- How to strip clear coat off of rims???
- Reversing odometer
- is it bad to do this....
- for people with keyless entry and shaved door locks/handles
- From touchup to the bodyshop...
- sparkplug replacement for 96 sedan LS
- ECU Chips
- Ahh, What do you'll think of the upcoming mods!
- is the oem front lip hard to install?
- Turbo or super charger??
- Front Strut Bar?????Difference in Handling??
- well just got an alignment after lowering my car.....
- Rattle sound at certian RPM's
- othe than the headlights and bumper...
- Got Boost? JRSC install pic.
- The typical next step question
- clutch update
- Need help and I have a question.
- What does this mean?
- getting exhaust
- Acura 91 - Timing Belt Problem
- Exedy organic race clutch
- ECU Code 54??
- H&R Cup Suspension Kit
- UKDM Integra
- does 95 integra come in green?
- rear bumper lip thingys
- i need help
- guys..i need your helP!
- New clutch. Opinions please!
- 01 GSR wheels
- Just a quick introduction
- clutch
- Loss of gas mileage
- Lots of questions. . .
- ITR Cams
- shiftpoint
- How do you remove Ball joint of LCA
- What does this do?
- how much do 17's take off of the quater mile time
- Downside to used Cam Gears
- After Market Newbie
- Question about Cams
- Need a lil help making a decision on a steering wheel
- itr header
- 93 GSR vs Prelude
- shaky..shaky
- Junkyard Turbo??
- Compression Question
- New JG headers?
- 98-01 ITR cluster on a 96 GS-R?
- 92 Integra Antenna
- Who is looking to buy rims...
- HELP! need turbo advice
- Dist. Cap and Rotor
- Ecu
- Teg Type-R Ecu
- coilover
- how much camber is too much????...
- Just wanted to introduce myself to everybody.
- hey whats up...
- This Saturday
- Fuel Injector Cleaner...
- Why
- new rotas
- Mugen strut bars and sway bars
- Tire decision...
- Shifter Linkage Question
- 2 Gen JDM Question
- Check out my Teg... Lemme know what u think
- Difference between 94-97 front end and 98+ front end
- Spark plug gap for a 94 gsr?
- i cant connect the axle ring to my tran.
- shift points?
- suspension setup of GS-R
- Hawk HP+ brake pads
- Dc Header
- Noob wants exhaust
- I need Advice
- 'Idiot Light' Question
- more clutch/tranny problems
- Corner Bulbs
- ABS Problem????
- Exhaust Questions...
- 92 integra
- 2nd gen headlights
- Front Jack Point
- Will 1995 exhaust fit on my 1996?
- Car Color Question
- Timing advancement on a teg
- Corner Lenses
- ECUs and their worth
- Where To Get...
- How much should I ask?
- Will broken EGR valve hurt my engine?
- Vtec-What Models??
- ITR header on LS
- OEM Body Kit
- Powdercoating
- Header For Non-vtec Integra
- Cheapest you ever found ACT clutches for?
- vtec engagement
- turbo timer took gave out
- dusted engine help
- HELP! on rear brakes
- wanted: 98 itr!
- best cams for LS
- vafc problem :(
- shaveing head
- First year for gsr??
- Replacing Brake Pads?
- just got chip installed!!!
- 98+ Rear Bumper
- Maybe a new integra owner
- Couple of Quick questions about JDM and body
- Does replacing the GSR chip with an ITR chip do anything?
- How hard is it to put in a bypass valve?
- engine swap
- s2000 antenna ... again..
- high downforce aero parts?
- what to do now?
- Oil change and lube?
- distressing brake problem
- Who whants this kit?
- sunroof question
- got it!
- Hybrid Forum FAQ
- ?? wats the url for New way ??
- Hit and Run
- carbon hoods
- Just did a major tune up... got some Questions
- What Color Is This
- weird color on GS-R sedan
- Attn:May sell the Rex for a Teg?
