- Gutted Cat and CEL
- New here!!!
- 4dr spoiler
- 92 GS-R fluctuating idle
- Advice/Suggestions
- high flow cat/test pipe?
- good header for GSR
- swap ls engine to b16a1?
- clutch question?
- Drivers window channel
- 2000 Acura Integra Check engine light issues
- Engine lag! Help!
- my frinds gsr ran a "13.6" please read
- pics of erik b's car
- SFI padding questions
- throttle body
- HELP....pin in rear caliper stuck
- Hondata?
- Type R Spring Questions
- Vafc throws code
- 80 thousand
- Integra throttle body
- my modified shifter
- Oversized or Standard pistons?
- **PLEASE LOOK** TYPE R STOCK SECURITY SYSTEM
- Debating on a Civic HB or Integra DC2 with JDM ITR Front End
- 0-140mph? post video!
- Front Brake Rotors & Minimum Allowed Thinckness
- Humming noise at high speeds
- Why do I hear a clicking sound in VTEC?
- What bulbs do Integras use?
- donut gasket
- no remote
- 0-140mph video?
- Whats a good asking price for a slightly used VAFC?
- Need input on problem...
- Didnt buy 93 GSR bout 93 LS what are good mods for these engines?
- Noise!!!?
- wha up , new to the board, yo!
- skunk2 sway bar worth it?
- gasket?
- quick question!
- New Car 1994 Ls Integra
- does replacing intake manifold really increase hp
- ITR stock compression
- Exedy OE Replacement or upgraded clutch?
- squeaking sound from driver's side?
- quick question, please help
- Hydraulic Jack
- New to Imports help, Is 1993 1.7L Acura Integra worth building up
- Keeping that annoying antenna down
- intake manifold questions
- E management?
- List Needed
- I got my ITR sway bar!
- Tanabe Sustec Pro SS Type II
- Valve cover swapping
- Heater Fan control resistor for G2
- paint questions
- 16" or 17" wheels?
- 89 LS Charging probs.
- Turbo Setup
- Expo related: VA and radar detectors
- parts replaced, and still bad idle
- Aftermarket clutch master cylinders?
- Integra Radio Code
- 17's for the R
- San Diego Help??
- throttle quickening
- optima battery
- How pissed am i
- Got some new toys today!
- Outsider question....
- Dyno of my 96 GSR
- Questions on how to Boost???
- So i got my new exhaust...
- rev hard manifold
- 92-93 GS-R head on a 91 GS?
- March 13th "BAY AREA TYPE R MEET" Information
- Is this worth it??
- Which would you prefer?
- 94 Integra problems-help
- drag radials vs roadrace slicks
- ITR Tranny or not?
- New ITR owner, second time around
- Heat Shields
- 90-93 DA owners
- ECU question and a few other ?'s.
- clifford alarm system?
- header ?
- GSR Throttle vs ITR
- I cant find a leak :confused:
- Oops, CD's in my headliner :|.
- Will 99 LS stock catback fit my 96 ls?
- whining noise when turning wheel??
- hayame
- A/C belt...
- Sorta know what works........
- Photo posting ?
- CAN ANYONE GET THROUGH TO HYBRID GARAGE OR IS IT JUST ME?
- Anyone interested in Track Day?
- GSR Header on LS Integra (1994)
- JIC FLTA-2's - also installed!!
- Autopower Rollbar Install - Big pics
- Any LS's out there with B16 Trannys?
- question on wheel diameter & suspension
- maintenence required light
- so much for shifter bushings...
- Just got back from my first dyno run!
- Can someone run a carfax for me?
- Block Question
- jun exhaust
- Will an RSX base model shift knob fit on an integra?
- which brake option would you chose?
- Stock Rims
- a couple questions for you guys.
- my turbo setup
- just wondering how much is your insurance?
- Mounting N20 bottle?
- car starts cold stalls when warm
- Clutch Questions
- Lojack - worthwhile??
