- changeing brakes
- SAFC (searched)
- need some quick alignment help
- car idels fast then slow @start up?
- help!!! car popping out of gear...
- where to buy OEM skirts?
- new time belt, time to replace it :( its going to suck!
- What kinda SPARK PLUGS do u use?
- whats the longest road trip you ever took in your R?
- skunk2 short shifter
- I need help with the ECU....
- When Do I Need to smog my car?
- topping off fluids
- Gas gauge/ tank capacity question
- ssible tranny problem '98 LS Automatic
- Cams?
- Post pictures if you got a paintjob done
- whats it take too make a type R?
- What does your R idle at?
- motor rebuild kit?? Do they make one??
- Timing Belt Tensioner Pulley
- springs
- My first time behind the wheel of an R
- idle rough
- smoked 98+ tails?
- new member
- Racing Hart 3 Peice wheels where to buy
- Problem not IACV but...FITV – Fast Idle Thermo Valve
- What do you guys think of these wheels?
- planning to get a 99 GSR
- this picture confuses me...
- Need some help estimating my swap budget.
- Side skirts
- Tire choices...
- Rims?
- FINALLY: Hondata tunned
- suspension bushings
- mildew smell
- throttle body
- Help Needed Please
- Questions regarding wheels & tires specs
- What Type R lip is this?
- quality carbon fiber hood
- new teg owner
- Honda-Acura.Net Passwords (Important)
- What do you think?
- Koni Yellow vs KYB AGX
- Help - 92 Integra LS starting problems............
- Damaged my rim. Pic inside.
- How easy it is to replace air filter and fuel filter
- Civic Type R coming to US?
- So the 1998 GS-R is governed at 130mph/6500rpm
- Where can I find an SiR-G lip?
- Radio code - original doesn't work
- what to do....
- Carbon Fiber Lip
- 12/13/03 open track day
- b18c5 costing 2300-2500
- Suspension install......
- To All G3 TURBO Integras
- Head Installation Help
- what is the process?
- New to the ITR community
- custom hood lift supports
- Help! - Question about turbo'ing my higher mileage integra
- thermostat installed
- Perferr Apexi N! Or Greddy Evo
- Help?plz Exhaust Picking
- lower tie bars
- Just got my turbo. I'm so excited.
- Redlining the R
- E-brake light stays on....
- ssautochrome turbo header for teg?
- water in hatch...?
- Clutch or something more $$$$?
- jdm climate control in dc4
- owned by suprise snowstorm
- New Member " Hello " with a question on Brake lines
- so confuse... which SRI?
- DC 4-1 or 4-2-1 for my 94 LS
- would it look good?
- URGENT:Emissions Fail
- anyone with VIN lookup?
- exhaust BREATHING...:)
- Aftermarket HID headlight housing for USDM Integra?
- Apexi N-1 Damper System
- so how much is your insurence?
- code-number
- A question for all you AutoXer's and Track Whores
- aem cai..what size K&N filter?
- idle rpm
- Buy a 92 LS?
- Repair Manuals
- help!!broken links on front swaybar
- CD PLAYER, Certain Type?
- swap suggestions (dream)
- questions about camber kit installation
- Which Cluster Do I Want?!
- Need help
- Confusion on ecu's and ignition
- HELP!!! CD replacement.. how to get my stock one out
- For TREY
- DC sports 4-1 header vs dc sports JDM header
- JDM header, SMSP cat, ground kit install...my .02
- Spoon Damper/Progessive Spring combo
- How do I take apart my middle console
- Silencer
- JDM type R idle problem
- JDM 4-1 ITR Header or Comptech?
- Cant adjust headlights
- different tire size
- online sites for resonator
- Apex i World Sport Exhaust
- axles for 5 lug conversion
- Which gear do you leave your car in?
- complete type r swap
- Normal for B18C1 to tick a little after hard driving?
- Underbody ?
- Interior lights *pics inside*
- installed the short shifter
- which header do you like?
- Viper SRT-10
- AEM Icebox?!
