- Automatic Transmission Woes
- nitrous
- Broken Antenna 98 GSR
- So I finally started fixing my car.. haha
- damaged front bumper...
- left top mount
- Acura badge
- Window won't go up.
- Sylvania Silverstars
- 1988 acura integra (honda motor?)
- Squeaky noise
- How To Remove a Rear Fender?
- New rotors...
- msd blaster 2
- Will this fit
- Installing Cams
- help...
- PCV valve help please!!!
- Slave cylinder
- Bored...thought i'd share the progress.
- Exhausted Exhaust: GSR vs LS
- Questions about Legend caliper / prelude rotor big brake upgrade
- What can cause a popping noise
- pcv help please
- what's wrong with my engine?
- AEM EMS on ebay
- oops!!!
- help please! gsr wont start randomly
- the integra quit on me today :!:
- 2.5 - 3.0 Bar Map Sensor
- Adjustable Suspension
- Cooling Fans...
- CAR STOLEN! 98 Acura Integra GSR w/ JDM Type R front end [AZ]
- wow horrible sounding muffler
- What is the best rear strut tower bar for a 92 GSR?
- hesitation
- Clutch or Transmission?
- Hood won't unlatch....
- trunk leak
- Should this be disconnected? [Name that part!]
- Greddy Front License Tag Cover?
- Will a DC Sports 4-2-1 one piece header fit in a 94 GSR with a Fluidyne radiator?
- Rust Replacement
- Crazy clicking sound from MAP area and relay?
- Ahhh think i need a new headgasket. Opinions?
- Compatiblilty questions
- Strut Bars Question about fitting
- Idle air control valve?
- Vtec problem
- B16A header on B18A
- which B-series injectors???
- Tires for Integra
- Belt whining
- Inboard CV joint play
- Gas for a GSR
- strange power window issue
- ABS Computer Location
- Civic distributor on Integra?
- 99 LS AT. Ignition problem?
- problems with start..
- LS shocks/springs on GS-R?
- Distributor help!! (teg DB1)
- B series versus CRV axles..........
- Do you suggest timing belt DIY?
- Light weight pully ??
- ECU connectors contacts part number needed Tyco Amp
- RS-R Exmag
- Freakin bummer...(suspension problem)
- transmission bolts
- problem installing intake mani...
- Setup Motors
- omg big vtech problem
- A/C problem
- 02 sensor the culprit?
- 98+ front end conversion
- Weird problem
- Drop Time =)
- Emanage
- Check Engine Light
- 91 projector foglight
- 93 rs auto trans prob
- how much boost
- backfiring problem
- ls vtec build...
- SIR-G Fogs on 98+ Integra
- A/C Question
- Hey guys, long time.. Omnipower Quick Clutch Cylinder?
- engine swap/start-up troubles, opinions and ideas please
- b18a and b18b-Same heads?
- Intake Sensor?
- Still need help with 01 gsr
- Side skirt / rocker panel hardware
- Broken spark plug
- 1991 integra engine rebuild????
- Need battery help ASAP
- 2001 gsr ecu?
- will these cams work?
- So I'm going for a piece together turbo kit...
- Short Shifter
- 00 Teg LS Sputtering?
- First Integra
- Lowering 98 GSR ?
- Lowered 90 Integra, do I need a camber kit?
- First Integra!
- Turbo argument [Fitment issues for 2000-2001 MY]
- 1999 Acura Integra GSR Clutch Replacement
- Best camshafts
- What should I max my credit card out on?
- Twin Turbos in a Teg?
- Quaife LSD.........
- new skunk2 mani + 73mm TB...running RICH!!??
- need some advice guys
- ITR Rear and Front Sway bars
- NA B18C1 Build
- Need help with 01 gsr
- blox
- Fuel Rail Help...PIX. HELP!
- gsr rods.help.......confused
- Toda vs DC header?
- Speedo; suggestions?
- Pruven Performance
- timing belt
- rim compatability
- Clutch & Header??
