- HELPPPP B16 in 88-91 Hb HELPPPPP
- O2 sensor ?
- 1st Gen B16 in 90 Integra???
- FS: 1994 Civic Hatch CX b18c1 swap on ebay
- Frankenstien Combo
- b18c5 + 91 crx question...
- 92 si tranny questions!
- engine starting problem
- 93 hatch, B20, CTR header, Tanabe cat-back... how will I connect 'em???
- Engine Timing
- B18 rattle on cold startup? Rod bearings?
- Obd-i Obd-ii
- Outer CV Boots
- clutch pedal noise
- Power Steering Q's
- P72 or p28 which is better?
- Clicking Hell
- can a stock h22a head haldle........
- Wiring Harness Question?
- Battery question
- b16a3
- b16a1 into 96 honda civic ex need help!!
- piston ring gap location
- my friend is thinking of buying this turbo
- Cant get crank pulley bolt off- 91 civic
- What is a complete head?
- B16 swap into a 94 hatch
- Installing AEM Cold Air Intake
- Custom Turbo Help
- Is there such a thing as a bolt on turbo kit?
- Spark Plug Wire
- N2O and FI
- Help
- losing horsepower
- Problem w/ FITV i beleive???
- Cam Question
- B20B...or is it a B20Z?
- So which way does it spin?
- 03' Accord Engine Mods
- Where do you guys buy your parts?
- Valve adjustment?
- Ls/vtec=gsr?
- 88 Prelude Performance Questions...
- Smoke Coming from Headers
- pros/cons of intank fuel pump-vs-inline
- prelude h22a type s pitstons
- What happens when your CAI sucks up water???
- Swaps for auto 98 Ex
- Cranks compatible?
- JDM Type R idling problem
- 99 accord f23a1 - BLOW BY
- transmission will only drive in first gear??? WTF did i do wrong?????????? help
- Where to buy a new engine harness
- Honda/acura V6 Conversion
- obs2~obd1 civic ecu swap
- air/fuel gauge Problem
- Civic Engines
- Anyone know of a good Haltech tuner in Florida/Georgia?
- Wiring in VTEC to a 92 cx w/d15b
- Crank pulley bolt: reverse thread?
- do i have a clutch problem?
- Stripped bolt on IM
- funny braking noise
- when buying a GSR motor for swap...
- NGK "G-Power" Platinum plugs
- cat converter
- parts suggestions for h22a civic
- do these chip really work
- SAFC 2 in a 90 Civic Si?
- lost reverse, why??
- Fluctuating Idle
- iacv replacement
- What/Where to buy for a tranny build up?
- Diff. between GSR and TypeR flywheel
- LS or GS-R?
- Crank ???
- 5th Gen Prelude Engine Swap
- What to do to get 12's?
- My vision...
- jumpers??
- Hard cold starting prob - please help!!
- act clutch question...
- short shifter question
- HELP where to find old honda parts?(86lude)
- Autometer Water Temp Mechanical...Install Help!!!
- Simple, subtle but effective upgrades
- CRVtec motors
- cyl pos sensor
- problems with idle & timing on B7-Z6 mini-me Pls Help!
- Fuel Injector Question
- b18c5 pistons in LS?
- b18c5 pistons in ls block?
- GSR Swap>Civic/ECU Wire Harness
- stupid question
- Turbo idling WAY high...
- Help injector ? cracking
- 96 Civic Auto Trans fit a Accord?
- Fmu
- Are turbo vtecs reliable
- y8 intake swap
- mini-me swap
- How hard is it?
- conversion
- wireing issues with b18b in 92 VX
- code help...
- Civic 03 Si (canadian)
- Question about reading ECU codes.
- headwork time?
- y8 IM on a z6
- D16y5 to a d16y8, a few questions.
- D-series swap questions??
- Will a B18A trans bolt up to a B18C motor?
- broken bolt
- h22a Aftermarket Oil and Water Pump
- pistons and WD40
- gsr in 95 civic
- b18b dies
- axel back vs cat back??
- cleaning?
