- Was wondering how much i should expect to pay for this turbo setup?
- h22a 93 integra
- LSD a few questions
- obd2 in a eg
- Water injection nozzle placement question
- B18B Add Ons?
- h22-b18c1-b16a2-in to 93 integra
- Vtec
- H22A nitrous questions please help
- technical people help please
- H22a swap into '97 civic hatch (auto-to-manual)
- need help
- thrown rod bearing
- gsr tranny 2nd and 3rd gear grind
- I hear a funny noise when I turn sharply...
- Sea Foam
- B Series Parts List?
- Oil Leaking Out Cylinder
- H22 or B18C
- b20Vtec Leaking
- Air intake for GSR swap
- ITR Head
- might buy b16a 97 civic swap
- Jackson Racing super charger b20 belt question.!
- B16A2 v-afc
- does anybody have torque specs for...
- Need advice on a gearing idea
- ITR '01 Cam Specs
- will a automatic OBD2 ECU work on a 5speed b16a2
- Swapping?
- h22 Civic
- How many miles on your turbo motor?
- engine hesitation
- New Tranny!!
- b18b (97 ls) into 00 civic ex ..HELP!!
- Quick swap info needed....
- help w/ fuel managment
- Head work
- how to change the valve springs?
- H22 Turbo
- Zc
- ZC motor
- Stroker B16A2
- rebuilding H22
- Need engine swap information
- Need engine swap info...
- b16-b18 redline
- installing short shifter
- b18b skunk2 intake mani install
- b18b into 6g EK hb
- Prob .. With My h22a
- B18C1 Crank Girdle
- nippon racing
- 99 Acura Integra Gs Problem
- ZMAX products good?
- GSR intake manifold
- Help......Car wont Start??
- Running Way To Lean . . . . Why?
- URGENT: Help me ID my Tranny via Gear Ratio
- Boosting...
- Boosted R with either AEM EMS or Hondata
- b18c1 problems
- Overheating on a track (pics)
- Idle High...2kRPM
- h22a into integra
- serial number
- H22A Cams and Piston Questions
- HKS S-AFR, opinions?
- Installing In-line fuel pump HELP
- H22A LSD also Grinding flywheel
- b18b swap ??'s
- Supercharged or Turbo
- Clicking after seafoaming
- 98 RL Flooding Problem
- Problem With Engine Check LIGHT
- 85 CRX swap questions
- Will d15b7 intake bolt onto d15b2?
- B16a1 with Darton sleeves, or B18c1
- obd2 B18B into obd1 Civic
- Ocassional Starting Problem
- Engine Swap ?'s Kinda Long I'ma Newbie
- 160,000 + turbo + nitrous = blown or not
- b20b swap info
- Spline whine?
- homemade supercharger?
- anybody got a step by step on a b16a cam seal?
- H22a wiring help!
- question about my ignition
- nos brand nitrous install
- 1992 Civic CX with a H23A DOHC VTEC Swap----->Exhaust Question...
- Hybrid Transmission: Anything missing? (D-series)
- C5 in '95 hatch: wiring question
- Having a Cam Gear Problem
- Assulting your oil pan
- 98 190K EL 1.6 vtec hesitation/bogging!
- B-16 clutch
- Tool for holding tension compressed
- SUGGESTION: What do you guys think?.. Please Read.
- Mounting BOV on the Intake Manifold
- rpm jumping up and down in different speed
- ELD Circuit High Input
- what kind of turbo is this?
- all this aftermarket computer stuff is overwhelming were to
- H22a swap into 94 Accord EX...how do i reconnect vacuum hoses/power lost!
- H22a swap...how do i reconnect vacuum hoses/power lost!
- Map sensor CEL with a Jet V-Force PCM (Help)
- noobie question
- Just Completed Swap
- Engine is Lagging after running outa gas
- ANNOYING problem! CV AXLE OR BRAKES? Input Wanted Plz!
- wiring harness question
- Compatibility question
- swapinfo??????????
- Fuel Pump sound
- nos shot?
- What are the best mods for a Honda?
- What's better? I'm a n00b at these stuff
- hight-flow catalyic converter vs oem catalytic
- Interesting Brake Question
- Im a cheap, cheap guy
- Age/Sitting Damage on Car and Engine, how impacting is this?
- cold air intake
- groundzero
- MAP sensor location
- swapping integra auto tranny for manual
- Helms manual says non-platinum for Integra LS, Why?
- AEM EMS for *just* headwork?
- Should I replace my...
