View Full Version : Integra & '97-'01 Integra Type-R
  1. Apex-i air filter????
  2. e-brake help needed
  3. What exhaust to buy?
  4. Leaky Teg
  5. 80amp fuse part#
  6. Spoon airfilter??
  7. i'd like some ppl's opinions on lowering a g3 teg
  8. integra paint shop
  9. 150BHP Shot Nitrous
  10. Stolen ITR
  11. Has anyone had much luck with auto auctions?
  12. issues with 225/50/r15 ?
  13. Hondas High emitters according to California
  14. Brake upgrades
  15. Need Expertise on Engine Build up !!!
  16. Hytech Exhaust System
  17. Anyone as proud of their ITRs....
  18. DC sports TCS
  19. I need more cargo capacity
  20. Annoying beeping sound?
  21. Front sway bar?
  22. AEM EMS Vs. Hondata s200b
  23. Wheel hop
  24. Bolt-on Recommendations
  25. Dial on AGX broke off..how to tell setting?
  26. serious probs during warmup this morn
  27. Couple Of Questions!!!!
  28. 1g integra
  29. 2dr vs 4dr GSRs
  30. Stage 1 cams,which ones & why (B18C)
  31. 91 integra ls brake problems
  32. Radiator?!?
  33. ECU Upgrade
  34. stock flat balck rims
  35. anyone put the jdm 25mm front and 23mm rear bars?
  36. 01 GSR no start after tehft
  37. Newbie need help b18c5!?!
  38. lsd broken?????
  39. Hot Start Problem
  40. B18B and B18C
  41. ITR expo 3 vid?
  42. might be a dumb question but i just need to know..
  43. JDM ITR cluster, cat converter light?
  44. mugen ECU or V-AFCII
  45. weird sounds coming from my integra
  46. What would you pay for a 96' GSR
  47. Dyno on 93 Integra LS
  48. found some rust on my teg :wtc:
  49. Some pictures of my car
  50. Pics of My exhaust
  51. someone please help. i have a type r with a gsr head
  52. please help
  53. which is faster
  54. ITR vs. GSR
  55. Radio Code?
  56. ideal drop for gs-r
  57. Tire poll
  58. scale weight...
  59. itr differences
  60. oil pan gasket
  61. DC 4-2-1 headers sounds better?
  62. Curious about bolt-on results.
  63. Whats up? I'm new.
  64. Expo: OFFICIAL Southern/Southeastern Caravan
  65. Clutch Friction pint high.
  66. Apex'i N1 Loud??
  67. ecu wiring question.
  68. NEW HP Chrome racing header for Acura ?
  69. megan rear lower control arm worth it?
  70. Dumb question
  71. NY Plate CJR 2256 Stolen Teg spotted.
  72. Tire pressure...
  73. which Suspension should i go with?
  74. The stolen GSR fake Type R incident
  75. How much for this car?
  76. 215/40/17 rubbing problems?
  77. O2 sensor?
  78. fuel pump??
  79. My friend made his GSR a type R. SO he could................
  80. vortec supercharger?
  81. where to mount a flip out screen ?
  82. Exhaust questions
  83. Question regarding pricing of a 1997 ITR.
  84. Mods for an almost stock 98 integra ls
  85. What do you think?
  86. Info about 90 speical edition
  87. Can the R be made to handle better without lowering it?
  88. hondata obd2?
  89. best damper adjustments for canyon racing?
  90. passing emission with turbo
  91. shopping list
  92. Rota Offset question
  93. valve adjustment ?
  94. Integra Interior
  95. ITR QUESTIONS! CONVERSIONS AND SO ON
  96. the shops other ITR turbo(new set up)
  97. Spark plug? NGK PZFR6F
  98. is this comtech icebox that much better than stock?
  99. hwo to remove rust spot
  100. JDM Conversion
  101. compression
  102. Rear Brake Problem
  103. Code 65
  104. Hondata Launch Control and Full Throttle Shifts
  105. Tech manuals for ITR?
  106. 94-97 JDM Amber Front Turn Signals?!?!?!?
  107. head installation question
  108. Exhaust Help Please
  109. buying a leather interior - mental debate
  110. part numbers acura/honda
  111. Nitrous
  112. Turbo
  113. Difference between a 215 and a 205 Azenis tire?
  114. b20/vtech important questions. HELP
  115. Basic Setup for 200hp N/A on a c1
  116. Question about igniters?
  117. june3 help?
  118. tire pressure ...
  119. B20B infusion with B18C GSR (JDM)
  120. Compression Test
  121. air intake innercooler look alikes?!?!?!
  122. Installation instruction for type r kit
  123. repair costs
  124. Timing belt, water pump...pricing, need info
  125. Integra Year Question
  126. Expo 4: Hotel Rooms are going faster . . .
  127. 9 blinks
  128. sways, tie bar and strut bars?
