- My first Sad mod but happy with myself
- B18c - B18c1 Jdm Vs Usdm
- gsr tranny
- Clutch will not disengage, HELP!
- PCV Valve on 1998 GSR
- Whistling noise... Probably normal
- mounts
- LS/GSR trans question
- New turbo up and running, but I have a question
- 1997 gsr interchange w/ 97 LS?
- i have 17s and just installed lowering springs
- Integra 92 ls part swap
- punted a deer, now I need a headlight...
- integra gsr to rsx hub conversion
- Gas Mileage
- JDM B18B1 Swap 95 Integra
- Unknown header, need gasket.. Help?
- !HELP!- Attempted car theft, ignition jacked - need help/info on ignition cylinder
- What's a good website for brake discs and pads?
- Lost Motion Assemblies
- gsr vs ls
- 1998 4dr GSR Exhaust Help
- Where to find cat...
- eagle rods
- Look what UPS brought me today!!
- b18a and b18c parts interchangeable?
- GSR Trans. identification
- Tires/Transmission/Speedometer??
- My Integra makes weird noise. Please help?
- it's all coming along
- integra side marker measurements
- bad scratch
- Rattling noise
- Car wont start...cant hear fuel pump. HELP!
- Question about fog light compatiblity
- Opinons on MSD Pro Billet Distributor?
- neeed help!!! check engine light
- Failed Smog... Help me out
- 96 integra is burning gas
- integra turn signal wiring? what wires are positive?
- 93 gsr brakes
- gsr dyno, whats wrong here?
- NEED HELP FAST....car runs like ass
- Finaly,the time has arrived! TURBO!!
- coopers on a teg
- timing belt
- Engine builders in the San Diego area
- Question about brands/Models for suspension
- Who's Boosted/All Motor near RDU,NC
- Snow tires pulling left
- gsr lock and temp problems.
- rust
- Just got car running!
- Hey guys how would this look on car?
- MAP Sensor
- Tranny Help
- Integra Short shifter HELP!!
- Integra Axles...ABS or not???
- water pump
- 1998 Integra
- Maybe getting integra, HELP!
- installing stock rad
- Radiator overflow tank never warms up
- enquiry
- 98 GSR timing belt re
- Trans Question
- $5500 too much?
- dent in oil pan
- What exhaust?
- I have a quick ??
- wheel spray paint
- Miles on your Teggy v. 4589652
- ecu
- pics of hks hi power on a teg?
- need help about turbo
- Best Intake for Turbo
- Another question...sorry for all the questions
- New here and I have some questions.
- Clutch acting funny?
- [Merged:] gs-r header [flywheel & clutch recommendation pls]
- Replace Axel and Arm Bushing
- 92 ls tranny HELP!
- Valve Cover Breather Filters
- swirling noise when engine is cold
- Steering Wheel Creak
- New exhaust but room for improvement?
- Gasket
- coilovers and struts
- ACL issues RODS & MAIN
- Got some new goodies....
- Spark Plug Stuck - Correction
- '95 GSR Sputtering
- Misfire: i cannot figure it out
- ? about the o2 sensor in 94 gsr
- What Timing Belt
- I need help on removing the front spindles on a 95 gsr
- What fuel management to use?
- Timing Belt
- B16 or B18???
- Question about Letting engine breath better
- what you guys think about this?
- Any Difference between B18C5 n B18C?
- Hatch Door Problem
- Question: Skunk2 Pro S Full Coilovers
- 93 integra GS - E brake light stayed on this morning, how to fix
- car swerves
- Idle at Start
- engine starting
- Oil question for boost application
- Quick question about 4x100 lug wheel offset.
- Type-R Cams in GSR
- Help me turbocharge my b18b1!
- Buddy Club P1 SF Lug-Nut help.
- rear brake caliper piston boot replacement?
- what rod bolts do i have???
- Need Help with Clutch Adjustment!!!!
- which turbo kit?
- 1990 LS, pinging
- maint required light flashes
- comparing suspensions
- having difficulty starting and rough idle
- Honda Newb:Teg ?'s thread - 94 GS-R JRSC
- Camshafts sugestions??
