- valve adjustment question
- Post your lightened Flywheel experiences
- Turbo BOV
- Vtec cutting off
- GSR Swap
- catlytic converter help
- cooling system pressure too high?
- nitrous problem
- help with civic h/b
- B16 swap?
- Just wondering???
- Want to swap. Wich Engine.
- b18c1-88 accord LXI (need wireing harness)
- supercharger Vs. Turbocharger
- Engine question
- Vtec & Turbo
- Whats the best to Turbo?
- fuel pressure on b16
- B20B vs. F22A
- B20b?
- Supercharger and Compression Ratio
- Swap Into a 99 Dx
- Stroked engine and Compression Ratio
- Need help....high idle and bad shifting
- Lsd?????????????
- Head Gasket?
- gsr sol looking to go awd
- Car dont wanna go past 4500 rpms b18c1
- B16a1/2/3
- OBD1&2 issues
- Need help about Bseries halfshafts.
- B18C into EG DX sedan pt. 1 (help!)
- Connecting The Speedometer
- teg typeR or b18c1 GsR engine ?? in a rover by the way!
- Water-Induced Vibration
- B18C5 -> 94 Civic Coupe: Does an aftermarket exhaust for the Civic work or....?
- ZC swap done but it won't start!!!
- No Heat
- HELP: In search for a new 89 integra engine.
- just turboed, need help
- Car won't start. Eletrical stuff.
- would a prelude TB bolt to a B intake mani?
- ls/vtec question
- Prelude H23 to H22 swat help
- Blox cams
- vtec not working
- NEED! D16Z6 Valve Clearance For Adjustment
- couple of questions about new motor b18c1
- LS/VTEC vs. LS/Turbo
- why does my car still look lowered?
- whats a girdle?
- crazy hp :D
- Honda Prelude (H22A engine swap) to a Acura Integra 91
- civic cx with b18c1 cant get tach to work need help
- What axles do I use? H22 type s Civic ex
- which ecu (ls/vtec)
- motor swap, need ifo please
- Need timing help on LS VTEC SWAP
- D16 to B20 civic HB swap
- Need help h22 swap
- Need some B20vtec info
- B20 question
- timing belt question
- H22a in Civic
- Msd Coil/Ignition
- D16Z6 Trade for B18A1?
- question for people with B-series swaps in civics
- More Teg Problems...
- JDMB16a(SIRII) into a 99 DX Coupe-Need Help
- H22a 6th Gen civic
- CEL code 73 not going away...any suggestions?
- whats the highest all motor hp from a b18c?
- Boost guage install ?
- Engine tuner
- do i need to swap the fuel pump also
- Can a F22A2 fitted into a Civic????
- Can a F22A2 Engine Fit into a Civic Pls help
- Defective IACV
- Spool Solenoid Valve
- Cooling Fan Relays/sensors
- wiring harness
- Lsd Questions
- D15b2 and y7 head...which timing belt?
- Opinons from people who have frankenstein motors
- b series starters
- Need help with engine swap....
- IT wont come OFF, help!
- cable tranny on 95 integra
- leakage on a manual trans 98 civic hx
- k20 swap vs evo 8 video
- Sos....
- swap..mount question
- compression results
- Another Question
- Check engine code
- has this been done??
- crazy swap
- ecu safe mode
- spoon earth ground kit help
- Engine QUESTION
- Slight break through (integ probs)
- k20a / k24a /k20a2 into EG EK DC2
- Temp Gauge is Driving me crazy!
- 2001 H22a4 into 95 Accord with p28 ecu
- 2000 accord ecu
- Gsr Head Look
- b18b1 to a b18b?
- strange cam gear question
- Urgent ... Broken axle?
- D series motor question
- Missfire in all cylinders. Help me please!
- Diffrences between GM & Pennzoil Synchromesh??
- B20B/B18B engine weight.
- Indivual THrottle Bodies....
- B20
- swap info !
- Problem With JRSC?
- Slightly off topic engine question..
- 226whp 206ft/lbs tq. 12 PSI D16Z6
- SC and Turbo quick question
- 00 ls into 97 civic ex.. which ecu to use?
- Snapped Timing Belt
- vigor chek engine light problem
- h22 problems...
- What OBD2 live data parameters does Honda support?