  129. tps sensor
  130. Sorry, another exhaust ?
  131. Expo4 Nightlife?
  132. Dyno
  133. What kind of cams for an S/C setup??
  134. Anybody have replica Type R lip?
  135. My teggy is giving me some problems
  136. Tuners in Jersey
  137. 93 teg suggestions
  138. alignment
  139. What should be next?
  140. 96+ gsr distributor work for 92-95 gsr
  141. Track Day: 2004 Talladega Driving School
  142. Congratulations to Clayton!
  143. My car got broken into
  144. Expo 4: Latest Sponsor News
  145. Today I watched the AEM car crach.
  146. Winter fuel economy
  147. GS-R Insurance much more than GS?
  148. Need some serious help
  149. Tuning an ECU
  150. what is the difference in...just curious
  151. ABS Light On
  152. Best place to have tune NA race motor in CA
  153. surging idle
  154. inlinepro headgasket?
  155. wheel hop
  156. Good clutch
  157. 94-01 Integra Fender
  158. not R related but nowhere elese to ask?
  159. Any Texas R's In here
  160. Skunk2 IM and Throttle body
  161. does gsr have rev limiter?
  162. Integra didnt pass smog check (California)
  163. New to this Forum
  164. ITRCA
  165. CBR600RR vs Integra Type-R
  166. JRSC Rs
  167. '98 ITR's white rims - how do i make them as white as before
  168. Got my 3 bottles of GM Synchromesh Tranny Fluid - Have questions
  169. vtec help
  170. USGP
  171. Best Spark plugs?
  172. LS Valve cover???
  173. turbo setup
  174. Hello All - First Post
  175. jdm guage clusters..
  176. type of gear box
  177. Will a Gauge Cluster From a 94 LS fit into a 98?
  178. oil return line leak
  179. Quick Master cylinder/Brake booster question
  180. Need help with JDM OEM HID pic...
  181. Southeast Honda Challenge
  182. Cat Question with Comptech setup
  183. 2000 LS engine into a 92 Teg
  184. having gear or clutch problems HELP!!!!!
  185. Expo: Official Midwest Caravan
  186. headlights
  187. oil
  188. power antenna rigging?
  189. Field Boxer Series SFC
  190. Itr Expo 4 Caravan Interest?
  191. not honda related but I had to post cause my jaw dropped
  192. Go boost or stay NA?
  193. WTF, Smog Test at test only station?
  194. Type R gripes
  195. Integra wheels
  196. info on the a spec kit for the 04 acura rsx?
  197. GReddy PE(Power Extreme)Exhaust
  198. clutch help
  199. What do you guys think (used car)
  200. Greddy Type S adjustment
  201. Check Engine Light "code 67" (2000 integra LS)
  202. HELP:VIN check please. dont want stolen motor!
  203. srr springs?
  204. Painting Tailights
  205. Good deal?
  206. school parking
  207. Should I sell?
  208. Cold Air Intake
  209. HELP!
  210. Automatic 1997 LS Advice (besides selling)
  211. WIll DIY camera mount pass tech at Expo 4?
  212. gauge problems
  213. Expo 4: Hotel Rooms are going fast!
  214. Dyno tuning coming up..
  215. Load of Integra Pictures..
  216. JDM vs. Ricer
  217. SAFC install
  218. Auto to Manual Conversion 1998 GS
  219. 5th gear grind at high RPMs
  220. can integras have 600 HP???without force induction
  221. OEM tailights
  222. 5 speed conversion need new axles?
  223. How do you get rid of a shell with no wheels?
  224. performace cv axles
  225. OEM flywheel weight
  226. distributor cap & spring tension
  227. motor swap guide
  228. Opinions needed - please advise
  229. Pedals
  230. ITR exhaust??
  231. I crashed my 2001 GS-R
  232. LoJack ?
  233. Rebuild HELP
  234. What to do
  235. Mysterious noise..... ooOOoooOOoooooo
  236. i have a problem wit trans/clutch
  237. Brake up grade ?'s
  238. Engine jerks when shifting gears
  239. My ITR Dyno
  240. Anyone Customized the interior of your ITR?
  241. '98-'01 OEM Foglight question.
  242. 9005 Conversion and associated gaskets...
  243. What do you guys have to protect your Type R?
  244. 1/4 questions
  245. RocketZ AutoSport Products...how are their bodykits?
  246. Here's a little website I made, check it out
  247. do the 97-98 perform and handle like the 00-01?
  248. running rich?
  249. Quick Help Changing Distributor
  250. Goin from stock to not
go
Search Engine Friendly URLs by vBSEO 3.5.2
