- b18 specs
- 97 civic p0170 & p0171 (fuel injectors?)
- Redline on B18C 93 Civic EX
- The second gear conspiracy
- Engine Rebuild
- Wiring Hell - OBD2 car/OBD1 motor
- ECU and emissions
- car overheat and wont start sometime
- fuel press causing no spark?
- 2001 Accord Excessive Oil Consumption
- More efficient CAI?
- How to identify the JDM DOHC ZC engine
- MSD Ignition, Can Someone Help Me...
- b-series engine timing theory
- This sound is killing me!
- Whats needed to obtain 400whp for (Turbo) Built H22
- building b18a1 block,do i need sleeves?
- Stalling Accord
- Turbo Vacum Lines
- HELP ME identify this Aftermarket H22A cam PLEASE
- wastegate for 14b turbo
- Transmission "thump" in new '04 Accord EX V6 AT
- LS+B16 VTEC HP gains
- E-Brake Light when i hit the gas
- overheating b18b
- getting close
- Resistor box for dsm 450's
- LS vtec swap please help
- V-AFC II help
- Turbo & Supercharger....
- A/C bracket hybrid save money!
- transmissions?
- LSVtec Distributor Problems
- SKUNK2 IM install on a 2001 base Lude
- turbo on stock internals?
- rex need help with identifacation
- HELP!!! Need to identify these cams
- Forced induction engine?
- swapping motor question
- 1996 Accord speedometer problem, help!!
- new muffler yay or nay?
- i'm stuck in a river
- Intermittent starting problem "87 Accord EXI
- what springs should i get?
- my friend blew his head gasket
- New Engine?
- S-AFC to V-AFC Harness
- ctr oil pump question
- HKS Head Gasket
- motor and trans in my 92 lude
- Swap of a diffrent breed...
- Which B-series swap?
- cometic head gasket
- Accord Manual trans comptibility
- NOISES CV or Transmission? - need help !!!
- Valves
- Quick question
- Teg 1990 GSR?
- ECU wiring
- sir swap
- 1.5l from 93civic to 1.7l 93 integra rs vtec
- Check Engine light reset
- what engine?
- Weird idiling & hesitation in acelrating
- What is a B18D5
- What all comes in a turbo kit?
- LS Swap or H22?
- whats this hose for??
- Dual set up on I-4 Accord
- Type of Fuel Injectors
- 2000 Civic DX (swapping in a 95 LS) Wiring Question
- motor swap question
- Question about Header
- Injectors
- 87 Accord threw the timing belt - need help!
- Turbo/Supercharging Designs?
- B18C swap
- B18c
- all problems fixed
- 90 Integra trans swap into 86 Accord ?
- b20b advice
- after market intake manifold? good investment?
- what are these nissin calipers doing on my '90 hatch???
- Weird sound from Y8
- all motor beast
- will this work
- question?
- Need more power!
- Oil Breather Question
- Intake Problem
- VTEC crossover Q
- 14b turbo install on civic d16z6 vtec engine
- LS/Vtec - vtec engagement ASAP response please
- need help
- About to swap motors
- Need Help and input
- uberdata
- firewall map with newer TB?
- 02 Civic Engine Swap Question
- JRSC for D16, what size s/c?
- Exhaust temp light on.......anyone?
- How is spring rate measured on a progressive spring?
- Modding a 97' LS AT
- OBDII OBD2 data logger
- No Spark... more complicated than normal!
- 97 civic ex should i put a ls block and gsr head?
- major problem with my accord PLEASE HELP!
- dashpot diaphragm line ?
- which o2 sensor for a/f gauge?
- Need Info H22a Swap(5g Civic)
- Does a new HU affects central locking?
- AEM V2 Intake
- vtec head
- turbo or supercharger??????
- hoping for 300whp
- BOV on a Diesel engine?
- Check tha link!
- f23a1 into 94 integra?
- need help, $7k to spend
- golden eagle vtec conversion system
- I NEED HELP fellow HANer's finding parts for this motor .....
- V-AFCII Help
- h22a swap, could use some assistance
- commandflo AND fmu?
- i keep blowing injector o rings?
- valve cover gasket?
- carb turbo?
- question on heads???!!!
- Need OBD2 ISO 9141 specification
- How low should I Go???
- B series catylitic convertor/exhaust bolt up in 92 Civic
- how do i go about bulding a motor to handle....