- help! no injector action in crank circuit
- OVER HEATING.. help
- B Series Swap into a 94 Civic EX
- Spark Gap for 1.5?
- Dirty Air Filter Clogups???
- My damn car keeps runnin outta gas!
- swap or LS/vtec?
- 1997 INTEGRA- where is the diagnostic cable located?
- For the Guru's:crx na b20 ?'s head work or bottom end?
- gsr fan not spinning
- Z10 oil pan
- HELP!!!! Problem with injection/ignition when the horn is used
- Unorthadox pulleys
- question on lsvtec wiring
- wierd noise !
- Integra Engine problems
- timing problem
- Tranny issues
- turbo vtec
- Turbo Tuning procedure
- B20 questions
- Cheap CAI..
- O2 sensor
- transmission questions
- B16+ Nitrous ?
- Wires......WORD!
- Rotary engine for sale?
- best swap for 97 civic ?
- using the AEM fuel rail for N2O
- Quick Question
- How do i check and see if there is oil int the transmission?
- H22 swap
- Failed Idle HC
- H22 Swap
- Secondaries on a GSR
- New to ECU
- b18c1 obd2b engine into a 94 del sol
- What ECU should I run?
- Putting new motor in! need help
- putting new motor in! got questions
- Modifiers in Canberra, Australia?
- Gsr In EG...
- can you use a jdm b16a (obd1) ecu with ls vtec?
- should i buy new rocker arms when replacing cam????
- More engine questions
- Egr????
- help!! motor gone mad!!
- In the dark about ATTS
- i want to get a exhaust which one is good
- i just got a swap and i want to know what people think i run in a quater mile
- Help valves constantly need to be adjust!
- P0420 code
- 02 civic si - emmissions light
- JDM Type-R swap...HELP!!
- SCAT rods?
- Longest swap project in the world :(
- stuttering engine
- CRX ZC swap questions
- Internal wastegate not actuating
- ImortBuilders.com
- GSR turbo...no power when at full boost
- i am swap a b18c1 into a 92 civc cx need help!!!
- 97 b18c1 motor with a y1 transmission need help!!
- did a swap today...
- 00 gsr v-afc hack
- Questions on interchangeability
- b20/turbo question about sleeving?
- just went h22...got some q's?
- Oh God...What have I done? JDM LS (OBD1) swap into USDM EJ6 (OBD2)
- SAFC Install
- H22 build question
- Which Intercooler?
- What size InJectorS for Fully built?
- Clean a Cat converter
- How Much CFM for a D16Z6?
- need help straightening this myth of flywheels
- 88 Accord Auto trans, stalls in gear
- Ls/vtec B16 Head Or Gsr
- B18 Turbo in a Del sol, Which B18?
- t3/t4 exhaust flange
- what c/r will this yeild?
- 92 Accord EX EGR port cleaning?
- High Nox Cant Pass Smog! Help!
- Swaps?
- 97 EX brake swap Questions..
- 98 RL overheating while stopped or idling.
- VTEC solenoid- 5v or 12v?
- Please Help w/ Swap
- Greddy blue box question...........
- Tach Wiring Question
- split second
- my brake saga continues
- Dyno'ed B18C
- Best Turbo/Most Power
- Fast Idle Thermo and Vacuum
- No acceleration...HElp!
- Newbie to moding need help
- B16a J1 Lsd
- excessive low emission gases
- VTEC in a D16Y7
- s100 p72 H22 EG, CEL 16 and 21
- What engine does a stock integra come with?LS&Gsr?
- B18C1, 89 Integra
- After-Dealer Warranty
- Wiring diagram needed for B18C3 transmission to wiring harnessq
- Intermittent stumble then dies.
- Gsr And Ls Motor Swap
- Turbo Specialties kit for B-17?
- CVT transmissoin draining.
- Idle fluctuation on JDM H22A
- egr valve
- ItS never fixed
- 2000 MDX Unexplained Vibration
- [B]civic type R EK LSD in SI tranny[/B]
- 00 Si engine stumbles - need help
- my all motor setup...
- Ceck Engine Light???
- Why is a ported and polished head better?
- Low Idle
- NEED HELP!!! b16a2 with ctr parts
- d16z6 head on a d15b2?
- OBD1 P72 wiring
- difference in ODB's
- 2nd gen itr?
- SRS and BREAK light
