- 94 engine and trans will fix my 91 integra
- Where's a cheap place to get Stage 2 or Stage 1 clutch?
- 94 Accura Integra Tach Meter Clicking Noise (help)
- integra rims sizes
- Will I be happy with this turbo GSR?
- 2000 Integra Air Conditiong Sudden Failure
- 4DR LS Brakes on a 1992 Civic?
- Teggy's Sold :(
- Code 13 91 integra OBD-0????????
- What Is This!!! -5 Imgs
- door actuators...manual to power :) ...question
- Cat issue n question...
- Window switch same for civic?
- wheel bearings
- havin to press gas pedal to get my ls started. Please help.
- Back in the game...just got a integra!
- Won't start in warm weather.
- Help please..Another no start
- will this linkage work
- 91 Integra I Broke Off A Pully Need Help!!
- Synchros are bad..What's next?
- Checking My GSR 4rm the botton
- 99 motor with a 91 tranny, what axles
- Question of JDM Part Prices
- v-tek
- quick help.. troubleshooting
- clutch help please
- Interior Question
- getting screwed by the shop
- v-tec ?
- Whats it worth?
- '97 GS Bolt-Ons.. Advice..
- need b18 guru help please
- flywheel and clutch
- Transmission broke!!
- shift linkage
- Boost Leak Tester
- fail MIL/CHECK ENGINE LIGHT
- How do you wire up the horn on a JDM DC2 Honda Integra Type R Steering Wheel?
- Coolant Pumps Into Overflow Tank But Not Back Into Radiator.
- Walbro 255 LPH & AEM Fuel Pressure Regulator
- Airbox bolt
- suggestion for lowering car
- suspension help
- Anyone's Teg Boggin At Low Rpm's?
- Integra not starting
- Transmission Issuses?
- code63 after exhaust sys install
- Air filters
- Service Manual Questions
- gsr help plss
- If its not one thing, its something else
- Cams & cam gears question?
- my lights are not working
- when i turn left...
- bearing Q's
- 94 integra swapped 97 gsr
- Need Help /advice very fast
- Changing transmission fluid
- What's wrong? (poss driveline?)
- RPM start up issue
- Timing mark issue
- ITR axels in an ls?
- exterior cleaning
- 2001 Integra GSR, SRS Airbag light will not go off,nopower from the OBD plug
- Basic tune up
- new timing belt?
- How high can i go? (rpm)
- GSR doesn't start, distrubutor problem i think
- Brake question
- burning oil
- Crossing border with parts and/or car mods
- Camshaft seal-
- first time gsr owner w/newbie questions
- Question for a friend
- tegra elec. problems... could use some input please
- will 00 civic si greddy header fit my 99 ls?
- 90 Integra Cooling problem
- Damn you, Omnipower!
- Question on Seat slider interchange
- How do you repair damaged clearcoat on gsr wheels?
- Shmoo's GSR Engine Build: Operation 400whp not 56k friendly
- Tranny is going
- Bushings for a 95 integra
- part number help?
- GSR Transmission
- Gas question
- obd0 to obd1
- VTEC on vacation
- help
- Clutch noise v.throwoutbearing?
- Wheels to big
- Spring install ruined my shocks?
- click noise
- Good alternative
- different engines
- shift linkage
- my car keeps dying..
- A/C will not blow cold
- engine for 96 integra
- installing a skunk2 intake manifold
- How do you get a firm brake pedal? Gravity brake bleed?
- help
- Clutch n pedal question
- Sunroof
- exhaust questions?
- well the teg is gone :(
- Stock Cat Replacement
- Don't buy autozone axles
- Anyone using JG PRO Series Head for B18C
- Finding Acura center Caps for my 03 Honda Civic SI EP3 Alloy Wheels
- my teg has gone dumb...
- Why are 15" tires better then 14" LS?
- Clutch problems
- Rim/Tire question
- Killer B: An Interesting Article
- My Teg was Stolen!
- keyless entry
- ITR 5lug question
- 88 Integra AC convertion
- Crower 404 + Nitrous
- unable to locate markings on pulley for TDC adjustment
- 98 type-r vss
- warped rotor
- Acceleration Problems...then car begins to die
- New But done some research, Please offer your advice...
