PDA
View Full Version : Integra & '97-'01 Integra Type-R
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. Time to start tuning
  2. Performance ? On A Type R
  3. Vibration after new clutch install
  4. Help!Wt is the code 01337 for?
  5. Suspension ?'s
  6. 2 Day install
  7. How do you know it's a Type-R tranny and not A GSR LSD tranny?
  8. What camshaft is better?
  9. Horsepower on a b18b motor
  10. LS/VTEC definition?
  11. parts for ls vtec conversion
  12. interior
  13. year difference
  14. looking for a summer project need help!
  15. ball joints
  16. 1990 acura integra window loose
  17. Question about Idle on 91 Integra
  18. Legal Cat or California Dreamin'
  19. battery light on???
  20. Brake Lamp
  21. Wired Header issue help..
  22. Power Antenna sticking question
  23. block max
  24. Stock LS to VTECH
  25. 95 GSR Suspension Q's
  26. Need help, B18C motor and trans problems
  27. Suspension ?? 98 Gsr
  28. 90 integra timing
  29. Best cam set
  30. F'n cooling problems won't stop!!!!!
  31. BLOX intake manifold???
  32. Turbo questions
  33. Question want to beat my friend
  34. installing cams and springs
  35. Supercharging vs. Turbocharging
  36. Advanced Timing?
  37. How do you pick?
  38. 2nd gen integra 14s?
  39. obd2 gsr pcv problem
  40. Shooting for 250 N/A Power, any advices?
  41. Tranny troubles
  42. Copper Spark Plugs?
  43. JDM/USDM dust shields
  44. I found this and thought it was interesting Exhaust Systems
  45. Auto tranny on GSR block?
  46. 97 GSR Distributor fit a 97 LS?
  47. Painted Calipers
  48. I finally know what i do
  49. Precision Head and Machine in San Diego
  50. Your Favorite brands of car parts..
  51. California smog question
  52. rims
  53. B20 crank in a B18?
  54. Swapping OBD1 240cc injectors for OBD2 ITR 270cc Injectors
  55. Guage cluster + mileage issue.
  56. Alt. Belt replacement...
  57. tail light prob
  58. Whats the main difference between LSD and reg. trannys?
  59. What power steering pump is this?
  60. ITR sedans
  61. Help all I hear is squeeeeek
  62. Noob issue: So I failed my smog test today
  63. stupid check engine light
  64. i need a diy for headlight
  65. Throttle Body....
  66. Somebody sideswiped me
  67. Got some extra money, questions
  68. how many quarts of gearoil in gearbox
  69. suspension questions
  70. Advice for buying a 95 gsr. *pics inside*
  71. 96 Integra Fuses
  72. Where The Nitrous? missing the <3
  73. What next?
  74. B16 into a DC??
  75. Is this true about headers or complete BS?
  76. What would cause a random misfire when cold, but only when cold?
  77. Gauge Cluster Not working....HELP!!!
  78. integra cruise control not working
  79. Rings for Nitrous
  80. Manual steering
  81. Help
  82. installing side markers
  83. Throttle body boring / mainfold port matching
  84. Attn header owners:
  85. 4 door gsr's
  86. Light in hatch...
  87. Looking for comfortable seats
  88. major antifreeze leak
  89. ahhh help!!!
  90. How to choose GC custom spring rate?
  91. 1992 Integra Transmission and Start-up Problem
  92. Front Suspension Issues?
  93. Convert Non-Vtec Distributor to Vtec
  94. antilock breaks
  95. Camshaft opinions
  96. gsr intake mani
  97. It probably would have been easier to just PM Shmoo...
  98. Body Part Questions
  99. hard shift to 1st and 2nd
  100. 1st post & Newb Questions!!!
  101. Automatic transmission problems - Integra 94
  102. Problem here, please read.
  103. What's good??
  104. [HID transplant Question]??
  105. brake issue
  106. clutch
  107. relay for brake light
  108. supension question/issues
  109. starter relay switch problem!!
  110. Tachometer problem
  111. 1991 Integra - IACV
  112. loud suspension
  113. Help please!!!!!!
  114. Help!!
  115. Question about fuel pump
  116. Jdm Gsr Vs Usdm Gsr?
  117. gauge cluster not working
  118. Brake light plz help
  119. amber cluster....
  120. Need a favor from a G3 owner with an ITR rear strut tower bar.
  121. Insulator
  122. GSR IM or ITR/Skunk2 IM
  123. Any one with Ideas, pleas post
  124. ITR Headers
  125. Start up problem....
  126. Iridium Spark plugs ?for or against?
  127. ITR parts into a GSR engine
  128. question about my 2000 Integra
  129. my vtec
  130. shift knob question
  131. belts
  132. piston question
  133. What Year/Model Integra Does this Fit?
  134. ls/vtec or Port and Polish??