- 90 CRX 1.5-92 LX 1.5 swap
- ECU pin diagrams?
- si INTO A type r
- Camshaft, valvesprings...supercharger
- header
- Mini Me swap
- cam gears???
- 96 gsr obd1 or obd2 or could u interchange them
- o2 sensor
- emissions question
- Thermo-wrap on Turbo Prelude
- B16b Into 94 Del Sol Si
- nothing
- Please Help!!!!!!!!!!
- Prelude B series help/questions. . .
- Gsr aem cai in eg w/b16a?
- Screwed Up Wiring
- Starting issues: 90 prelude/95h22a
- air conditioner / engine noise
- Scantool detected something.......
- which set up is better
- Why do turbo intakes sit in hot air?
- jet v-force power control modules???
- Exhaust smells like antifreeze
- hybrid exhaust
- Broken cam caps
- Dropping Idle
- '92 LS vs. GS/GSR Differences in header/convertor/exhause???
- Weird Ticking Noise
- ecu pin out count?
- is this normal?
- need new tranny
- Pics of my new conversion harness
- damn that oil filter!
- Which brand hand tools to get??
- How-To: Halfshaft & Polish TB (56k beware!)
- Help with a Ctr tb and Skunk2 Intake
- Track times for hybrid civic
- wiring question
- d16z6 and d15b7 intake manifolds
- compression test on ls b18b
- ecu question
- Compression test
- Integra, S2000 Drive Tran
- slow imports?
- civic mini-me (tech help needed)
- HKS Turbo Timer problem
- Suggestions for Selling Hybrid
- Difficulty rating to install a Greddy Turbo
- turbo install?
- Rainy turbo
- Help Idle Proublems
- ECU connection
- IAT sensor O_o for P72 OBDIIA
- b16a plug wires?
- Need help please! Won`t rev up pass 5K rpm!!!
- Mudguards
- eacv problem
- Header fitment question....
- Knocking noise under load at high speedonly.
- Please respond d16z6 into 95 cx
- B18B/B20B piston question: plz help :)
- Spark Plug wires. Which one?
- boost problems
- Complete OBD1 B18C1 into Civic VX Wiring instructions.
- Exhaust?
- Anyone had problems with Storm Performance?
- wiring b16 into civic
- B16 swap/ 75 CVCC
- Coolant Thermostat Location 96 Integra
- Need Help Badly, transmission problems
- ls/vtec ecu
- shortest shift linkage
- mr2 supercharger??
- Would a Le Baron Turbo Fit??
- k-series motor swap
- No Power
- h22a aftermarket stuff
- Ecu question
- D16Z6 help please!
- **help with greddy/mitsubishi turbo**
- Which clutch disc?
- d16y8 question
- turbo problem
- Car wont start
- buy complete or build?
- where can i buy good motor parts online?
- turbo h22 hatch
- update
- Head Gasket on 95 Accord
- just curious
- LCA questions
- Turbo Kit Question
- engine light
- i need help guys
- H22 head on F22 block?
- Dry Oil Filter!!!
- Turbo H22 vs. Turbo B18C1?
- Crazy stuff, Help.
- B18B1 turbo HP ratings... help me out.
- TDC ECU Pinout?
- Car stalling!! Please help!
- lots of questions...
- Oil Leak Help Major!
- Oil Leak Major!
- Spring Suggestions for H22 Civic
- TPS Sensor problem!
- Engine And Radiator Problem
- My stupid questions for the pros....
- Ctr pistons installed on b18c1
- VTEC lifters problem
- need help with si harness in 97 hatch
- si harness in 97 hatch
- Trans tech: synchro lockout from cold stop
- ??? Boosting???
- Coolant leak
- Caution on Powdercoat valvecovers
- GSR swap questions...
- valve spring compressors, removing VS's
- H22 Dyno Charts
- Is this a good deal and brand header?
- hondata...
- wierd smell
- rev limiter kicks in too early...
- B16B Specs
- ls crank in a b16
- coilovers or springs
- what head do I have?
- Dyno Results w/ pics (1MB)
- intake question
- starting problem
