion question...
- pulled out my engine
- Tuning/Dyno in Texas
- Too high idle in LS/VTEC
- unique turbos
- price of engine installation
- oil control jet for mini-me swap! HELP
- 93 Hatch With H22 Swap
- throttle adjustment
- differences between these engines?
- Just brought my first Integra...help this newbie :)
- H22 Engine noise - MP3 inside
- D16A1 to ???
- D16a block with a D15b head
- timing belt cracking?
- what do you guys think of my engine bay?
- Mini-Me swap questions!!
- Civic Conversion Problems!!! Help
- civic conversion problems!!! HELP
- engine problems HELP
- I Need new Axles, "stage I or II" help!
- What setup do u think i should get????
- Best place to send and engine for rebuild?
- clutch tech question
- What Kind of Exhaust Should I Get?
- Whats a generous price range for...
- egr valve hose
- need lots of info (warning really long)
- Valve cover gasket Accord 94 qt?
- VTEC engagement activated swtich!HELP
- Where online can u get a vetec
- Do CA 96-00 EX's have less torque or power?
- civic tranny shudder
- 92 hatch d15b
- How to wire secondaries in Eg/GSR?
- BAD idealing
- Engine upgrade
- help..need technical advice
- engineering question, about tach reading vs vehicle speed
- swap help?
- f-max mf2 swap for safc??
- need motor selection help
- Prep work 4 Supercharged Si?
- spiderwebbing on transmission.
- b18c1 block question..
- Wont Rev above 2.5 rpms with load
- OBDI O2 sensor question...
- B18C1 redline?
- cracking sound from radiator
- 94 integra ABS accumulator removal?
