- valve tap....
- I got a trouble with the inmobilizing system
- jdm d15b getting the max??
- help. will my dizzy work or not???
- New to this!!!!!
- anyone have a clue what this is?
- 02 civic si in integra clothing
- how will i know vtec is turn on or open???
- supercharged ls tuning
- wiring info
- ZC...b series head?
- help Engine problem with fuel system
- 1988-1987integra engine swap questions,help
- Please help with swap, evap.
- what is this??? 1988 crx dx block.
- Same Engine - Different (Very Different) Oil?
- Changing displacement-prelude
- D series transmission hybrids
- Revvs dropping problem
- The Honda B18 Engine - A lil help!
- help please
- Type R in civic-good or bad
- 1988 acura engine swap problem
- The ultimate Question :Turbo or supercharger
- move peak torque....
- TSX w/Comptech Supercharger in Sport Compact
- Advice Please
- D16a3 yanked toss in a D16a8/9???
- What combos work best
- Engine Vibrating
- o2 sensor help
- LS turbo question?
- Help Me Wit My Car
- is it a must to upgrade water and oil pump
- K20A into a 6th gen civic?
- sputtering civic
- possable to swap? D16a3 to a D16a8/9
- someone explain detonation...
- Thermostat and Fan switch???
- CTR or ITR cams
- Speeds above 80MPH my 98 C43 shakes/vibrates
- Aem Uego
- Plz help! Replacing sensors {H22 into Integra}
- Exhaust problem
- exhaust manifold broke HELP HELP
- keep blowing alternator fuse. help
- fuel injectors
- OBD2B to OBD1 conversion and CEL 6 (Engine coolant temperature high/low circuit)
- Please help with h22 swap!
- can an obd2 gsr run right in an obd1 civic?
- b16 surges vacuum ? plz help!!!
- Help, integra motor problem
- b18 single cam vtec
- B16a
- 92 civic block swapped for a 88 crx block??
- head cleaning?
- New Project {H22 into 93 Integra}
- problem: Low rpm; 94 honda accord.....pleaseeee help
- H22/b18 fuel line question
- b18b into 92 civic hatch, down pipe problem!?
- d15b vtec swao
- having some problems after the swap
- Another VAFC Question
- raising compression of b20?
- CRVTEC vs LSVTEC
- Im new to Honda/Acura so could somebody help me out with engine/car combos!
- Halfshaft bearing h22 vtec
- oxygen sensor heater code 41 HELP
- ALRIGHTY!!!! GSR Manifold vs Skunk2..lets do it
- Street/drag
- gsr in 92 si hatch wont start. plz help
- Obd 2 obd1
- engine swap into an 89 civic hatchback
- anyone else using 5w-20 honda oil for older cars...
- SMSP header
- fully built ls vtec
- Element CEL
- Header question.
- Sputtering!
- coil pack question
- 1998 Honda Civic Coupe/ b18b
- turbo questions
- vafc 2 ?'s
- Exhauat leak making problems ?!?
- darton sleeve issue
- 98 Accord w/ 336k miles
- Engine help
- h series peeps i need axle help
- Summer tires
- what is the max you can go with honeing
- Wiring help: HEADLIGHTS
- eagle rods and oem pistons
- H22 belt question! Plz help asap
- Header bolt pattern.
- EGR Help
- car wont start.. single pop/spark sound
- 90 civic dx idle problem
- b16a2 turbo kits??
- cost of rebuild
- F22A parts question
- Building an h22 from the block up ?
- 92 accord speed sensor location
- ...?which engine?...
- MC & Power Booster Swap
- Clutch change?
- h22 pricing question
- h22 into a civic
- aem
- Gude Head Package??
- Little help please
- performance chips
- H22 into integra question
- B18c1, Skunk2 Stage1's, Valvetrain....?!
- F series Question
- B18C1 Throttle Body Gasket
- quick ques.
- which clutch master cylinder
- B18c1 for a 98 civic coupe... is it OBDII?
- gsr header?
- h22
- head gasket
- Random Stalling Problem
- 94 GSR in a civic HB si with concerns on vtec
- meter fuses problem.
- Part fit??
