View Full Version : Integra & '97-'01 Integra Type-R
  1. clutch install?
  2. AEM clearance sale ebay link.
  3. shift light ?
  4. Moonroof stuck in vent open position
  5. Poor gas mileage on my new purchase
  6. Could my timing be off???
  7. Starter 91 teg??
  8. JDM DC2 FRONT END conversion FOR 1993 integra DA
  9. B16 Crank in GSR motor?
  10. Transmission woes
  11. Poping when Boosting...HELP!
  12. Heat only works on full blast
  13. Turbo kit, Yes or No go?
  14. check engine light
  15. WS2 exhaust noise
  16. 90 Teg Stock Engine Swap
  17. engine whine...exhaust manifold gasket?
  18. 3rd gear grinds
  19. front tire not centered
  20. faster or same
  21. Question short ram part missing need help
  22. fuse keeps blowing??
  23. Spherical Upper Control Arm Rod Ends Integra/Civic
  24. Ignition Woes....
  25. wheel bearing
  26. ARGH need help shopping
  27. Idling Issues
  28. Cooling water leaking
  29. Brake fluid leaking
  30. Problem areas in a 1994 GSR sedan
  31. Looking for ELD sensor
  32. maybe new wheel options for the teggy
  33. Lug nut wheel stud options for JDM ITR 5 lug???
  34. 94 Integra Rear Spoiler
  35. Smoking under acceleration
  36. car problems
  37. Header and Exhaust
  38. brake booster problems
  39. 91 Teg problems..
  40. Integra Top Fuel Front Lip
  41. project: ressurection
  42. quick releases
  43. IACV problem, related problems? 2 part question
  44. type r ajustable camgears on a integra ls
  45. push start button
  46. idle problem
  47. Tein Super Street Non-Type-R settings
  48. Need some expertise!!
  49. my FAN is acting up
  50. Sea Foam Help
  51. Brakes and Fluid Question ?
  52. need help 98 gsr tranny
  53. Hid
  54. Need advice on do it yourself clear bra for a 92 integra GSR
  55. 93 integra problem
  56. Speed sensitive steering problem?
  57. Fan?
  58. Help!!!!!!!!!!!!
  59. Type r spoiler
  60. 2 Problems or 1 Problem?
  61. Need Help tonight, sway bar
  62. help
  63. 98 Integra GSR- Emission readiness not set.
  64. Should I upgrade to Spoon or NSX calipers?
  65. where did the legroom go?
  66. Anyone know where they hide the alarm on an Integra?
  67. Problems after new Tranny
  68. Rl Wheel Sensor
  69. Torque steer situation
  70. Abnormal Tire Wear.
  71. Please tell me what is wrong with my Turbo GS-R!!!!
  72. Pro-C coilovers need help installing
  73. Steering Rack and micro vibrations when driving need advice
  74. Do I need an alignment?
  75. Need help from you acura specialist plz
  76. Speedometer RPM Engine Temp Clock all dead
  77. what engine should i get
  78. low oil pressure caused by squirters?
  79. recharge a/c?
  80. strut top mounts
  81. GSR trans rebuild question
  82. throttle body size?
  83. help finding the ecu unit?
  84. EXHAUST problem
  85. question about a brake problem
  86. PLZ Need Help With 93 Integra PLZ
  87. 2000 integra shaking??????help plz
  88. Need help with fans on my 93 integra
  89. vtec
  90. Reminder - EVERYONE CHANGING OIL
  91. reverse front seats - 98 Integra LS
  92. are ls/gs spring rates different than gsr?
  93. Torque Damper
  94. JDM front end
  95. b18b1 tune up
  96. CEL question
  97. 96 Acura LS 190 HP
  98. how much to fix this?
  99. Used Block
  100. New to the site, question bout motor build
  101. Somone Tried to break into my Integra ):
  102. How to install halo projectors in 91 integra
  103. If you had an opportunity to trade your 4 door GSR for a 2 door GSR, would you?
  104. What to do with $600
  105. 87 d16A1 code 6
  106. need some 4 door teg help
  107. i jest traided my auto integra for a black 5 speed integra LS in ment condision
  108. Selling '99 GSR - Need input
  109. Questions about parts
  110. CV axles?
  111. 2000 GSR Polyurethane kits
  112. gsr shocks
  113. Wheel stud replacement for 91 integra. Need help ASAP
  114. Compatible VSS?
  115. Magic tricks for getting the driver side window switch out?
  116. 92 Integra random no start. S3 light?
  117. Oil light came on followed by knocking/pinging...
  118. Speedometer and milage just stopped working..
  119. Front Camber Kits Recommendations
  120. Timing Belt Question
  121. 2nd gen top speed
  122. what ecu <p75> did this come out of and what modle of car
  123. integra ecu obd0 to obd1 problums
  124. Half Radiator?
  125. check engine light bulb?
  126. 2000 Integra: "toc" noise: rive train? TRans? Suspension?
