- B20/Vtec [Recommendation on Head Gasket?]
- turbos from ebay good or not so good..?
- integra swap..[b20/vtec]
- Rebuild Or get New
- Apexi V-FAC2
- best civic performance chips...
- How do i remove the shift linkage from the tranny?
- b16 head/b18c1 block
- Help 99 civic !!!!!! my car cut off
- Civic Head Gasket/Honda Bulletin 97-047
- would this suck or blow?
- Help,please.OBDO O2.
- Low Rpm Power Loss
- Is Greddy Exhaust System worth the extra $$ ?
- b20b help for everyone
- wastegate problem
- Help w/ buildup for B18C1 (gsr) into civic
- what is the best way to tune a turbocharged engine?
- Help.
- help!!!!!! [Swap options for 92 Integra]
- Legal B20
- How much boost can a stock internal D16Y8 block handle?
- best mod for torque?
- Crankshaft Pulley Bolt threads 92 Civic
- F22B - S/N 1106842 - information?
- Code 41???
- check valves
- dyno today
- Aem Ems
- Best P28 Program for LSVTEC?
- There will be no "hey check this out" here.
- damn real main seal leaking
- Just curios.
- need a good shop
- trasmission shift linkage seal
- jdm engines, and replacing parts
- CAD Designs of Exhaust Flange
- Eliminated my breather tube heater
- TPS Sensor, need help
- hitting vtec?
- Conversion harness and P72 Question
- Immobilizer
- Which Injectors on LsVtec? B16a or LS?
- i want to turbo my 95 civic
- CTR Fuel Rail on LS/VTEC? Worth it?
- swap Q
- Difference between obd2a and obd2b Conversion Harness? How to tell
- Wire Harness Conversion for Integra obd2a to Obd1
- got A 95 Gsr In A 93 Hatch Need V-tec Wiring Diagram?????
- H22 head on H23 block..
- Knock sensor wiring
- Garrett GT28R or Turbonetics T3/T4 Hybrid?
- boost a h22
- Swap Question
- engine swap d13b2 #4# d16y8
- light stays on
- OIL made my engine tick louder?
- B18B tranny/clutch question
- LS/VTEC Question about Wiring/ECU??
- whats should the average # be when doing a compression test?
- damn turbo
- Looking For Honda Aftermarket Parts Shop - Houston
- Which filter?
- Need HAN to help me pass smog inspection
- B20 swap from 92 integra to a 90 integra
- [B18A1] Ignition timing [CRX Hybrid]
- Spark Plug Tube Seals / Valve Cover Grommet..
- will a b16 bolt up to the stock mounts in a 95 civic coupe?
- My car over heats when i don't step on the gas. help? please.
- Reputable shops/dealerships in So Cal to do maintenance?
- 1.5L guys.....
- Which is a better muffler??
- Engine F23A
- Back Pressure???...Good?..Bad?....Non at all??
- B18 sir-g From H-motors
- USDM H22 Specs
- Nos Users!!!!!!!!!! Read!!!
- So how does this setup sound..
- Blaster Coil 2???
- Need help please!!!! pin out for the b16 ecu
- Fuel Pressure Regulator
- Booosting
- ls/vtec not that bad
- I Need some help , b18c5 or b18c1 ? in 00 Si
- Junkyard engines
- Which oil for B16a1 [CRX Hybrid]
- No fuel?
- Block Sleeving?
- Apexi vafc2 wiring
- No fucking power at all
- Car making wierd noises
- Yet another O2 sensor thread
- D16a6 wiring, help please
- I Hate Timing Please Help
- Msd Blaster Coil
- Help w/ B Swap please
- SRS Light stays on
- turbo and manifold for $180 ??
- F22B3 header for a prelude
- B16A1 in a Civic 97 hatchback?
- looking for some advice
- Vtec head on 1990 b18a1 motor?
- JUICE BOX chip / module on eBay - anyone buy?
- Amatuer swap?
- ECU tuning with cams and pistons
- Rev limiter 10,000 and fuel map
- Adjustable CAMS How do to adjust???
- D15 Stroker Kit
- Installing AEM bypass valve
- Timing Advanced
- Apexi WS catback problem
- Japan Star Motor or Japan star motors?
- Twin Turbo
- Zeitronix Group Buy
- Honda Accord - Oil Leak
- B20 Swap
- Vafc 2 Help!!!!
