PDA
View Full Version : Integra & '97-'01 Integra Type-R
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. Headers
  2. Got ma new clizutch...
  3. B18B1 Timing
  4. i need compression numbers !
  5. Starting to think about getting a type-r again...
  6. UPS sent me a gift ;)
  7. pro's and con's between 4-1 and 4-2-1 header design
  8. 2 questions: tire and motor oil
  9. integra lips help
  10. Questions on High flow cat.
  11. Painting stock plastic side skirst
  12. do you need a fpr with I/H/E and a high flow cat
  13. Stolen g2 gsr!
  14. Type R Lip w/WW side skirts?
  15. Using OBD to scan miles
  16. Passenger Side Mirror HIT, Where to buy a cheap replacement and how to install?
  17. '91 Integra front suspension
  18. Cranks but won't turnover
  19. gsr insurance costs
  20. stock pad or aftermarket
  21. tranny noise...
  22. stock car running rich
  23. 1990 Acura Integra GS *Need Carfax Report*
  24. Does gasoline eat paint?
  25. skunk2 springs..killing my shocks?
  26. an1 got 17" racing hart C5 's on their teg? or something similiar? *5 thick spokes)
  27. Help with computer message
  28. I am running rich and need help, what should I do?
  29. Tein S. Tech springs on stock shocks
  30. some ****er spray painted my integra last night
  31. Reset CPU?
  32. What U Guys Think About This
  33. Radiator Problems
  34. !7" wheels. What size tire?
  35. Compare 1999 to 2000 Acura Integra
  36. What's Next
  37. brake questions... yes i searched
  38. short shifter causing problems
  39. Factory Performance Control Arms?
  40. I just got myself banned by posting SPAM.
  41. Racing Pedals
  42. ono!! maintence req light
  43. STR Cam Seal.. any good? anyone have them or have bad or good expirences with them?
  44. My cars done....
  45. Original MSRP
  46. momo wheels
  47. 2.0 L B18b?
  48. o2 sensor-help
  49. Superhonda
  50. Adjusting Cam Sprokets
  51. 4x100 to 4x114.3 conversion
  52. What kind of plugs and wires would you recommend?
  53. Turbo set ups..
  54. what changes i product line of integra from 98-2001
  55. '96 Integra LS Hatch
  56. shock question
  57. Traded my lip
  58. 87 Integra shudder
  59. Stupid Question
  60. WOW!!!! My type R
  61. Identify ECU
  62. Car transport carriers
  63. if i were to block off the waste gate...
  64. Radiator is leaking
  65. Difference b/w GC's and GC's Limited Ediiton...
  66. Painting Valve Cover (merged)
  67. Want to shave badges, question
  68. proper way to use meguires quick detailer?
  69. toda spec B or skunk 2 stage II
  70. Best motor to put in a 94 Teg ??
  71. what yr.
  72. Launching at what RPM...
  73. Upgrading brakes
  74. intake manifold q's (itr and skunk2)
  75. 5 lug conversion - how to?
  76. ITR vs GSR calipers
  77. OEM ITR front bumper
  78. ls to vtec info needed
  79. LS downpipe in a GSR?
  80. k guys, wheres the fuel pump relay...
  81. TIRE question Nitto Vs Khumo
  82. Check Engine Light!!
  83. H22 in 93 teg
  84. OEM Keyless Entry Q's
  85. Bolts on cat
  86. A lot of people having trans/clutch/synchro probs.
  87. Post pics of your integra w/ H&R or Neuspeed Sports
  88. Has anyone ever....
  89. Quick question: spark plugs are 14mm correct?
  90. question on swaping engines
  91. turbo manifold question
  92. Having to clutch several times before getting in gear (help)
  93. JDM Front end??
  94. Altenator- NO GOOD!!!
  95. 3500 at 120 km/h ???
  96. April 19th Massachusetts Meet
  97. April 19th Massachusetts Meet
  98. Octane Boost?
  99. Head Gasket recommendation
  100. Help Autometer Pro-comp pro-stock tach install
  101. How many of you use Synthetic Oil instead of regular oil?
  102. Darton Sleeves...
  103. Pics of Kaminari sides and rear?
  104. FS: stock 98 CW ITR 18,000mi
  105. Where's the engine code?
  106. Jacking up an Integra
  107. Idle Help!!
  108. Gs/ls/gs-r?
  109. HyTech or Toda
  110. ANY ONE KNOW TH PHONE # TO V-Spec IN CALIFORNIA
  111. b16 rods in a b18 block...compatible??
  112. strange noise when accelarating
  113. HELP Tech Infor Needed: !!!!!
  114. Camber????
  115. Hir 80w
  116. nitrous shot
  117. light bulbs
  118. stereo or Exhaust ?
