- Nakayama rims
- jdm nissian skyline taillights
- about Comptech filter...............
- wiring diagram
- fuel pressure setting
- where to get gaskets.
- question on timeslip
- did i get a good deal??
- Rough shifting
- rear bumper problem
- Just some humor for today
- Body Shops in the Raleigh, NC area
- jg intake manifold or itr intake manifold all motor setup?
- are oil coolers worth it?
- Pic from last auto-cross
- greddy emanage...
- stock injector size??
- 2001 ITR steering wheel on '94 LS
- Vtec burning oil
- GSR tranny
- So I'm lookin for a rear bumper...
- wheel tilting outwards
- Better OEM air filter replacement: K&N OR Comptech ????
- Fastest N/A ITR on this board?
- New driver looking for good integra!
- Lo Jack
- Redundant Question / 1998-2001
- Lightweight Flywheel, anyone have one?
- changed fuel filter, car wont start
- Mant. REQ light is on...?
- Making an Integ RWD
- better headlights for 94-97
- Remove Inner Liner for Larger Wheels?
- new ACT clutch
- What mods should i look into getting
- what kind of exhaust
- Manual Trans< Help!!!
- chips really work?
- brake upgrade?
- Engine Bogging! Help!!
- lower control arm removal
- First engine mod...more to come.
- Digital Guages instead of Analog
- Air vents speed setting 1 and 2 not working. 96 Integra... Suggestions?
- how do you install a Oil Catch Can??
- car alarm with pager
- How do I know if my PCV is bad?? Been getting bad gas mileage lately.
- HELP*Wut year/model Integra is this and wat modifications are done to this Integra??
- Advice on setup
- front lower arm
- Resetting ECU without pulling battery terminal...which fuse????
- Reseting the ECU
- My setup
- Is there a "best" year GSR to get?
- Bog down in third and fourth
- for 97 integra LS, when do we need to change timing belt, etc?
- time for tires
- Throwing codes is cause problem
- Help, loss of power after shifting to 2nd
- anybody with a fbp/nbp wanna trade for a py
- Difference in 1999 to 1997 p72?
- HELP!!! Keyless entry woes
- people need to open their eyes....
- dealership itr's???
- When to Launch
- Has anyone used Zaino products before?
- carbon fiber hood
- Mugen Front Fascia 90-91 Integra?
- Need to replace rotors. Do I NEED to replace pads also?...
- poly or rubber ingalls?
- Car Shaking
- Rear speaker wire - which on is + and _
- steering sounds like a cellar door
- secondaries open all the time?
- installed header
- Phoenix Yellow paint needed
- Here is my new manifold I got today
- Pics of my dyno
- Just Wondering
- can someone post my dyno chart??
- rebuild?
- Gauge modification
- Finally got rid of Mazda
- I Need Replacement Parts
- żżżmaint Rego???
- what color to paint my car?
- advanced timing - making odd sound
- gas probs!!!!
- Installed J's intake yesterday
- Are LS and GSR Fronts the same??
- smokin' at Vtec
- Need Cheap JDM Conversion Kit!!!
- Short block pics
- <<Metro area Type R's>>
- Half Cuts vs Engine Packages.
- nawz and turbo
- beasty18c5's set up pics (preview)
- Best exhaust diameter for turbo setup?
- i/c question
- 93 integra ls clutch pedal spring question
- turbo; which route should I go for?
- s-afc
- need ideas(liscence plates)
- better shifter dual single bend or straight
- 2nd gen teg, type r engine swap
- *cheap koni yellows*
- Installing CAI for 91 Teg
- 2001 ITR steering wheel on a '94 LS?
- individual throttle bodies?
- body work
- 17x7.5" rims
- best cams for a B18A with a JRSC
- Need help on choosing a size of tires
- does 97 integra LS coupe come with clear coat paint? what's the mpg for same car?
- Recaro ITR seats
- WANT TO BUY: 99+ Integra Front Driver's side ABS/Wheel Speed sensor
- where to buy oem body parts???
- Re-welding buzzing A-pipe: part #s for bolts & gaskets
- Question for you guys that have AMSOIL oil
- Boost on gs-r stock internals
- Transmission Fluid:
- Clutch Help, quick plz
- lowering springs
- How to identify a turbo?
