- will a 97 Type R lip fit a 99 integra?
- Well, not sure whats causing this...
- Whats the difference?
- CAI vs SRI
- tire question
- tanabe hyper med vs apex dunk
- 94 ABS accumulator removal?
- Installed H&R Sport springs and brakes...
- Need pics of Cimate Control Unit
- Integra G3 Stock Height
- Lip spoiler pics?
- axle nut...
- Clutch replacement - a few questions...
- Gas Mileage?
- alarms?
- fill in wheel well gap or not?
- Fuel Pump Fuse
- Secondaries dont work
- My Dream Type-R
- What next?
- Who has Hyper Ground Systems
- How do you get a smell out of a carpet??
- ebrake sensor?
- Integra prices..
- Any good mechanics out there?
- fixing sunroof rattle
- SP or Evo
- bogging/stuttering...
- Is the RSX(JDM Integra) Type R ever coming to the US?
- Suspension
- Spring Rates
- C.E.L what do i do?
- H&R Springs on G3Teg - Pic Request
- Problem diagnosis... help!
- how to check if the engine is worn out
- short shifter-thoughts
- Tranny fluid Q
- fuel tank capacity for a 89, teg
- HELP !!! 95 GS-R...tailights dont work !
- ABS Problem
- JMD integra headlights. How much in japan?
- New integra check it out.
- HKS Hiper or Greddy MX
- 1986-89 Integra
- so exactly how much does your wheel weight effect your 1/4 time?
- What are signs of an axle or cv joint going out?
- Pedal Wear and tear. Aftermarket Pedals?
- Must go faster
- Auto X in the Metro Area
- How can I reduce loud/noisy motor?
- Is this that good a deal or not?
- Hi i am new + 1 question
- So, what kind of power should I be making.........
- whats the best kind of header for a teg
- helms manual?
- Cheapest Place to buy Rotas?
- Gauging intrest... Carbon fiber and fiberglass rear deck lids
- Max HP on stock fuel pump?
- A few exterior mods..yay or nay?
- My own passenger door problems..
- Better Auto Tranny?
- yes i have found a place...
- breather filter
- ECU?
- Red transparent paint
- more pics of teg. *i think 56k is fine.*
- Oiling all intakes?
- READ THIS! - you will not believe it
- what kit is this?
- Alabama Region Solo 2 Super Summer Shootout July 6th Huge Course!
- Got My Rims On.
- Damaged headers....
- Weird buzz sound from under car....
- which do you prefer one day or two day DE Events? Planning some DEs
- lowering h22a integra?
- mini me swap???s
- new headlight casings????/
- Fuse problem?
- Pissed Off!
- Power Window Problems (already did a search)
- VIBRATION WHEN STARTING, ANY IDEAS?
- replacing clutch
- Spring Compressor
- ah yes.. my new toy....
- bolt on tranny for integra
- gsr intake manifold on ls
- Type R conversion
- 10.3 OBX Wires
- Gauge Cluster -- Problem!!! 1992 GSR!!!
- Having engine trouble, need help
- JRSC High Boost kit?
- ITR vs 240sx
- Engine swap or build
- looking for a type r shell
- Sylvania Silverstar bulbs
- Integra OEM kit
- specail edition question
- Wierd noise?
- 4 lug vs 5 lug
- KYB AGX / Comptech Springs (pics/review)
- Integra Type R - A good everyday driver?
- Nice Teg
- I might have found my car BUT>>>>>
- Question about GSR...
- a/c stinks
- B16a2 Block and Crank on B18C
- Check engine light ? Code 9
- Integra pcv valve
- post your websites
- integra gsr with skunk 2 stage 1 cams
- how is the gsr theft in the bay area?
- any help (tell me what you think)
- EXHAUSTS....
- 88 crx hf or 89 integra ls
- YOUR TIMESLIP!
- Side skirts for ITR
- GT2: post your fastest timeslips
- TYPE R or a GSR
- wondering on a price
- Is this Full Coilover Set good?
- increase torque...
- Remote door lock problem
- camber 4.0?
