PDA
View Full Version : Integra & '97-'01 Integra Type-R
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 [82] 83 84 85 86 87
  1. Is there any way to protect bottom of header?
  2. Compression Ratios
  3. 1 piece headlights...
  4. overheating head unit
  5. 95' GSR w/ 206k mi.
  6. Reduced performance
  7. cd changer question
  8. First time to the track...
  9. ????Maintenance Light on????
  10. What's the going rate?
  11. Any LS/VTECS in here?
  12. Is it worth a B16a2
  13. How Much for an AEM Intake???
  14. obd1 Vs obd2
  15. How long did it take your car to settle?
  16. I Need Help
  17. Need part numbers for Non HID black housing JDM Integra Type R headlight assemblies.
  18. loook at came in the mail today *pic*
  19. ATTS vs. LSD
  20. OMG problem occured today
  21. header wrap
  22. Crower rods on stillen.com ??
  23. Teg Front Lips...
  24. Pondering the thought...
  25. TEG Brakes...
  26. Teg Lighting question...
  27. Ground Control vs Comptech
  28. abs problem
  29. Electrical problems on G2 Integra
  30. Spoon Rear Lower tie bar problem
  31. K.O.S Header for B series motor - Info Inside
  32. 01 GSR & Apexi WS
  33. cwest usdm kit
  34. Carsound Cats
  35. Using Cold Air Intake in the rain
  36. Do DC headers make GSRs run rich???
  37. it it bad to cruise at 4000RPM+ for a long time?
  38. Neuspeed Strut Bars
  39. Supercharger questions
  40. How much will it cost to put a new B18B into my LS?
  41. Maintenance req. light won't go away
  42. wrapping the filter with a bag?
  43. Good websites for these car parts?
  44. missing link/VAFC
  45. all i want is 14's
  46. 94 GSR gets a mettalic rattle at 3500 RPM, anyone else have the same problem
  47. Clear Coat ??
  48. Apexi Ws
  49. can i swap a civic radiator into my integra
  50. strut bar question
  51. right hand drive integra
  52. What do you think of my engine build up?
  53. What shocks for H&R Race?
  54. what's the tinting law in NY?
  55. How much hp would . . .
  56. Air Conditioner Filter location
  57. Timing marks, aftermarket crank pulley?
  58. new teg owner!
  59. CL conversion
  60. good price?
  61. repairing a cracked body kit
  62. itr cams
  63. Any ITR owners showing at NOPI?
  64. 1st Year Anniversary (PICS)
  65. weird hid problem
  66. Prepin for Turbo
  67. what size are your rims?
  68. I just installed my konis...
  69. Looking for a 90-93 Integra...
  70. Compression Test #'s to CR?
  71. What fuel press should I run???
  72. Places in the bay area where i can get a B18b engine
  73. How much for a new B18B engine?
  74. Drag 2 kit for $1600?
  75. oh my god! 400 miles in a tank!!!
  76. Highering my car? Please help me!!!
  77. Worth it or not?
  78. question about shocks
  79. Fading spoiler
  80. How much power can I/H/E generate on the LS B18B1?
  81. wings west
  82. all NJ peeps and surrounding areas, check this
  83. Has anyone seen these tails
  84. H&R Sports Aren't as Low as others?
  85. 98 rear bumper on 94
  86. cv boots
  87. Why does a rear windshield cost $1200 to replace?
  88. why wont my teg start?
  89. Buying Header today... HELP
  90. AEM CAI question
  91. integra exhaust quieter on sohc civic
  92. need help on oil by fri
  93. anyone with SI wheels on a teg?
  94. Anyone know about the Auto Butler Polishing System?
  95. Civic type r cams in gsr
  96. ACT clutch...
  97. car has been sitting for over a month
  98. 01 GSR rims vs 95 SE Rims
  99. what's up with the domestic guys all up in here?
  100. Wheres the fuel pump relay??
  101. my car
  102. just picked up a 95 ls se today
  103. Where are our cars manufactured
  104. Clear Corners
  105. CD Changer Question
  106. 15 inch or 17 inch Rota Subzeros?
  107. Gas mileage with boost?
  108. I'm a new teg owner *pix*
  109. OEM Fog light question
  110. Weird noise
  111. mudgaurds?
  112. Need your help....
  113. Help! on 97 Ls Parts
  114. Finally pics of my R!! They are kinda big though..sorry!
  115. How low is too low?
  116. AEM Water Bypass
  117. Coilover sleeve adjustments after shock install
  118. Top 2 things you're most proud of on your Integra
  119. big problem....
  120. what exactly is bottoming out?
  121. just got koni reds.....got a question.