- need ecu advice/help
- Del Sol VTEC A/C bracket same as 99-00 SI A/C Bracket?
- ecu or piggyback???
- B18C1 Turbo'd in a civic
- turbo '89?
- 98EX with JDM B16A EK4 motor...WHAT FUEL LINE DO I USE?
- Uber Noob question
- 1997 Cl
- little grease on pressure plate or fly?? hurt it?
- Turbo Cams
- Question about B20B swap
- need dizzy help with 91 civic hb with a 97 d16y7 w-(mini-me)
- O2 sensor question
- 91 DX pist.=92-95 DX pist.?????????
- B18B build-up
- Hondata owners with the blasted hesitation problem
- Help with cams in b16
- Exospeed cams set-up, comments?
- Bore size effect on L
- 96 Accord EX V6 2.7l Lifter Problems
- *Help! 96 teg w b20b
- uberdata question
- Just out of curiousity.....
- Cool mods for your Honda?
- Radiator Tank Busted
- Which Injectors
- B20B vs. B20Z
- Looking for a better performance book
- Fuel pressure setting
- H22a TPS broken...what replacement?
- 96 integra RS
- b20/vtec boost question.
- I'm very close to be CRAZY
- b16a hybrid axles?
- Let me borrow a leakdown tester! (NY)
- Vibration at idle 97 2.5tl
- 93 integra
- HELP! 1991 dx coverted to zc si, now need to goto 1st gen b16a.
- 10W-30 too thin for 8.5 psi boost?
- 93 integra
- 1988 Integra Electical Problem
- need code 91 help
- Sleeving B16A2 for Turbo
- Horsepower & Torque
- OBD for handheld
- The Honda Tick
- How to Increase Torque on H22A ???
- Swap ??????'s
- Where to get Turbo Jet Polished????
- LSVTEC head
- 11:1 CR Pistons in F22B1?
- k-series weights.
- Spring Tune-Up
- Ground Wires
- 95 EX Overheating..Fan Not Coming On While Idleing..
- Building H22a to Type S Specs ???
- VTEC ECU running in a non-VTEC vehicle?!?
- Angled feeler guage required for (Integra) B18B1 valve adjust?
- Can loose (tapping) valves cause oil consumption?
- JDM B18CR into Integra LS
- Starting Boosted b18b Budget
- TDC Question\New camgear installed
- head comparison (b20b & b18b)
- How much to rebuild tranny?
- 1998 EK Hatch OBD2 Wiring Problem - Test your Skills
- d16a1 pistons
- Got my h22 from hmo today. What else do I need?
- Engine wizards -- can you call this one?
- ls/vtec coversion or gsr swap
- Turbodyne Turbopac™ Electric Supercharger/Turbo
- H22 head on H23 block
- hi ppls
- some Q's about swapping a B16A into my 1998 EX
- D15B Swap Help
- 30 Seconds of Joy - H22 / f22 Electrical Problem
- Turbo kit for H23
- JRSC part question
- Swap Question...
- gsr head
- Timing belt vibrations (video)
- L/S timing belt problems....HELP!!!
- B18C1 into EK..... Shaking..... O_O
- H22 Accord engine swap
- 200 WHP out of ITR?
- Civic Engine swap help
- Thinner Head Gasket for D16?
- D16Y7 Tune Up
- Can someone point me in the right direction??
- B18B1 swap into 6 gen. HB question...
- Asap Help D16z6 Swap D16y8
- Do I have to Gap my spark plugs??
- How should I tune my Cam Gears?
- Fuel Filter question
- GSRcivic with chiped p08 (J's racing)...what plugs and wires???!
- b series harmonic balancer
- OBD 2 restrictions
- B18C5 and LSV questions
- ***Golden Eagle vs. STR cam seal plug - which one doesn't leak***
- Grounding Kit differences.
- TRANNY IS OUT, i'm pizzumped!!! :)
- engine repair question
- blue printed engine
- h22 in to a 97 accord lx
- b18c1 in to 93 integra
- type R in to 93 integra
- SiR-II wont start
- Funny idle in '95 LS w/ JDM H22 swap
- More B18b Questions....
- engine swap questions
- jdm motors website
- B-16A gear ratio's
- JG edelbrock intake manifold and fuel pressure regulator fitment.
- hey guys what you recommend to cut a pipe
- Questions bout B18B1.....
- Mini-Me on a cx block?
- obd 1 teg engine to obd 2 civic ex
- b20a5 into a 91 civic dx?
- intake manifolds
- Temperature Fluctuates...Help
- turbo + wide tranny