- Attn: Techs, Passenger door lock problems...
- 250 supercharged hp? give it to me straight, doc.....
- skunk2 coilovers on kyb agx?
- Body shops?
- Integras in Erie Pa.
- Symptoms of hydraulic failure
- engine info
- light weight pulleys
- How to - Swapping a H22a Into a Integra
- Anyone know a good online parts store...?
- AEM brake kit...where to buy?
- is the 1998 white the same as the 1998 white?
- Pricing on Koni Yellow and Ground Controls
- Railings for front seats
- post pics or links for me please!
- BASIC TUNE UP on a teg....What else ?
- HP question
- spark plug wires
- G3 GSR rims on a G2
- good and bad about cams
- Maint Reqd. list of stuff to do
- easiest way to get a throttle position sensor off of the throttle body?
- A JDM final drive question...
- Air Cylinders
- LS/VTEC shops & pricing
- Cheapest Place for OEM Tailights?
- My car.
- A question about vtec controllers....
- NEed pics of Apex N1 On Teg
- A question about a 92gs-r
- ig
- offset Q
- where to get an alternator
- New Exhaust...
- so cal people: where to get JDM front end
- Acura Integra GSR and VTM signal
- help: camber kit question for teg with H&R sports???
- Turbo without intercooler....YES ????
- GS-R Engine Swap
- how much hp gains
- tire dimensions/speedo
- Shaved antenna kit?
- Finally... (pics inside)
- Wheres antenna on 98+?
- Question about GSR
- Got Dynotuned today! Check it out!
- oem body kit on gsr sedan
- Check these cams out...what cams are they?
- Short Shifter
- Please give informative Opinions on Turbo
- Help: Removing stock rear spoiler on DC2
- precautions before running 35 shot of n20?
- AEM CAI sound...
- Type R Front Lip
- Clear Corners
- need a stock shifter
- where is a cheap place to buy redline MTF from?
- clutch or tranny, which si going? help me out.
- ##Who has a low price on a Fluidyne radiator for a 1994 Integra GSR?
- Best c/o system for AutoX
- how much....
- Universal Carsound cat....?
- taking off rear view mirror cap
- Turbo..
- adjusting headlights
- ABS light on?
- Thinking about doing a 5-lug conversion
- Help with Brakes...
- JDM ITR metal fenders.. .
- AutoX and first gear questions?
- does anybody know..
- Good Deal???
- steam cleaning interior/seats?
- Couple Pics of my Teg
- Trunk Spoiler Plug HELP!?!?!!?
- Big Project
- Anyone know where to get a 3'' resonator?
- growing tired of the GReddy...
- Selling the Yellow Dragon
- cutting 9005
- To those with supersonic blue...
- National Grand Prix Pictures.
- Check out my car (pics inside)
- would i need an ITR CAI for this??
- Love the Koni Adjustables
- Motor PICS
- check this
- Please Read To All Acura Integra Owners/fans!
- Help - How do I flush R-12 out of my A/C system (Acura Integre 1992 GS)
- knock sensor code (23)
- CARFAX please JH4DC446XVS021298
- im new and got a dumb question
- ????Door adjusting locks and striker?????
- integra body styles.. generations.. year.. stuff
- Allow myself to introduce...myself
- CEL 45: System Too Lean or Too Rich malfunction in the fuel monitoring systems
- hey all new user here by way of Hondavision and Honda Tech...
- New O2 sensor pricing...
- what should i do
- short shifters
- Lowering Question
- Skunk 2 Manifold Questions
- b18c1 head questions
- Fuel injectors?
- Wings WEst Type W
- (94 to 98 front end conversion??)
- Clutch and Flywheel Combo???
- RS*R Integra exhaust, any interest?
- RSX vs. teg
- g2 teg power locks ...
- Pics of the ride (56k beware)
- Anyone with odd ticking....
- itr muffler
- Please Help in VA
- well it's been just over a year....
- 4-Door GSR?
