- h22a swap into eg shift linkage
- J32A2 into a 4th gen Accord (1996 specifically)
- Vtec question for newbie
- ????? Which Evap Purge Solenoid for Swap ??????
- 97 LS in a 93 Teg??
- icm (ignitor) signal
- Ignition problem.
- To intake or not to intake?
- Anyone know where to rebuild a tranny
- Synchros
- Head Gasket Question. Help??
- Bseries flywheel bolts vs Dseries !!!FACT!!!
- f22b2 swap to f22b1
- LS Engine.
- TSX K24 V6 engine VAFC2 installation problem!
- whats the next best upgrade
- turbo help?!
- Rpm Reading At Idle On Accord
- What gearbox to b20b??
- Bigger fuel pump?
- distributor q's
- Obd2 gsr swap
- LSD tranny worth it?
- Intermediate Shaft leak
- b18 gsr
- anyone know how much a NA b20 will handle
- anyone know where to have rods shotpeened
- B20b or b20z ??
- Sohc Engine Rebuild. Anyone have great info?
- Sohc Engine Rebuild. Anyone have a great article?
- dsm injectors in b16a1
- Car wont stay on. NEED HELP!
- thoughts on ctr OS pistons
- Newbie,chck Out The Whip In My Garage And Tell Me What U Think
- How do you fit ITR pistons on LS rods
- most successful car setup?
- Want to build AWD,RWD, or midengine del sol...
- Pressure plate bolts
- Engine Blew Out New 2000 GSR Motor
- Headers over heating?
- H22 into EG Hatch info
- Want to change FLYWHEEL dont want to loose anythin, Flywheel
- ZC Engine Mods?
- Electronic? fuel?
- B16a2 in 94 hatch
- 4wd accord question
- B20 built with B16/B18c1 head...
- b16 dyno testing@ methodmotor works in fresno
- K&N Typhoon
- B18C swap
- Intake Air Sensor "Code 10" help
- Spongy Brakes
- Help on Building LS B18 for 8K rpms
- compression test results
- Pistons and Cams in SIR-G
- 911...WHAT TRANNY DO I HAVE< HELP FAST
- possible intake manifold issue.
- 91BlkSiRcivic,LSD changeover
- Need help finding Headers with 2.5" collector
- 5W-20 or 0W-30?
- engine light...02 sensor
- turbo problems...help!
- This dyno number possible?
- golden eagle girdle kit?
- Please Help SWAP
- help with turbo upgrade
- Oil Capacity Question
- Happy Holiday's Hybird Forum
- H22 in a 2G?
- Oil problem on B18C swap
- RSX K20a2 in Civic EG...Anyone know NEThing!?!?!
- Aem Ems
- crx rear disks
- engine swap
- B20A5 Bad rod... Fixed but now won't start!
- Whats this part called?
- Are these real B18C5 Engine for ITR?
- Piecing together a Turbo
- Electrical Problems?? 88 Lude
- help!!!! oil in exhaust
- Spec B's and portflow valve springs
- Fuel pumps and OBD's
- Power Steering pump compatibility.
- Idle Problem with integra
- b18c swap
- Questions about stock fuel pumps
- 98 civic hb upgrades?
- Was wondering
- Could anyone explain this
- To teh experts(srt-4)
- JE Pistons or CTR Pistons?
- need lots of help
- d16 dohc block with y8 head
- B20 Builder Needs Help
- Screw fell in oil passage (oil duct , oil way) - effect?
- 523 HP civic need help Intake manifold
- B16A not running right Please Help
- Turbo Problem
- best trbuo for an integra ??????????
- Performance/Maintenance Installation Shop in DFW
- Need reputable Shop in So. MD
- Imas?
- New Hybrids
- part2: b20 vtec(b16a) supercharging questions
- B18C1 and B18C5 intake manifold bolt patterns
- Intake manifold benefits
- B18B Buildup
- 93 Accord With H22a Swap
- Jackson Racing Supercharger for LS/VTEC?
- New Timing Belt Install
- b20 vtec(b16a) supercharging questions
- how much do a flange cost for a BOV
- Vacuum diagrams please
- Forced Induction Reading Material
- Looking for So. Cali dyno's
- ECU for 89 Civic 4WD Wagon Manual(ZC)
- What is the better option.....?
- Losing Power with Acceleration 2002 Ex
- header 4-2-1vs.4-1?