  135. integra 99 alarm
  136. Anti Theft
  137. Question about engine
  138. cam tech
  139. Cams
  140. Oxygen Sensor
  141. Light weight flywheels
  142. OEM camshaft recognition???
  143. S.D. / Orange County Honda Engine Builders
  144. Swapping Heads
  145. alternator fuse
  146. Big Heating Problem!!! please help!!!
  147. ls-v tec vs. ls turbo?
  148. Cam Specs?
  149. need help with serious clutch issue
  150. Blown Gasket
  151. Fuel Setup
  152. Heater fan quit
  153. gsr
  154. door remote fcc code
  155. megan racing header
  156. header hookup
  157. For Turbo?
  158. Resonation @ 3000 RPM
  159. Integra Door Lock Problem
  160. AEM cold air intake installation question
  161. 95 integra ball joint came out broken seal no grease
  162. Transmission parts
  163. How to set up a custom turbo kit for 96 LS using stock eclipse snail.
  164. Block Guard????
  165. quick question, 92 teg RS OBD0 or OBD1?
  166. Rear pannel replacement on a 92 RS
  167. ECU fuse keeps blowing
  168. shift kit
  169. Turbo horsepower question...
  170. tips for installing left steering rack boot?
  171. Wheel Stud
  172. 1995 Integra Water Pump Replacement
  173. throwing a 17 for VSS help
  174. should i buy OEM or other?
  175. What kind of clutch to get?
  176. 97 LS cranks but won't start, help!
  177. Tranny is Good, or is it?
  178. suspension question
  179. problem with MAP sensor
  180. where is good site to buy just wiring harnesses?
  181. Aftermarket CV boots?
  182. injectors
  183. buddy club cam
  184. Automatic transmission fluid question...
  185. Ah fudge! Burning Oil?
  186. 95 RS Greddy Turbo
  187. TDC sensor
  188. mileage
  189. why are turbos so cheap?!?!
  190. Boosting Type-R?
  191. EVAP & Aftermarket IM
  192. Uk 98 Integra Type R
  193. Brake Failure
  194. b18c rockerarm assembly needed also valvetrain
  195. Throttle Body Question
  196. my DIY air intake setup
  197. Changing 5th Gear
  198. Looking To Move Up
  199. Is my rpm high
  200. Motor philosophy
  201. Failed smog for the 3rd time
  202. altenator help
  203. Head gasket question:
  204. 96 gsr gauge cluster question
  205. Cup holder removal....
  206. Weird Problem... Out Of Ideas...
  207. '92 Integra SeatBelt Sensor
  208. Ok need help with internal work
  209. B18C1 Integra Greddy Turbo Problem
  210. Grinding noise...
  211. Cruise problem!
  212. Crower Stage 2 Turbo Cams
  213. venom injector questions
  214. Is there anything I should check or have checked?
  215. drain plug
  216. Headbolt size?.. M11 x ? for B18B1
  217. Altenator replacement...?
  218. busted tranny
  219. Getting a new Suspension question
  220. Just got a Magnaflow cat for my GSR
  221. Problem with 5th gear!!!
  222. 91 teg sputtering....
  223. Anyone have an ignitor go out?
  224. 92 integra misfire, no CEL
  225. Turn signal blinking fast, BUT
  226. HELP: Someone tell me the color wires going to there horn..
  227. how do you know if secondary butterflies are opening on b18c
  228. 2000 gs-r replacement side mirror
  229. A lessson Learned: Car Dealerships
  230. 2007 Acura Integra Type R Expo 7, join us!
  231. Radiator Over flow tank needed??
  232. will a bad master cylinder affect clutch performance
  233. coolant spraying in my engine bay
  234. speedometer
  235. Transmission/Clutch Issues after Clutch Job
  236. Pic of header... can you help identify brand?
  237. Blowing blue smoke on first start, in the morning.
  238. crx/integra shocks
  239. P1607 PCM Internal circuit Failure 01 GSR
  240. POLL: Quiet Exhaust
  241. gm syncromesh oil
  242. I am taking my Acura to a local Independent
  243. broken window help!!!!!
  244. Cleaning O2 sensor
  245. erradic idle
  246. turbo gsr
  247. Need help with Ignition install
  248. Which springs with 17's?
  249. planning to boost my b20?
  250. Picked up a CTR intake cam over the weekend...