- DC in the making
- 91 integra ls
- Which spark plugs do you use/prefer
- noise under battery
- Spark Plug Stuck
- 1990 Integra RS won't start (sometimes)
- I need help with vtec
- would i hit 200hp??
- clutch help for a newbie plz!
- installin tach
- Changing rear brake pads... minor problem
- Timing belt problems
- need help on firing order
- Need some help drawing 12v power from fuse
- Stripped Treads On Block
- 99+ Hid
- m3 mirrors for integra? hookup question
- sylvania ultra headlight bulbs...
- Yet another Vtec question
- boosted 92 integra questions
- Collector
- choosing coilovers
- Need some help finding
- CAI vs Short Ram [Merged]
- Question about Performance with car.
- 95 integra CTS problem, long time listener
- Weird problem... need advice
- speedometer sticks when its cold.
- Questions about turbo kit? Injectors
- Need DYI guide for Password:JDM Hardened Shift Link
- Honda / Acura speedometer and odometer accuracy issues
- question about pcv system
- help with my 2000 Integra - engine Problem?
- Totaled on 10/24
- condensation and fog on the inside of my windshield
- SRS light reset on OBD1 95 integra
- Clutch adjustment?
- I need the following:
- Help: 95 integra right wheel alignment question??
- adjustable springs help on integra
- Need Help raising my car...
- AC belt how do I tighten it up? 95 integra LS
- $3000 Integra?
- Still having ect trouble
- [exhaust manifold] gasket
- cooling problem
- h22 vs gsr motor
- idling high???
- firewall bolts size for 3 pt front strut bar
- short ram or cold air intake
- Anyone know where i can get parts for an 89 integra
- o2 sensor help!!!!!!!!!!
- Will this header [fit] my B17?
- Whats up dudes, i have a quetion....
- How much could I get for...
- Running Rich in Bank One
- just a new guy helping a firend out Intera 90
- kit help?
- looking to lower my car, advice.
- Emissions, 1990 LS
- part # plz... i stripped the head
- Opinions on ECU
- Head swap
- need help with my headlights
- oil leak...
- Supercharged or turbo GSR?
- Cam seal plug broken, easy to fix?
- gsr pulls forward when starting
- What ALL do i need to go to manual
- Turbo question
- high and pulsing idle
- camber kit
- Whats your setup??
- Who makes the best performance bushing kit?
- [ITR]front end conversion?
- Major '88 problem
- 95 GSR Sedan? Worth the investment?
- Need engine diagnosis....
- rs ls?
- i need help tightening bolts on ball joints on uca and lca
- dual exhaust
- front bumper
- Some Help Please!!!
- Megan Racing Headers...
- My comp and leakdown test...questions?
- This Is Really Pissing Me Off!!
- gsr potential
- Squeaky chirping sound at idle...like a belt noise.
- what type oil to use for a gsr
- Shifting problem
- Is it worth upgrading to MSD ignition?
- Motor Boating Problem!!!
- ABS Modulator noise
- Fans
- Ignition misfire?
- 2000 Integra ls
- Engine thoughts
- Just like the other dave said
- clutch slipping and smoking?
- turbo
- Blower fan not working...
- integra horn not working
- Buying a 92 gsr
- AEM short ram and stock exhaust
- Defogger help
- My door sounds like it's kinda rattling?
- T1R exhaust
- gsr motor rebuild
- Not Starting
- Ls? Gsr?
- mainetance req light
- Please Advise - 95 Integra H&K Cup Kit Problems
- Can't get motor to idle right
- Do civic 92-95 springs fit in integras?
- da6 cams and cam gears
- parts?
- engine problem
- Rear Windshield Wiper Help needed
- Vtec Not Fully Kicking If Not At All
- Have a question
- Opinons. LS/Vtec conversion or more boost??
- something broke on my suspension
- 97 Integra Need help
- Integra Coolant Gauge Issue
- 92 Acura "i need help"
- How to Install JDM SiR-G Fogz on a 2001 Integra Bumper ???
- Integra Totaled :( Maybe Salvage......