- Integra Type R DC2 seats
- Header ground clearance?
- evap purge system hack fix on a 95 integra
- Turbo Purchase for Teg LS
- gsr w/ type r pistons advice and opinions!!! plz!!!
- Header?
- burning anti-freeze....
- What kind of clutch?
- My new teg
- b18 block with b16 head??
- i was bored.....
- ITR struts
- Strange odo reading
- Add a b16a intake manifold to a b18b?
- header recomendations
- First Upgrade to Make?
- Temporary Fix
- hatch and rack squeak
- Tire question
- Replaced brake master cylinder 4 times in 8 months
- b18 non-vtec
- narrowing it down
- Clutch Stages and Drivability VS Performance
- JDM b16a crank in a b18b?
- 99 gsr question
- new motor?
- motor codes
- 91 acura integra parts
- my 1988 integra
- Supercharger
- Possible setups for my LS which one do you like?
- CTR cam in gsr!!help
- Noob Question 90' Rs Have VTEC?
- 94 Acura Integra LS won't start after hitting a bump
- Wheels
- head questions
- Synthetic Motor Oil options..........
- Filling MTF
- 94 Integra - Engine randomly stops
- tuned p28 in an LS-VTEC?
- Buying a 95 Integra - Questions!
- automatic tranny+cromepro
- Mystery Part 94 GSR
- Buying Intake
- jdm side markers
- Cant start my 1999 Integra GSR
- GSR running awful - Detailed description, help?
- Type R Sway Bars?
- Headlight thought..
- Header/Cat-back issues
- Who makes the best Camber kit?
- S3, and S4 Question
- Vtec Mod Vs. Pistions/Camshafts
- 1995 gsr b18c1 help!!!!
- HELP bad differential of something else?
- Another upgrade thread (sorry)
- OS pistons
- Shopping spree coming soon.
- b16a in dc2?
- 93 Acura Integra Non-v Tech
- Replacement Shifter Knobs?
- [broken] wheel stud
- Starter
- Removing Tint How to
- Turn signal lights problem
- New Tires
- need some help guys
- 91 itegra engine stalling
- 95 Turbo Gsr stolen...
- Brakes
- matching valvetrain
- automatic...ugh...
- Transmission fluid
- Clutch
- j's racing intake
- Temp and Exhaust
- GSR - A Question of Power
- do shocks typically get stiffer when its cold?
- newb Integra question: 4dr ???
- Front suspension & Type R Cluster?
- Pulleys??
- Radiator Issue 98 GSR?
- Front End "Wheel Hop"
- Integra GSR RPM's / Engine Mods / Newbie
- Oxygen Sensor - location?
- Dual Exhaust?
- b20 problems
- Cold start
- Intercooler or aftercooler?????
- test pipe?
- GSR Rebuild Suggestions
- Decided on a manual swap
- Shifting Between 1st and 2nd
- Alternator
- Help replacing heater control unit 91 teg
- Killer G2 Integra
- 05 integra idle goes up and down alot while warming up
- Foglight question
- Throwing a CEL Code 21
- What headbolt is better?
- anyone ever painted the silver jdm dc2 headlights to black like the type R ones
- awd integra
- rota wheels
- ecu question
- Pull tab on one rear seat in 94 hatch broken... how to fix?
- Blue dash lights
- tokico suspension
- Suspension Suspense
- auto trans options?
- high pitch sound, need help identifiing
- Just Wondering
- Problems: Fast idle / surging idle / weird temp reading
- excessive tire wear
- Best Performing Stock ECU
- Rear Tie Bar
- shopping for the best
- Rear brake question(interchangeable pads)
- door panel insert problems
- Birthday [98+ turn signals]
- need help
- Help
- Hello Everybody
- 94 Acura Integra - Remove interior door panels
- new clutch.....now car wont move?!
- oil pressure guage connected to the vtec oil pressure sensor
- HID Light ?