  119. Window Tint Stripping
  120. Detailing Type R's rotors, calipers and wheelwell
  121. rebuild?
  122. Tie Bar
  123. Clutch Install (B16)
  124. new member
  125. Are there any differences between the LS, GS, & GSR in terms of brake system?
  126. New with an 2001 ITR!
  127. how do you know each of your four corners are the same height with coilovers?
  128. Integra Headlights
  129. Getting my new clutch and flywheel...
  130. your teggys 1/4 time
  131. tire width
  132. adjusting the projector beams
  133. Anyone have experience with the H&R Cup Kit?
  134. 2 problems NEED HELP
  135. Painting Headlight Housing
  136. ITR CAI question
  137. This car is Awsome
  138. 98 Type R with P28
  139. KYB AGX skunk2 problem
  140. vacuum test
  141. Good place to find rims?
  142. Carsound Cat
  143. SYNCHROS??
  144. Toda Spec-C
  145. g2 altezzas
  146. Does your hood steam in the rain too?
  147. which are better: tokico illumina or kyb agx shocks?
  148. '89 Integra LS
  149. aem big brake kit and brake pad
  150. LUG Nut Accord conversion??
  151. Help with FAST IDLE THERMO VALVE
  152. Problem
  153. Got new rims on the way
  154. condensation in head lights
  155. Slicks!
  156. Unorthodox Racing Pulleys and shifting question??
  157. Type R Pistons, Type R tranny
  158. synthetic oil???? or no synthetic oil
  159. any1 have pics of tegs with racing hart c5's?
  160. No such thing is a Black ITR...then how do i own one?
  161. Zdyne Group Buy (for those with a pr4 ecu)
  162. i'm new need help how to take off the key chip
  163. help with tranny fluid bolt??
  164. New Forum
  165. !!HELP!! BOMEX body kit... Where to find?
  166. Rattling noise...
  167. 95 Integra - leaking
  168. Optimal tire sizes for a gs-r
  169. Light bulb question
  170. Best boost for Integra
  171. Car hesitates on take off
  172. any opinions about goodridge or earls s.s. brake lines?
  173. Few drag racing tips please?
  174. Needa picture of a paint color
  175. brake-squealing problem
  176. Post Stage 1
  177. Help: I'm a new ITR owner and have some tranny problems.
  178. short shifter
  179. is the car prewired for a changer
  180. DOH!!! i meant, are ITR labeled P73? not P72
  181. Rims purchased, now the wait...
  182. ~~~~>I need 94/up INTEGRA COMPLETE SUSPENSION<~~~~
  183. fuel injectors too big....
  184. Here a Picture of my Type R
  185. Smoked bumper lenses
  186. Looking for JDM 4 Door ITR Sideskirts
  187. clock problem...
  188. Shaved Doors...
  189. Emblem Removal
  190. Need help fixing a few things....
  191. GSR and theft
  192. G2 KYB AGX's
  193. Importfan.com
  194. suspensions probs.
  195. Finally dropped my car off
  196. need help with cams!?
  197. HELP ME!!!!
  198. need adv
  199. tires?
  200. Coilovers
  201. distributor question?
  202. Importing a Canadian R to Texas??
  203. NEED HELP ! ASAP ON Tips.
  204. Nitrous Question?
  205. help
  206. Finally got the 95 rs!
  207. Acura Question
  208. Reputable Dyno shops in Southern Cali.?
  209. Headlight????
  210. tires
  211. 99 integra leather seat
  212. Thermal or Magnaflow Cat-back?
  213. Exhaust sugg.?
  214. type r lip
  215. flowmaster exhaust...
  216. New ITR Owner
  217. selling the GSR, buying a '95 GS-T
  218. Anyone here hardwire their Radar Detector?
  219. Stereo Equip...
  220. O2 sensor
  221. !!Urethane Body Kit Manufacturers LIST!!!
  222. data link cable
  223. I finally have some money!
  224. dc sports cat back 95 rs?
  225. exhaust HELP
  226. short shifter.
  227. 2-degree Ignition timing?
  228. short shifter?
  229. can someone answer this for me
  230. Considering buying a 95 LS
  231. Pic of my split clutch lever.
  232. Pic of my split clutch lever.
  233. anyone knows?
  234. Went to the track on Friday
  235. I have a GSR hp question..
  236. best struts??
  237. Questions on installing camshafts
  238. Albany Meet
  239. Why are my brakes not working? HELP!!!
  240. JDM HID type-r headlights
  241. Moroso Oil Pan?????
  242. would like some feedback...
  243. How the hell do I.....
  244. Wiper Blade Motor
  245. power
  246. Advanced Clutch Technologies
  247. where to find spoon n1 online
  248. How To: Deal With SRS Indicator
  249. Spoon Type-R???
  250. Engine Specs