  127. 91 integra battery drain
  128. 92' integra ls with JDM B16A vtec
  129. horn button wire
  130. clutch master cylinder
  131. oem is king
  132. Finally dynoed my GSRT
  133. need help....seat conversion!!!
  134. Bad Cat Converter on Boosted GSR
  135. Transmission ACquisition
  136. Houston area,help my teg got stolen!!
  137. Wont Fire
  138. IAB Plug, how do you pin it in?
  139. Vacuum Teeing Question
  140. whats the cover under the wheel fender called
  141. Need your opinion on ITR Coilovers
  142. will a vafc work on a non vtec integra LS
  143. integra LS with b16A pistons
  144. 1991 honda wont start
  145. Radiator is leaking
  146. wiring diagram needed asap
  147. brake pads
  148. won't start when engine run hot
  149. is it my clutch or my transmissions?
  150. Tociko Shocks OOPSIE
  151. P28 with no IAB Controller Question
  152. steering wheel off centered........
  153. how much damage
  154. ABS Module 91 Teg
  155. 94 integra gsr shifter messin with me
  156. They are at it again!!
  157. AEM fuel pressure regulator question
  158. Exterior Door handle
  159. urgent help please... my integra is in the open at walmart
  160. Track Day v. Flyin' Miata open house
  161. Engine question
  162. 97 rear interior panel
  163. Quick should i buy question
  164. Tein Type-Flex or any fully adjustable coilovers
  165. type r brake booster
  166. 97 GSR Radiator, which one
  167. radiator leak
  168. oil level
  169. Does this sound like a Master Cylinder problem?
  170. Shifter and tranny question
  171. brakes
  172. Thinking of doing the timing belt in my 99 GSR.
  173. Integra Front Hub Assembly Removal
  174. timing belt
  175. Indy shop in Seattle
  176. Test Pipe?
  177. Blox LCA for my Gsr
  178. Automatic Transmission Hiccup
  179. 94 engine and trans will fix my 91 integra
  180. Where's a cheap place to get Stage 2 or Stage 1 clutch?
  181. 94 Accura Integra Tach Meter Clicking Noise (help)
  182. integra rims sizes
  183. Will I be happy with this turbo GSR?
  184. 2000 Integra Air Conditiong Sudden Failure
  185. 4DR LS Brakes on a 1992 Civic?
  186. Teggy's Sold :(
  187. Code 13 91 integra OBD-0????????
  188. What Is This!!! -5 Imgs
  189. door actuators...manual to power :) ...question
  190. Cat issue n question...
  191. Window switch same for civic?
  192. wheel bearings
  193. havin to press gas pedal to get my ls started. Please help.
  194. Back in the game...just got a integra!
  195. Won't start in warm weather.
  196. Help please..Another no start
  197. will this linkage work
  198. 91 Integra I Broke Off A Pully Need Help!!
  199. Synchros are bad..What's next?
  200. Checking My GSR 4rm the botton
  201. 99 motor with a 91 tranny, what axles
  202. Question of JDM Part Prices
  203. v-tek
  204. quick help.. troubleshooting
  205. clutch help please
  206. Interior Question
  207. getting screwed by the shop
  208. v-tec ?
  209. Whats it worth?
  210. '97 GS Bolt-Ons.. Advice..
  211. need b18 guru help please
  212. flywheel and clutch
  213. Transmission broke!!
  214. shift linkage
  215. Boost Leak Tester
  216. fail MIL/CHECK ENGINE LIGHT
  217. How do you wire up the horn on a JDM DC2 Honda Integra Type R Steering Wheel?
  218. Coolant Pumps Into Overflow Tank But Not Back Into Radiator.
  219. Walbro 255 LPH & AEM Fuel Pressure Regulator
  220. Airbox bolt
  221. suggestion for lowering car
  222. suspension help
  223. Anyone's Teg Boggin At Low Rpm's?
  224. Integra not starting
  225. Transmission Issuses?
  226. code63 after exhaust sys install
  227. Air filters
  228. Service Manual Questions
  229. gsr help plss
  230. If its not one thing, its something else
  231. Cams & cam gears question?
  232. my lights are not working
  233. when i turn left...
  234. bearing Q's
  235. 94 integra swapped 97 gsr
  236. Need Help /advice very fast
  237. Changing transmission fluid
  238. What's wrong? (poss driveline?)
  239. RPM start up issue
  240. Timing mark issue
  241. ITR axels in an ls?
  242. exterior cleaning
  243. 2001 Integra GSR, SRS Airbag light will not go off,nopower from the OBD plug
  244. Basic tune up
  245. new timing belt?
  246. How high can i go? (rpm)
  247. GSR doesn't start, distrubutor problem i think
  248. Brake question
  249. burning oil
  250. Crossing border with parts and/or car mods
go
Search Engine Friendly URLs by vBSEO 3.5.2