  122. Just joined...
  123. brake problem
  124. I want to add my car
  125. Integra Door Lock Problems
  126. OEM Bodykit...
  127. rattling brake light from SUB
  128. noise while driving
  129. Good price on a new complete Exedy clutch kit
  130. I ran my car
  131. What Cams to Go With
  132. clutch help quick!!!!!!!!
  133. 94 ls diagrams
  134. What would you get..?
  135. which springs?????
  136. do they make 1993 integra lip kits?
  137. major problem with axles.. help><><><><
  138. Well, it's slow, so ill do this. *pics*
  139. Removing GS-R Spoiler
  140. Oil Coolers
  141. LS/VTEC oil line
  142. type r wing
  143. corner light problemo
  144. waxing all night....
  145. Exhaust Tip
  146. Drag Racing Traction ????'s
  147. Required Maintanance
  148. Whats a good Fuel Pressure Regulator?
  149. What size injectors?
  150. Jrsc Lsvtec
  151. engine swap
  152. 60k miles
  153. Water Leaking in from front right corner of sunroof
  154. Turbo Info
  155. 95 GS-R maint.
  156. ?some kind of problem?
  157. *Ground control vs Skunk2*
  158. Stock GSR rims
  159. 2nd and 3rd Gen Shocks?
  160. are there any clean..
  161. Tanabe exhaust
  162. Vtech vs stock LS special edition engine?
  163. Opinions on the Price of a GS-R
  164. PIcs of my ride!!!
  165. ATTN Integra Owners - Opinions Wanted
  166. Ls/vtec
  167. Advice with which clutch i should go with
  168. Really WEIRD electrical problem...
  169. Tire Sidewall Bulging
  170. Spark Plugs on 2000 LS
  171. Any problems with racing harnesses and GSR seats?
  172. Tow hitch for my Integra
  173. question about internals for my ls
  174. opinions on kits..
  175. GReddy SS 4-2-1 (1 Piece) Header Question.
  176. need pic of blk leathers
  177. blown shock?
  178. Need Help!!!!!!!!!
  179. There is a NX nitrous kit and a NX bottle heater in the classifieds :)
  180. oppinion post
  181. Newbie Prepping for Solo2
  182. big difference between mesh gsr rims & the rota circuit 15
  183. integra ls modes, whats next??
  184. wheel locks
  185. Need advice on Intake/header/exhaust setup for 99 GS-R
  186. Recommendations : Wheel Repair in Tampa / St. Petersurg Area
  187. so a truck hit me in manhattan last night
  188. What tires?
  189. new TIRES
  190. 4 door w/ oem body KIT
  191. Someone backed up onto my hood!!!
  192. Accesories for Integra
  193. '90 LS - where is the ecu???
  194. adding subs in rear speaker area
  195. dc ceramic headers
  196. Tires Rub on wheelwells???
  197. Apexi Worldsprot
  198. regrets
  199. Overfilling gas tank
  200. Modifications / products u regret buying
  201. Dual Exhaust, fit?
  202. Question about Type R vs. GSR
  203. whining when i slow down
  204. supercharger or turbo??
  205. Primary Oxygen Sensor – Heater Circuit Malfunction
  206. Redline MTL voiding warranty?
  207. sunny stylin cf hood.....goood??bad??? help??
  208. wanted:: pics of 96 gsr interior
  209. Which color of yellow would you put on your car?
  210. ww rs type2 lip on 98
  211. Replacing front wheel bearing on 88 Integra RS
  212. Crank Pulley Bolt
  213. Does anybody have the Realtime Racing Integra Video?
  214. Any Pics of a Thermal 3'' ??
  215. Compression test numbers
  216. What makes a car chirp gears?
  217. Legal Tint, I plan on...
  218. Airbox Cover
  219. VTEC Engagement Variables
  220. Opinion (what would you do)
  221. stickin caliper??
  222. 88 Acura Integra stalling
  223. funny smell need help!!
  224. help with my integra!!
  225. if i lower my car more.....
  226. where is the friggin PCV valve on my 95 GSR?
  227. water/condensation in stock tails?
  228. spring question..please help
  229. Tolerance for fornt rotors
  230. teggy clubs
  231. prolock system
  232. h&r springs......
  233. what to do..springs, or headers
  234. When to get an alignment?
  235. JDM ITR Exhaust
  236. Clutch, transmission? This one is tough..
  237. Will a GSR exhaust fit a Type R?
  238. Here's my Integra 95 lsvtec
  239. Recommended RPM's
  240. Sunroof's Rubber Gasket is all Screwed up
  241. HID Kit help!!!!?? A.S.A.P
  242. Pictures of my '01 GS-R
  243. Need some advice
  244. I need good ALL SEASON tires for my GSR.
  245. Convince me to buy this Type R...
  246. Cam help
  247. can someone explain something to me?
  248. Are Falken Azenis heavy tires?
  249. ABS light odd
  250. anyone have 90-93teg B18a crank pulley to spare?