- HID's installed
- Comptech Spring Questions
- finally my own R
- Upper Balljoints
- exhaust rattle: common problem???
- Short throw shifters, bought a Skunk2 Dual bend, but....
- ABS light ILLUMINATED on '92 GS! Diagnostics plz!!!
- How to correctly position JDM sidemarker lights...
- how many miles on your R and any warranty items replaced?
- people in houston
- Video: Dial-up Killer Though
- bad gas mileage
- Video: 13.5 @ 100mph
- what can I excpect when I get my car smogged?
- 1992 GS Transmission Info
- How to clean IACV...
- Largest Tires On A Stock Wheel?
- Help me find a place to BUY my exhast!!!!
- wheel nuts size
- What color rims for a green integra?
- gsr engines...
- B18A idling. Does intake resonator affect idle?
- Hi! New to the teg forum. Questions.
- Another one gone.
- Hid kits
- Required Maintenance
- Numba 1 exHAUST
- 1994 LS Motor
- E-brake ? HELP!!
- 18 degree timing
- how to get corners off?!?
- How's the brake job coming? I'll tell you how it's coming...
- My turbo TypeR video
- Tein Ha's for street use ??
- Suspension question for LS
- what's a good clutch for a ITR?
- Missing 2nd??
- Antenna is bent from the wind hitting it...
- 5th gear RPMs ?
- D15 into 91 Integra...possible?
- What exhuast for a turbo setup??
- 2nd/3rd gen suspension ?
- Signs to change the manual transmission fluids?
- GSR & LS owners, I have a quick question
- OEM brake pads
- Teg Door Panels HOW TO GET OFF?
- pass smog?
- Aem pads for track day
- Changing Oil
- got new stuff for teggie...
- Should i tune?
- apex'i n1
- Spoon Parts
- integra dash cluster lights
- when buying a GSR motor for swap...
- Any pics of a RS-R exmag exhaust?
- 98-01 Halo headlights
- my 1992 Teg with 1996 GSR wheels
- Replacing Cap and Rotor
- Gray Integra with bronze rims?
- Skunk2 Camber Kit
- Good Midwest Tuner
- winter proofing the car
- meguiar type R sideskirt
- replacing stock cd player
- LSD Tranny:To get or not to get
- 03 Civic CD player in 92 teg
- oil light
- RS-R ExMag Exhaust clip
- another obd-IIb issue
- Engine choice?
- Question about tires...?
- possible del sol
- Some Vids from LimeRock on 11/10/03
- Best Body Kits For Integra
- mugen clutch
- New here.
- Please Explain: What is a Leak Down Test?
- Drag Turbo Kit Install Question
- Weird Idle...Help plz?
- T3 turbo HELP PLEASE
- For TREY or any one thats kno's about the Ice Box
- How much for your GSR?
- Fastest all motor type R daily driven?
- help: Bilstein shocks question
- exhaust
- Short Ram Power?
- N/A or Turbo, All Comments Welcomed
- Fresh Air Filter / Cheapest place to buy?
- Roof Liner & Moon Roof Shade REMOVAL....
- titanium exhaust systems
- OBD-I vs. OBD-II
- K&N Question
- Muffler question...
- '92 GS S3 Light
- Brake Upgrades (searched)
- Advice?
- maybe just paranoia
- Video of my Integra racin :)
- Some pics integra..
- What does Type R stand for?
- R-code
- Radio Code
- good news about my car
- integra CF stickers?
- engine light
- So, after you bid farewell to your Integra...
- i love my integra
- what could i get for this??
- C west??
- Dome Light
- so the insurance wants to total my car
- rsx type S VS type R who do you think would win in a drag
- ebrake ?
- Timing belt and water pump done..
- Changing Brakes on a 92
- cbleading clutch
- JDM ITR exhaust. What do I need?
- Comptech Header
- wtf? chassis codes
- Radio
- #1329 may be sick......
- Pedals
- Integra Exhausts
- Shifter is Squeaky! HElp!!!