- 02 Civic SI Oil Problem
- i need more hp to my car engine
- flashing engine check light
- All you AFC hackers READ THIS!
- Member Setups
- Moderation, Engine Tech, and Yu0!
- 1990 Acura Integra
- auto P75 ECU conversion
- a few tuning questions for GSR w/ Wet N2O
- Turboing an LS
- want turbo basics
- turbo B20
- Best Motor For Turbo?
- How to test an alternator on a B18C1, and charging system troubleshooting ?'s
- what tranny for B20B in 94 Integra?
- VFAC enough for low-boost turbo setup?
- missing firing in cylinder 1, ecl code 71
- Steering Problem HELP :(
- External Coil Accord ....Internal H22?
- moisture coming from exhaust
- EGR Solenoid Valve?
- Super Charged 818c5
- 60mm exhaust big enough for turbo?
- Would this work?
- Would this work?
- Probably a really dumb H22 question
- B20/VTEC first start hangs with fast flashing CEL
- b16a1
- 1996 ITR DISTRIBUTOR, help!!!!!!!!!!!!!!!!
- Prelude Engine in a 97 GSR?
- H E L P Anyone
- which B16 for turbo?
- LS/Vtec Question.
- 96 ls swap in 92 CX hatch. HELP!!
- 92 Cx 1.5L with 96 1.6L head questions
- Codes 3,21,22,23 are coming up. Check Engine HELP !!!!!!!!!!!
- Problems with my AC
- Diy Blockposting
- A few issues with my beater 1990 civic hatch. help me out.
- B18C GSR manifold wiring diagram
- which one
- 94-95 Ls Swap Into 96-up Civic
- help
- some quick questions
- CALLING ALL FAVORS IN ON THIS! > Need ECU pin out for OBD2a JDM Euro Accord TypeR H22
- Different timing belt lengths: followup
- help me keep my hybrid - emissions!
- Problem with code 22 in LS/VTEC
- Strange problem with 5th gear in LS/VTEC
- 94 Integra LS sedan and '92 Civic VX
- turbo and nitrous
- so many problems HELP
- b18c1 questions?
- jdm p13 ecu questions.
- B18C3 Idles funny need help
- Car won't start
- Which 1986-1990 Honda engine is best?
- serious clutch problems
- B18C Header to Catalytic Converter
- throttle body replacement
- adjust idle?
- turboing a d series need help
- Best way to ship an engine?
- 98 spec Itr swap into CX. Wont start
- no spark from my plugs?
- Built Engine: Red line?
- t25 manifold for b series
- help with motor advice , im clueless
- LsVetc Electrical
- Smoke at 5500 wide open
- What would it take to get a D16Z6...
- B18C1 in Civic
- Swaped a D16Y8 engine with a D16Y5 lately..?
- Help Me!!!
- swap help!!
- aem v2 dyno sheets
- DPFI to MPFI and Vacuum
- maint reqd light
- 92-93 B17 into a 95 civic CX
- Should I build up my D16y5??
- will 97 JDM integra type r axles work w/ b18b swap?
- jdm b18c(gsr) swap into 97 civic, obd1 or obd2
- engine b20b in 93
- b18c1 to b18c5??
- honda prelude white smoke from tailpipe
- '96 Civic CX throttle body question
- engine swap
- Missfire brlem on B18C6 engine
- Good Place for Engine Rebuild Kits Online?
- Some hybrid questions
- Boost Pressure
- D16Z6 into 91 CRX DX
- if you are not confident on knowing how to fix your car ....
- Help I Think I Broke It.....
- Oil Cooler on b18a1?
- 88 Legend Junkyard Turbo
- A Tribute to the motor that started it all.
- B18C Wiring into 93 EX
- OBD1------> OBD0 Swap??
- car running REALLY rough all of a sudden... help!
- used itr motors???
- fan
- does this give any extra effect?
- nitrous question
- '82 Civic wagon M1
- Turbo Question
- The real story on timing
- new catylytic convertor.. no hole for o2 sensor
- sensors? .....arrr...
- jdm or usdm ? howto tell which
- H22A in a G2 integra.
- Help W/ Misfire At Idle
- Reversing VTEC for a turbo?
- Nitrous use & cam gear /timing tuning....
- I need help!!!!!
- Just replaced oil pan and it's leaking!!!!
- quick OBD question
- greddy evo2 vs. apexi world sport exhaust...need help!