- So So Sad...
- Automatic transmission question
- Will HX eng fit into EF civic?
- power steering repair
- Honda Accord Injectors
- Anyone have a ScanGauge?
- In Drag....B18 bottom + B16 Head vrs. H22....Who wins?
- d15a3 to d16a1 motor and tranny swap ?s
- project ol school/new school Ludeness
- weird teg problem
- Older VTEC vs. New VTEC
- Installing the Timing belt
- Speed limiter?
- cooling problems in ohio
- Somewhat serious clutch issues
- old accord high idle help???
- Exhaust Manifold Heat
- k-swap with power steering?
- zc timing cover
- oil filter seal bursting... need help!!!
- Engine identification numbers..
- which head
- 92 Prelude Mechanics please help!!!
- Make it more eficient
- what kinda turbo is this?
- Long Rods :D
- ls or b16??????
- elusive oil leak
- Which Walbro should I get?
- About cleaning injectors
- Gude Performance
- Hubs?? 4? 5?
- B18A1 into CRX help
- B18A1 CRX swap
- Engine Rebuild Question
- Stock JDM B16a ...... N/A , Turbo , or Supercharged.
- wire harness for 90 civic/crx
- race project
- Engine Compairison: b16, b18c[5&1] and B18b
- swapping engine need help
- RHD Starting problems, Injectors not firing
- CRX Axle Swap - Wheels
- DTM Exhaust
- struts/springs
- Easy way to put a OBD1 Engine into OBD2 Car?
- Need Pro's and Con's on these:
- I Need Help ASAP!!!
- Where can I find a B or H series motor?
- erratic idle
- What is a Long Block?
- motor swap help
- help on b20 swap
- '92 Prelude cuts out at full throttle??
- difference between vtec and nonvtec dizzy
- A D16Z6 for a B20Bomber
- timing balancer belt marks
- oe or not oe??
- OBD and my CRX
- ECU confusion / pin question / who's on the ball?
- R/S Ratio
- Tech Question
- b16 help in 88crx hf
- redoing my timing and other stuff
- problem with swap!!!!!
- clutch to the floor...
- My Integra failed smog yesterday.
- $2,000 and a 92 civic LX!! What would you do??
- tach problems
- Question about Turbo?
- little pricing on a b16a swap help..
- 1998 civic hatchback MOTOR SWAP
- 98 civic hatchback help needed..
- Compression for boost
- Ghetto rig a cold air intake?
- Exhaust setup
- d16y5 to d16y8 or y6
- B18B1 94 Civic?
- Will A B18B1 Engine Fit in a 94 civic?
- Aftermarket ignition query.
- F-series?
- H22 Accord System Lean
- Now axles are the issue!
- B16a2 into a 92 civic LX how hard is it?
- LS VTEC ECU Question
- B20 vtec question
- B16 Stroke
- Vtec problem in F22B1
- Injectors for 91 'Teg w/ B16 swap
- Will A B18A1 Integra motor work in a 1994 honda civic?
- Turbo Parts List
- b18a swap 92 si hatch
- valve adjustment question
- Post your lightened Flywheel experiences
- Turbo BOV
- Vtec cutting off
- GSR Swap
- catlytic converter help
- cooling system pressure too high?
- nitrous problem
- help with civic h/b
- B16 swap?
- Just wondering???
- Want to swap. Wich Engine.
- b18c1-88 accord LXI (need wireing harness)
- supercharger Vs. Turbocharger
- Engine question
- Vtec & Turbo
- Whats the best to Turbo?
- fuel pressure on b16
- B20B vs. F22A
- B20b?
- Supercharger and Compression Ratio
- Swap Into a 99 Dx
- Stroked engine and Compression Ratio
- Need help....high idle and bad shifting
- Lsd?????????????
- Head Gasket?
- gsr sol looking to go awd
- Car dont wanna go past 4500 rpms b18c1
- B16a1/2/3
- OBD1&2 issues
- Need help about Bseries halfshafts.
- B18C into EG DX sedan pt. 1 (help!)
- Connecting The Speedometer
- teg typeR or b18c1 GsR engine ?? in a rover by the way!
- Water-Induced Vibration
- B18C5 -> 94 Civic Coupe: Does an aftermarket exhaust for the Civic work or....?
- ZC swap done but it won't start!!!
- No Heat
- HELP: In search for a new 89 integra engine.