- Exhaust Leak...cannot find it!
- Iridium vs. Platnium spark plugs: Is Iridium worth the extra $$$?
- Gator Axles
- Integra 96 no stero power
- Acura universal holding tool for p/s pump?
- bad linkage maybe?
- P/S pump reseal kit, how to?
- Shifter shaft was hott
- acura integra tail light water
- key fob
- Losing power?
- Huge Problem
- Transmission Problem?
- I need front side windows for ´90 4D Integra..
- your thoughts on header
- Greddy Evo2??
- blox or skunk2 pro IM??
- YS1 tranny
- 90-93 da6 integra armrest--- NEED HELP
- Integra AC R134 conversion
- exhaust tickets suck!!
- Starter removal...
- Stalled out...then couldn't start
- name that engine!
- Header?!
- Noises
- rattling noise
- New Project! Bringing my 01 GSR back to life...
- Greddy Turbo Kit Injector Upgrade
- Total suspension revamp.
- Lagging start-up
- COde 20 ELD please someone help
- integra ignition switch
- New headlights.
- a/c not workin
- Help, Integra '88 Horn not working
- Jerking problem?
- A couple questions before Crower 404 Cam Installation
- 94 GSR Wont Start
- Built or Bought?
- valve adjustment
- OEM ITR Battery
- Crackling noise
- dizzy question
- 94 teg wont start
- shifting difculty
- I need help! (hood&windshield to Finland) PLEASE, HELP! =)
- shift boot adjustment
- Looking for a GSR
- Break Pedal sometimes goes to the floor
- Integra Radiator Pressure Problems
- 3 way Catalytic converter question?
- Wheels too big?
- My new ride + some goodies
- regular unleaded gas vs premium
- Body Panels: Best place to get them.
- new integra owner
- please help death wobble
- Will a 02 Civic Si or 05 S2000 steering wheel fit on a DA?
- What I need to lower my integra..
- '90 Integra starting problem: help?
- Solid Check Engine Light
- car STILL backfires...
- which CAI???
- Heat shields necessary?
- oil leak from drain plug
- Difference in Engine parts?
- 90 Integra head options?
- 94 teg ps
- rage header
- Integra Type R valve clearances
- another tire is losing air...what gives?
- Damsel in Distress
- shop jacked my bumpstops! Help please
- Installing some new things need help
- Pricing on Rims and wheels =)
- Dimming Headlights!?
- gsr turbo problems
- overheating
- Tire/Rim question.. Im a noobie
- Question about my b-series tranny
- Which spoiler should I put on my 01 GSR? The stock GSR or the Type R?
- Some Questions About b18a1 Tranny
- Coolant temperature sensor issues??
- Does Anyone know where to find the OEM bodykit for a 2001 Acura Integra GSR?
- Normail oil burning?
- What do I need to buy to change a head gasket?
- 96 nose on a 90
- Vibration upon acceleration
- 95 GSR still F'ed up
- CEL Code 67
- New Parts :)
- 1991 Acura Integra - Stock Muffler
- is this normal?
- Timing Belt Installation
- Which K&N filter for CAI
- where is Starter Relay on 93 Integra???
- 98 LS Blues
- A/C out
- Which intake is better?
- Touch up paint
- Shifter arm removal.
- Ft. Lower Control Arms
- Antenna Problem
- RS-R ExMag: To Be or Not To Be?
- valve springs for B18A
- 94 Teg not getting power to fuel pump
- Switching to Synthetic
- Door Indicator And Brake Warning Lamp
- Fluttering noise when the clutch is out
- Key wont stay..
- Question about ordering parts Acura online..
- Fake knock off GSR wheels for sale
- BODY JOB advice - includes pics!
- Toda header with Apex'i WS II
- Rebuilding Turbo
- ***Which aftermarket brand cam seal works?***
- keyless push button start
- whining coming from engine bay
- Hatch stuck on G3
- Choice of Exhaust System
- Anyone put a JRSC on a 90-93 Integra?
- Tach Problem
- exhaust system