- Wiring and vacuum diagrams
- is there any freeware for reading and clearing DTC's?
- Idle...
- B16 Sleeves
- Throttle Body
- acura legend will not start
- B20BVTEC header
- my motor wont vtech
- Need A Power Steering Pump!! Asap!
- 1.5L d15 non vtec able 2 swap into 99 1.6L d16 vtec sohc coupe EX ;same bolt pattern?
- Lsd *help* Lsd
- electric door swap
- Newbie help me....
- It just won't start
- what is next ???
- engine swap ?? new guy
- Adjusting Butterfly valve
- ecu?
- What conversions are needed to put 94 engine in 90 teg
- clutch, pressure plate; cable, hyrdro
- Best Clutch and Tuning
- Engine Swap Help
- Everyone's insight is needed...plz comment!!
- Best way to clean valve?
- engine problem could be tps?
- OBD2 head w/ OBD0 harness n block
- Idle drop..on jrsc gsr
- h22 in Si?!
- ACT stage 1 or Clutch masters stage 1
- motor swap
- motor swap
- Wiring question?
- Best clutch for B20vtec setup/ everyday driver, I need the best compromise between co
- Wiring Help Itr Hatch
- what types of engine these honda make.
- Intake swap form Prelude to F23 Accord?
- fix speedometer for a 1986 ford crown victoria
- Skunk 2 intake mainfold tuning ?
- only an idiot would have this problem..
- port and polish
- GSR intake manifold on B16A2 Head?
- low compression
- Tranny Question
- Cylinder 3/4 misfire
- Engine starting troubles
- tuning help...
- gsr is fuel laging at high rpm
- 95 GSR manual transmission...is the case of it cast iron, or aluminum?
- clicking sound in b16 head!!!
- Spark Plug Wires Question!
- turbo si problem w/greddy fcu any help please
- balance shaft
- no compression no start timing ?
- Project Turbo On 99-00 Civic Si Need Help
- Ls/vtec
- please help whats my best option???
- How much HP will a d engine sleeves handle
- silly obd1 dohc zc
- Engine problem
- wheel brand
- power steering in an h22 civic/integra?
- B18B in a 97 civic
- i want a new exhaust 2.5" ideas?
- B16 turbo??
- question on a b18a1 engine
- Question about GS-R block!
- o2 sensor wiring help!
- question about b18a1 block
- is this a good deal?
- Gsr or type r? [DC4 (?) contemplating swap]
- Oil flooding spark plugs!!!!
- High Boost HEad
- o2 sensor wiring question
- Rods and pistons
- b16 in what 92-95 civic hatch???
- Any options for F22 vtec motor?
- motor swap
- blew my head gasket
- another noise thread
- Intake Sound Help!
- what do YOU think?!
- Swapped 95 Civic
- 5 speed conversion???
- ITR head or B16 Head
- What is a bypass valve?
- conversion wiring harness!
- Need help making an ecu decision.
- Good shops for a build up ls/vtec
- MSD Ignition help!!!
- Fault code clearing
- Timing
- Seized engine good for rebuilt?
- Thinking of boost....96 Accord
- 01 Civic Frankenstien
- running rich?
- Head Gasket help
- pick up coil
- New Start
- what cams to get
- Benifit of getting Hondata on stock engine?
- CRXSI doesnt go passed 31/2 rpm?????
- swapping cams- need pics!
- obd2 b16a2 in 95 civic ex obd1 w/ obd1 p28 ecu!
- ls crank in gsr block
- 96 LS motor in a 91 teg
- Cams
- B16B with Si harness
- Car Won't Start ...
- ek swap..no start..lots of problem.
- New Dyno & Shop Location in Virginia...
- 1998 Accord EX V6 w/check engine light
- help honda engine swap
- Possible Engine Swap?????
- Engine Bore
- Obd2 Ecu Performance Help
- gsr problems
- hmmmmmm
- ls b18b1 swap problems.
- LS Vtec understanding/questions
- power
- Exhaust System Upgrade for '04 Civic EX
- Vtec ques
- NEED HELP! CL wont start
- H22a Accord jumping idle
- type r swap into a 92 civic cx