- Compression Test Results- good or bad?
- TINT PROBLEM......I think i got robbed...
- Dh-racing "Space age" Intake Manifold
- swappin blocks...quick question!!
- ii hate people
- A Little help w/ silencers
- Which is better, a stock ITR air filter, or a Spoon replacement filter?
- brake problems
- Is this '90 G2 worth it?
- ITR
- Speed Shops in Buffalo?
- which flywheel
- To all you guys out there who have removed your power locks...
- drag rims
- why do people put CTR pistons ect in their gsr's?
- Seat Q
- eibach pro system
- B18 powered Civic and B18 powered Integra
- B16A
- HELP for my integra!!!
- help for my integra
- Want to build up my B18C1, how should I go?
- RS integra
- launch @ what RPM for best time?
- Popping noise from exhaust
- check engine llight
- oil leak found
- $1000 to spend on gsr motor, what do you do?
- greddy evo exhaust or skunk2 megapower
- JDM mirrors/shell swap
- How light is to light
- CE light
- Rattling noise in exhaust
- no. 9 code 89 teg.
- Closest Aftermarket to stock 98 rims
- VTEC surge... how hard?
- aftermarket throttle body
- more low end torque???
- How do you get by emissions?
- Smokin' High RPM'S HELP
- mugen lip help
- 90-93 JDM one piece headlights weird glow??
- has anyone put 17 inch without drop?
- How Much Will Suspension Drop Cost?????
- Anyone Heard Of Sprint St Brand Shocks?????????
- AC drop
- Wich Motor Oil is best to use
- Transmission Rebuild Problem
- Permision to create a ITRCA Logo (attn. mods)
- rod cap bolt torque specs
- sleeper/hidden turbo setup
- Eagle Talon TSi AWD or wait for a GS-R?
- Anyone with Tein Coilovers
- How do I make mine to look like this????
- smelly exhaust
- How many of your run 195/50/15
- what to do 2 an Integra Vti-R?
- exhaust question difference 2 or 4 door?
- Aftermarket sway bar endlinks
- will 98+ teg bumper lens fit on 94-97 tegs?
- Bridgestone S0-3 or Toyo T1-S?
- Valve float?
- Lame or OK?
- checking oil
- lucky find
- Somebody hit my car :(
- I need some 1:1 ratio G3 GSR gauge scans
- ? for everyone with a lowered suspension
- How to get steelies off
- Thanks to everyone at han
- '92 Integra Rear Mud Guards?
- Lame or OK?
- stupid icebox question
- Apexi WS- quick question
- JRSC on the ITR
- Ok I want to buy an Integra, but I'm new to the scene.
- 0-60 times
- s2000 trans in teg?
- ITR Red Seats?
- Loan out your Honda Pulley Tool?
- '92 Integra Floormats?
- Stolen Type R
- Why do/don't you like the Integra more/less then the RSX?
- Is the K&N OEM filter replacement worth it???
- hard to shift
- 03 si vs 98 ls
- Question about o2 sensor
- STP fuel injector cleaner?
- spark plugs; how tight should they be?
- Wheel Bearing... and hub?
- Help with plug wires...
- !991 integra 4/dr
- Gsr 4/dr squeak
- Thinking about buying V-AFC controler for GSR
- my uk itr
- No beef.. I have legit hid ?'s
- Engine Problem ..... anybody can help?
- honda fest
- Anybody got Spoon Sports front lower strut bar on their car
- My babe !
- Finicky starter
- i need type r interior
- ECU question
- would OEM side and rear skirts affect performance?
- Spoon Air Filter
- Pics of my R
- Problems with fit on Comptech Icebox
- If I were to sell...how much could I get...
- a/c
- wastegate v. ebc?
- quick question 4 ITR owners with jdm conversion
- Valve Calibration
- sub box options
- new to forums
- JDM HID headlights
- opinions on thermal r&d exhaust
- '97 1.8 (1834cc) '2000 1.8 (1.797cc) ?
- HID
- For Dawhiteboy
- H.I.D kits for Honda/Acura
- 96 itr swap
- hello from Uk ITR owner & questions
- Help: Yellow Bulbs
- ITR HUMOR!
- which cold air intake to get :roll: ?