- Resleeving shops in Colorado
- Engine tapping between 3000-4000rpm
- '98 EK H22A upgrade hints plz
- What Should I Swap My Stock Engine For?
- Spark Plugs Won't ignite
- Balance Shaft Elimination H22A
- Double checking OBD2a to OBD1 harness
- car wont start after ls swap in 93 civic
- ls/vtec pistons
- Clutch master cylinder leak
- wiring the Vtec
- still fixing the problem
- 1994 integ ls
- Swap or Rebuild 89 Teg again
- what caused my radiator to split
- b series motor help
- Need help.
- b16a problems
- Bad Sencros
- DIY turbo manifold for D-series w/mitsu turbo
- connecticut tuners
- is it possible to convert an obd1 b18c1 to obd2b
- bad TPS?
- b20 swap into a 1995 civic si?
- 1995 civic si 105,000kms on stock motor, should i build or swap (crvtec b20)?
- Installing B20b into 2000 civic si
- Tuning!!!?!?
- OBD2 to OBD1 conversion issue
- Sheared Bolt in Crankshaft
- Integra Xsi manual.
- Looking for a good value wideband O2 sensor...
- not sure what this means
- Cluster Problem
- b18a
- F20C in 6th gen Accord coupe.
- What can go wrong with a leaking oil filter?
- Clutch break in.......
- Just curious.
- noob
- ecu comp....
- My new ITR tranny!
- how involved is doing a valve adjustment
- 03 Accord Check Engine Light, HOW TO CLEAR
- axle replacement question
- Need To Find Engine Parts
- any ideas on how to separate the axle from the half shaft?
- why wont my car start?
- Garrett GT35R or Prcesion SC61??
- 93 no start
- Jdm/usdm turbo issues
- car wants to die sometimes...
- Valve Spring/Retainer Replacement Tool
- Next modification?
- lifter ticking?
- TD04HL-13T from volvo how would this fit a d1.6?
- FrankenStein Wont Kick Over
- my bud calls me dumb yet smart
- How much to shave a head?
- I need help please
- ECU chips
- Advise on replacing tranny
- what do you guys think about ITB?
- ITR tranny on b16a2 problems
- ECU Code: 1 & 43... translation please
- 95mm stroker questions
- Best turbo manifold-gsr hatchie
- obd1 b18b in ek help?
- tuning the H22
- is it possible H22block b16head ????
- GSR short shifter for a 92 -95 hatch
- ITR tranny on b16a2???
- making a da8 right hand drive
- ARP head studs/bolts
- Denso Iridium Spark Plug Performance
- b16 swap from 89 rex to 92 si
- 97 accord check engine light code help
- B16a1 head knock
- Skunk 2
- Need TimeSert - BigSert kit
- Running rich???
- Thanks - ZC Swap
- Hondata update
- b Series Swap into a 97 ex???
- check engine light and rev limiter probelms
- Spark plug Temps.
- problem solving
- Vortech fmu question
- D16z6 code 9/16 and safe mode? help me
- Rebuilding an h22
- K20A6 vs. K20A2 injectors?
- why do my pluggs keep fouling?
- T3/T4 flange dimensions/size?
- valve springs
- GSR gauge cluster into 93-95 hatch
- what kind of power.....
- GSR Tranny problems
- What ecu to b20z??
- Intake for HF - ZC Swap
- transmission question
- Disadvantages to VTEC Turbo?
- timing advise on my d16z6 crx
- I need Help with my H23 Engine
- B-Series Swap Wiring
- Turbo vs SuperCharging
- Time for a new air cleaner?/ *PIC*
- Recently ported T72 Compressor Housing
- problem with ls/vtec
- still need help ......
- I need help troubleshooting an automotive electricity problem.
- haveing coolant leak
- Are HAN vendors legit?
- 98 Honda Accord ex Check engine light
- details on installing new head
- Spark plug gap?
- Wideband O2 system for a N/A car
- is the waterpump that impotant?
- help on a nissan V-6
- Which BOV should i buy?
- b18C1
- GSR short block with b16a1 head
- B16B OS Pistons -> B18C?
- b18a in a CRX
- ZC Swap - Timing/Distributor
- rev limiter
- need some timing help
- Installing mixture Gauge and A/F meter
- just a quick answer
- Vtec engaging early in b16a1
- jdm b16 and jdm tranny wierd gear ratio?
- Drop some engine swap knowledge..
- is a b16a2 a good engine to turbo?
- Plan to boost. need help
- d16z6
