- Break problem
- idle probelm
- vtec whooas. need help!!
- Steering Column
- Coolant mysteriously disappearing...
- Complaint: Goodridge SS brake lines
- Hesitating Start
- What Color is your ITR
- timing belt probelm
- Thinking about short ram
- Heard of Electronic Cut-Out System ??
- ebay wheels
- Not as many miles on a full tank
- Camber Kit or no?
- warming drag radials
- s2k antenna kit
- Fuse Question...
- 95 gsr
- Quick JDM teg question
- DISTURBING, yet flattering, STUDY
- Tranny / Clutch Problem
- which cams:?
- Questions about my drop.
- What's a good 1/4 mile time
- Bored and toying with ideas...
- Type R
- Acura Integra Kit
- Can Generic Ebay Strut Bars and Tie Bars Do the Same THing?
- What do you guys mod your car for?
- Car Emblems Removal
- kinda long but please read
- what's the difference between LS, GS,GS-R, Type R?
- ITR safe for college student
- Might a good "hot bedding" fix brake shudder?
- Best "bang for buck" (smog legal) performance upgrade?
- What are the exact steps in removing superglued emblems?
- Power antenna--how to replace?
- Bumpstop question
- Will a 98 condenser unit fit on a 95?
- Oil Pressure Gauge
- I need help with a type-r swap into a Gsr...
- "free" mods
- Abs
- I need help with a 2000 type-r swap...
- Value of 94 LS sedan
- ABS bleeding on 98+ teg????
- Electron Blue
- LED bulbs in bumper/parking lens... anyone have pix?
- other TEIN coilovers besides SS
- thinkin about getting this gsr...need OPINION!!
- 94 integra hatch rear seat removal
- Starter Issues and Flashing S3
- Skunk2 cams/ valve springs????
- Clutch problem NEED TO FIX
- what kind of fuel line i need for skunk 2 im install
- Vtec
- Integra sticker removal
- Questions From New GSR Owner
- Towing with an '88 Integra?
- Nu-B EBRAKE!
- e-brake light on??
- Adding new Instruments would like some ideas
- 98 GSR makes weird buzzing sound
- Expo "Eye Candy"
- rear engine seal
- boost controller
- I Need A Tranny!
- Making weird noise!
- can anyone answere this???
- How fast can an integra go ?
- b18a VS b18b Question
- Really Bad Torque Steer after lowering
- how much HP`
- wierd noise at VTEC
- Blake Fuller's old Supercharged ITR owning up!-video!!-
- 94 Integra auto
- ECU Programs
- hondata question
- Question: steering wheel replacement
- Caring for GSR
- ITR 5 Lug... suggestions
- Another icebox question
- Door edge stuff...
- which integras have knock sensorS?
- when do you replace your rotors?
- Azenis tire fitment
- Little Warning for Sellers
- IAB vacuum problem...
- idle stuck after skunk 2 im install
- Brake Bleeding HELP!
- 94-01 Integra needed for test fitting: Irvine, CA
- 90-93 Integra 2dr/4dr Needed for test fitting: Irvine, CA
- Interior accessories?
- JDM Conversion Install
- airbag
- Jdm Integra Light Question please help
- koni yellows
- Final Drive Gear Set
- Can't get coolant to flow
- GSR Price check/other questions.
- Fuel Economy Experiment
- A few ?? for Hondata owners.....
- ::few photo shoots of my teggy::
- Inst Sway Bar Kit
- Anyone has the inside fuse box diagram for Teg 99
- HELP Brake master cylinder won't go in!
- PLEASE HELP- OBD2 B18c1 in OBD1 car w/ OBD1 ecu
- LS oem side skirts?
- JDM CRX sun roof?
- window tinting shops in the Bay Area
- bushing install (finally)
- Lowering the car
- bye bye GSR
- just got a 2000 integra ls for my bday..would like sum help
- How much power are you guys pushing at the wheel?
- Need Pattern for JDM Side Markesr
- Header
- New to this forum, please help
- 89 header?
- small steering wheel
- Norcal meet for Integras
- Opinion ons this Silver GS for sale please
- opinion on this 96 GSR thats for sale
- maint reqd light
- Stock spring with Tokico HP shocks????