- At the dyno again, HyTech powered car, plots and modification list inside
- anyone for spooMs
- GSR Stock Spark Plugs
- i need modded type R pics for my gallery!
- where to find 02 sensor on ecu
- Auto Teg 1/4 Mile Times
- Wat clutch for a 98 SIR? helpin a friend
- black housing bumpers
- MSD Box For Vtec Motor???
- MSD Box For Vtec Motors???
- 90-93 JDM seats
- Real serious question
- weird noise?
- Anyone heard about this intake
- Who has stainless brake lines on their Integra?
- buying a gsr
- DA auto to manual swap
- Kumho's in the snow
- GSR exhausts, searched, please don't grill me
- does this seem right to you?????
- Attn: Please Use The Search Function
- Will 97+ teg brake master cyl work in a 94 teg?
- Getting Pistons....options...is this safe...?
- Header, Exhaust, cat back
- Integra hatch... Too small for my sub box...
- Question on apexi vafc
- Header Suggestions!
- replacing trunk components.
- Removing Spindle nut to get rotor off
- Brief R Questions
- RPM limitation
- what spark plugs to use?
- what gas to use
- I Need Ls/vtec Help!!!!!!!
- Best Exhaust
- Quiestest aftermarket exhaust/muffler?
- Anyone Selling a silver spoiler?
- Coil Overs or Springs
- camber? or no camber?
- rear seat swapping
- Paint Job
- S-AFC2 or V-AFC -which is better for teg
- Halos!?!?
- skunk2 intake manifolds
- Camber Settings
- venom or zex
- b20 pistons in a bored out ls
- Losing AC w/ chipped ECU?
- Question about forced induction
- lowering springs w/o shocks...
- What kind of 0-60 times are you guys getting?
- Good price for a 94 RS?
- New mods for the teg.
- Clutch Problem
- Engine pull to Jdm front end conversion...
- 205/40/17?
- Neuspeed Race Springs
- Just found a picture of my car..
- Security Suggestion!
- Well... that didn't take long...
- problem with A/F in LS/VTEC
- brands of superchargers
- 2000 ITR spring Color-code
- what free mods can I do for my 98 LS?
- front end is shaking!!!!help!!
- K&N Airfilter
- dash kits
- suspension?
- headlights.
- picking up my integra today
- hood / trunk locks?
- OT: does anyone know how to get rid of possums?
- comptech or K&N filter
- Crazy car alarm!
- My Integra Value
- is this the correct plug wire order for gsr???
- Anyone here try the throttle body coolant-bypass mod??....
- JDM ITR Gunmetals
- Shaving the Emblems
- All motor or Turbo or Nitrous
- Stuck in Drive
- SW388 on a nbp itr
- Next mods...
- Engine shakes at upper revs.......
- help a newb on his CD player
- stock gauge cluster for 97 gsr
- Ground clearance vs Suspension drop
- What causes clutch chatter
- Fuel Rail??
- Car help
- does lowering your car wear your tires out faster?
- Choking at VTEC w/ Skunk2 cams
- do you guys ever bump your head getting into your car?
- Stock CD Player doesn't play CDs
- shaved door moldings, how much?
- remove badges?
- Bbs Rims
- 17 inch 5 lugs?
- lowering springs
- Help! Low compression in 4th cyl.
- white smoke wtf!?
- JDM TypeR Transaxle conversion
- Free exhaust system!! 98-99 Integra GSR
- how much do i need to drop my 96 sedan for my rims to tuck?
- Should i add EXTRA tranny oil for better shifting?.....
- where can i buy WW kit in pieces?
- sonic blue or purple?
- Wheel Size
- are there 2 different styles of ITR lips?
- what ems are you guys running??(few more questions)
- not boosting? need your help!!!
- What psi u guys running on ur tires at auto X events?
- OEM Body kits help!!
- replacing a door
- Axxis Ultimate Integra
- Help
- knock knock
- Looking for this shift knob..
- stock stereo?
- JDM engine question
- Who Knows
- your opinion?
- damn it! Looked all over the place..still cant find it
- DAMN IT..Looked all over...still cant find it
- Reserve your copy of the official Expo 3 Multimedia CD here....