- Differance btw 97 and 00 ITR cams
- Suspention noise
- Customizing ITR fnot end conversion
- Reset code/cost
- moroso oil pan
- Brake line problem
- caliper help
- GSR curb weight
- Rims for 98 ls?
- chassis, block, tranny vin numbers
- 12-second Integra?
- how much should i offer for 98+ tail lights?
- Just put on (JDM DC Header, cat back...pics!)
- USDM vs JDM
- Mugen MF10
- Help me pass Emissions!
- Ticking noise while turning...
- Tranny fluid recommendations needed
- How to remove cd player?
- can someone help?
- The mystery continues
- Those with OEM ITR Lips
- wierd clutch action on start-up
- Need help with timing and tuning HELP
- What Should I Buy
- Gears sticking
- gas octane for GSR
- IM picture with TB
- clutch pedal/sticking
- Tranny rattle
- Any major differences between ITRs
- Parts diagrams for integras
- Too early to get summer tires?
- whoever asked for a free carfax last time
- Best Intakes For 99'Integra GSR?
- size difference btwn '99 GS-R Coupe and Sedan
- Will a MSD cap for a GSR fit a TYPE R
- Tapping Noise
- Sound Setup
- Boost on b18b1 motor..
- New Owner
- Radio reset code
- racing gas
- New to the Board...
- weird temp guage
- 91 integra passenger window not working..
- Question about RevHard
- New to the forum
- Question about major water leak in rear ?
- GS vs GSR
- help with gauge installation
- 0-60 time?
- Difference between Vtec and non-vtec
- OEM ITR Lip Hardware?
- rsx steering wheel
- best shocks for neuspeed race springs
- Help Fast
- going for LS-vtec (definitely)
- ACT extreme pressure plate clutch
- bolt pattern?
- Do I really need my rear strut bar?
- Been told i have knackered gearbox!! Please help!!
- my stolen teg recovered
- ***Golden Eagle vs. STR cam seal plug - which one doesn't leak***
- Interior swap
- how do i clean my engine?
- How to install shocks/springs?
- Best Coilovers
- best intake for ls
- OT: New TypeR owner (pic)
- Any Type-R owners near Talladega, AL
- 2000 ITR turbo dyno plot/videos (broadband only)
- hello, newbie here
- getting ready for expo :)
- Car part
- exhaust component material
- Which one is more beneficial?
- What do you think about 1992 Teg RS?
- vtec head on ls,rs, or se?
- 1991 Integra LS Cold Air Intake
- b18a to b18b1
- just got greddy sp catback exhaust
- Car struggles at 60mph
- 210KPH+ and the blade came off
- Newbie: how to attach Apexi filter
- Knocking sound when you turn right 91 LS
- clutch question
- need help on what size injectors i need
- DOHC Vtec LSD hatch sticker
- Got Real Lucky! Timing Belt story
- Please help Trey complete the Expo preparation...
- Which GSR OBDI?
- new GAB copy.... w000t!!
- need help! .. for those of you who have removed your carpet
- What can I do with a worn out 91 integra?
- Cv Joint Blown
- Am I lucky or Unlucky?
- n00b...please help
- rod bearings
- Headlamp color matching
- advantages of VTEC
- JDM Final Drive Installed, TRANNY TECH NEEDED *HELP*
- EXPO HELP
- how does greddy sp exhaust sound
- si transmission
- How much for a 94 gsr?
- Yellow headlights?
- Noob Wit Qs
- ITR Gear Ratio/MPH Excel Spreadsheet
- VIN Discrepancy: Checking your VIN? Good info here.
- How many GSR sedans were made?
- Suspention decision
- ACT Extreme pressure plate clutch
- Should I get the 30,000 mile service from Acura?
- new 99 integra owner w/ ?
- ls/vtec instllation and opinions
- more power?
- 96 integra
- horsepower loss to the floor
- 97 ls head
- let it slip?
- ground control coil-over kit part # for koni yellow sp3s?
- is tanabe super hyper medallion quiet
- Can I get a car fax on this car?
- Headunit Question
- Alignment question