- uuuuhhh... i screwed something up again.
- need new cat
- So I disconnected my muffler today.......
- ummm why the change???
- Thought you guys would like to see some great AX or RR wheels and tires FS.
- At what speed will a type r shut down?
- k&n filter?
- Clock stopped working. How to fix??
- My GSR sounds like an aircooled Volkswagon
- Icebox question
- ABS Pump Motor Over-Run?
- 89 LS swap?
- my teg pics!
- my dyno graph!
- when do you know the clutch is starting to slip?
- will an integra 2-door spolier fit a 4-door
- 96-spec ITR parts...
- 93 Integra timing 1.8
- info jdm vis version 2 coilovers
- RS or LS?
- 1990 teg problem
- Trouble Starting 94 Integ, Help!
- brake help please
- what kind of header?
- 95 Integra will not start - HELP!
- Turbo ITR owners...your assistance is needed.
- B18C1 Bottom End Rebuild Advice
- Wheel/Tire help
- 45 or 40 Profile Tires for My 16x7 Milanos
- PLEASE help
- conversion
- Acura timing belts clarification.
- DA: H&R Race Springs w/ KYB GR-2 shocks
- Upgrade questions…Some history and what’s next?
- Bad water pump
- Pics of my g2 teg
- ITB or no?
- Axle problem
- ITR Muffler on GSR
- Clutch slippage in my Integra GSR?!
- Timing Belt / Valve Clearance
- Will a CAI for 00 SI fit 00 GSR?
- need help want to go 5 lug
- Tuning problems with VAFC
- need opinion on GSR
- My New ITR!!
- Ignition Timing
- Strange Water Leak
- skunk 2 ecu for GSR?
- air condition
- Changing Transmission Fluid on 97 Integra GS
- Cylinders Misfiring
- buying used teg.. worth it??
- Integra Type R
- where to buy turbo?
- turbo!
- ITR or GSR
- question on LS cylinder head
- ITR idle rpm?
- help
- Auto to manual
- Hard to start periodically...
- What do i do next?some help:)
- 89 Teg troubleshoot Code 16 PGM-FI
- CYP Sensor
- Black 2001 ITR
- Has anyone hardwired their iPod Mini to a '95 Acura Integra?
- Fuel Filter Direction
- Anyone go to Englishtown yesterday in north jersey....see that 9 seconds Integra?
- Best ECU CHIP for 95 ls?
- Intake systems
- Differences between 00 and 01
- Integra OEM Alarm System
- loose t belt
- All this week
- Help! Alarm problems and car won't start.
- Please Help
- short block??
- ecu codes for 96 integra 45 and 67...Need advice.
- 99 teggy
- Well I just got a 95 tegra!
- Dummy shaft on a GSR
- 98 b18c1, P72 ecu, O2 sensor help me
- Installing Polyurethane Bushings
- signal auto stop
- What is a B18C3
- where is my tps?
- Need torque specs.. from head up.. 99 integra
- Need to know what's what!
- Engine bay fuse box.
- New How To - Honda or Acura Axle Replacement Tutorial
- New writeup: Skunk2 manifold for the GSR/P72 head
- A way from keeping ur ITR stolen??
- Buying ITR and needs some help~!
- Koni Yellows or Koni Yellow SP3's
- Finding wider rims and rubber
- H&R vote
- wheels for teh teg??
- question on integra innsurance
- fall out of vtec?
- Turboing a GSR?
- Skunk2 IM throttle body
- I finally got my motor back in
- Airbag switch
- dead integra
- third brake light removal
- 1991 LS Special Edition
- Upgrading brakes on bottom end integra?
- black smoke!!!
- Replacing my LS Tranny!
- 99 integra rear bumper 4 or 2 door?
- Check engine light anyone?
- Help me diagnose my clutch problems
- skunk IM installed..questions
- integra flywheel ?
- Exhaust help needed...
- Can someone CARFAX for me please
- HELP Front Bumper Removal
- Will This Fit? 2000 OEM Civic SI Axles on 94 Teg LS Auto
- progress arb
- AEM Cold Air Soft Mount
- Valve lash for my b20
- See pics...Lower?
- Integra Accessories?
- body componets
